[PATCH v2 1/2] rockchip: rk3568: Add support for FriendlyARM NanoPi R5S
FriendlyElec Nanopi R5S is an open-sourced mini IoT gateway device.
Board Specifications - Rockchip RK3568 - 2 or 4GB LPDDR4X - 8GB or 16GB eMMC, SD card slot - GbE LAN (Native) - 2x 2.5G LAN (PCIe) - M.2 Connector - HDMI 2.0, MIPI DSI/CSI - 2xUSB 3.0 Host - USB Type C PD, 5V/9V/12V - GPIO: 12-pin 0.5mm FPC connector
The device tree is taken from kernel v6.4-rc1.
Signed-off-by: Tianling Shen cnsztl@gmail.com ---
No changes in v2.
--- arch/arm/dts/Makefile | 1 + arch/arm/dts/rk3568-nanopi-r5s-u-boot.dtsi | 33 ++ arch/arm/dts/rk3568-nanopi-r5s.dts | 136 +++++ arch/arm/dts/rk3568-nanopi-r5s.dtsi | 590 +++++++++++++++++++++ board/rockchip/evb_rk3568/MAINTAINERS | 8 + configs/nanopi-r5s-rk3568_defconfig | 90 ++++ 6 files changed, 858 insertions(+) create mode 100644 arch/arm/dts/rk3568-nanopi-r5s-u-boot.dtsi create mode 100644 arch/arm/dts/rk3568-nanopi-r5s.dts create mode 100644 arch/arm/dts/rk3568-nanopi-r5s.dtsi create mode 100644 configs/nanopi-r5s-rk3568_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 480269fa60..e2eda3ffcb 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -169,6 +169,7 @@ dtb-$(CONFIG_ROCKCHIP_RK3568) += \ rk3566-anbernic-rgxx3.dtb \ rk3566-radxa-cm3-io.dtb \ rk3568-evb.dtb \ + rk3568-nanopi-r5s.dtb \ rk3568-rock-3a.dtb
dtb-$(CONFIG_ROCKCHIP_RK3588) += \ diff --git a/arch/arm/dts/rk3568-nanopi-r5s-u-boot.dtsi b/arch/arm/dts/rk3568-nanopi-r5s-u-boot.dtsi new file mode 100644 index 0000000000..b37ad1e72d --- /dev/null +++ b/arch/arm/dts/rk3568-nanopi-r5s-u-boot.dtsi @@ -0,0 +1,33 @@ +// SPDX-License-Identifier: GPL-2.0-or-later OR MIT +/* + * Copyright (c) 2022 FriendlyElec Computer Tech. Co., Ltd. + * (http://www.friendlyelec.com) + * + * Copyright (c) 2023 Tianling Shen cnsztl@gmail.com + */ + +#include "rk356x-u-boot.dtsi" + +/ { + chosen { + stdout-path = &uart2; + u-boot,spl-boot-order = "same-as-spl", &sdmmc0, &sdhci; + }; +}; + +&sdhci { + cap-mmc-highspeed; + mmc-hs200-1_8v; +}; + +&sdmmc0 { + bus-width = <4>; + bootph-pre-ram; + u-boot,spl-fifo-mode; +}; + +&uart2 { + clock-frequency = <24000000>; + bootph-pre-ram; + status = "okay"; +}; diff --git a/arch/arm/dts/rk3568-nanopi-r5s.dts b/arch/arm/dts/rk3568-nanopi-r5s.dts new file mode 100644 index 0000000000..b6ad8328c7 --- /dev/null +++ b/arch/arm/dts/rk3568-nanopi-r5s.dts @@ -0,0 +1,136 @@ +// SPDX-License-Identifier: GPL-2.0-or-later OR MIT +/* + * Copyright (c) 2022 FriendlyElec Computer Tech. Co., Ltd. + * (http://www.friendlyelec.com) + * + * Copyright (c) 2023 Tianling Shen cnsztl@gmail.com + */ + +/dts-v1/; +#include "rk3568-nanopi-r5s.dtsi" + +/ { + model = "FriendlyElec NanoPi R5S"; + compatible = "friendlyarm,nanopi-r5s", "rockchip,rk3568"; + + aliases { + ethernet0 = &gmac0; + }; + + gpio-leds { + compatible = "gpio-leds"; + pinctrl-names = "default"; + pinctrl-0 = <&lan1_led_pin>, <&lan2_led_pin>, <&power_led_pin>, <&wan_led_pin>; + + led-lan1 { + color = <LED_COLOR_ID_GREEN>; + function = LED_FUNCTION_LAN; + function-enumerator = <1>; + gpios = <&gpio3 RK_PD6 GPIO_ACTIVE_HIGH>; + }; + + led-lan2 { + color = <LED_COLOR_ID_GREEN>; + function = LED_FUNCTION_LAN; + function-enumerator = <2>; + gpios = <&gpio3 RK_PD7 GPIO_ACTIVE_HIGH>; + }; + + power_led: led-power { + color = <LED_COLOR_ID_RED>; + function = LED_FUNCTION_POWER; + linux,default-trigger = "heartbeat"; + gpios = <&gpio4 RK_PD2 GPIO_ACTIVE_HIGH>; + }; + + led-wan { + color = <LED_COLOR_ID_GREEN>; + function = LED_FUNCTION_WAN; + gpios = <&gpio2 RK_PC1 GPIO_ACTIVE_HIGH>; + }; + }; +}; + +&gmac0 { + assigned-clocks = <&cru SCLK_GMAC0_RX_TX>, <&cru SCLK_GMAC0>; + assigned-clock-parents = <&cru SCLK_GMAC0_RGMII_SPEED>, <&cru CLK_MAC0_2TOP>; + assigned-clock-rates = <0>, <125000000>; + clock_in_out = "output"; + phy-handle = <&rgmii_phy0>; + phy-mode = "rgmii"; + pinctrl-names = "default"; + pinctrl-0 = <&gmac0_miim + &gmac0_tx_bus2 + &gmac0_rx_bus2 + &gmac0_rgmii_clk + &gmac0_rgmii_bus>; + snps,reset-gpio = <&gpio0 RK_PC5 GPIO_ACTIVE_LOW>; + snps,reset-active-low; + /* Reset time is 15ms, 50ms for rtl8211f */ + snps,reset-delays-us = <0 15000 50000>; + tx_delay = <0x3c>; + rx_delay = <0x2f>; + status = "okay"; +}; + +&mdio0 { + rgmii_phy0: ethernet-phy@1 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <1>; + pinctrl-0 = <ð_phy0_reset_pin>; + pinctrl-names = "default"; + }; +}; + +&pcie2x1 { + num-lanes = <1>; + reset-gpios = <&gpio0 RK_PB6 GPIO_ACTIVE_HIGH>; + status = "okay"; +}; + +&pcie30phy { + data-lanes = <1 2>; + status = "okay"; +}; + +&pcie3x1 { + num-lanes = <1>; + reset-gpios = <&gpio0 RK_PA0 GPIO_ACTIVE_HIGH>; + vpcie3v3-supply = <&vcc3v3_pcie>; + status = "okay"; +}; + +&pcie3x2 { + num-lanes = <1>; + num-ib-windows = <8>; + num-ob-windows = <8>; + reset-gpios = <&gpio2 RK_PD6 GPIO_ACTIVE_HIGH>; + vpcie3v3-supply = <&vcc3v3_pcie>; + status = "okay"; +}; + +&pinctrl { + gmac0 { + eth_phy0_reset_pin: eth-phy0-reset-pin { + rockchip,pins = <0 RK_PC4 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + gpio-leds { + lan1_led_pin: lan1-led-pin { + rockchip,pins = <3 RK_PD6 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + lan2_led_pin: lan2-led-pin { + rockchip,pins = <3 RK_PD7 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + power_led_pin: power-led-pin { + rockchip,pins = <4 RK_PD2 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + wan_led_pin: wan-led-pin { + rockchip,pins = <2 RK_PC1 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; +}; diff --git a/arch/arm/dts/rk3568-nanopi-r5s.dtsi b/arch/arm/dts/rk3568-nanopi-r5s.dtsi new file mode 100644 index 0000000000..58ba328ea7 --- /dev/null +++ b/arch/arm/dts/rk3568-nanopi-r5s.dtsi @@ -0,0 +1,590 @@ +// SPDX-License-Identifier: GPL-2.0-or-later OR MIT +/* + * Copyright (c) 2022 FriendlyElec Computer Tech. Co., Ltd. + * (http://www.friendlyelec.com) + * + * Copyright (c) 2023 Tianling Shen cnsztl@gmail.com + */ + +/dts-v1/; +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/input/input.h> +#include <dt-bindings/leds/common.h> +#include <dt-bindings/pinctrl/rockchip.h> +#include <dt-bindings/soc/rockchip,vop2.h> +#include "rk3568.dtsi" + +/ { + aliases { + mmc0 = &sdmmc0; + mmc1 = &sdhci; + }; + + chosen: chosen { + stdout-path = "serial2:1500000n8"; + }; + + hdmi-con { + compatible = "hdmi-connector"; + type = "a"; + + port { + hdmi_con_in: endpoint { + remote-endpoint = <&hdmi_out_con>; + }; + }; + }; + + vdd_usbc: vdd-usbc-regulator { + compatible = "regulator-fixed"; + regulator-name = "vdd_usbc"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + }; + + vcc3v3_sys: vcc3v3-sys-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc3v3_sys"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&vdd_usbc>; + }; + + vcc5v0_sys: vcc5v0-sys-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc5v0_sys"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&vdd_usbc>; + }; + + vcc3v3_pcie: vcc3v3-pcie-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc3v3_pcie"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + enable-active-high; + gpios = <&gpio0 RK_PD4 GPIO_ACTIVE_HIGH>; + startup-delay-us = <200000>; + vin-supply = <&vcc5v0_sys>; + }; + + vcc5v0_usb: vcc5v0-usb-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc5v0_usb"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&vdd_usbc>; + }; + + vcc5v0_usb_host: vcc5v0-usb-host-regulator { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio0 RK_PA6 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&vcc5v0_usb_host_en>; + regulator-name = "vcc5v0_usb_host"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&vcc5v0_usb>; + }; + + vcc5v0_usb_otg: vcc5v0-usb-otg-regulator { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio0 RK_PA5 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&vcc5v0_usb_otg_en>; + regulator-name = "vcc5v0_usb_otg"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&vcc5v0_usb>; + }; + + pcie30_avdd0v9: pcie30-avdd0v9-regulator { + compatible = "regulator-fixed"; + regulator-name = "pcie30_avdd0v9"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <900000>; + vin-supply = <&vcc3v3_sys>; + }; + + pcie30_avdd1v8: pcie30-avdd1v8-regulator { + compatible = "regulator-fixed"; + regulator-name = "pcie30_avdd1v8"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + vin-supply = <&vcc3v3_sys>; + }; +}; + +&combphy0 { + status = "okay"; +}; + +&combphy1 { + status = "okay"; +}; + +&combphy2 { + status = "okay"; +}; + +&cpu0 { + cpu-supply = <&vdd_cpu>; +}; + +&cpu1 { + cpu-supply = <&vdd_cpu>; +}; + +&cpu2 { + cpu-supply = <&vdd_cpu>; +}; + +&cpu3 { + cpu-supply = <&vdd_cpu>; +}; + +&gpu { + mali-supply = <&vdd_gpu>; + status = "okay"; +}; + +&hdmi { + avdd-0v9-supply = <&vdda0v9_image>; + avdd-1v8-supply = <&vcca1v8_image>; + status = "okay"; +}; + +&hdmi_in { + hdmi_in_vp0: endpoint { + remote-endpoint = <&vp0_out_hdmi>; + }; +}; + +&hdmi_out { + hdmi_out_con: endpoint { + remote-endpoint = <&hdmi_con_in>; + }; +}; + +&hdmi_sound { + status = "okay"; +}; + +&i2c0 { + status = "okay"; + + vdd_cpu: regulator@1c { + compatible = "tcs,tcs4525"; + reg = <0x1c>; + fcs,suspend-voltage-selector = <1>; + regulator-name = "vdd_cpu"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <1150000>; + regulator-ramp-delay = <2300>; + vin-supply = <&vcc5v0_sys>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + rk809: pmic@20 { + compatible = "rockchip,rk809"; + reg = <0x20>; + interrupt-parent = <&gpio0>; + interrupts = <RK_PA3 IRQ_TYPE_LEVEL_LOW>; + #clock-cells = <1>; + pinctrl-names = "default"; + pinctrl-0 = <&pmic_int>; + rockchip,system-power-controller; + vcc1-supply = <&vcc3v3_sys>; + vcc2-supply = <&vcc3v3_sys>; + vcc3-supply = <&vcc3v3_sys>; + vcc4-supply = <&vcc3v3_sys>; + vcc5-supply = <&vcc3v3_sys>; + vcc6-supply = <&vcc3v3_sys>; + vcc7-supply = <&vcc3v3_sys>; + vcc8-supply = <&vcc3v3_sys>; + vcc9-supply = <&vcc3v3_sys>; + wakeup-source; + + regulators { + vdd_logic: DCDC_REG1 { + regulator-name = "vdd_logic"; + regulator-always-on; + regulator-boot-on; + regulator-init-microvolt = <900000>; + regulator-initial-mode = <0x2>; + regulator-min-microvolt = <500000>; + regulator-max-microvolt = <1350000>; + regulator-ramp-delay = <6001>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_gpu: DCDC_REG2 { + regulator-name = "vdd_gpu"; + regulator-always-on; + regulator-init-microvolt = <900000>; + regulator-initial-mode = <0x2>; + regulator-min-microvolt = <500000>; + regulator-max-microvolt = <1350000>; + regulator-ramp-delay = <6001>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_ddr: DCDC_REG3 { + regulator-name = "vcc_ddr"; + regulator-always-on; + regulator-boot-on; + regulator-initial-mode = <0x2>; + + regulator-state-mem { + regulator-on-in-suspend; + }; + }; + + vdd_npu: DCDC_REG4 { + regulator-name = "vdd_npu"; + regulator-init-microvolt = <900000>; + regulator-initial-mode = <0x2>; + regulator-min-microvolt = <500000>; + regulator-max-microvolt = <1350000>; + regulator-ramp-delay = <6001>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_1v8: DCDC_REG5 { + regulator-name = "vcc_1v8"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdda0v9_image: LDO_REG1 { + regulator-name = "vdda0v9_image"; + regulator-min-microvolt = <950000>; + regulator-max-microvolt = <950000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdda_0v9: LDO_REG2 { + regulator-name = "vdda_0v9"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <900000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdda0v9_pmu: LDO_REG3 { + regulator-name = "vdda0v9_pmu"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <900000>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <900000>; + }; + }; + + vccio_acodec: LDO_REG4 { + regulator-name = "vccio_acodec"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vccio_sd: LDO_REG5 { + regulator-name = "vccio_sd"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc3v3_pmu: LDO_REG6 { + regulator-name = "vcc3v3_pmu"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3300000>; + }; + }; + + vcca_1v8: LDO_REG7 { + regulator-name = "vcca_1v8"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcca1v8_pmu: LDO_REG8 { + regulator-name = "vcca1v8_pmu"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vcca1v8_image: LDO_REG9 { + regulator-name = "vcca1v8_image"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_3v3: SWITCH_REG1 { + regulator-name = "vcc_3v3"; + regulator-always-on; + regulator-boot-on; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc3v3_sd: SWITCH_REG2 { + regulator-name = "vcc3v3_sd"; + regulator-always-on; + regulator-boot-on; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + }; + + }; +}; + +&i2c5 { + status = "okay"; + + hym8563: rtc@51 { + compatible = "haoyu,hym8563"; + reg = <0x51>; + interrupt-parent = <&gpio0>; + interrupts = <RK_PD3 IRQ_TYPE_LEVEL_LOW>; + #clock-cells = <0>; + clock-output-names = "rtcic_32kout"; + pinctrl-names = "default"; + pinctrl-0 = <&hym8563_int>; + wakeup-source; + }; +}; + +&i2s0_8ch { + status = "okay"; +}; + +&pcie30phy { + data-lanes = <1 2>; + status = "okay"; +}; + +&pinctrl { + hym8563 { + hym8563_int: hym8563-int { + rockchip,pins = <0 RK_PD3 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + pmic { + pmic_int: pmic-int { + rockchip,pins = <0 RK_PA3 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + usb { + vcc5v0_usb_host_en: vcc5v0-usb-host-en { + rockchip,pins = <0 RK_PA6 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + vcc5v0_usb_otg_en: vcc5v0-usb-otg-en { + rockchip,pins = <0 RK_PA5 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; +}; + +&pmu_io_domains { + pmuio1-supply = <&vcc3v3_pmu>; + pmuio2-supply = <&vcc3v3_pmu>; + vccio1-supply = <&vccio_acodec>; + vccio3-supply = <&vccio_sd>; + vccio4-supply = <&vcc_1v8>; + vccio5-supply = <&vcc_3v3>; + vccio6-supply = <&vcc_1v8>; + vccio7-supply = <&vcc_3v3>; + status = "okay"; +}; + +&saradc { + vref-supply = <&vcca_1v8>; + status = "okay"; +}; + +&sdhci { + bus-width = <8>; + max-frequency = <200000000>; + non-removable; + pinctrl-names = "default"; + pinctrl-0 = <&emmc_bus8 &emmc_clk &emmc_cmd>; + status = "okay"; +}; + +&sdmmc0 { + max-frequency = <150000000>; + no-sdio; + no-mmc; + bus-width = <4>; + cap-mmc-highspeed; + cap-sd-highspeed; + disable-wp; + vmmc-supply = <&vcc3v3_sd>; + vqmmc-supply = <&vccio_sd>; + pinctrl-names = "default"; + pinctrl-0 = <&sdmmc0_bus4 &sdmmc0_clk &sdmmc0_cmd &sdmmc0_det>; + status = "okay"; +}; + +&tsadc { + rockchip,hw-tshut-mode = <1>; + rockchip,hw-tshut-polarity = <0>; + status = "okay"; +}; + +&uart2 { + status = "okay"; +}; + +&usb_host0_ehci { + status = "okay"; +}; + +&usb_host0_ohci { + status = "okay"; +}; + +&usb_host0_xhci { + extcon = <&usb2phy0>; + dr_mode = "host"; + status = "okay"; +}; + +&usb_host1_ehci { + status = "okay"; +}; + +&usb_host1_ohci { + status = "okay"; +}; + +&usb_host1_xhci { + status = "okay"; +}; + +&usb2phy0 { + status = "okay"; +}; + +&usb2phy0_host { + phy-supply = <&vcc5v0_usb_host>; + status = "okay"; +}; + +&usb2phy0_otg { + status = "okay"; +}; + +&usb2phy1 { + status = "okay"; +}; + +&usb2phy1_host { + phy-supply = <&vcc5v0_usb_otg>; + status = "okay"; +}; + +&usb2phy1_otg { + status = "okay"; +}; + +&vop { + assigned-clocks = <&cru DCLK_VOP0>, <&cru DCLK_VOP1>; + assigned-clock-parents = <&pmucru PLL_HPLL>, <&cru PLL_VPLL>; + status = "okay"; +}; + +&vop_mmu { + status = "okay"; +}; + +&vp0 { + vp0_out_hdmi: endpoint@ROCKCHIP_VOP2_EP_HDMI0 { + reg = <ROCKCHIP_VOP2_EP_HDMI0>; + remote-endpoint = <&hdmi_in_vp0>; + }; +}; diff --git a/board/rockchip/evb_rk3568/MAINTAINERS b/board/rockchip/evb_rk3568/MAINTAINERS index 6b2e7c7575..9222682461 100644 --- a/board/rockchip/evb_rk3568/MAINTAINERS +++ b/board/rockchip/evb_rk3568/MAINTAINERS @@ -7,6 +7,14 @@ F: configs/evb-rk3568_defconfig F: arch/arm/dts/rk3568-evb-boot.dtsi F: arch/arm/dts/rk3568-evb.dts
+NANOPI-R5S +M: Tianling Shen cnsztl@gmail.com +S: Maintained +F: configs/nanopi-r5s-rk3568_defconfig +F: arch/arm/dts/rk3568-nanopi-r5s.dts +F: arch/arm/dts/rk3568-nanopi-r5s.dtsi +F: arch/arm/dts/rk3568-nanopi-r5s-u-boot.dtsi + RADXA-CM3 M: Jagan Teki jagan@amarulasolutions.com S: Maintained diff --git a/configs/nanopi-r5s-rk3568_defconfig b/configs/nanopi-r5s-rk3568_defconfig new file mode 100644 index 0000000000..041fa6d84f --- /dev/null +++ b/configs/nanopi-r5s-rk3568_defconfig @@ -0,0 +1,90 @@ +CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_COUNTER_FREQUENCY=24000000 +CONFIG_ARCH_ROCKCHIP=y +CONFIG_TEXT_BASE=0x00a00000 +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_NR_DRAM_BANKS=2 +CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y +CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0xc00000 +CONFIG_DEFAULT_DEVICE_TREE="rk3568-nanopi-r5s" +CONFIG_ROCKCHIP_RK3568=y +CONFIG_SPL_ROCKCHIP_COMMON_BOARD=y +CONFIG_SPL_SERIAL=y +CONFIG_SPL_STACK_R_ADDR=0x600000 +CONFIG_TARGET_EVB_RK3568=y +CONFIG_SPL_STACK=0x400000 +CONFIG_DEBUG_UART_BASE=0xFE660000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_SYS_LOAD_ADDR=0xc00800 +CONFIG_DEBUG_UART=y +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3568-nanopi-r5s.dtb" +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_MAX_SIZE=0x40000 +CONFIG_SPL_PAD_TO=0x7f8000 +CONFIG_SPL_HAS_BSS_LINKER_SECTION=y +CONFIG_SPL_BSS_START_ADDR=0x4000000 +CONFIG_SPL_BSS_MAX_SIZE=0x4000 +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +# CONFIG_SPL_SHARES_INIT_SP_ADDR is not set +CONFIG_SPL_STACK_R=y +CONFIG_SPL_ATF=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y +CONFIG_CMD_PMIC=y +CONFIG_CMD_REGULATOR=y +# CONFIG_SPL_DOS_PARTITION is not set +CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_LIVE=y +CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_SPL_DM_WARN=y +CONFIG_SPL_REGMAP=y +CONFIG_SPL_SYSCON=y +CONFIG_SPL_CLK=y +CONFIG_ROCKCHIP_GPIO=y +CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MISC=y +CONFIG_SUPPORT_EMMC_RPMB=y +CONFIG_MMC_DW=y +CONFIG_MMC_DW_ROCKCHIP=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_SDMA=y +CONFIG_MMC_SDHCI_ROCKCHIP=y +CONFIG_DM_ETH=y +CONFIG_ETH_DESIGNWARE=y +CONFIG_GMAC_ROCKCHIP=y +CONFIG_POWER_DOMAIN=y +CONFIG_PHY_ROCKCHIP_INNO_USB2=y +CONFIG_PHY_ROCKCHIP_NANENG_COMBOPHY=y +CONFIG_DM_PMIC=y +CONFIG_PMIC_RK8XX=y +CONFIG_REGULATOR_PWM=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_SPL_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_REGULATOR_RK8XX=y +CONFIG_PWM_ROCKCHIP=y +CONFIG_SPL_RAM=y +CONFIG_BAUDRATE=1500000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SYS_NS16550_MEM32=y +CONFIG_SYSRESET=y +CONFIG_SYSRESET_PSCI=y +CONFIG_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_OHCI_HCD=y +CONFIG_USB_OHCI_GENERIC=y +CONFIG_USB_DWC3=y +CONFIG_ERRNO_STR=y
FriendlyARM NanoPi R5C is an open-sourced mini IoT gateway device.
