[U-Boot] U-Boot: Erasing NOR Memory, only half of the content erased
Hello U-Boot team,
We are facing a problem with our NOR Memory.
We try to update the content of this memory, the process is normally:
* Reset the target memory address range => back to 0xFF * Flash the new data * done
But, we noticed that the memory is not fully erased. The first block of 64KiB is reset and the next 64KiB block not, etc..
I join a log that presents our problem (erase NOR half.txt), the U-Boot config (u-boot.cfg) and the datasheet of the concerned memory (MX25U25645GMI00.pdf).
About our config:
* software development based on the DENX U-Boot V2019.10 revision * custom board with the CPU NXP LS1043a Layerscape * exact memory reference 'Macronix MX25U25645GMI00/TR' connected on a QSPI interface * We don't have any trouble to flash this memory with a Lauterbach debugger
Is this problem already known ?
Could you provide us a patch ?
If needed, I can transmit more information.
Mit freundlichen Grüßen Florian Manoël
Siemens AG Digital Industries Process Automation Software House Khe DI PA CI R&D 2 Östliche Rheinbrückenstr. 50 76187 Karlsruhe, Deutschland Tel.: +49 721 595-1433 mailto:florian.manoel@siemens.com www.siemens.com/ingenuityforlifehttps://siemens.com/ingenuityforlife
Siemens Aktiengesellschaft: Vorsitzender des Aufsichtsrats: Jim Hagemann Snabe; Vorstand: Joe Kaeser, Vorsitzender; Roland Busch, Lisa Davis, Klaus Helmrich, Janina Kugel, Cedrik Neike, Michael Sen, Ralf P. Thomas; Sitz der Gesellschaft: Berlin und München, Deutschland; Registergericht: Berlin Charlottenburg, HRB 12300, München, HRB 6684; WEEE-Reg.-Nr. DE 23691322
