[U-Boot] [PATCH 1/2] spi: cf_spi: Use to_cf_spi_slave to resolve cfslave from slave
Don't assume slave is always the first member of struct cf_spi_slave. Use container_of instead of casting first structure member.
Signed-off-by: Axel Lin axel.lin@ingics.com --- drivers/spi/cf_spi.c | 11 +++++++++-- 1 file changed, 9 insertions(+), 2 deletions(-)
diff --git a/drivers/spi/cf_spi.c b/drivers/spi/cf_spi.c index 879a809..7453538 100644 --- a/drivers/spi/cf_spi.c +++ b/drivers/spi/cf_spi.c @@ -46,6 +46,11 @@ DECLARE_GLOBAL_DATA_PTR; #define SPI_MODE_MOD 0x00200000 #define SPI_DBLRATE 0x00100000
+static inline struct cf_spi_slave *to_cf_spi_slave(struct spi_slave *slave) +{ + return container_of(slave, struct cf_spi_slave, slave); +} + void cfspi_init(void) { volatile dspi_t *dspi = (dspi_t *) MMAP_DSPI; @@ -105,7 +110,7 @@ u16 cfspi_rx(void) int cfspi_xfer(struct spi_slave *slave, uint bitlen, const void *dout, void *din, ulong flags) { - struct cf_spi_slave *cfslave = (struct cf_spi_slave *)slave; + struct cf_spi_slave *cfslave = to_cf_spi_slave(slave); u16 *spi_rd16 = NULL, *spi_wr16 = NULL; u8 *spi_rd = NULL, *spi_wr = NULL; static u32 ctrl = 0; @@ -326,7 +331,9 @@ struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs,
void spi_free_slave(struct spi_slave *slave) { - free(slave); + struct cf_spi_slave *cfslave = to_cf_spi_slave(slave); + + free(cfslave); }
int spi_claim_bus(struct spi_slave *slave)
Make local functions static and remove unneeded forward declarations.
Signed-off-by: Axel Lin axel.lin@ingics.com --- drivers/spi/cf_spi.c | 20 +++++++------------- 1 file changed, 7 insertions(+), 13 deletions(-)
diff --git a/drivers/spi/cf_spi.c b/drivers/spi/cf_spi.c index 7453538..6ce1101 100644 --- a/drivers/spi/cf_spi.c +++ b/drivers/spi/cf_spi.c @@ -20,13 +20,6 @@ struct cf_spi_slave { int charbit; };
-int cfspi_xfer(struct spi_slave *slave, uint bitlen, const void *dout, - void *din, ulong flags); -struct spi_slave *cfspi_setup_slave(struct cf_spi_slave *cfslave, uint mode); -void cfspi_init(void); -void cfspi_tx(u32 ctrl, u16 data); -u16 cfspi_rx(void); - extern void cfspi_port_conf(void); extern int cfspi_claim_bus(uint bus, uint cs); extern void cfspi_release_bus(uint bus, uint cs); @@ -51,7 +44,7 @@ static inline struct cf_spi_slave *to_cf_spi_slave(struct spi_slave *slave) return container_of(slave, struct cf_spi_slave, slave); }
-void cfspi_init(void) +static void cfspi_init(void) { volatile dspi_t *dspi = (dspi_t *) MMAP_DSPI;
@@ -89,7 +82,7 @@ void cfspi_init(void) #endif }
-void cfspi_tx(u32 ctrl, u16 data) +static void cfspi_tx(u32 ctrl, u16 data) { volatile dspi_t *dspi = (dspi_t *) MMAP_DSPI;
@@ -98,7 +91,7 @@ void cfspi_tx(u32 ctrl, u16 data) dspi->tfr = (ctrl | data); }
-u16 cfspi_rx(void) +static u16 cfspi_rx(void) { volatile dspi_t *dspi = (dspi_t *) MMAP_DSPI;
@@ -107,8 +100,8 @@ u16 cfspi_rx(void) return (dspi->rfr & 0xFFFF); }
-int cfspi_xfer(struct spi_slave *slave, uint bitlen, const void *dout, - void *din, ulong flags) +static int cfspi_xfer(struct spi_slave *slave, uint bitlen, const void *dout, + void *din, ulong flags) { struct cf_spi_slave *cfslave = to_cf_spi_slave(slave); u16 *spi_rd16 = NULL, *spi_wr16 = NULL; @@ -181,7 +174,8 @@ int cfspi_xfer(struct spi_slave *slave, uint bitlen, const void *dout, return 0; }
-struct spi_slave *cfspi_setup_slave(struct cf_spi_slave *cfslave, uint mode) +static struct spi_slave *cfspi_setup_slave(struct cf_spi_slave *cfslave, + uint mode) { /* * bit definition for mode:
uint mode)
{ /* * bit definition for mode: -- 1.9.1
Applied to u-boot-spi/master
thanks!
free(slave);
free(cfslave);
1.9.1
thanks!
Axel Lin
Jagan Teki
