[U-Boot] [PATCH] Add NanoBone board support
NanoBone Specification: ----------------------- Memory: 256MB DDR3 64MB NOR flash 256MB NAND flash 128KB FRAM
Ethernet: 2 x 10/100 connected to SMSC LAN8710 PHY
USB: 1 x USB2.0 Type A
I2C: 2Kbit EEPROM (Microchip 24AA02) RTC (Maxim DS1338) GPIO Expander (Microchip MCP23017)
Expansion connector: 6 x UART 1 x MMC/SD 1 x USB2.0
Signed-off-by: Mark Jackson mpfj@newflow.co.uk --- MAINTAINERS | 4 + board/newflow/nanobone/Makefile | 46 ++++++ board/newflow/nanobone/board.c | 337 +++++++++++++++++++++++++++++++++++++++ board/newflow/nanobone/board.h | 24 +++ board/newflow/nanobone/mux.c | 203 +++++++++++++++++++++++ boards.cfg | 1 + include/configs/nanobone.h | 291 +++++++++++++++++++++++++++++++++ 7 files changed, 906 insertions(+) create mode 100644 board/newflow/nanobone/Makefile create mode 100644 board/newflow/nanobone/board.c create mode 100644 board/newflow/nanobone/board.h create mode 100644 board/newflow/nanobone/mux.c create mode 100644 include/configs/nanobone.h
diff --git a/MAINTAINERS b/MAINTAINERS index 1614b91..7778883 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -710,6 +710,10 @@ Ilko Iliev iliev@ronetix.at PM9263 AT91SAM9263 PM9G45 ARM926EJS (AT91SAM9G45 SoC)
+Mark Jackson mpfj@newflow.co.uk + + NANOBONE ARM ARMV7 (AM33xx Soc) + Michael Jones michael.jones@matrix-vision.de
omap3_mvblx ARM ARMV7 (OMAP3xx SoC) diff --git a/board/newflow/nanobone/Makefile b/board/newflow/nanobone/Makefile new file mode 100644 index 0000000..67a87a1 --- /dev/null +++ b/board/newflow/nanobone/Makefile @@ -0,0 +1,46 @@ +# +# Makefile +# +# Copyright (C) 2011 Texas Instruments Incorporated - http://www.ti.com/ +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed "as is" WITHOUT ANY WARRANTY of any +# kind, whether express or implied; without even the implied warranty +# of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +ifdef CONFIG_SPL_BUILD +COBJS := mux.o +endif + +COBJS += board.o +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(call cmd_link_o_target, $(OBJS) $(SOBJS)) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak $(obj).depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/newflow/nanobone/board.c b/board/newflow/nanobone/board.c new file mode 100644 index 0000000..e8f7e00 --- /dev/null +++ b/board/newflow/nanobone/board.c @@ -0,0 +1,337 @@ +/* + * board.c + * + * Board functions for Newflow NanoBone board + * + * Copyright (C) 2013, Newflow Ltd - http://www.newflow.co.uk/ + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR /PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <common.h> +#include <errno.h> +#include <asm/arch/clock.h> +#include <asm/arch/cpu.h> +#include <asm/arch/ddr_defs.h> +#include <asm/arch/gpio.h> +#include <asm/arch/hardware.h> +#include <asm/arch/sys_proto.h> +#include <asm/arch/mem.h> +#include <asm/arch/mmc_host_def.h> +#include <asm/arch/omap.h> +#include <asm/emif.h> +#include <asm/gpio.h> +#include <asm/io.h> +#include <cpsw.h> +#include <i2c.h> +#include <miiphy.h> +#include <spl.h> +#include "board.h" + +DECLARE_GLOBAL_DATA_PTR; + +/* FRAM config */ +#define FRAM_CS 1 +#define FRAM_BASE 0x1c000000 +#define FRAM_SIZE GPMC_SIZE_16M +static u32 gpmc_fram_config[GPMC_MAX_REG] = { + 0x00001200, + 0x00101000, + 0x00020201, + 0x0f030f03, + 0x010d1010, + 0x000301c0, + 0 +}; + +/* NOR Flash config */ +#define NOR_CS 3 +#define NOR_BASE 0x18000000 +#define NOR_SIZE GPMC_SIZE_64M +static u32 gpmc_nor_config[GPMC_MAX_REG] = { + 0x00001200, + 0x00101004, + 0x00020201, + 0x10041004, + 0x010f1010, + 0x000601c0, + 0 +}; + +static struct wd_timer *wdtimer = (struct wd_timer *)WDT_BASE; +#ifdef CONFIG_SPL_BUILD +static struct uart_sys *uart_base = (struct uart_sys *)DEFAULT_UART_BASE; +#endif + +/* MII mode defines */ +#define PORT1_MII_MODE_ENABLE 0x0 +#define PORT2_MII_MODE_ENABLE 0x0 + +static struct ctrl_dev *cdev = (struct ctrl_dev *)CTRL_DEVICE_BASE; + +/* UART Defines */ +#ifdef CONFIG_SPL_BUILD +#define UART_RESET (0x1 << 1) +#define UART_CLK_RUNNING_MASK 0x1 +#define UART_SMART_IDLE_EN (0x1 << 0x3) + +static void rtc32k_enable(void) +{ + struct rtc_regs *rtc = (struct rtc_regs *)RTC_BASE; + + /* + * Unlock the RTC's registers. For more details please see the + * RTC_SS section of the TRM. In order to unlock we need to + * write these specific values (keys) in this order. + */ + writel(0x83e70b13, &rtc->kick0r); + writel(0x95a4f1e0, &rtc->kick1r); + + /* Enable the RTC 32K OSC by setting bits 3 and 6. */ + writel((1 << 3) | (1 << 6), &rtc->osc); +} + +static const struct ddr_data ddr3_data = { + .datardsratio0 = MT41J128MJT125_RD_DQS, + .datawdsratio0 = MT41J128MJT125_WR_DQS, + .datafwsratio0 = MT41J128MJT125_PHY_FIFO_WE, + .datawrsratio0 = MT41J128MJT125_PHY_WR_DATA, + .datadldiff0 = PHY_DLL_LOCK_DIFF, +}; + +static const struct cmd_control ddr3_cmd_ctrl_data = { + .cmd0csratio = MT41J128MJT125_RATIO, + .cmd0dldiff = MT41J128MJT125_DLL_LOCK_DIFF, + .cmd0iclkout = MT41J128MJT125_INVERT_CLKOUT, + + .cmd1csratio = MT41J128MJT125_RATIO, + .cmd1dldiff = MT41J128MJT125_DLL_LOCK_DIFF, + .cmd1iclkout = MT41J128MJT125_INVERT_CLKOUT, + + .cmd2csratio = MT41J128MJT125_RATIO, + .cmd2dldiff = MT41J128MJT125_DLL_LOCK_DIFF, + .cmd2iclkout = MT41J128MJT125_INVERT_CLKOUT, +}; + +static struct emif_regs ddr3_emif_reg_data = { + .sdram_config = MT41J128MJT125_EMIF_SDCFG, + .ref_ctrl = MT41J128MJT125_EMIF_SDREF, + .sdram_tim1 = MT41J128MJT125_EMIF_TIM1, + .sdram_tim2 = MT41J128MJT125_EMIF_TIM2, + .sdram_tim3 = MT41J128MJT125_EMIF_TIM3, + .zq_config = MT41J128MJT125_ZQ_CFG, + .emif_ddr_phy_ctlr_1 = MT41J128MJT125_EMIF_READ_LATENCY, +}; +#endif /* CONFIG_SPL_BUILD */ + +#if defined(CONFIG_NAND_OMAP_GPMC) & !defined(CONFIG_SPL_BUILD) +/****************************************************************************** + * OMAP3 specific command to switch between NAND HW and SW ecc + *****************************************************************************/ +static int do_switch_ecc(cmd_tbl_t * cmdtp, int flag, int argc, char * const argv[]) +{ + if (argc < 2) + goto usage; + if (strncmp(argv[1], "hw", 2) == 0) + { + int type = 1; + if (argc == 3) + type = simple_strtoul(argv[2], NULL, 