[U-Boot] [PATCH] doc: verified-boot: fix crypto algorithm examples
As you see in crypto_algos in common/image-sig.c, the algorithm should be either "rsa2048" or "rsa4096". "rs2048" is a typo.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
doc/uImage.FIT/signature.txt | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/doc/uImage.FIT/signature.txt b/doc/uImage.FIT/signature.txt index a57cdab..2ece4c4 100644 --- a/doc/uImage.FIT/signature.txt +++ b/doc/uImage.FIT/signature.txt @@ -85,7 +85,7 @@ allow the signer to operate. These should be added to the .its file. Signature nodes sit at the same level as hash nodes and are called signature@1, signature@2, etc.
-- algo: Algorithm name (e.g. "sha1,rs2048") +- algo: Algorithm name (e.g. "sha1,rsa2048")
- key-name-hint: Name of key to use for signing. The keys will normally be in a single directory (parameter -k to mkimage). For a given key <name>, its @@ -139,7 +139,7 @@ public key in U-Boot's control FDT (using CONFIG_OF_CONTROL). Public keys should be stored as sub-nodes in a /signature node. Required properties are:
Optional properties are:
On 19 October 2017 at 12:37, Masahiro Yamada yamada.masahiro@socionext.com wrote:
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com Reviewed-by: Simon Glass sjg@chromium.org
Masahiro Yamada
