[U-Boot-Users] [Patch 02/17] U-Boot-V2:Common:Clock Handle case of clock rollover for get_time_ns
get_time_ns does a simplistic delta = cycle_now - cycle_last. It is possible that the h/w counter reached max and reset back to 0. This patch addresses this issue by checking for rollover condition.
NOTE 1: This does not guarantee that you cannot confuse get_time_ns. You could possibly wait for two reset cycles and then get a messed up value. To fix that we may need interrupt mode timer tick - something on the lines of jiffies on linux. NOTE 2: the question of cs->mask is not clear. if the mask is for the tick, then it is better done with (cycle_now & cs->mask) - (cs->cycle_last & cs->mask). Do we need min and max for register read?
Signed-off-by: Nishanth Menonx0nishan@ti.com
--- common/clock.c | 14 ++++++++++++-- 1 file changed, 12 insertions(+), 2 deletions(-)
Index: u-boot-v2.git/common/clock.c =================================================================== --- u-boot-v2.git.orig/common/clock.c 2008-05-20 17:19:44.000000000 -0500 +++ u-boot-v2.git/common/clock.c 2008-05-20 17:26:31.000000000 -0500 @@ -37,14 +37,24 @@ uint64_t get_time_ns(void) { struct clocksource *cs = current_clock; - uint64_t cycle_now, cycle_delta; + uint64_t cycle_now, cycle_delta = 0; uint64_t ns_offset;
/* read clocksource: */ cycle_now = cs->read();
/* calculate the delta since the last call: */ - cycle_delta = (cycle_now - cs->cycle_last) & cs->mask; + + /* Handle rollover case */ + if (cycle_now < cs->cycle_last) { + /* FIXME: I am not convinced about the cs->mask operation.. + * I am assuming cs->mask is max! Probably need to change + * clocksource structure to have min and max + */ + cycle_delta = cs->mask - (cs->cycle_last & cs->mask); + cs->cycle_last = 0; + } + cycle_delta += (cycle_now & cs->mask) - (cs->cycle_last & cs->mask);
/* convert to nanoseconds: */ ns_offset = cyc2ns(cs, cycle_delta);
/* read clocksource: */ cycle_now = cs->read(); /* calculate the delta since the last call: */
Look closer, the rollover case is handled implicitly by the unsigned arithmetics.
You are right, we do not have a possibility to detect a double rollover without interrupts. Normally this is not an issue as this code is used in timeout polling loops where the current time is polled often enough. Anyway, maybe some comment should mention that this function is not useful to measure long periods of time where 'long' is highly architecture specific.
regards, Sascha
cs->cycle_last = 0;
Sascha,
-----Original Message----- From: Sascha Hauer [mailto:s.hauer@pengutronix.de] Sent: Tuesday, June 03, 2008 3:08 AM To: Menon, Nishanth Cc: u-boot-users@lists.sourceforge.net; Laurent Desnogues; dirk.behme@googlemail.com; philip.balister@gmail.com; Gopinath, Thara; Kamat, Nishant; Syed Mohammed, Khasim Subject: Re: [Patch 02/17] U-Boot-V2:Common:Clock Handle case of clockrollover for get_time_ns
Agreed for logic when mask is the max value attainable. IMHO, The concept of cs->mask is messy. We do need a min, max and a mask. When: cycle_now = cs->read(); cs->cycle_last = cycle_now; (cycle_now - cs->cycle_last) & cs->mask is wrong. Assumptions made: A) The bits masked out by cs->mask will remain constant. This may not be true. B) Roll over assume the min is 0 and max is cs->mask. This need not be the case. It would be good to be explicit.
Yes, there are indenting issue + no doxygen documentation.. It helps as clock_source is critical implementation required in the system.
Regards, Nishanth Menon
On Tue, Jun 03, 2008 at 07:47:25AM -0500, Menon, Nishanth wrote:
Sascha,
Now cycle_now == cs->cycle_last...
...so 0 & cs->mask = 0
This makes no sense, but this is not the order of execution in current code.
Eh? That's why they are masked out.
Do you know any counter that does not start counting from zero? If you have, noone prevents you from substracting the value in your clocksource read function.
Sascha,
-----Original Message----- From: Sascha Hauer [mailto:s.hauer@pengutronix.de] Sent: Tuesday, June 03, 2008 9:15 AM To: Menon, Nishanth Cc: u-boot-users@lists.sourceforge.net; Laurent Desnogues; dirk.behme@googlemail.com; philip.balister@gmail.com; Gopinath, Thara; Kamat, Nishant; Syed Mohammed, Khasim Subject: Re: [Patch 02/17] U-Boot-V2:Common:Clock Handle case ofclockrollover for get_time_ns
For the sake of discussion: unsigned int now = 0x120; unsigned int last = 0x128; unsigned int mask = 0xFFF0; unsigned int delta1 = now - last; unsigned int delta2 = (now & mask) - (last & mask); printf ("delta1=0x%08X maskdelta1=0x%08X delta2=0x%08X\n",delta1, delta1 & mask, delta2);
Output will be: delta1=0xFFFFFFF8 maskdelta1=0x0000FFF0 delta2=0x00000000
What we will get now is maskdelta1, while delta2 is the right value.
I do not. I am just being a paranoid idiot ;)..
Max however is assumed to be cs->mask then. We could have timers which can be configured for ticking till a configured max. probably my paranoia kicking in again?
On Tue, Jun 03, 2008 at 09:39:51AM -0500, Menon, Nishanth wrote:
Sascha,
It's not that I thought of the code by myself, I just looked into the kernel and it's exactly like this in the kernel code. So you either just found a kernel bug or we both understand something wrong.
If that's the only possibility to program this timer then go out and kill the chip designer ;)
Sascha
Sascha,
-----Original Message----- From: Sascha Hauer [mailto:s.hauer@pengutronix.de] Sent: Tuesday, June 03, 2008 10:14 AM To: Menon, Nishanth Cc: u-boot-users@lists.sourceforge.net; Laurent Desnogues; dirk.behme@googlemail.com; philip.balister@gmail.com; Gopinath, Thara; Kamat, Nishant; Syed Mohammed, Khasim Subject: Re: [Patch 02/17] U-Boot-V2:Common:Clock Handle caseofclockrollover for get_time_ns
Here is a revisit of this patch. The change will ensure cycle_now and last will be masked.
--- common/clock.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
Index: u-boot.v2/common/clock.c =================================================================== --- u-boot.v2.orig/common/clock.c 2007-10-10 21:50:14.000000000 -0500 +++ u-boot.v2/common/clock.c 2008-06-03 11:16:05.000000000 -0500 @@ -41,7 +41,7 @@ uint64_t ns_offset;
/* read clocksource: */ - cycle_now = cs->read(); + cycle_now = cs->read() & cs->mask;
/* calculate the delta since the last call: */ cycle_delta = (cycle_now - cs->cycle_last) & cs->mask;
Menon, Nishanth
Sascha Hauer