10); + omap_nand_switch_ecc(type); + } + else if (strncmp(argv[1], "sw", 2) == 0) + omap_nand_switch_ecc(0); + else + goto usage; + + return 0; + +usage: + printf ("Usage: nandecc %s\n", cmdtp->usage); + return 1; +} + +U_BOOT_CMD( + nandecc, 3, 1, do_switch_ecc, + "switch OMAP3 NAND ECC calculation algorithm", + "[hw 1/hw 2/sw] - Switch between NAND ecc algorithm\n" + " hw 1 = kernel/FS layout\n" + " hw 2 = xloader/uboot layout\n" + " sw = 1-bit software" +); + +#endif /* CONFIG_NAND_OMAP_GPMC & !CONFIG_SPL_BUILD */ + +/* + * early system init of muxing and clocks. + */ +void s_init(void) +{ + /* WDT1 is already running when the bootloader gets control + * Disable it to avoid "random" resets + */ + writel(0xAAAA, &wdtimer->wdtwspr); + while (readl(&wdtimer->wdtwwps) != 0x0) + ; + writel(0x5555, &wdtimer->wdtwspr); + while (readl(&wdtimer->wdtwwps) != 0x0) + ; + +#ifdef CONFIG_SPL_BUILD + /* Setup the PLLs and the clocks for the peripherals */ + pll_init(); + + /* Enable RTC32K clock */ + rtc32k_enable(); + + /* UART softreset */ + u32 regVal; + regVal = readl(&uart_base->uartsyscfg); + regVal |= UART_RESET; + writel(regVal, &uart_base->uartsyscfg); + while ((readl(&uart_base->uartsyssts) & + UART_CLK_RUNNING_MASK) != UART_CLK_RUNNING_MASK) + ; + + /* Disable smart idle */ + regVal = readl(&uart_base->uartsyscfg); + regVal |= UART_SMART_IDLE_EN; + writel(regVal, &uart_base->uartsyscfg); + + config_ddr(303, MT41J128MJT125_IOCTRL_VALUE, &ddr3_data, + &ddr3_cmd_ctrl_data, &ddr3_emif_reg_data, 0); + + gd = &gdata; + + enable_board_pin_mux(); + + preloader_console_init(); + + i2c_init(CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SLAVE); +#endif /* CONFIG_SPL_BUILD */ +} + +/* + * Basic board specific setup. Pinmux has been handled already. + */ +int board_init(void) +{ + i2c_init(CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SLAVE); + + gd->bd->bi_boot_params = PHYS_DRAM_1 + 0x100; + + gpmc_init(); + + /* enable FRAM chip select */ + enable_gpmc_cs_config(gpmc_fram_config, &gpmc_cfg->cs[FRAM_CS], + FRAM_BASE, FRAM_SIZE); + /* enable NOR flash chip select */ + enable_gpmc_cs_config(gpmc_nor_config, &gpmc_cfg->cs[NOR_CS], + NOR_BASE, NOR_SIZE); + + return 0; +} + +int board_late_init(void) +{ + setenv("board_name", "nanobone"); + setenv("board_rev", "0001"); + + return 0; +} + +static void cpsw_control(int enabled) +{ + /* VTP can be added here */ + + return; +} + +static struct cpsw_slave_data cpsw_slaves[] = { + { + .slave_reg_ofs = 0x208, + .sliver_reg_ofs = 0xd80, + .phy_id = 0, + }, + { + .slave_reg_ofs = 0x308, + .sliver_reg_ofs = 0xdc0, + .phy_id = 1, + }, +}; + +static struct cpsw_platform_data cpsw_data = { + .mdio_base = CPSW_MDIO_BASE, + .cpsw_base = CPSW_BASE, + .mdio_div = 0xff, + .channels = 8, + .cpdma_reg_ofs = 0x800, + .slaves = 2, + .slave_data = cpsw_slaves, + .ale_reg_ofs = 0xd00, + .ale_entries = 1024, + .host_port_reg_ofs = 0x108, + .hw_stats_reg_ofs = 0x900, + .mac_control = (1 << 5), + .control = cpsw_control, + .host_port_num = 0, + .version = CPSW_CTRL_VERSION_2, +}; + +int board_eth_init(bd_t *bis) +{ + int rv, n = 0; + uint8_t mac_addr[6]; + uint32_t mac_hi, mac_lo; + + if (!getenv("ethaddr")) { + printf("<ethaddr> not set. Reading from E-fuse\n"); + /* try reading mac address from efuse */ + mac_lo = readl(&cdev->macid0l); + mac_hi = readl(&cdev->macid0h); + mac_addr[0] = mac_hi & 0xff; + mac_addr[1] = (mac_hi & 0xff00) >> 8; + mac_addr[2] = (mac_hi & 0xff0000) >> 16; + mac_addr[3] = (mac_hi & 0xff000000) >> 24; + mac_addr[4] = mac_lo & 0xff; + mac_addr[5] = (mac_lo & 0xff00) >> 8; + + if (is_valid_ether_addr(mac_addr)) + eth_setenv_enetaddr("ethaddr", mac_addr); + } + + if (!getenv("eth1addr")) { + printf("<eth1addr> not set. Reading from E-fuse\n"); + /* try reading mac address from efuse */ + mac_lo = readl(&cdev->macid1l); + mac_hi = readl(&cdev->macid1h); + mac_addr[0] = mac_hi & 0xff; + mac_addr[1] = (mac_hi & 0xff00) >> 8; + mac_addr[2] = (mac_hi & 0xff0000) >> 16; + mac_addr[3] = (mac_hi & 0xff000000) >> 24; + mac_addr[4] = mac_lo & 0xff; + mac_addr[5] = (mac_lo & 0xff00) >> 8; + + if (is_valid_ether_addr(mac_addr)) + eth_setenv_enetaddr("eth1addr", mac_addr); + } + + writel(PORT1_MII_MODE_ENABLE | PORT2_MII_MODE_ENABLE, &cdev->miisel); + cpsw_slaves[0].phy_if = cpsw_slaves[1].phy_if = PHY_INTERFACE_MODE_MII; + + rv = cpsw_register(&cpsw_data); + if (rv < 0) + printf("Error %d registering CPSW switch\n", rv); + else + n += rv; + + return n; +} diff --git a/board/newflow/nanobone/board.h b/board/newflow/nanobone/board.h new file mode 100644 index 0000000..9f5075b --- /dev/null +++ b/board/newflow/nanobone/board.h @@ -0,0 +1,24 @@ +/* + * board.h + * + * TI AM335x boards information header + * + * Copyright (C) 2011, Texas Instruments, Incorporated - http://www.ti.com/ + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR /PURPOSE. See the + * GNU General Public License for more details. + */ + +#ifndef _BOARD_H_ +#define _BOARD_H_ + +void enable_board_pin_mux(void); + +#endif diff --git a/board/newflow/nanobone/mux.c b/board/newflow/nanobone/mux.c new file mode 100644 index 0000000..bf9c999 --- /dev/null +++ b/board/newflow/nanobone/mux.c @@ -0,0 +1,203 @@ +/* + * mux.c + * + * Copyright (C) 2013, Newflow Ltd - http://www.newflow.co.uk/ + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation version 2. + * + * This program is distributed "as is" WITHOUT ANY WARRANTY of any + * kind, whether express or implied; without even the implied warranty + * of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <common.h> +#include <asm/arch/sys_proto.h> +#include <asm/arch/hardware.h> +#include <asm/arch/mux.h> +#include <asm/io.h> +#include <i2c.h> +#include "board.h" + +static struct module_pin_mux gpmc_pin_mux[] = { + {OFFSET(gpmc_ad0), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* GPMC AD0 */ + {OFFSET(gpmc_ad1), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* GPMC AD1 */ + {OFFSET(gpmc_ad2), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* GPMC AD2 */ + {OFFSET(gpmc_ad3), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* GPMC AD3 */ + {OFFSET(gpmc_ad4), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* GPMC