[U-Boot] [PATCH v3 4/4] c6x: Add support c6745-som board
Add support board c6745-som (http://inmys.ru/?_=/products/som_c6745) with C6745 cpu.
Signed-off-by: Dmitry Bondar bond@inmys.ru Cc: Tom Rini trini@ti.com --- MAINTAINERS | 3 + board/inmys/c6745-som/Makefile | 27 ++++ board/inmys/c6745-som/c6745-som.c | 246 +++++++++++++++++++++++++++++++ boards.cfg | 1 + include/configs/c6745-som-inmys.h | 294 +++++++++++++++++++++++++++++++++++++ 5 files changed, 571 insertions(+), 0 deletions(-) create mode 100644 board/inmys/c6745-som/Makefile create mode 100644 board/inmys/c6745-som/c6745-som.c create mode 100644 include/configs/c6745-som-inmys.h
diff --git a/MAINTAINERS b/MAINTAINERS index e55893b..710f3df 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -62,6 +62,9 @@ Jerry Van Baren gerald.vanbaren@smiths-aerospace.com
sacsng MPC8260
+Dmitry Bondar bond@inmys.ru + c6745-som c674x + Oliver Brown obrown@adventnetworks.com
gw8260 MPC8260 diff --git a/board/inmys/c6745-som/Makefile b/board/inmys/c6745-som/Makefile new file mode 100644 index 0000000..9a91ed2 --- /dev/null +++ b/board/inmys/c6745-som/Makefile @@ -0,0 +1,27 @@ +# (C) Copyright 2012 Dmitry Bondar bond@inmys.ru +# +# This file is released under the terms of GPL v2 and any later version. +# See the file COPYING in the root directory of the source tree for details. + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +COBJS-$(CONFIG_MACH_INMYS_C6745_SOM) += c6745-som.o + +COBJS := $(COBJS-y) + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(call cmd_link_o_target, $(OBJS) $(SOBJS)) + +######################################################################### +# This is for $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/inmys/c6745-som/c6745-som.c b/board/inmys/c6745-som/c6745-som.c new file mode 100644 index 0000000..d71ac2b --- /dev/null +++ b/board/inmys/c6745-som/c6745-som.c @@ -0,0 +1,246 @@ +/* + * (C) Copyright 2012 Dmitry Bondar bond@inmys.ru + * From da830. Original Notices follow: + * + * Copyright (C) 2009 Nick Thompson, GE Fanuc, Ltd. nick.thompson@gefanuc.com + * + * Base on code from TI. Original Notices follow: + * + * (C) Copyright 2008, Texas Instruments, Inc. http://www.ti.com/ + * + * Modified for DA8xx EVM. + * + * Copyright (C) 2007 Sergey Kubushyn ksi@koi8.net + * + * Parts are shamelessly stolen from various TI sources, original copyright + * follows: + * ----------------------------------------------------------------- + * + * Copyright (C) 2004 Texas Instruments. + * + * ---------------------------------------------------------------------------- + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + * ---------------------------------------------------------------------------- + */ + +#include <common.h> +#include <i2c.h> +#include <net.h> +#include <netdev.h> +#include <asm/arch/hardware.h> +#include <asm/arch/emif_defs.h> +#include <asm/arch/emac_defs.h> +#include <asm/io.h> +#include <asm/arch/davinci_misc.