Specification: - Rockchip RK3568 - 1/4GB LPDDR4X RAM - 8/32GB eMMC - SD card slot - M.2 Connector - 2x USB 3.0 Port - 2x 2500 Base-T (PCIe, r8125) - HDMI 2.0 - MIPI DSI/CSI - USB Type C 5V
Changes in v2: add dtb to Makefile
--- arch/arm/dts/Makefile | 1 + arch/arm/dts/rk3568-nanopi-r5c-u-boot.dtsi | 3 + arch/arm/dts/rk3568-nanopi-r5c.dts | 112 +++++++++++++++++++++ board/rockchip/evb_rk3568/MAINTAINERS | 7 ++ configs/nanopi-r5c-rk3568_defconfig | 90 +++++++++++++++++ 5 files changed, 213 insertions(+) create mode 100644 arch/arm/dts/rk3568-nanopi-r5c-u-boot.dtsi create mode 100644 arch/arm/dts/rk3568-nanopi-r5c.dts create mode 100644 configs/nanopi-r5c-rk3568_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index e2eda3ffcb..507bfb512a 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -169,6 +169,7 @@ dtb-$(CONFIG_ROCKCHIP_RK3568) += \ rk3566-anbernic-rgxx3.dtb \ rk3566-radxa-cm3-io.dtb \ rk3568-evb.dtb \ + rk3568-nanopi-r5c.dtb \ rk3568-nanopi-r5s.dtb \ rk3568-rock-3a.dtb
diff --git a/arch/arm/dts/rk3568-nanopi-r5c-u-boot.dtsi b/arch/arm/dts/rk3568-nanopi-r5c-u-boot.dtsi new file mode 100644 index 0000000000..fe5bc6af47 --- /dev/null +++ b/arch/arm/dts/rk3568-nanopi-r5c-u-boot.dtsi @@ -0,0 +1,3 @@ +// SPDX-License-Identifier: GPL-2.0-or-later OR MIT + +#include "rk3568-nanopi-r5s-u-boot.dtsi" diff --git a/arch/arm/dts/rk3568-nanopi-r5c.dts b/arch/arm/dts/rk3568-nanopi-r5c.dts new file mode 100644 index 0000000000..f70ca9f047 --- /dev/null +++ b/arch/arm/dts/rk3568-nanopi-r5c.dts @@ -0,0 +1,112 @@ +// SPDX-License-Identifier: GPL-2.0-or-later OR MIT +/* + * Copyright (c) 2022 FriendlyElec Computer Tech. Co., Ltd. + * (http://www.friendlyelec.com) + * + * Copyright (c) 2023 Tianling Shen cnsztl@gmail.com + */ + +/dts-v1/; +#include "rk3568-nanopi-r5s.dtsi" + +/ { + model = "FriendlyElec NanoPi R5C"; + compatible = "friendlyarm,nanopi-r5c", "rockchip,rk3568"; + + gpio-keys { + compatible = "gpio-keys"; + pinctrl-names = "default"; + pinctrl-0 = <&reset_button_pin>; + + button-reset { + debounce-interval = <50>; + gpios = <&gpio0 RK_PB7 GPIO_ACTIVE_LOW>; + label = "reset"; + linux,code = <KEY_RESTART>; + }; + }; + + gpio-leds { + compatible = "gpio-leds"; + pinctrl-names = "default"; + pinctrl-0 = <&lan_led_pin>, <&power_led_pin>, <&wan_led_pin>, <&wlan_led_pin>; + + led-lan { + color = <LED_COLOR_ID_GREEN>; + function = LED_FUNCTION_LAN; + gpios = <&gpio3 RK_PA3 GPIO_ACTIVE_HIGH>; + }; + + power_led: led-power { + color = <LED_COLOR_ID_RED>; + function = LED_FUNCTION_POWER; + linux,default-trigger = "heartbeat"; + gpios = <&gpio3 RK_PA2 GPIO_ACTIVE_HIGH>; + }; + + led-wan { + color = <LED_COLOR_ID_GREEN>; + function = LED_FUNCTION_WAN; + gpios = <&gpio3 RK_PA4 GPIO_ACTIVE_HIGH>; + }; + + led-wlan { + color = <LED_COLOR_ID_GREEN>; + function = LED_FUNCTION_WLAN; + gpios = <&gpio3 RK_PA5 GPIO_ACTIVE_HIGH>; + }; + }; +}; + +&pcie2x1 { + pinctrl-names = "default"; + pinctrl-0 = <&pcie20_reset_pin>; + reset-gpios = <&gpio3 RK_PC1 GPIO_ACTIVE_HIGH>; + status = "okay"; +}; + +&pcie3x1 { + num-lanes = <1>; + reset-gpios = <&gpio0 RK_PA0 GPIO_ACTIVE_HIGH>; + vpcie3v3-supply = <&vcc3v3_pcie>; + status = "okay"; +}; + +&pcie3x2 { + num-lanes = <1>; + reset-gpios = <&gpio0 RK_PB6 GPIO_ACTIVE_HIGH>; + vpcie3v3-supply = <&vcc3v3_pcie>; + status = "okay"; +}; + +&pinctrl { + gpio-leds { + lan_led_pin: lan-led-pin { + rockchip,pins = <3 RK_PA3 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + power_led_pin: power-led-pin { + rockchip,pins = <3 RK_PA2 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + wan_led_pin: wan-led-pin { + rockchip,pins = <3 RK_PA4 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + wlan_led_pin: wlan-led-pin { + rockchip,pins = <3 RK_PA5 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + