[U-Boot] Please pull u-boot-fsl-qoriq master
Tom,
The following changes since commit f23baa572f96e1e13d7f1a3c8addb61b5d0dbd29:
cmd_dhry.c: Use lldiv for vax_mips calculation as well (2016-03-17 10:14:25 -0400)
git://git.denx.de/u-boot-fsl-qoriq.git master
for you to fetch changes up to 6dedcedd6442295428ea7f02b0d30739499858a2:
driver: net: fsl-mc: Return from DPAA_exit if boot_status !=0 (2016-03-21 12:42:15 -0700)
---------------------------------------------------------------- Alexander Graf (1): arm64: Fix layerscape mmu setup
Alison Wang (2): arm: ls102xa: fdt: Update FSL_QSPI_COMPAT and FSL_DSPI_COMPAT arm: ls102xa: Enable CONFIG_SYS_CONSOLE_IS_IN_ENV support
Aneesh Bansal (3): drivers/crypto/fsl: correct error checking in run_descriptor drivers/crypto/fsl: add constructs for protocol descriptors drivers/crypto/fsl: define structures for PDB
Prabhakar Kushwaha (4): armv8: lsch3: Enable WUO config for RNI-20 node driver: net: ldpaa_eth: Add support of PHY framework armv8: ls2085a: Remove phy configuration from QDS and RDB driver: net: fsl-mc: Return from DPAA_exit if boot_status !=0
Pratiyush Srivastava (1): armv8: fsl-layerscape: Updating entries in Serdes Table
Shaohui Xie (1): armv8: ls2080ardb: invert irq pins polarity for AQR405 PHY
Shengzhou Liu (2): driver/ddr/fsl: Add address parity support for DDR4 UDIMM/discrete driver/ddr/fsl: Add workaround for erratum A-009803
Stuart Yoder (5): armv8: ls2080a: remove obsolete stream ID partitioning support armv8: ls2080a: update stream ID partitioning info pci: make pci_get_hose_head() available to external users pci/layerscape: add defines for LUT pci/layerscape: set LUT and msi-map for discovered PCI devices
Wenbin Song (3): freescale: vid: Return i2c mux to default channel armv8/ls1043aqds: Return i2c mux to default chennel armv8/ls1043aqds: Enable ID_EEPROM support for ls1043aqds
Yangbo Lu (1): armv8/fsl-lsch2: fix sdhc clock frequency value
York Sun (1): boards: ls2080: Fix default bootargs
arch/arm/cpu/armv8/cache_v8.c | 2 +- arch/arm/cpu/armv8/fsl-layerscape/cpu.c | 5 + arch/arm/cpu/armv8/fsl-layerscape/fdt.c | 113 ---------- .../arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c | 4 + arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S | 8 + arch/arm/cpu/armv8/fsl-layerscape/ls2080a_serdes.c | 14 +- arch/arm/include/asm/arch-fsl-layerscape/config.h | 3 + .../include/asm/arch-fsl-layerscape/immap_lsch3.h | 8 + .../asm/arch-fsl-layerscape/ls2080a_stream_id.h | 55 +++-- arch/arm/include/asm/arch-ls102xa/config.h | 4 +- arch/arm/lib/ccn504.S | 21 ++ board/freescale/common/vid.c | 12 +- board/freescale/ls1043aqds/ls1043aqds.c | 6 +- board/freescale/ls2080aqds/eth.c | 25 --- board/freescale/ls2080ardb/eth_ls2080rdb.c | 39 ---- board/freescale/ls2080ardb/ls2080ardb.c | 4 + doc/README.fsl-ddr | 9 + drivers/crypto/fsl/desc.h | 80 ++++++++ drivers/crypto/fsl/desc_constr.h | 27 +++ drivers/crypto/fsl/jr.c | 2 +- drivers/ddr/fsl/ctrl_regs.c | 55 ++++- drivers/ddr/fsl/fsl_ddr_gen4.c | 44 +++- drivers/ddr/fsl/options.c | 15 +- drivers/net/fsl-mc/mc.c | 3 +- drivers/net/ldpaa_eth/ldpaa_eth.c | 121 ++++++++--- drivers/pci/pcie_layerscape.c | 217 +++++++++++++------- include/configs/ls1021aqds.h | 1 + include/configs/ls1021atwr.h | 1 + include/configs/ls1043aqds.h | 10 + include/configs/ls2080a_common.h | 2 +- include/configs/ls2080ardb.h | 3 +- include/fsl_ddr_sdram.h | 11 +- include/pci.h | 1 + 33 files changed, 591 insertions(+), 334 deletions(-)
Thanks.
York
On Tue, Mar 22, 2016 at 03:52:25PM +0000, york sun wrote:
Tom,
york sun
