[PATCH V3] cpu: imx8_cpu: Avoid revision to corrupt device tree
U-Boot device tree is padded just after U-Boot proper. After the whole stuff loaded to DRAM space, the device tree area is conflict with BSS region before U-Boot relocation.
So any write to BSS area before reloc_fdt will corrupt the device tree. Without the fix, there is issue that “binman_init failed:-2” on i.MX8MP-EVK board.
Drop 'revision' and use malloc area in cpu_imx_plat->rev.
Signed-off-by: Peng Fan peng.fan@nxp.com ---
V3: Update commit Pass CI
V2: Move to use malloc area for revision
drivers/cpu/imx8_cpu.c | 32 +++++++++++++++++--------------- 1 file changed, 17 insertions(+), 15 deletions(-)
diff --git a/drivers/cpu/imx8_cpu.c b/drivers/cpu/imx8_cpu.c index 6c0a8c0cbe4..51262befaff 100644 --- a/drivers/cpu/imx8_cpu.c +++ b/drivers/cpu/imx8_cpu.c @@ -20,10 +20,11 @@
DECLARE_GLOBAL_DATA_PTR;
+#define IMX_REV_LEN 4 struct cpu_imx_plat { const char *name; - const char *rev; const char *type; + char rev[IMX_REV_LEN]; u32 cpu_rsrc; u32 cpurev; u32 freq_mhz; @@ -69,28 +70,29 @@ static const char *get_imx_type_str(u32 imxtype) } }
-static const char *get_imx_rev_str(u32 rev) +static void get_imx_rev_str(struct cpu_imx_plat *plat, u32 rev) { - static char revision[4]; - if (IS_ENABLED(CONFIG_IMX8)) { switch (rev) { case CHIP_REV_A: - return "A"; + plat->rev[0] = 'A'; + break; case CHIP_REV_B: - return "B"; + plat->rev[0] = 'B'; + break; case CHIP_REV_C: - return "C"; + plat->rev[0] = 'C'; + break; default: - return "?"; + plat->rev[0] = '?'; + break; } + plat->rev[1] = '\0'; } else { - revision[0] = '1' + (((rev & 0xf0) - CHIP_REV_1_0) >> 4); - revision[1] = '.'; - revision[2] = '0' + (rev & 0xf); - revision[3] = '\0'; - - return revision; + plat->rev[0] = '1' + (((rev & 0xf0) - CHIP_REV_1_0) >> 4); + plat->rev[1] = '.'; + plat->rev[2] = '0' + (rev & 0xf); + plat->rev[3] = '\0'; } }
@@ -318,7 +320,7 @@ static int imx_cpu_probe(struct udevice *dev) set_core_data(dev); cpurev = get_cpu_rev(); plat->cpurev = cpurev; - plat->rev = get_imx_rev_str(cpurev & 0xFFF); + get_imx_rev_str(plat, cpurev & 0xFFF); plat->type = get_imx_type_str((cpurev & 0x1FF000) >> 12); plat->freq_mhz = imx_get_cpu_rate(dev) / 1000000; plat->mpidr = dev_read_addr(dev);
Applied, thanks.
Fabio Estevam
Peng Fan (OSS)