AD4 */ + {OFFSET(gpmc_ad5), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* GPMC AD5 */ + {OFFSET(gpmc_ad6), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* GPMC AD6 */ + {OFFSET(gpmc_ad7), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* GPMC AD7 */ + {OFFSET(gpmc_ad8), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* GPMC AD8 */ + {OFFSET(gpmc_ad9), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* GPMC AD9 */ + {OFFSET(gpmc_ad10), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* GPMC AD10 */ + {OFFSET(gpmc_ad11), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* GPMC AD11 */ + {OFFSET(gpmc_ad12), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* GPMC AD12 */ + {OFFSET(gpmc_ad13), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* GPMC AD13 */ + {OFFSET(gpmc_ad14), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* GPMC AD14 */ + {OFFSET(gpmc_ad15), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* GPMC AD15 */ + {OFFSET(gpmc_csn0), (MODE(0) | PULLUDEN)}, /* GPMC_CSN0 */ + {OFFSET(gpmc_csn1), (MODE(0) | PULLUDEN)}, /* GPMC_CSN1 */ + {OFFSET(gpmc_csn2), (MODE(0) | PULLUDEN)}, /* GPMC_CSN2 */ + {OFFSET(gpmc_csn3), (MODE(0) | PULLUDEN)}, /* GPMC_CSN3 */ + {OFFSET(gpmc_advn_ale), (MODE(0) | PULLUDEN)}, /* GPMC_ADV_ALE */ + {OFFSET(gpmc_oen_ren), (MODE(0) | PULLUDEN)}, /* GPMC_OE */ + {OFFSET(gpmc_wen), (MODE(0) | PULLUDEN)}, /* GPMC_WEN */ + {OFFSET(gpmc_be0n_cle), (MODE(0) | PULLUDEN)}, /* GPMC_BE_CLE */ + {OFFSET(gpmc_wait0), (MODE(0) | RXACTIVE)}, /* NAND WAIT */ + {OFFSET(lcd_data1), (MODE(1) | PULLUDDIS)}, /* GPMC A17 */ + {OFFSET(lcd_data2), (MODE(1) | PULLUDDIS)}, /* GPMC A18 */ + {OFFSET(lcd_data3), (MODE(1) | PULLUDDIS)}, /* GPMC A19 */ + {OFFSET(lcd_data4), (MODE(1) | PULLUDDIS)}, /* GPMC A20 */ + {OFFSET(lcd_data5), (MODE(1) | PULLUDDIS)}, /* GPMC A21 */ + {OFFSET(lcd_data6), (MODE(1) | PULLUDDIS)}, /* GPMC A22 */ + {OFFSET(lcd_data7), (MODE(1) | PULLUDDIS)}, /* GPMC A23 */ + {OFFSET(lcd_data8), (MODE(1) | PULLUDDIS)}, /* GPMC A24 */ + {OFFSET(lcd_data9), (MODE(1) | PULLUDDIS)}, /* GPMC A25 */ + {OFFSET(lcd_data10), (MODE(1) | PULLUDDIS)}, /* GPMC A26 */ + {-1}, +}; + +static struct module_pin_mux i2c0_pin_mux[] = { + {OFFSET(i2c0_sda), (MODE(0) | RXACTIVE | + PULLUDEN | SLEWCTRL)}, /* I2C_DATA */ + {OFFSET(i2c0_scl), (MODE(0) | RXACTIVE | + PULLUDEN | SLEWCTRL)}, /* I2C_SCLK */ + {-1}, +}; + +static struct module_pin_mux mii1_pin_mux[] = { + {OFFSET(mii1_col), MODE(0) | RXACTIVE}, /* MII1_COL */ + {OFFSET(mii1_crs), MODE(0) | RXACTIVE}, /* MII1_CRS */ + {OFFSET(mii1_rxerr), MODE(0) | RXACTIVE}, /* MII1_RXERR */ + {OFFSET(mii1_txen), MODE(0)}, /* MII1_TXEN */ + {OFFSET(mii1_rxdv), MODE(0) | RXACTIVE}, /* MII1_RXDV */ + {OFFSET(mii1_txd3), MODE(0)}, /* MII1_TXD3 */ + {OFFSET(mii1_txd2), MODE(0)}, /* MII1_TXD2 */ + {OFFSET(mii1_txd1), MODE(0)}, /* MII1_TXD1 */ + {OFFSET(mii1_txd0), MODE(0)}, /* MII1_TXD0 */ + {OFFSET(mii1_txclk), MODE(0) | RXACTIVE}, /* MII1_TXCLK */ + {OFFSET(mii1_rxclk), MODE(0) | RXACTIVE}, /* MII1_RXCLK */ + {OFFSET(mii1_rxd3), MODE(0) | RXACTIVE}, /* MII1_RXD3 */ + {OFFSET(mii1_rxd2), MODE(0) | RXACTIVE}, /* MII1_RXD2 */ + {OFFSET(mii1_rxd1), MODE(0) | RXACTIVE}, /* MII1_RXD1 */ + {OFFSET(mii1_rxd0), MODE(0) | RXACTIVE}, /* MII1_RXD0 */ + {OFFSET(mdio_data), MODE(0) | RXACTIVE | PULLUP_EN}, /* MDIO_DATA */ + {OFFSET(mdio_clk), MODE(0) | PULLUP_EN}, /* MDIO_CLK */ + {-1}, +}; + +static struct module_pin_mux mii2_pin_mux[] = { + {OFFSET(gpmc_a0), MODE(1)}, /* MII2_TXEN */ + {OFFSET(gpmc_a1), MODE(1) | RXACTIVE}, /* MII2_RXDV */ + {OFFSET(gpmc_a2), MODE(1)}, /* MII2_TXD3 */ + {OFFSET(gpmc_a3), MODE(1)}, /* MII2_TXD2 */ + {OFFSET(gpmc_a4), MODE(1)}, /* MII2_TXD1 */ + {OFFSET(gpmc_a5), MODE(1)}, /* MII2_TXD0 */ + {OFFSET(gpmc_a6), MODE(1) | RXACTIVE}, /* MII2_TXCLK */ + {OFFSET(gpmc_a7), MODE(1) | RXACTIVE}, /* MII2_RXCLK */ + {OFFSET(gpmc_a8), MODE(1) | RXACTIVE}, /* MII2_RXD3 */ + {OFFSET(gpmc_a9), MODE(1) | RXACTIVE}, /* MII2_RXD2 */ + {OFFSET(gpmc_a10), MODE(1) | RXACTIVE}, /* MII2_RXD1 */ + {OFFSET(gpmc_a11), MODE(1) | RXACTIVE}, /* MII2_RXD0 */ + {OFFSET(gpmc_wpn), MODE(1) | RXACTIVE}, /* MII2_RXERR */ + {OFFSET(gpmc_be1n), MODE(1) | RXACTIVE}, /* MII2_COL */ + {OFFSET(mdio_data), MODE(0) | RXACTIVE | PULLUP_EN}, /* MDIO_DATA */ + {OFFSET(mdio_clk), MODE(0) | PULLUP_EN}, /* MDIO_CLK */ + {-1}, +}; + +static struct module_pin_mux mmc0_no_cd_pin_mux[] = { + {OFFSET(mmc0_dat3), (MODE(0) | RXACTIVE | PULLUP_EN)}, /* MMC0_DAT3 */ + {OFFSET(mmc0_dat2), (MODE(0) | RXACTIVE | PULLUP_EN)}, /* MMC0_DAT2 */ + {OFFSET(mmc0_dat1), (MODE(0) | RXACTIVE | PULLUP_EN)}, /* MMC0_DAT1 */ + {OFFSET(mmc0_dat0), (MODE(0) | RXACTIVE | PULLUP_EN)}, /* MMC0_DAT0 */ + {OFFSET(mmc0_clk), (MODE(0) | RXACTIVE | PULLUP_EN)}, /* MMC0_CLK */ + {OFFSET(mmc0_cmd), (MODE(0) | RXACTIVE | PULLUP_EN)}, /* MMC0_CMD */ + {OFFSET(mcasp0_aclkr), (MODE(4) | RXACTIVE)}, /* MMC0_WP */ + {OFFSET(emu1), (MODE(7) | RXACTIVE)}, /* MMC0_CD */ + {-1}, +}; + +static struct module_pin_mux uart0_pin_mux[] = { + {OFFSET(uart0_rxd), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* UART0_RXD */ + {OFFSET(uart0_txd), (MODE(0) | PULLUDEN)}, /* UART0_TXD */ + {-1}, +}; + +static struct module_pin_mux uart1_pin_mux[] = { + {OFFSET(uart1_ctsn), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* UART1_CTSN */ + {OFFSET(uart1_rtsn), (MODE(0) | PULLUDEN)}, /* UART1_RTSN */ + {OFFSET(uart1_rxd), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* UART1_RXD */ + {OFFSET(uart1_txd), (MODE(0) | PULLUDEN)}, /* UART1_TXD */ + {-1}, +}; + +static struct module_pin_mux uart2_pin_mux[] = { + {OFFSET(lcd_data8), (MODE(6) | PULLUP_EN | RXACTIVE)}, /* UART2_CTSN */ + {OFFSET(lcd_data9), (MODE(6) | PULLUDEN)}, /* UART2_RTSN */ + {OFFSET(spi0_sclk), (MODE(1) | PULLUP_EN | RXACTIVE)}, /* UART2_RXD */ + {OFFSET(spi0_d0), (MODE(1) | PULLUDEN)}, /* UART2_TXD */ + {-1}, +}; + +static struct module_pin_mux uart3_pin_mux[] = { + {OFFSET(lcd_data10), (MODE(6) | PULLUP_EN | RXACTIVE)}, /* UART3_CTSN */ + {OFFSET(lcd_data11), (MODE(6) | PULLUDEN)}, /* UART3_RTSN */ + {OFFSET(spi0_cs1), (MODE(1) | PULLUP_EN | RXACTIVE)}, /* UART3_RXD */ + {OFFSET(ecap0_in_pwm0_out), (MODE(1) | PULLUDEN)}, /* UART3_TXD */ + {-1}, +}; + +static struct module_pin_mux uart4_pin_mux[] = { + {OFFSET(lcd_data12), (MODE(6) | PULLUP_EN | RXACTIVE)}, /* UART4_CTSN */ + {OFFSET(lcd_data13), (MODE(6) | PULLUDEN)}, /* UART4_RTSN */ + {OFFSET(uart0_ctsn), (MODE(1) | PULLUP_EN | RXACTIVE)}, /* UART4_RXD */ + {OFFSET(uart0_rtsn), (MODE(1) | PULLUDEN)}, /* UART4_TXD */ + {-1}, +}; + +static struct module_pin_mux uart5_pin_mux[] = { + {OFFSET(lcd_data14), (MODE(4) | PULLUP_EN | RXACTIVE)}, /* UART5_RXD */ + {OFFSET(rmii1_refclk), (MODE(3) | PULLUDEN)}, /* UART5_TXD */ + {-1}, +}; + +static struct module_pin_mux usb0_pin_mux[] = { + {OFFSET(usb0_dm), (MODE(0) | RXACTIVE)}, /* USB0_DM */ + {OFFSET(usb0_dp), (MODE(0) | RXACTIVE)}, /* USB0_DP */ + {OFFSET(usb0_ce), (MODE(0) | RXACTIVE)}, /* USB0_CE */ + {OFFSET(usb0_id), (MODE(0) | RXACTIVE)}, /* USB0_ID */ + {OFFSET(usb0_vbus), (MODE(0) | RXACTIVE)}, /* USB0_VBUS */ + {OFFSET(usb0_drvvbus), (MODE(0) | PULLUDEN)}, /* USB0_DRVVBUS */ + {-1}, +}; + +static struct module_pin_mux usb1_pin_mux[] = { + {OFFSET(usb1_dm), (MODE(0) | RXACTIVE)}, /* USB1_DM */ + {OFFSET(usb1_dp), (MODE(0) | RXACTIVE)}, /* USB1_DP */ + {OFFSET(usb1_ce), (MODE(0) | RXACTIVE)}, /* USB1_CE */ + {OFFSET(usb1_id), (MODE(0) | RXACTIVE)}, /* USB1_ID */ + {OFFSET(usb1_vbus), (MODE(0) | RXACTIVE)}, /* USB1_VBUS */ + {OFFSET(usb1_drvvbus), (MODE(0) | PULLUDEN)}, /* USB1_DRVVBUS */ + {-1}, +}; + +void enable_board_pin_mux() +{ + configure_module_pin_mux(gpmc_pin_mux); + configure_module_pin_mux(i2c0_pin_mux); + configure_module_pin_mux(mii1_pin_mux); + configure_module_pin_mux(mii2_pin_mux); + configure_module_pin_mux(mmc0_no_cd_pin_mux); + configure_module_pin_mux(uart0_pin_mux); + configure_module_pin_mux(uart1_pin_mux); + configure_module_pin_mux(uart2_pin_mux); + configure_module_pin_mux(uart3_pin_mux); + configure_module_pin_mux(uart4_pin_mux); + configure_module_pin_mux(uart5_pin_mux); + configure_module_pin_mux(usb0_pin_mux); + configure_module_pin_mux(usb1_pin_mux); +} diff --git a/boards.cfg b/boards.cfg index 5fc70be..b2f68e9 100644 --- a/boards.cfg +++ b/boards.cfg @@ -241,6 +241,7 @@ am335x_evm_uart3 arm armv7 am335x ti am335x_evm_uart4 arm armv7 am335x ti am33xx am335x_evm:SERIAL5,CONS_INDEX=5 am335x_evm_uart5 arm armv7 am335x ti am33xx am335x_evm:SERIAL6,CONS_INDEX=6 am335x_evm_usbspl arm armv7 am335x ti am33xx am335x_evm:SERIAL1,CONS_INDEX=1,SPL_USBETH_SUPPORT +nanobone arm armv7 nanobone newflow am33xx ti814x_evm arm armv7 ti814x ti am33xx pcm051 arm armv7 pcm051 phytec am33xx pcm051 highbank arm armv7 highbank - highbank diff --git a/include/configs/nanobone.h b/include/configs/nanobone.h new file mode 100644 index 0000000..184f06a --- /dev/null +++ b/include/configs/nanobone.h @@ -0,0 +1,291 @@ +/* + * nanobone.h + * + * Copyright (C) 2013 Newflow Ltd - http://www.newflow.co.uk/ + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation version 2. + * + * This program is distributed "as is" WITHOUT ANY WARRANTY of any + * kind, whether express or implied; without even the implied warranty + * of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#ifndef __CONFIG_NANOBONE_H +#define __CONFIG_NANOBONE_H + +#define CONFIG_AM33XX + +#include <asm/arch/omap.h> + +#define CONFIG_DMA_COHERENT +#define CONFIG_DMA_COHERENT_SIZE (1 << 20) + +#define CONFIG_ENV_SIZE (128 << 10) /* 128 KiB */ +#define CONFIG_SYS_MALLOC_LEN (1024 << 10) +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ +#define CONFIG_SYS_PROMPT "U-Boot# " +#define CONFIG_BOARD_LATE_INIT +#define CONFIG_SYS_NO_FLASH +#define MACH_TYPE_NANOBONE 4483 +#define CONFIG_MACH_TYPE MACH_TYPE_NANOBONE + +#define CONFIG_OF_LIBFDT +#define CONFIG_CMD_BOOTZ +#define CONFIG_CMDLINE_TAG /* enable passing of ATAGs */ +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_INITRD_TAG + +/* commands to include */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_ASKENV +#define CONFIG_VERSION_VARIABLE + +/* set to negative value for no autoboot */ +#define CONFIG_BOOTDELAY 0 +#define CONFIG_ZERO_BOOTDELAY_CHECK +#define CONFIG_ENV_VARS_UBOOT_CONFIG +#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG +#ifndef CONFIG_SPL_BUILD +#define CONFIG_EXTRA_ENV_SETTINGS \ + "loadaddr=0x80200000\0" \ + "fdtaddr=0x80f80000\0" \ + "fdt_high=0xffffffff\0" \ + "console=ttyO0,115200n8\0" \ + +#endif /* CONFIG_SPL_BUILD */ + +#define CONFIG_BOOTCOMMAND "mtdparts default; " \ + "nand read $loadaddr kernel; bootm" +#define CONFIG_BOOTARGS "console=ttyO0,115200n8 noinitrd ip=off " \ + "mem=256M rootwait=1 ubi.mtd=4,2048 " \ + "rootfstype=ubifs root=ubi0:rootfs " \ + "ignore_loglevel" + +/* Clock Defines */ +#define V_OSCK 26000000 /* Clock output from T2 */ +#define V_SCLK (V_OSCK) +#define CONFIG_SYS_MPUCLK 720 + +#define CONFIG_CMD_ECHO + +/* max number of command args */ +#define CONFIG_SYS_MAXARGS 16 + +/* Console I/O Buffer Size */ +#define CONFIG_SYS_CBSIZE 512 + +/* Print Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE \ + + sizeof(CONFIG_SYS_PROMPT) + 16) + +/* Boot Argument Buffer Size */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE + +/* + * memtest works on 8 MB in DRAM after skipping 32MB from + * start addr of ram disk + */ +#define CONFIG_SYS_MEMTEST_START (PHYS_DRAM_1 + (64 * 1024 * 1024)) +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START \ + + (8 * 1024 * 1024)) + +#define CONFIG_SYS_LOAD_ADDR 0x81000000 /* Default load address */ +#define CONFIG_SYS_HZ 1000 /* 1ms clock */ + +#define CONFIG_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_OMAP_HSMMC +#define CONFIG_CMD_MMC +#define CONFIG_DOS_PARTITION +#define CONFIG_CMD_FAT +#define CONFIG_CMD_EXT2 +#define CONFIG_CMD_EXT4 +#define CONFIG_CMD_FS_GENERIC + + /* Physical Memory Map */ +#define CONFIG_NR_DRAM_BANKS 1 /* 1 bank of DRAM */ +#define PHYS_DRAM_1 0x80000000 /* DRAM Bank #1 */ +#define CONFIG_MAX_RAM_BANK_SIZE (1024 << 20) /* 1GB */ + +#define CONFIG_SYS_SDRAM_BASE PHYS_DRAM_1 +#define CONFIG_SYS_INIT_SP_ADDR (NON_SECURE_SRAM_END - \ + GENERATED_GBL_DATA_SIZE) + /* Platform/Board specific defs */ +#define CONFIG_SYS_TIMERBASE 0x48040000 /* Use