[U-Boot] [PATCH 1/2] NAND: ADD page Parameter to all read_page/read_page_raw API's
This patch adds a new "page" parameter to all NAND read_page/read_page_raw APIs. The read_page API for the new mode ECC_HW_OOB_FIRST requires the page information to send the READOOB command and read the OOB area before the data area.
This patch has been accepted by Andrew Morton and can be found at http://userweb.kernel.org/~akpm/mmotm/broken-out/mtd-nand-add-page-parameter...
WE would like this to become part of the u-boot GIT as well
Signed-off-by: Sandeep Paulraj s-paulraj@ti.com Signed-off-by: Sneha Narnakaje nsnehaprabha@ti.com --- drivers/mtd/nand/fsl_elbc_nand.c | 2 +- drivers/mtd/nand/nand_base.c | 16 +++++++++------- include/linux/mtd/nand.h | 4 ++-- 3 files changed, 12 insertions(+), 10 deletions(-)
diff --git a/drivers/mtd/nand/fsl_elbc_nand.c b/drivers/mtd/nand/fsl_elbc_nand.c index 77a33c0..50cb4aa 100644 --- a/drivers/mtd/nand/fsl_elbc_nand.c +++ b/drivers/mtd/nand/fsl_elbc_nand.c @@ -662,7 +662,7 @@ static int fsl_elbc_wait(struct mtd_info *mtd, struct nand_chip *chip)
static int fsl_elbc_read_page(struct mtd_info *mtd, struct nand_chip *chip, - uint8_t *buf) + uint8_t *buf, int page) { fsl_elbc_read_buf(mtd, buf, mtd->writesize); fsl_elbc_read_buf(mtd, chip->oob_poi, mtd->oobsize); diff --git a/drivers/mtd/nand/nand_base.c b/drivers/mtd/nand/nand_base.c index 360b070..ca02628 100644 --- a/drivers/mtd/nand/nand_base.c +++ b/drivers/mtd/nand/nand_base.c @@ -895,7 +895,7 @@ static int nand_wait(struct mtd_info *mtd, struct nand_chip *this) * @buf: buffer to store read data */ static int nand_read_page_raw(struct mtd_info *mtd, struct nand_chip *chip, - uint8_t *buf) + uint8_t *buf, int page) { chip->read_buf(mtd, buf, mtd->writesize); chip->read_buf(mtd, chip->oob_poi, mtd->oobsize); @@ -909,7 +909,7 @@ static int nand_read_page_raw(struct mtd_info *mtd, struct nand_chip *chip, * @buf: buffer to store read data */ static int nand_read_page_swecc(struct mtd_info *mtd, struct nand_chip *chip, - uint8_t *buf) + uint8_t *buf, int page) { int i, eccsize = chip->ecc.size; int eccbytes = chip->ecc.bytes; @@ -919,7 +919,7 @@ static int nand_read_page_swecc(struct mtd_info *mtd, struct nand_chip *chip, uint8_t *ecc_code = chip->buffers->ecccode; uint32_t *eccpos = chip->ecc.layout->eccpos;
- chip->ecc.read_page_raw(mtd, chip, buf); + chip->ecc.read_page_raw(mtd, chip, buf, page);
for (i = 0; eccsteps; eccsteps--, i += eccbytes, p += eccsize) chip->ecc.calculate(mtd, p, &ecc_calc[i]); @@ -1032,7 +1032,7 @@ static int nand_read_subpage(struct mtd_info *mtd, struct nand_chip *chip, uint3 * Not for syndrome calculating ecc controllers which need a special oob layout */ static int nand_read_page_hwecc(struct mtd_info *mtd, struct nand_chip *chip, - uint8_t *buf) + uint8_t *buf, int page) { int i, eccsize = chip->ecc.size; int eccbytes = chip->ecc.bytes; @@ -1077,7 +1077,7 @@ static int nand_read_page_hwecc(struct mtd_info *mtd, struct nand_chip *chip, * we need a special oob layout and handling. */ static int nand_read_page_syndrome(struct mtd_info *mtd, struct nand_chip *chip, - uint8_t *buf) + uint8_t *buf, int page) { int i, eccsize = chip->ecc.size; int eccbytes = chip->ecc.bytes; @@ -1219,11 +1219,13 @@ static int nand_do_read_ops(struct mtd_info *mtd, loff_t from,
/* Now read the page into the buffer */ if (unlikely(ops->mode == MTD_OOB_RAW)) - ret = chip->ecc.read_page_raw(mtd, chip, bufpoi); + ret = chip->ecc.read_page_raw(mtd, chip, + bufpoi, page); else if (!aligned && NAND_SUBPAGE_READ(chip) && !oob) ret = chip->ecc.read_subpage(mtd, chip, col, bytes, bufpoi); else - ret = chip->ecc.read_page(mtd, chip, bufpoi); + ret = chip->ecc.read_page(mtd, chip, bufpoi, + page); if (ret < 0) break;
diff --git a/include/linux/mtd/nand.h b/include/linux/mtd/nand.h index 3e0044b..d6aa392 100644 --- a/include/linux/mtd/nand.h +++ b/include/linux/mtd/nand.h @@ -268,13 +268,13 @@ struct nand_ecc_ctrl { uint8_t *calc_ecc); int (*read_page_raw)(struct mtd_info *mtd, struct nand_chip *chip, - uint8_t *buf); + uint8_t *buf, int page); void (*write_page_raw)(struct mtd_info *mtd, struct nand_chip *chip, const uint8_t *buf); int (*read_page)(struct mtd_info *mtd, struct nand_chip *chip, - uint8_t *buf); + uint8_t *buf, int page); int (*read_subpage)(struct mtd_info *mtd, struct nand_chip *chip, uint32_t offs, uint32_t len,
s-paulraj@dal.design.ti.com