pcie { + pcie20_reset_pin: pcie20-reset-pin { + rockchip,pins = <2 RK_PD2 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + rockchip-key { + reset_button_pin: reset-button-pin { + rockchip,pins = <4 RK_PA0 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; +}; diff --git a/board/rockchip/evb_rk3568/MAINTAINERS b/board/rockchip/evb_rk3568/MAINTAINERS index 9222682461..a8ed2508a1 100644 --- a/board/rockchip/evb_rk3568/MAINTAINERS +++ b/board/rockchip/evb_rk3568/MAINTAINERS @@ -7,6 +7,13 @@ F: configs/evb-rk3568_defconfig F: arch/arm/dts/rk3568-evb-boot.dtsi F: arch/arm/dts/rk3568-evb.dts
+NANOPI-R5C +M: Tianling Shen cnsztl@gmail.com +S: Maintained +F: configs/nanopi-r5c-rk3568_defconfig +F: arch/arm/dts/rk3568-nanopi-r5c.dts +F: arch/arm/dts/rk3568-nanopi-r5c-u-boot.dtsi + NANOPI-R5S M: Tianling Shen cnsztl@gmail.com S: Maintained diff --git a/configs/nanopi-r5c-rk3568_defconfig b/configs/nanopi-r5c-rk3568_defconfig new file mode 100644 index 0000000000..1168bc6e76 --- /dev/null +++ b/configs/nanopi-r5c-rk3568_defconfig @@ -0,0 +1,90 @@ +CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_COUNTER_FREQUENCY=24000000 +CONFIG_ARCH_ROCKCHIP=y +CONFIG_TEXT_BASE=0x00a00000 +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_NR_DRAM_BANKS=2 +CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y +CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0xc00000 +CONFIG_DEFAULT_DEVICE_TREE="rk3568-nanopi-r5c" +CONFIG_ROCKCHIP_RK3568=y +CONFIG_SPL_ROCKCHIP_COMMON_BOARD=y +CONFIG_SPL_SERIAL=y +CONFIG_SPL_STACK_R_ADDR=0x600000 +CONFIG_TARGET_EVB_RK3568=y +CONFIG_SPL_STACK=0x400000 +CONFIG_DEBUG_UART_BASE=0xFE660000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_SYS_LOAD_ADDR=0xc00800 +CONFIG_DEBUG_UART=y +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3568-nanopi-r5c.dtb" +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_MAX_SIZE=0x40000 +CONFIG_SPL_PAD_TO=0x7f8000 +CONFIG_SPL_HAS_BSS_LINKER_SECTION=y +CONFIG_SPL_BSS_START_ADDR=0x4000000 +CONFIG_SPL_BSS_MAX_SIZE=0x4000 +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +# CONFIG_SPL_SHARES_INIT_SP_ADDR is not set +CONFIG_SPL_STACK_R=y +CONFIG_SPL_ATF=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y +CONFIG_CMD_PMIC=y +CONFIG_CMD_REGULATOR=y +# CONFIG_SPL_DOS_PARTITION is not set +CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_LIVE=y +CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_SPL_DM_WARN=y +CONFIG_SPL_REGMAP=y +CONFIG_SPL_SYSCON=y +CONFIG_SPL_CLK=y +CONFIG_ROCKCHIP_GPIO=y +CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MISC=y +CONFIG_SUPPORT_EMMC_RPMB=y +CONFIG_MMC_DW=y +CONFIG_MMC_DW_ROCKCHIP=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_SDMA=y +CONFIG_MMC_SDHCI_ROCKCHIP=y +CONFIG_DM_ETH=y +CONFIG_ETH_DESIGNWARE=y +CONFIG_GMAC_ROCKCHIP=y +CONFIG_POWER_DOMAIN=y +CONFIG_PHY_ROCKCHIP_INNO_USB2=y +CONFIG_PHY_ROCKCHIP_NANENG_COMBOPHY=y +CONFIG_DM_PMIC=y +CONFIG_PMIC_RK8XX=y +CONFIG_REGULATOR_PWM=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_SPL_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_REGULATOR_RK8XX=y +CONFIG_PWM_ROCKCHIP=y +CONFIG_SPL_RAM=y +CONFIG_BAUDRATE=1500000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SYS_NS16550_MEM32=y +CONFIG_SYSRESET=y +CONFIG_SYSRESET_PSCI=y +CONFIG_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_OHCI_HCD=y +CONFIG_USB_OHCI_GENERIC=y +CONFIG_USB_DWC3=y +CONFIG_ERRNO_STR=y
Specification:
- Rockchip RK3568
- 1/4GB LPDDR4X RAM
- 8/32GB eMMC
- SD card slot
- M.2 Connector
- 2x USB 3.0 Port
- HDMI 2.0
- MIPI DSI/CSI
- USB Type C 5V
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
- rk3568-nanopi-r5c.dtb \ rk3568-nanopi-r5s.dtb \ rk3568-rock-3a.dtb
- Copyright (c) 2022 FriendlyElec Computer Tech. Co., Ltd.
