[U-Boot] [PULL] : Please pull u-boot-imx
Hi Albert,
please pull from u-boot-imx, thanks.
The following changes since commit 34275d70fec6cc369a931090ebb686bc213bb80d:
arch-mx6: add mx6dl_pins.h (2012-11-10 08:15:40 +0100)
git://www.denx.de/git/u-boot-imx.git master
for you to fetch changes up to 1d4fd0dc3b45de7b7a706285845ef5b527422014:
mx28: Fix typo in POWER_DCLIMITS_NEGLIMIT_OFFSET (2012-11-24 16:21:37 +0100)
---------------------------------------------------------------- Benoît Thébaudeau (16): mx31: Move EHCI definitions to ehci-fsl.h ehci-mxc: Clean up ehci-mx5: Clean up ehci-mx5: Fix OC_DIS usage ehci-mx5: Fix OPM usage ehci-mx5: Fix *PM usage for i.MX53 ehci-mx5: Add missing OC_DIS for i.MX53 ehci-mxc: Make EHCI power/oc polarities configurable ehci-mxc: Make i.MX25 EHCI configurable ehci-mxc: Define host offsets ehci-mxc: Add support for i.MX35 mx35pdk: Add support for OTG ehci-mx5/6: Make board_ehci_hcd_init() optional ehci-mxc: Fix host power mask bit for i.MX35 ehci-mxc: Fix host power mask bit for i.MX25 mx5: Mark lowlevel_init board-specific code
Fabio Estevam (13): mx5: Align SPI CS naming with i.MX53 reference manual mx5: Print CSPI clock in 'clock' command spi: mxc_spi: Fix handling of chip select spi: mxc_spi: Fix spi clock glitch durant reset mx6: clock: Only show CSPI clock if CSPI is enabled mx28evk: Configure CONFIG_BOOTDELAY to one second mx53loco: Configure CONFIG_BOOTDELAY to one second mx6qsabrelite: Configure CONFIG_BOOTDELAY to one second mx6qsabre_common: Configure CONFIG_BOOTDELAY to one second mx51evk: Configure CONFIG_BOOTDELAY to one second mx25pdk: Configure CONFIG_BOOTDELAY to one second mx31pdk: Configure CONFIG_BOOTDELAY to one second mx35pdk: Configure CONFIG_BOOTDELAY to one second
Marek Vasut (2): mx28: Fix typo in POWER_MINPWR_VBG_OFF mx28: Fix typo in POWER_DCLIMITS_NEGLIMIT_OFFSET
arch/arm/cpu/armv7/mx5/clock.c | 4 +- arch/arm/cpu/armv7/mx5/lowlevel_init.S | 2 +- arch/arm/cpu/armv7/mx6/clock.c | 2 + arch/arm/include/asm/arch-mx25/imx-regs.h | 1 + arch/arm/include/asm/arch-mx31/imx-regs.h | 27 +--- arch/arm/include/asm/arch-mx35/imx-regs.h | 2 + arch/arm/include/asm/arch-mx5/mx5x_pins.h | 6 +- arch/arm/include/asm/arch-mxs/regs-power.h | 4 +- board/freescale/mx35pdk/lowlevel_init.S | 4 + board/freescale/mx35pdk/mx35pdk.c | 21 +++ doc/README.imx5 | 5 + drivers/spi/mxc_spi.c | 9 +- drivers/usb/host/ehci-mx5.c | 146 ++++++++++++++---- drivers/usb/host/ehci-mx6.c | 5 + drivers/usb/host/ehci-mxc.c | 225 +++++++++++++++++++++------- include/configs/mx25pdk.h | 2 +- include/configs/mx28evk.h | 2 +- include/configs/mx31pdk.h | 2 +- include/configs/mx35pdk.h | 16 +- include/configs/mx51_efikamx.h | 1 + include/configs/mx51evk.h | 3 +- include/configs/mx53loco.h | 2 +- include/configs/mx6qsabre_common.h | 2 +- include/configs/mx6qsabrelite.h | 2 +- include/configs/vision2.h | 1 + include/configs/zmx25.h | 6 +- include/usb/ehci-fsl.h | 28 +++- 27 files changed, 401 insertions(+), 129 deletions(-)
Hi Stefano,
On Sat, 24 Nov 2012 16:29:03 +0100, Stefano Babic sbabic@denx.de wrote:
Hi Albert,
Applied to u-boot-arm/master, thanks!
Amicalement,
Albert ARIBAUD
Stefano Babic