Timer2 */ +#define CONFIG_SYS_PTV 2 /* Divisor: 2^(PTV+1) => 8 */ +#define CONFIG_SYS_HZ 1000 + +/* NS16550 Configuration */ +#define CONFIG_SYS_NS16550 +#define CONFIG_SYS_NS16550_SERIAL +#define CONFIG_SERIAL_MULTI +#define CONFIG_SYS_NS16550_REG_SIZE (-4) +#define CONFIG_SYS_NS16550_CLK (48000000) +#define CONFIG_SYS_NS16550_COM1 0x44e09000 /* UART0 */ +#define CONFIG_SYS_NS16550_COM2 0x48022000 /* UART1 */ +#define CONFIG_SYS_NS16550_COM3 0x48024000 /* UART2 */ +#define CONFIG_SYS_NS16550_COM4 0x481a6000 /* UART3 */ +#define CONFIG_SYS_NS16550_COM5 0x481a8000 /* UART4 */ +#define CONFIG_SYS_NS16550_COM6 0x481aa000 /* UART5 */ +#define CONFIG_CONS_INDEX 1 + +/* I2C Configuration */ +#define CONFIG_I2C +#define CONFIG_CMD_I2C +#define CONFIG_HARD_I2C +#define CONFIG_SYS_I2C_SPEED 100000 +#define CONFIG_SYS_I2C_SLAVE 1 +#define CONFIG_I2C_MULTI_BUS +#define CONFIG_DRIVER_OMAP24XX_I2C +#define CONFIG_CMD_EEPROM +#define CONFIG_SYS_I2C_EEPROM_ADDR 0x50 /* Main EEPROM */ +#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 2 +#define CONFIG_SYS_I2C_MULTI_EEPROMS + +#define CONFIG_OMAP_GPIO + +#define CONFIG_BAUDRATE 115200 + +#define CONFIG_SYS_CONSOLE_INFO_QUIET + +/* Defines for SPL */ +#define CONFIG_SPL +#define CONFIG_SPL_FRAMEWORK +#define CONFIG_SPL_TEXT_BASE 0x402F0400 +#define CONFIG_SPL_MAX_SIZE (101 * 1024) +#define CONFIG_SPL_STACK CONFIG_SYS_INIT_SP_ADDR + +#define CONFIG_SPL_BSS_START_ADDR 0x80000000 +#define CONFIG_SPL_BSS_MAX_SIZE 0x80000 /* 512 KB */ + +#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR 0x300 /* address 0x60000 */ +#define CONFIG_SYS_U_BOOT_MAX_SIZE_SECTORS 0x200 /* 256 KB */ +#define CONFIG_SYS_MMC_SD_FAT_BOOT_PARTITION 1 +#define CONFIG_SPL_FAT_LOAD_PAYLOAD_NAME "u-boot.img" +#define CONFIG_SPL_MMC_SUPPORT +#define CONFIG_SPL_FAT_SUPPORT +#define CONFIG_SPL_I2C_SUPPORT + +#define CONFIG_SPL_LIBCOMMON_SUPPORT +#define CONFIG_SPL_LIBDISK_SUPPORT +#define CONFIG_SPL_LIBGENERIC_SUPPORT +#define CONFIG_SPL_SERIAL_SUPPORT +#define CONFIG_SPL_GPIO_SUPPORT +#define CONFIG_SPL_YMODEM_SUPPORT +#define CONFIG_SPL_NET_SUPPORT +#define CONFIG_SPL_NET_VCI_STRING "AM335x U-Boot SPL" +#define CONFIG_SPL_ETH_SUPPORT +#define CONFIG_SPL_LDSCRIPT "$(CPUDIR)/omap-common/u-boot-spl.lds" + +#define CONFIG_SPL_BOARD_INIT +#define CONFIG_SPL_NAND_AM33XX_BCH +#define CONFIG_SPL_NAND_SUPPORT +#define CONFIG_SPL_NAND_BASE +#define CONFIG_SPL_NAND_DRIVERS +#define CONFIG_SPL_NAND_ECC +#define CONFIG_SYS_NAND_5_ADDR_CYCLE +#define CONFIG_SYS_NAND_PAGE_COUNT (CONFIG_SYS_NAND_BLOCK_SIZE / \ + CONFIG_SYS_NAND_PAGE_SIZE) +#define CONFIG_SYS_NAND_PAGE_SIZE 2048 +#define CONFIG_SYS_NAND_OOBSIZE 64 +#define CONFIG_SYS_NAND_BLOCK_SIZE (128*1024) +#define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS +#define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, \ + 10, 11, 12, 13, 14, 15, 16, 17, \ + 18, 19, 20, 21, 22, 23, 24, 25, \ + 26, 27, 28, 29, 30, 31, 32, 33, \ + 34, 35, 36, 37, 38, 39, 40, 41, \ + 42, 43, 44, 45, 46, 47, 48, 49, \ + 50, 51, 52, 53, 54, 55, 56, 57, } + +#define CONFIG_SYS_NAND_ECCSIZE 512 +#define CONFIG_SYS_NAND_ECCBYTES 14 + +#define CONFIG_SYS_NAND_ECCSTEPS 4 +#define CONFIG_SYS_NAND_ECCTOTAL (CONFIG_SYS_NAND_ECCBYTES * \ + CONFIG_SYS_NAND_ECCSTEPS) + +#define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE + +#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x20000 + +/* + * 1MB into the SDRAM to allow for SPL's bss at the beginning of SDRAM + * 64 bytes before this address should be set aside for u-boot.img's + * header. That is 0x800FFFC0--0x80100000 should not be used for any + * other needs. + */ +#define CONFIG_SYS_TEXT_BASE 0x80800000 +#define CONFIG_SYS_SPL_MALLOC_START 0x80208000 +#define CONFIG_SYS_SPL_MALLOC_SIZE 0x100000 + +/* Since SPL did pll and ddr initialization for us, + * we don't need to do it twice. + */ +#ifndef CONFIG_SPL_BUILD +#define CONFIG_SKIP_LOWLEVEL_INIT +#endif /* CONFIG_SPL_BUILD */ + +/* Unsupported features */ +#undef CONFIG_USE_IRQ + +#define CONFIG_CMD_NET +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_PING +#define CONFIG_DRIVER_TI_CPSW +#define CONFIG_MII +#define CONFIG_BOOTP_DEFAULT +#define CONFIG_BOOTP_DNS +#define CONFIG_BOOTP_DNS2 +#define CONFIG_BOOTP_SEND_HOSTNAME +#define CONFIG_BOOTP_GATEWAY +#define CONFIG_BOOTP_SUBNETMASK +#define CONFIG_NET_RETRY_COUNT 10 +#define CONFIG_NET_MULTI +#define CONFIG_PHY_GIGE +#define CONFIG_PHYLIB +#define CONFIG_PHY_ADDR 0 +#define CONFIG_PHY_SMSC + + +/* UBIFS support */ +#define CONFIG_CMD_UBI +#define CONFIG_CMD_UBIFS +#define CONFIG_RBTREE +#define CONFIG_LZO + +/* NAND support */ +#define CONFIG_NAND +#define CONFIG_CMD_NAND +#define CONFIG_CMD_NAND_TRIMFFS + +#define CONFIG_MTD_DEVICE +#define CONFIG_MTD_PARTITIONS +#define CONFIG_CMD_MTDPARTS +#define MTDIDS_DEFAULT "nand0=nand" +#define MTDPARTS_DEFAULT "mtdparts=nand:" \ + "128k(spl)," \ + "1792k(boot)," \ + "128k(env)," \ + "4m(kernel)," \ + "64m(rootfs)," \ + "-(data)" + +#define CONFIG_NAND_OMAP_GPMC +#define GPMC_NAND_ECC_LP_x8_LAYOUT 1 +#define CONFIG_SYS_NAND_BASE (0x08000000) /* physical address */ + /* to access nand at */ + /* CS0 */ +#define CONFIG_SYS_MAX_NAND_DEVICE 1 /* Max number of NAND + devices */ +#undef CONFIG_ENV_IS_NOWHERE +#define CONFIG_ENV_IS_IN_NAND +#define CONFIG_ENV_OFFSET 0x1e0000 /* environment starts here */ +#define CONFIG_SYS_ENV_SECT_SIZE (128 << 10) /* 128 KiB */ + +#endif /* ! __CONFIG_NANOBONE_H */
On Tue, Apr 16, 2013 at 04:02:34PM +0100, Mark Jackson wrote:
[snip]
- .sdram_config = MT41J128MJT125_EMIF_SDCFG,
- .ref_ctrl = MT41J128MJT125_EMIF_SDREF,
- .sdram_tim1 = MT41J128MJT125_EMIF_TIM1,
- .sdram_tim2 = MT41J128MJT125_EMIF_TIM2,
- .sdram_tim3 = MT41J128MJT125_EMIF_TIM3,
- .zq_config = MT41J128MJT125_ZQ_CFG,
- .emif_ddr_phy_ctlr_1 = MT41J128MJT125_EMIF_READ_LATENCY,
On the READ_LATENCY, you probably want | PHY_EN_DYN_PWRDN for that (since it's not part of MT41J128MJT125_EMIF_READ_LATENCY) bit of savings.
Why are we bringing this in?
[snip]
- config_ddr(303, MT41J128MJT125_IOCTRL_VALUE, &ddr3_data,
And are you unable to run at 400MHz here? Or just weren't aware / having tried updating the timing parameters, etc?