- Copyright (c) 2023 Tianling Shen cnsztl@gmail.com
- model = "FriendlyElec NanoPi R5C";
- compatible = "friendlyarm,nanopi-r5c", "rockchip,rk3568";
- gpio-keys {
button-reset {
label = "reset";
- gpio-leds {
led-lan {
led-wan {
led-wlan {
+&pcie2x1 {
- pinctrl-names = "default";
- pinctrl-0 = <&pcie20_reset_pin>;
- reset-gpios = <&gpio3 RK_PC1 GPIO_ACTIVE_HIGH>;
- status = "okay";
+&pcie3x1 {
- num-lanes = <1>;
- reset-gpios = <&gpio0 RK_PA0 GPIO_ACTIVE_HIGH>;
- vpcie3v3-supply = <&vcc3v3_pcie>;
- status = "okay";
+&pcie3x2 {
- num-lanes = <1>;
- reset-gpios = <&gpio0 RK_PB6 GPIO_ACTIVE_HIGH>;
- status = "okay";
+&pinctrl {
- gpio-leds {
- pcie {
- rockchip-key {
- NANOPI-R5S M: Tianling Shen cnsztl@gmail.com S: Maintained
Specification:
- Rockchip RK3568
- 1/4GB LPDDR4X RAM
- 8/32GB eMMC
- SD card slot
- M.2 Connector
- 2x USB 3.0 Port
- HDMI 2.0
- MIPI DSI/CSI
- USB Type C 5V
[snip]
Recommend similar changes to defconfig as for r5s.
Regards, Jonas
- Rockchip RK3568
- 2 or 4GB LPDDR4X
- GbE LAN (Native)
- M.2 Connector
- 2xUSB 3.0 Host
Thanks, - Kever
No changes in v2.
- chosen {
+&sdhci {
- cap-mmc-highspeed;
- mmc-hs200-1_8v;
+&sdmmc0 {
- bus-width = <4>;
- bootph-pre-ram;
- u-boot,spl-fifo-mode;
+&uart2 {
- clock-frequency = <24000000>;
- bootph-pre-ram;
- status = "okay";
- model = "FriendlyElec NanoPi R5S";
- compatible = "friendlyarm,nanopi-r5s", "rockchip,rk3568";
- aliases {
ethernet0 = &gmac0;
- gpio-leds {
led-lan1 {
led-lan2 {
led-wan {
+&gmac0 {
- assigned-clocks = <&cru SCLK_GMAC0_RX_TX>, <&cru SCLK_GMAC0>;
- assigned-clock-parents = <&cru SCLK_GMAC0_RGMII_SPEED>, <&cru CLK_MAC0_2TOP>;
- assigned-clock-rates = <0>, <125000000>;
- clock_in_out = "output";
- phy-handle = <&rgmii_phy0>;
- phy-mode = "rgmii";
- pinctrl-0 = <&gmac0_miim
&gmac0_tx_bus2
&gmac0_rx_bus2
&gmac0_rgmii_clk
&gmac0_rgmii_bus>;
- snps,reset-gpio = <&gpio0 RK_PC5 GPIO_ACTIVE_LOW>;
- snps,reset-active-low;
- /* Reset time is 15ms, 50ms for rtl8211f */
- snps,reset-delays-us = <0 15000 50000>;
- tx_delay = <0x3c>;
- rx_delay = <0x2f>;
- status = "okay";
+&mdio0 {
- rgmii_phy0: ethernet-phy@1 {
reg = <1>;
+&pcie2x1 {
- num-lanes = <1>;
- status = "okay";
+&pcie30phy {
- data-lanes = <1 2>;
- status = "okay";
+&pcie3x1 {
- num-lanes = <1>;
- status = "okay";
+&pcie3x2 {
- num-lanes = <1>;
- num-ib-windows = <8>;
- num-ob-windows = <8>;
- reset-gpios = <&gpio2 RK_PD6 GPIO_ACTIVE_HIGH>;
- status = "okay";
+&pinctrl {
- gmac0 {
- gpio-leds {
- aliases {
mmc0 = &sdmmc0;
mmc1 = &sdhci;
- chosen: chosen {
- hdmi-con {
type = "a";
port {
- vdd_usbc: vdd-usbc-regulator {
regulator-boot-on;
- vcc3v3_sys: vcc3v3-sys-regulator {
regulator-boot-on;
- vcc5v0_sys: vcc5v0-sys-regulator {
regulator-boot-on;
- vcc3v3_pcie: vcc3v3-pcie-regulator {
enable-active-high;
- vcc5v0_usb: vcc5v0-usb-regulator {
regulator-boot-on;
- vcc5v0_usb_host: vcc5v0-usb-host-regulator {
enable-active-high;
regulator-boot-on;
- vcc5v0_usb_otg: vcc5v0-usb-otg-regulator {
enable-active-high;
- pcie30_avdd0v9: pcie30-avdd0v9-regulator {
regulator-boot-on;
- pcie30_avdd1v8: pcie30-avdd1v8-regulator {
regulator-boot-on;
+&combphy0 {
- status = "okay";
+&combphy1 {
- status = "okay";
+&combphy2 {
- status = "okay";
+&cpu0 {
- cpu-supply = <&vdd_cpu>;
+&cpu1 {
+&cpu2 {
+&cpu3 {
+&gpu {
- mali-supply = <&vdd_gpu>;
- status = "okay";
+&hdmi {
- avdd-0v9-supply = <&vdda0v9_image>;
- avdd-1v8-supply = <&vcca1v8_image>;
- status = "okay";
+&hdmi_in {
- hdmi_in_vp0: endpoint {
+&hdmi_out {
- hdmi_out_con: endpoint {
+&hdmi_sound {
- status = "okay";
+&i2c0 {
