[U-Boot] Help needed on Colibri T20 - Iris Board
We are 2 engineering students from Fribourg, Switzerland working on a embedded systems project.
The fact is that we're looking to setup U-Boot on a Colibri Iris Board using the Colibri T20 module with NVIDIA Tegra 2 processor.
Since the Iris board is a relatively new board, it is difficult for us to find information about it.
We managed to install a recent uboot on the board but it is not very efficient. The major problem is that we aren't able to run the *saveenv*command in order to save the environnement. Does anyone have any ideas about the problem? Or patches to recommend us?
We don't have much experience in embedded systems so a little help from you would be much appreciated.
Thank you in advance
Dear =?ISO-8859-1?Q?St=E9phane_Carvalho?=,
In message CAJq7D22dStVsKUq3DTsM7OXYMATycUgX2bz2Q2OSW2bbceJX-g@mail.gmail.com you wrote:
It would definitely be helpful if you describe which actual problem you see?
Is the "saveenv" command not available at all? Does it reaturn any error messages? Which exact messages?
In message <CAJq7D22dStVsKUq3DTsM7OXYMATycUgX2bz2Q2OSW2bbceJX-
Hi Wolfgang,
they don't have any storage media. They PMed me and I explained to them. Anyway, I suspect we won't be getting any further here as they decided to use out-of- tree port (sadly).
M
Hi Stéphane,
On Wed, Jan 11, 2012 at 1:52 AM, Stéphane Carvalho carvalho.stephane@gmail.com wrote:
Sorry I don't know anything about that particular board either.
We managed to install a recent uboot on the board but it is not very efficient. The major problem is that we aren't able to run the saveenv command in order to save the environnement. Does anyone have any ideas about the problem? Or patches to recommend us?
Where is your environment supposed to be stored? If you are booting from NAND or MMC then you could store it there. There are various CONFIG_ENV_IS_IN_... variables to define depending on where you want the environment. The README file lists each of these and explains how to use them. You also need to define CONFIG_CMD_SAVEENV or perhaps better #include <config_default.h>.
OK, please reply on this thread if you have further questions.
Hi guys,
Here's the situation:
We applied the following patches to an original u-boot source code (2011.09 version):
[U-Boot] [PATCH 1/2] Tegra2: Make XTal speed configurable [U-Boot] [PATCH 2/2] Tegra2: Add support for Toradex Colibri T20 board
And we use the antmicro patches for the Colibri T20 available on http://antmicro.com/blog.html (category ARM) Their patches are used to add the USB drivers for using the USB-to-Ethernet port.
Then, we take the following patches:
[U-Boot] [PATCH v2 0/8] Tegra2: Implement SPI flash and saved environment
The problem is that this patch is for the Seaboard. We adapted it for the Iris Board but this ain't working. We wonder if this patch is the right one.
2012/1/11 Simon Glass sjg@chromium.org
Hi Stéphane,
using
about
you
Hi Stéphane,
On Fri, Jan 13, 2012 at 6:03 AM, Stéphane Carvalho carvalho.stephane@gmail.com wrote:
Hi guys,
OK. There is a USB series on the list also. I can see a tar file on that web page but didn't look at it. I presume it works for you ok so that is fine.
Well the series includes the driver support but also turns on the environment options in seaboard.h. So at the least you would need to turn these options on in your config file.
Also check that the pinmux is being set in tegra2_spi.c. The final few patches to do this cleanly for Seaboard were NAKed (NS16550 changes and buffering) so this might be slightly different on your platform. It looks like you use UARTA so won't have the SPI/UART conflict, but you still need to make sure that SPI's pinmux is enabled.
Hi Stéphane,
Stéphane Carvalho