[snip]
- .mdio_base = CPSW_MDIO_BASE,
- .cpsw_base = CPSW_BASE,
- .mdio_div = 0xff,
- .channels = 8,
- .cpdma_reg_ofs = 0x800,
- .slaves = 2,
Is this all that was needed for both interfaces to work in U-Boot, along with a config change or two? If so, I should take a stab at getting both working on the EVM-SK.
[snip]
- writel(PORT1_MII_MODE_ENABLE | PORT2_MII_MODE_ENABLE, &cdev->miisel);
- cpsw_slaves[0].phy_if = cpsw_slaves[1].phy_if = PHY_INTERFACE_MODE_MII;
Can't you just do that in the struct? And avoid the checkpatch warning too.
[snip]
But you have NOR. Is it not working yet?
- memtest works on 8 MB in DRAM after skipping 32MB from
- start addr of ram disk
Please see doc/README.memory-test and then eiter update the range to be most of memory or drop these and add #undef CONFIG_CMD_MEMTEST.
[snip]
I see this is a copy/paste problem too from am335x_evm.h, can you fix there and pcm051.h?
Same (not needed anymore, not sure how it didn't get removed before).
[snip]
Do you really have the EEPROM at 0x50 like the TI boards do (and then at other offets for capes/daughter cards) ?
[snip]
Another problem duplicated from am335x_evm.h :(
[snip]
"128k(spl)," \
"1792k(boot)," \
This isn't quite right. Your first 128k chunks are ROM-checked redundant locations for SPL to live (hence the write of U-Boot at 512k in).
Did you ever set this? I don't think so... on am335x_evm.h we do since we can build for SPI env or NAND env.
All that said, yay for another board to try and help flush out generic problems in am33xx land!
[snip]
Okay, I'd not looked at the DDR setup in great detail, simply copying what the EVM-SK did.
There's currently no way to enable BCH8 ECC mode. I need this so that all writes to the on-board NAND have the correct ECC values.
There's a similar bunch of code in the OMAP3 board.c file, so I just copied that principal.
Ah ... I've just seen this changed recently (don't know why my code even compiles now as the headers are different !!). I'll just back this out and use the existing version.
Again, I just copied the EVM-SK code.
DDR3 is a new technology for us, but now the board essentially works I should (when I have time !!) be able do some further timing tweaks.
- .mdio_div = 0xff,
- .channels = 8,
- .slaves = 2,
Yes ... the config change is just to set CONFIG_PHY_ADDR to the correct value.
Unfortunately, since the CONFIG_PHY_ADDR value is "hard-coded" into quite a bit of the uboot code, to change ports, you need to re-compile !! Not ideal, and I don't suppose it's too much work to get both working together, but I don't see much demand for it.
Sure, will do.
We do have NOR and it's working, but it doesn't contain any "user accessible" data. We use it as long-term storage using a custom layout, so there's no point in exposing it to uboot.
I'll just drop memtest.
[snip]
Sure, I'll post a "remove duplicate #defines" patch.
Ok.
Yes, but it doesn't contain the same TI EEPROM data structure. In fact, at the moment, it doesn't contain anything (!!).
It's just there for future expansion .... in which case, should I remove the #defines for the time being ?
I'll add it to the "remove duplicates" patch.
"128k(spl)," \
"1792k(boot)," \
Ah, I see ... so that's part of on-chip "bios" ... nice!!
I'll put them back in.
Okay.
Well, this board certainly knock the socks off it's predecessor (based on the AVR32). We're getting a 10-14x performance boost :-)
Thanks for the review ... I'll post a v2 shortly.
Mark J.
[snip]
Right, for am335x we just always do BCH8 in hardware (can't easily make SW matching BCH8). Once we have BCH16 it'll also be automatic switching since that's what the ROM does and we always want to be ROM-compatible.
You should be able to come up with optimal ones with your DDR data sheet and the TRM at hand.
- .mdio_div = 0xff,
- .channels = 8,
- .slaves = 2,
Ah, so it's not quite right :( Other platforms support multiple interfaces, but I don't know how they're setup.
[snip]
A comment above please, roughly to that effect?
[snip]
[snip]
Ok.
Thanks!
No, that's fine, just making sure it's really there.
Thanks!
<snip>
- .mdio_div = 0xff,
- .channels = 8,
- .slaves = 2,
Tom
I can see in drivers/net/cpsw.c:-
static int cpsw_phy_init(struct eth_device *dev, struct cpsw_slave *slave) { ... phydev = phy_connect(priv->bus, CONFIG_PHY_ADDR, dev, slave->data->phy_if); ... }
As you can see the hardcoded CONFIG_PHY_ADDR is being used, despite the fact that it might be different for each slave.
Could you just replace that with "slave->data->phy_id" ?
I'll give it a try and see what happens.
Cheers Mark J.
<snip>
- .mdio_div = 0xff,
- .channels = 8,
- .slaves = 2,
Tom
No, that doesn't fix things.
It looks like the PHY device is stored in the cpsw struct (rather than in the slave struct) ... from cpsw.c:-
struct cpsw_priv { struct eth_device *dev; struct cpsw_platform_data data; int host_port;
struct cpsw_regs *regs; void *dma_regs; struct cpsw_host_regs *host_port_regs; void *ale_regs;
struct cpdma_desc *descs; struct cpdma_desc *desc_free; struct cpdma_chan rx_chan, tx_chan;
struct cpsw_slave *slaves; struct phy_device *phydev; <<<<<<<<<<<<<<<<< struct mii_dev *bus;
u32 mdio_link; u32 phy_mask; };
So there's an assumption that you can only have a single PHY (even though you can have 2 slaves).
I've gone as far as I dare with my limited knowledge.
Regards Mark J.
<snip>
Replied a bit too soon on this one ... I thought they were duplicated, but they're not.
what's the problem with these lines ?
<snip>
'#define<tab>' not '#define<space>'. A general fixup patch is fine.
<snip>
Actually, neither CONFIG_SYS_NAND_ECCTOTAL nor CONFIG_SYS_NAND_ECCSTEPS are used anywhere in the code !!
I'll just remove them.
<snip>
Forgive my ignorance, but where does the 400MHz come from ?
I thought that 303MHz was the max clock speed on the AM335x (TRM 7.3.2.2), or am I missing something ?
Cheers Mark J.
-----BEGIN PGP SIGNED MESSAGE----- Hash: SHA1
<snip>
- config_ddr(303, MT41J128MJT125_IOCTRL_VALUE, &ddr3_data, +
Ah, OK. The nearly released now board I'm referring to that does have 400MHz there has newer silicon that does really support DDR3-800 and there is a new TRM that reflects this. I suspect however you have PG1.0 and 303 is your max speed. Sorry for the confusion!
- -- Tom
Mark,
A small nit-pick, you sent the commit using email id as "mpfj-list@mimc.co.uk" But in the maintainer file, it shows as "mpfj@newflow.co.uk".
Is this valid/correct?
Regards Gururaja
- NANOBONE ARM ARMV7 (AM33xx Soc)
- $(call cmd_link_o_target, $(OBJS) $(SOBJS))
+clean:
- rm -f $(SOBJS) $(OBJS)
+distclean: clean
- rm -f $(LIB) core *.bak $(obj).depend
- board.c
- Board functions for Newflow NanoBone board
- Copyright (C) 2013, Newflow Ltd - http://www.newflow.co.uk/
- MERCHANTABILITY or FITNESS FOR A PARTICULAR /PURPOSE. See the
- 0x00001200,
- 0x00101000,
- 0x00020201,
- 0x0f030f03,
- 0x010d1010,
- 0x000301c0,
- 0
- 0x00001200,
- 0x00101004,
- 0x00020201,
- 0x10041004,
- 0x010f1010,
- 0x000601c0,
- 0
- struct rtc_regs *rtc = (struct rtc_regs *)RTC_BASE;
- writel(0x83e70b13, &rtc->kick0r);
- writel(0x95a4f1e0, &rtc->kick1r);
- /* Enable the RTC 32K OSC by setting bits 3 and 6. */
- writel((1 << 3) | (1 << 6), &rtc->osc);
- .datardsratio0 = MT41J128MJT125_RD_DQS,
- .datawdsratio0 = MT41J128MJT125_WR_DQS,
- .datafwsratio0 = MT41J128MJT125_PHY_FIFO_WE,
- .datawrsratio0 = MT41J128MJT125_PHY_WR_DATA,
- .datadldiff0 = PHY_DLL_LOCK_DIFF,
- .cmd0csratio = MT41J128MJT125_RATIO,
- .cmd0dldiff = MT41J128MJT125_DLL_LOCK_DIFF,
- .cmd0iclkout = MT41J128MJT125_INVERT_CLKOUT,
- .cmd1csratio = MT41J128MJT125_RATIO,
- .cmd1dldiff = MT41J128MJT125_DLL_LOCK_DIFF,
- .cmd1iclkout = MT41J128MJT125_INVERT_CLKOUT,
- .cmd2csratio = MT41J128MJT125_RATIO,
- .cmd2dldiff = MT41J128MJT125_DLL_LOCK_DIFF,
- .cmd2iclkout = MT41J128MJT125_INVERT_CLKOUT,
- OMAP3 specific command to switch between NAND HW and SW ecc
- if (argc < 2)
goto usage;
- if (strncmp(argv[1], "hw", 2) == 0)
int type = 1;
if (argc == 3)
- else if (strncmp(argv[1], "sw", 2) == 0)
- else
goto usage;
+usage:
- printf ("Usage: nandecc %s\n", cmdtp->usage);
- return 1;
+U_BOOT_CMD(
- nandecc, 3, 1, do_switch_ecc,
- "switch OMAP3 NAND ECC calculation algorithm",
- "[hw 1/hw 2/sw] - Switch between NAND ecc algorithm\n"
- " hw 1 = kernel/FS layout\n"
- " hw 2 = xloader/uboot layout\n"
- " sw = 1-bit software"
- early system init of muxing and clocks.
