[PATCH 1/1] x86: sizeof-array-div error in lpc_common_early_init
Building qemu-x86_64_defconfig with GCC 11.0 fails with:
arch/x86/cpu/intel_common/lpc.c: In function ‘lpc_common_early_init’: arch/x86/cpu/intel_common/lpc.c:56:40: error: expression does not compute the number of elements in this array; element type is ‘struct reg_info’, not ‘u32’ {aka ‘unsigned int’} [-Werror=sizeof-array-div] 56 | sizeof(values) / sizeof(u32)); | ^ arch/x86/cpu/intel_common/lpc.c:56:40: note: add parentheses around the second ‘sizeof’ to silence this warning arch/x86/cpu/intel_common/lpc.c:50:11: note: array ‘values’ declared here 50 | } values[4], *ptr; | ^~~~~~
Add parentheses to silence warning.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- arch/x86/cpu/intel_common/lpc.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/x86/cpu/intel_common/lpc.c b/arch/x86/cpu/intel_common/lpc.c index 23befbef15..f31fddb6fa 100644 --- a/arch/x86/cpu/intel_common/lpc.c +++ b/arch/x86/cpu/intel_common/lpc.c @@ -53,7 +53,7 @@ int lpc_common_early_init(struct udevice *dev)
count = fdtdec_get_int_array_count(gd->fdt_blob, dev_of_offset(dev), "intel,gen-dec", (u32 *)values, - sizeof(values) / sizeof(u32)); + sizeof(values) / (sizeof(u32))); if (count < 0) return -EINVAL;
-- 2.30.0
On Sat, Feb 20, 2021 at 5:05 PM Heinrich Schuchardt xypron.glpk@gmx.de wrote:
applied to u-boot-x86, thanks!
Bin Meng