- status = "okay";
- vdd_cpu: regulator@1c {
reg = <0x1c>;
regulator-boot-on;
- rk809: pmic@20 {
reg = <0x20>;
#clock-cells = <1>;
wakeup-source;
regulators {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
+&i2c5 {
- status = "okay";
- hym8563: rtc@51 {
reg = <0x51>;
#clock-cells = <0>;
wakeup-source;
+&i2s0_8ch {
- status = "okay";
+&pcie30phy {
- status = "okay";
+&pinctrl {
- hym8563 {
- pmic {
- usb {
+&pmu_io_domains {
- pmuio1-supply = <&vcc3v3_pmu>;
- pmuio2-supply = <&vcc3v3_pmu>;
- vccio1-supply = <&vccio_acodec>;
- vccio3-supply = <&vccio_sd>;
- vccio4-supply = <&vcc_1v8>;
- vccio5-supply = <&vcc_3v3>;
- vccio6-supply = <&vcc_1v8>;
- vccio7-supply = <&vcc_3v3>;
- status = "okay";
+&saradc {
- vref-supply = <&vcca_1v8>;
- status = "okay";
+&sdhci {
- bus-width = <8>;
- max-frequency = <200000000>;
- non-removable;
- pinctrl-0 = <&emmc_bus8 &emmc_clk &emmc_cmd>;
- status = "okay";
+&sdmmc0 {
- max-frequency = <150000000>;
- no-sdio;
- no-mmc;
- bus-width = <4>;
- cap-sd-highspeed;
- disable-wp;
- vmmc-supply = <&vcc3v3_sd>;
- vqmmc-supply = <&vccio_sd>;
- pinctrl-0 = <&sdmmc0_bus4 &sdmmc0_clk &sdmmc0_cmd &sdmmc0_det>;
- status = "okay";
+&tsadc {
- rockchip,hw-tshut-mode = <1>;
- rockchip,hw-tshut-polarity = <0>;
- status = "okay";
+&uart2 {
- status = "okay";
+&usb_host0_ehci {
- status = "okay";
+&usb_host0_ohci {
- status = "okay";
+&usb_host0_xhci {
- extcon = <&usb2phy0>;
- dr_mode = "host";
- status = "okay";
+&usb_host1_ehci {
- status = "okay";
+&usb_host1_ohci {
- status = "okay";
+&usb_host1_xhci {
- status = "okay";
+&usb2phy0 {
- status = "okay";
+&usb2phy0_host {
- phy-supply = <&vcc5v0_usb_host>;
- status = "okay";
+&usb2phy0_otg {
- status = "okay";
+&usb2phy1 {
- status = "okay";
+&usb2phy1_host {
- phy-supply = <&vcc5v0_usb_otg>;
- status = "okay";
+&usb2phy1_otg {
- status = "okay";
+&vop {
- assigned-clocks = <&cru DCLK_VOP0>, <&cru DCLK_VOP1>;
- assigned-clock-parents = <&pmucru PLL_HPLL>, <&cru PLL_VPLL>;
- status = "okay";
+&vop_mmu {
- status = "okay";
+&vp0 {
- vp0_out_hdmi: endpoint@ROCKCHIP_VOP2_EP_HDMI0 {
- RADXA-CM3 M: Jagan Teki jagan@amarulasolutions.com S: Maintained
- Rockchip RK3568
- 2 or 4GB LPDDR4X
- GbE LAN (Native)
- M.2 Connector
- 2xUSB 3.0 Host
No changes in v2.
- rk3568-nanopi-r5s.dtb \ rk3568-rock-3a.dtb
- chosen {
+&sdhci {
- mmc-hs200-1_8v;
Because this is a rk3568 you can probably also add:
mmc-ddr-1_8v; mmc-hs400-1_8v; mmc-hs400-enhanced-strobe;
and a pinctrl with emmc_datastrobe according to schematic:
pinctrl-0 = <&emmc_bus8 &emmc_clk &emmc_cmd &emmc_datastrobe>;
+&sdmmc0 {
- bus-width = <4>;
- bootph-pre-ram;
The sdmmc0 node is not needed: - bus-width is set in linux dts - bootph-pre-ram is set in rk356x-u-boot.dtsi - u-boot,spl-fifo-mode is not needed on rk356x
+&uart2 {
- bootph-pre-ram;
Recommended to be bootph-all, in case TPL support gets added in future.
- status = "okay";
[snip]
REGULATOR_PWM and DM_REGULATOR_GPIO is not referenced in device tree. DM_REGULATOR_FIXED is selected in arch Kconfig
I would recommend running moveconfig.py to clean up/re-order this file.
Regards, Jonas
Hi Jonas,
- Rockchip RK3568
- 2 or 4GB LPDDR4X
- GbE LAN (Native)
- M.2 Connector
- 2xUSB 3.0 Host
No changes in v2.
chosen {
+&sdhci {
cap-mmc-highspeed;
mmc-hs200-1_8v;
+&sdmmc0 {
bus-width = <4>;
bootph-pre-ram;
+&uart2 {
bootph-pre-ram;
Thank you so much for all of these explanations and suggestions! I will test them later today and send v3.
Thanks, Tianling.
status = "okay";
[snip]
Regards, Jonas
Jonas Karlman
Kever Yang
Tianling Shen