- /* WDT1 is already running when the bootloader gets control
- writel(0xAAAA, &wdtimer->wdtwspr);
- while (readl(&wdtimer->wdtwwps) != 0x0)
- writel(0x5555, &wdtimer->wdtwspr);
- /* Setup the PLLs and the clocks for the peripherals */
- pll_init();
- /* Enable RTC32K clock */
- rtc32k_enable();
- /* UART softreset */
- u32 regVal;
- regVal = readl(&uart_base->uartsyscfg);
- regVal |= UART_RESET;
- writel(regVal, &uart_base->uartsyscfg);
- while ((readl(&uart_base->uartsyssts) &
- /* Disable smart idle */
- regVal |= UART_SMART_IDLE_EN;
- gd = &gdata;
- enable_board_pin_mux();
- preloader_console_init();
- i2c_init(CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SLAVE);
- Basic board specific setup. Pinmux has been handled already.
- gd->bd->bi_boot_params = PHYS_DRAM_1 + 0x100;
- gpmc_init();
- /* enable FRAM chip select */
- enable_gpmc_cs_config(gpmc_fram_config, &gpmc_cfg->cs[FRAM_CS],
- /* enable NOR flash chip select */
- enable_gpmc_cs_config(gpmc_nor_config, &gpmc_cfg->cs[NOR_CS],
- setenv("board_name", "nanobone");
- setenv("board_rev", "0001");
- /* VTP can be added here */
- return;
.phy_id = 0,
.phy_id = 1,
- .mdio_div = 0xff,
- .channels = 8,
- .slaves = 2,
- .slave_data = cpsw_slaves,
- .ale_reg_ofs = 0xd00,
- .ale_entries = 1024,
- .host_port_reg_ofs = 0x108,
- .hw_stats_reg_ofs = 0x900,
- .mac_control = (1 << 5),
- .control = cpsw_control,
- .host_port_num = 0,
- .version = CPSW_CTRL_VERSION_2,
- int rv, n = 0;
- uint8_t mac_addr[6];
- uint32_t mac_hi, mac_lo;
- if (!getenv("ethaddr")) {
- if (!getenv("eth1addr")) {
- rv = cpsw_register(&cpsw_data);
- if (rv < 0)
- else
n += rv;
- return n;
- board.h
- TI AM335x boards information header
- Copyright (C) 2011, Texas Instruments, Incorporated - http://www.ti.com/
- mux.c
- published by the Free Software Foundation version 2.
- This program is distributed "as is" WITHOUT ANY WARRANTY of any
- kind, whether express or implied; without even the implied warranty
- of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
- {OFFSET(gpmc_ad0), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* GPMC AD0 */
- {OFFSET(gpmc_ad1), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* GPMC AD1 */
- {OFFSET(gpmc_ad2), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* GPMC AD2 */
- {OFFSET(gpmc_ad3), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* GPMC AD3 */
- {OFFSET(gpmc_ad4), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* GPMC AD4 */
- {OFFSET(gpmc_ad5), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* GPMC AD5 */
- {OFFSET(gpmc_ad6), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* GPMC AD6 */
- {OFFSET(gpmc_ad7), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* GPMC AD7 */
- {OFFSET(gpmc_ad8), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* GPMC AD8 */
- {OFFSET(gpmc_ad9), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* GPMC AD9 */
- {OFFSET(gpmc_ad10), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* GPMC AD10 */
- {OFFSET(gpmc_ad11), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* GPMC AD11 */
- {OFFSET(gpmc_ad12), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* GPMC AD12 */
- {OFFSET(gpmc_ad13), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* GPMC AD13 */
- {OFFSET(gpmc_ad14), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* GPMC AD14 */
- {OFFSET(gpmc_ad15), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* GPMC AD15 */
- {OFFSET(gpmc_csn0), (MODE(0) | PULLUDEN)}, /* GPMC_CSN0 */
- {OFFSET(gpmc_csn1), (MODE(0) | PULLUDEN)}, /* GPMC_CSN1 */
- {OFFSET(gpmc_csn2), (MODE(0) | PULLUDEN)}, /* GPMC_CSN2 */
- {OFFSET(gpmc_csn3), (MODE(0) | PULLUDEN)}, /* GPMC_CSN3 */
- {OFFSET(gpmc_advn_ale), (MODE(0) | PULLUDEN)}, /* GPMC_ADV_ALE */
- {OFFSET(gpmc_oen_ren), (MODE(0) | PULLUDEN)}, /* GPMC_OE */
- {OFFSET(gpmc_wen), (MODE(0) | PULLUDEN)}, /* GPMC_WEN */
- {OFFSET(gpmc_be0n_cle), (MODE(0) | PULLUDEN)}, /* GPMC_BE_CLE */
- {OFFSET(gpmc_wait0), (MODE(0) | RXACTIVE)}, /* NAND WAIT */
- {OFFSET(lcd_data1), (MODE(1) | PULLUDDIS)}, /* GPMC A17 */
- {OFFSET(lcd_data2), (MODE(1) | PULLUDDIS)}, /* GPMC A18 */
- {OFFSET(lcd_data3), (MODE(1) | PULLUDDIS)}, /* GPMC A19 */
- {OFFSET(lcd_data4), (MODE(1) | PULLUDDIS)}, /* GPMC A20 */
- {OFFSET(lcd_data5), (MODE(1) | PULLUDDIS)}, /* GPMC A21 */
- {OFFSET(lcd_data6), (MODE(1) | PULLUDDIS)}, /* GPMC A22 */
- {OFFSET(lcd_data7), (MODE(1) | PULLUDDIS)}, /* GPMC A23 */
- {OFFSET(lcd_data8), (MODE(1) | PULLUDDIS)}, /* GPMC A24 */
- {OFFSET(lcd_data9), (MODE(1) | PULLUDDIS)}, /* GPMC A25 */
- {OFFSET(lcd_data10), (MODE(1) | PULLUDDIS)}, /* GPMC A26 */
- {-1},
- {OFFSET(i2c0_sda), (MODE(0) | RXACTIVE |
- {OFFSET(i2c0_scl), (MODE(0) | RXACTIVE |
- {-1},
- {OFFSET(mii1_col), MODE(0) | RXACTIVE}, /* MII1_COL */
- {OFFSET(mii1_crs), MODE(0) | RXACTIVE}, /* MII1_CRS */
- {OFFSET(mii1_rxerr), MODE(0) | RXACTIVE}, /* MII1_RXERR */
- {OFFSET(mii1_txen), MODE(0)}, /* MII1_TXEN */
- {OFFSET(mii1_rxdv), MODE(0) | RXACTIVE}, /* MII1_RXDV */
- {OFFSET(mii1_txd3), MODE(0)}, /* MII1_TXD3 */
- {OFFSET(mii1_txd2), MODE(0)}, /* MII1_TXD2 */
- {OFFSET(mii1_txd1), MODE(0)}, /* MII1_TXD1 */
- {OFFSET(mii1_txd0), MODE(0)}, /* MII1_TXD0 */
- {OFFSET(mii1_txclk), MODE(0) | RXACTIVE}, /* MII1_TXCLK */
- {OFFSET(mii1_rxclk), MODE(0) | RXACTIVE}, /* MII1_RXCLK */
- {OFFSET(mii1_rxd3), MODE(0) | RXACTIVE}, /* MII1_RXD3 */
- {OFFSET(mii1_rxd2), MODE(0) | RXACTIVE}, /* MII1_RXD2 */
- {OFFSET(mii1_rxd1), MODE(0) | RXACTIVE}, /* MII1_RXD1 */
- {OFFSET(mii1_rxd0), MODE(0) | RXACTIVE}, /* MII1_RXD0 */
- {OFFSET(mdio_data), MODE(0) | RXACTIVE | PULLUP_EN}, /* MDIO_DATA */
