[PATCH 1/1] lib: move rtc-lib.c to lib
Function rtc_to_tm() is needed for FAT file system support even if we don't have a real time clock. So move it from drivers/ to lib/.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- drivers/rtc/Makefile | 1 - drivers/rtc/rtc-lib.c | 77 ------------------------------------------- lib/Makefile | 1 + lib/rtc-lib.c | 77 +++++++++++++++++++++++++++++++++++++++++++ 4 files changed, 78 insertions(+), 78 deletions(-) delete mode 100644 drivers/rtc/rtc-lib.c create mode 100644 lib/rtc-lib.c
diff --git a/drivers/rtc/Makefile b/drivers/rtc/Makefile index f668cf9050..331a49ab59 100644 --- a/drivers/rtc/Makefile +++ b/drivers/rtc/Makefile @@ -7,7 +7,6 @@ obj-$(CONFIG_$(SPL_TPL_)DM_RTC) += rtc-uclass.o
obj-$(CONFIG_RTC_AT91SAM9_RTT) += at91sam9_rtt.o -obj-y += rtc-lib.o obj-$(CONFIG_RTC_ARMADA38X) += armada38x.o obj-$(CONFIG_RTC_DAVINCI) += davinci.o obj-$(CONFIG_RTC_DS1302) += ds1302.o diff --git a/drivers/rtc/rtc-lib.c b/drivers/rtc/rtc-lib.c deleted file mode 100644 index 1f7bdade29..0000000000 --- a/drivers/rtc/rtc-lib.c +++ /dev/null @@ -1,77 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * rtc and date/time utility functions - * - * Copyright (C) 2005-06 Tower Technologies - * Author: Alessandro Zummo a.zummo@towertech.it - * - * U-Boot rtc_time differs from Linux rtc_time: - * - The year field takes the actual value, not year - 1900. - * - January is month 1. - */ - -#include <common.h> -#include <rtc.h> -#include <linux/math64.h> - -static const unsigned char rtc_days_in_month[] = { - 31, 28, 31, 30, 31, 30, 31, 31, 30, 31, 30, 31 -}; - -#define LEAPS_THRU_END_OF(y) ((y) / 4 - (y) / 100 + (y) / 400) - -/* - * The number of days in the month. - */ -int rtc_month_days(unsigned int month, unsigned int year) -{ - return rtc_days_in_month[month] + (is_leap_year(year) && month == 1); -} - -/* - * rtc_to_tm - Converts u64 to rtc_time. - * Convert seconds since 01-01-1970 00:00:00 to Gregorian date. - * - * This function is copied from rtc_time64_to_tm() in the Linux kernel. - * But in U-Boot January is month 1 and we do not subtract 1900 from the year. - */ -void rtc_to_tm(u64 time, struct rtc_time *tm) -{ - unsigned int month, year, secs; - int days; - - days = div_u64_rem(time, 86400, &secs); - - /* day of the week, 1970-01-01 was a Thursday */ - tm->tm_wday = (days + 4) % 7; - - year = 1970 + days / 365; - days -= (year - 1970) * 365 - + LEAPS_THRU_END_OF(year - 1) - - LEAPS_THRU_END_OF(1970 - 1); - while (days < 0) { - year -= 1; - days += 365 + is_leap_year(year); - } - tm->tm_year = year; /* Not year - 1900 */ - tm->tm_yday = days + 1; - - for (month = 0; month < 11; month++) { - int newdays; - - newdays = days - rtc_month_days(month, year); - if (newdays < 0) - break; - days = newdays; - } - tm->tm_mon = month + 1; /* January = 1 */ - tm->tm_mday = days + 1; - - tm->tm_hour = secs / 3600; - secs -= tm->tm_hour * 3600; - tm->tm_min = secs / 60; - tm->tm_sec = secs - tm->tm_min * 60; - - /* Zero unused fields */ - tm->tm_isdst = 0; -} diff --git a/lib/Makefile b/lib/Makefile index 6825671955..be45d4ab06 100644 --- a/lib/Makefile +++ b/lib/Makefile @@ -133,6 +133,7 @@ obj-$(CONFIG_SSCANF) += sscanf.o endif
obj-y += date.o +obj-y += rtc-lib.o obj-$(CONFIG_LIB_ELF) += elf.o
# diff --git a/lib/rtc-lib.c b/lib/rtc-lib.c new file mode 100644 index 0000000000..1f7bdade29 --- /dev/null +++ b/lib/rtc-lib.c @@ -0,0 +1,77 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * rtc and date/time utility functions + * + * Copyright (C) 2005-06 Tower Technologies + * Author: Alessandro Zummo a.zummo@towertech.it + * + * U-Boot rtc_time differs from Linux rtc_time: + * - The year field takes the actual value, not year - 1900. + * - January is month 1. + */ + +#include <common.h> +#include <rtc.h> +#include <linux/math64.h> + +static const unsigned char rtc_days_in_month[] = { + 31, 28, 31, 30, 31, 30, 31, 31, 30, 31, 30, 31 +}; + +#define LEAPS_THRU_END_OF(y) ((y) / 4 - (y) / 100 + (y) / 400) + +/* + * The number of days in the month. + */ +int rtc_month_days(unsigned int month, unsigned int year) +{ + return rtc_days_in_month[month] + (is_leap_year(year) && month == 1); +} + +/* + * rtc_to_tm - Converts u64 to rtc_time. + * Convert seconds since 01-01-1970 00:00:00 to Gregorian date. + * + * This function is copied from rtc_time64_to_tm() in the Linux kernel. + * But in U-Boot January is month 1 and we do not subtract 1900 from the year. + */ +void rtc_to_tm(u64 time, struct rtc_time *tm) +{ + unsigned int month, year, secs; + int days; + + days = div_u64_rem(time, 86400, &secs); + + /* day of the week, 1970-01-01 was a Thursday */ + tm->tm_wday = (days + 4) % 7; + + year = 1970 + days / 365; + days -= (year - 1970) * 365 + + LEAPS_THRU_END_OF(year - 1) + - LEAPS_THRU_END_OF(1970 - 1); + while (days < 0) { + year -= 1; + days += 365 + is_leap_year(year); + } + tm->tm_year = year; /* Not year - 1900 */ + tm->tm_yday = days + 1; + + for (month = 0; month < 11; month++) { + int newdays; + + newdays = days - rtc_month_days(month, year); + if (newdays < 0) + break; + days = newdays; + } + tm->tm_mon = month + 1; /* January = 1 */ + tm->tm_mday = days + 1; + + tm->tm_hour = secs / 3600; + secs -= tm->tm_hour * 3600; + tm->tm_min = secs / 60; + tm->tm_sec = secs - tm->tm_min * 60; + + /* Zero unused fields */ + tm->tm_isdst = 0; +} -- 2.30.2
Hi Heinrich,
On Sat, Jun 12, 2021 at 2:22 PM Heinrich Schuchardt xypron.glpk@gmx.de wrote:
Please use "git mv"
Regards, Bin
On Saturday 12 June 2021 18:55:12 Bin Meng wrote:
Hi Heinrich,
Please use "git mv"
"git mv" probably does not help as git internally does not track information about movement... "git mv" should od same thing as "git add" && "git rm".
Rather you need to generate patch with "-M" option to detect file movement.
Regards, Bin
Hi Heinrich,
Please use "git mv"
patman should do that automatically. If it does not, can you let me know the details?
Bin Meng
Pali Rohár