- {OFFSET(mdio_clk), MODE(0) | PULLUP_EN}, /* MDIO_CLK */
- {-1},
- {OFFSET(gpmc_a0), MODE(1)}, /* MII2_TXEN */
- {OFFSET(gpmc_a1), MODE(1) | RXACTIVE}, /* MII2_RXDV */
- {OFFSET(gpmc_a2), MODE(1)}, /* MII2_TXD3 */
- {OFFSET(gpmc_a3), MODE(1)}, /* MII2_TXD2 */
- {OFFSET(gpmc_a4), MODE(1)}, /* MII2_TXD1 */
- {OFFSET(gpmc_a5), MODE(1)}, /* MII2_TXD0 */
- {OFFSET(gpmc_a6), MODE(1) | RXACTIVE}, /* MII2_TXCLK */
- {OFFSET(gpmc_a7), MODE(1) | RXACTIVE}, /* MII2_RXCLK */
- {OFFSET(gpmc_a8), MODE(1) | RXACTIVE}, /* MII2_RXD3 */
- {OFFSET(gpmc_a9), MODE(1) | RXACTIVE}, /* MII2_RXD2 */
- {OFFSET(gpmc_a10), MODE(1) | RXACTIVE}, /* MII2_RXD1 */
- {OFFSET(gpmc_a11), MODE(1) | RXACTIVE}, /* MII2_RXD0 */
- {OFFSET(gpmc_wpn), MODE(1) | RXACTIVE}, /* MII2_RXERR */
- {OFFSET(gpmc_be1n), MODE(1) | RXACTIVE}, /* MII2_COL */
- {-1},
- {OFFSET(mmc0_dat3), (MODE(0) | RXACTIVE | PULLUP_EN)}, /* MMC0_DAT3 */
- {OFFSET(mmc0_dat2), (MODE(0) | RXACTIVE | PULLUP_EN)}, /* MMC0_DAT2 */
- {OFFSET(mmc0_dat1), (MODE(0) | RXACTIVE | PULLUP_EN)}, /* MMC0_DAT1 */
- {OFFSET(mmc0_dat0), (MODE(0) | RXACTIVE | PULLUP_EN)}, /* MMC0_DAT0 */
- {OFFSET(mmc0_clk), (MODE(0) | RXACTIVE | PULLUP_EN)}, /* MMC0_CLK */
- {OFFSET(mmc0_cmd), (MODE(0) | RXACTIVE | PULLUP_EN)}, /* MMC0_CMD */
- {OFFSET(mcasp0_aclkr), (MODE(4) | RXACTIVE)}, /* MMC0_WP */
- {OFFSET(emu1), (MODE(7) | RXACTIVE)}, /* MMC0_CD */
- {-1},
- {OFFSET(uart0_rxd), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* UART0_RXD */
- {OFFSET(uart0_txd), (MODE(0) | PULLUDEN)}, /* UART0_TXD */
- {-1},
- {OFFSET(uart1_ctsn), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* UART1_CTSN */
- {OFFSET(uart1_rtsn), (MODE(0) | PULLUDEN)}, /* UART1_RTSN */
- {OFFSET(uart1_rxd), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* UART1_RXD */
- {OFFSET(uart1_txd), (MODE(0) | PULLUDEN)}, /* UART1_TXD */
- {-1},
- {OFFSET(lcd_data8), (MODE(6) | PULLUP_EN | RXACTIVE)}, /* UART2_CTSN */
- {OFFSET(lcd_data9), (MODE(6) | PULLUDEN)}, /* UART2_RTSN */
- {OFFSET(spi0_sclk), (MODE(1) | PULLUP_EN | RXACTIVE)}, /* UART2_RXD */
- {OFFSET(spi0_d0), (MODE(1) | PULLUDEN)}, /* UART2_TXD */
- {-1},
- {OFFSET(lcd_data10), (MODE(6) | PULLUP_EN | RXACTIVE)}, /* UART3_CTSN */
- {OFFSET(lcd_data11), (MODE(6) | PULLUDEN)}, /* UART3_RTSN */
- {OFFSET(spi0_cs1), (MODE(1) | PULLUP_EN | RXACTIVE)}, /* UART3_RXD */
- {OFFSET(ecap0_in_pwm0_out), (MODE(1) | PULLUDEN)}, /* UART3_TXD */
- {-1},
- {OFFSET(lcd_data12), (MODE(6) | PULLUP_EN | RXACTIVE)}, /* UART4_CTSN */
- {OFFSET(lcd_data13), (MODE(6) | PULLUDEN)}, /* UART4_RTSN */
- {OFFSET(uart0_ctsn), (MODE(1) | PULLUP_EN | RXACTIVE)}, /* UART4_RXD */
- {OFFSET(uart0_rtsn), (MODE(1) | PULLUDEN)}, /* UART4_TXD */
- {-1},
- {OFFSET(lcd_data14), (MODE(4) | PULLUP_EN | RXACTIVE)}, /* UART5_RXD */
- {OFFSET(rmii1_refclk), (MODE(3) | PULLUDEN)}, /* UART5_TXD */
- {-1},
- {OFFSET(usb0_dm), (MODE(0) | RXACTIVE)}, /* USB0_DM */
- {OFFSET(usb0_dp), (MODE(0) | RXACTIVE)}, /* USB0_DP */
- {OFFSET(usb0_ce), (MODE(0) | RXACTIVE)}, /* USB0_CE */
- {OFFSET(usb0_id), (MODE(0) | RXACTIVE)}, /* USB0_ID */
- {OFFSET(usb0_vbus), (MODE(0) | RXACTIVE)}, /* USB0_VBUS */
- {OFFSET(usb0_drvvbus), (MODE(0) | PULLUDEN)}, /* USB0_DRVVBUS */
- {-1},
- {OFFSET(usb1_dm), (MODE(0) | RXACTIVE)}, /* USB1_DM */
- {OFFSET(usb1_dp), (MODE(0) | RXACTIVE)}, /* USB1_DP */
- {OFFSET(usb1_ce), (MODE(0) | RXACTIVE)}, /* USB1_CE */
- {OFFSET(usb1_id), (MODE(0) | RXACTIVE)}, /* USB1_ID */
- {OFFSET(usb1_vbus), (MODE(0) | RXACTIVE)}, /* USB1_VBUS */
- {OFFSET(usb1_drvvbus), (MODE(0) | PULLUDEN)}, /* USB1_DRVVBUS */
- {-1},
- configure_module_pin_mux(gpmc_pin_mux);
- configure_module_pin_mux(i2c0_pin_mux);
- configure_module_pin_mux(mii1_pin_mux);
- configure_module_pin_mux(mii2_pin_mux);
- configure_module_pin_mux(mmc0_no_cd_pin_mux);
- configure_module_pin_mux(uart0_pin_mux);
- configure_module_pin_mux(uart1_pin_mux);
- configure_module_pin_mux(uart2_pin_mux);
- configure_module_pin_mux(uart3_pin_mux);
- configure_module_pin_mux(uart4_pin_mux);
- configure_module_pin_mux(uart5_pin_mux);
- configure_module_pin_mux(usb0_pin_mux);
- configure_module_pin_mux(usb1_pin_mux);
- nanobone.h
- Copyright (C) 2013 Newflow Ltd - http://www.newflow.co.uk/
- "loadaddr=0x80200000\0" \
- "fdtaddr=0x80f80000\0" \
- "fdt_high=0xffffffff\0" \
- "console=ttyO0,115200n8\0" \
"ignore_loglevel"
- /* Physical Memory Map */
- /* Platform/Board specific defs */
- 1MB into the SDRAM to allow for SPL's bss at the beginning of SDRAM
- 64 bytes before this address should be set aside for u-boot.img's
- header. That is 0x800FFFC0--0x80100000 should not be used for any
- other needs.
- we don't need to do it twice.
"128k(spl)," \
"1792k(boot)," \
"128k(env)," \
"4m(kernel)," \
"64m(rootfs)," \
"-(data)"
/* CS0 */
devices */
1.7.9.5
On 17/04/13 06:27, Hebbar, Gururaja wrote:
Mark,
<snip>
Yes ... the newflow address is my official work one.
But I have a separate email address for all my mailing lists which makes sorting out my mailboxes *so* much easier.
I trust this isn't an issue.
Cheers Mark J.
Mark,
<snip>
AFAIK Email id in Maintainer file will be used for all communications.
So I believe, you have enabled mail fwd from mpfj@newflow.co.uk to mpfj-list@mimc.co.uk
Cheers Mark J.
Regards, Gururaja
Mark,
<snip>
I don't mind "direct" contact on my standard email address ... I just have all my mailing list traffic sent to another email address.
I've actually now change to mpfj-list at newflow.co.uk, so does that make things a bit clearer ?
Regards Mark J.
Hebbar, Gururaja
Mark Jackson
Mark Jackson