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define pinmux(x) (&davinci_syscfg_regs->pinmux[x]) + +/* SPI0 pin muxer settings */ +static const struct pinmux_config spi0_pins[] = { + { pinmux(7), 1, 3 }, + { pinmux(7), 1, 4 }, + { pinmux(7), 1, 5 }, + { pinmux(7), 1, 6 }, + { pinmux(7), 1, 7 } +}; + +/* EMIF-A bus pins for 8-bit NAND support on CS3 */ +static const struct pinmux_config emifa_nand_pins[] = { + { pinmux(13), 1, 6 }, + { pinmux(13), 1, 7 }, + { pinmux(14), 1, 0 }, + { pinmux(14), 1, 1 }, + { pinmux(14), 1, 2 }, + { pinmux(14), 1, 3 }, + { pinmux(14), 1, 4 }, + { pinmux(14), 1, 5 }, + { pinmux(15), 1, 7 }, + { pinmux(16), 1, 0 }, + { pinmux(18), 1, 1 }, + { pinmux(18), 1, 4 }, + { pinmux(18), 1, 5 }, +}; + +/* EMAC PHY interface pins */ +static const struct pinmux_config emac_pins[] = { + { pinmux(9), 0, 5 }, + { pinmux(10), 2, 1 }, + { pinmux(10), 2, 2 }, + { pinmux(10), 2, 3 }, + { pinmux(10), 2, 4 }, + { pinmux(10), 2, 5 }, + { pinmux(10), 2, 6 }, + { pinmux(10), 2, 7 }, + { pinmux(11), 2, 0 }, + { pinmux(11), 2, 1 }, +}; + +/* UART pin muxer settings */ +static const struct pinmux_config uart_pins[] = { + { pinmux(8), 2, 7 }, + { pinmux(9), 2, 0 } +}; + +/* I2C pin muxer settings */ +static const struct pinmux_config i2c_pins[] = { + { pinmux(8), 2, 3 }, + { pinmux(8), 2, 4 } +}; + +/* USB0_DRVVBUS pin muxer settings */ +static const struct pinmux_config usb_pins[] = { + { pinmux(9), 1, 1 } +}; + +static const struct pinmux_resource pinmuxes[] = { +#ifdef CONFIG_SPI_FLASH + PINMUX_ITEM(spi0_pins), +#endif + PINMUX_ITEM(uart_pins), + PINMUX_ITEM(i2c_pins), +#ifdef CONFIG_USB_DA8XX + PINMUX_ITEM(usb_pins), +#endif +#ifdef CONFIG_USE_NAND + PINMUX_ITEM(emifa_nand_pins), +#endif +#if defined(CONFIG_DRIVER_TI_EMAC) + PINMUX_ITEM(emac_pins), +#endif +}; + +static const struct lpsc_resource lpsc[] = { + { DAVINCI_LPSC_AEMIF }, /* NAND, NOR */ + { DAVINCI_LPSC_SPI0 }, /* Serial Flash */ + { DAVINCI_LPSC_EMAC }, /* image download */ + { DAVINCI_LPSC_UART2 }, /* console */ + { DAVINCI_LPSC_GPIO }, +}; + +int board_early_init_f(void) +{ +#ifndef CONFIG_USE_IRQ + irq_init(); +#endif + +#ifdef CONFIG_NAND_DAVINCI + /* EMIFA 100MHz clock select */ + writel(readl(&davinci_syscfg_regs->cfgchip3) & ~2, + &davinci_syscfg_regs->cfgchip3); + /* NAND CS setup */ + writel((DAVINCI_ABCR_WSETUP(0) | + DAVINCI_ABCR_WSTROBE(2) | + DAVINCI_ABCR_WHOLD(0) | + DAVINCI_ABCR_RSETUP(0) | + DAVINCI_ABCR_RSTROBE(2) | + DAVINCI_ABCR_RHOLD(0) | + DAVINCI_ABCR_TA(2) | + DAVINCI_ABCR_ASIZE_8BIT), + &davinci_emif_regs->ab2cr); +#endif + + /* arch number of the board */ + /*gd->bd->bi_arch_number = MACH_TYPE_DAVINCI_DA830_EVM;*/ + gd->bd->bi_arch_number = 0; + + /* address of boot parameters */ + gd->bd->bi_boot_params = LINUX_BOOT_PARAM_ADDR; + + /* + * Power on required peripherals + * ARM does not have access by default to PSC0 and PSC1 + * assuming here that the DSP bootloader has set the IOPU + * such that PSC access is available to ARM + */ + if (da8xx_configure_lpsc_items(lpsc, ARRAY_SIZE(lpsc))) + return 1; + + /* setup the SUSPSRC for ARM to control emulation suspend */ + writel(readl(&davinci_syscfg_regs->suspsrc) & + ~(DAVINCI_SYSCFG_SUSPSRC_EMAC | DAVINCI_SYSCFG_SUSPSRC_I2C | + DAVINCI_SYSCFG_SUSPSRC_SPI0 | DAVINCI_SYSCFG_SUSPSRC_TIMER0 | + DAVINCI_SYSCFG_SUSPSRC_UART2), + &davinci_syscfg_regs->suspsrc); + +#if 1 + /* configure pinmux settings */ + if (davinci_configure_pin_mux_items(pinmuxes, ARRAY_SIZE(pinmuxes))) + return 1; +#endif + /* + * If we boot over UART, Terminal doesn't display characters + * Reset the values set by Boot ROM + */ +#if 1 + { + int j; + for (j = 0; j < 15; j++) + REG(DAVINCI_UART2_BASE + (j*4)) = 0; + } + REG(DAVINCI_UART2_BASE + 0x30) = 1 | (1 << 13) | (1 << 14); +#endif + /* enable the console UART */ + writel((DAVINCI_UART_PWREMU_MGMT_FREE | DAVINCI_UART_PWREMU_MGMT_URRST | + DAVINCI_UART_PWREMU_MGMT_UTRST), + &davinci_uart2_ctrl_regs->pwremu_mgmt); + + return 0; +} + +int board_init() +{ + return 0; +} + + +#if defined(CONFIG_DRIVER_TI_EMAC) + +#define PHY_SW_I2C_ADDR 0x57 /* Address of PHY on i2c bus */ + +/* + * Initializes on-board ethernet controllers. + */ +int board_eth_init(bd_t *bis) +{ + u_int8_t mac_addr[6]; + struct eth_device *dev; + + /* Read Ethernet MAC address from EEPROM */ + if (dvevm_read_mac_address(mac_addr)) + /* set address env if not already set */ + davinci_sync_env_enetaddr(mac_addr); + + /* read the address back from env */ + if (!eth_getenv_enetaddr("ethaddr", mac_addr)) + return -1; + + /* finally, initialise the driver */ + if (!davinci_emac_initialize()) { + printf("Error: Ethernet init failed!\n"); + return -1; + } + + dev = eth_get_dev(); + + /* provide the resulting addr to the driver */ + memcpy(dev->enetaddr, mac_addr, 6); + dev->write_hwaddr(dev); + + return 0; +} +#endif /* CONFIG_DRIVER_TI_EMAC */ + diff --git a/boards.cfg b/boards.cfg index a723f67..7acbfd1 100644 --- a/boards.cfg +++ b/boards.cfg @@ -302,6 +302,7 @@ ip04 blackfin blackfin pr1 blackfin blackfin tcm-bf518 blackfin blackfin tcm-bf537 blackfin blackfin +c6745-som-inmys c6x c674x c6745-som inmys davinci c6745-som-inmys M52277EVB m68k mcf5227x m52277evb freescale - M52277EVB:SYS_SPANSION_BOOT,SYS_TEXT_BASE=0x00000000 M52277EVB_stmicro m68k mcf5227x m52277evb freescale - M52277EVB:CF_SBF,SYS_STMICRO_BOOT,SYS_TEXT_BASE=0x43E00000 M5235EVB m68k mcf523x m5235evb freescale - M5235EVB:SYS_TEXT_BASE=0xFFE00000 diff --git a/include/configs/c6745-som-inmys.h b/include/configs/c6745-som-inmys.h new file mode 100644 index 0000000..7c8d567 --- /dev/null +++ b/include/configs/c6745-som-inmys.h @@ -0,0 +1,294 @@ +#ifndef __CONFIG_H +#define __CONFIG_H + +/* Based on da830evm.h +*/ +#define TMPVAL 0 + +/* + * Board + */ +#define CONFIG_USE_NAND +#define CONFIG_DRIVER_TI_EMAC +#define CONFIG_CMD_GPIO +#define CONFIG_DA8XX_GPIO +/*#define CONFIG_DISPLAY_CPUINFO*/ +#define CONFIG_SKIP_LOWLEVEL_INIT + +#if 0 +#define CONFIG_USE_SPIFLASH +#endif + +/* + * SoC Configuration + */ +#define CONFIG_MACH_INMYS_C6745_SOM +#define CONFIG_C6X /* */ +#define CONFIG_SOC_DA8XX /* TI DA8xx SoC */ +#define CONFIG_SYS_CLK_FREQ clk_get(DAVINCI_ARM_CLKID) +#define CONFIG_SYS_OSCIN_FREQ 24000000 +#define CONFIG_SYS_TIMERBASE DAVINCI_TIMER0_BASE +#define CONFIG_SYS_HZ_CLOCK clk_get(DAVINCI_AUXCLK_CLKID) +#define CONFIG_SYS_HZ 1000 +#define CONFIG_SKIP_LOWLEVEL_INIT +#define CONFIG_SYS_TEXT_BASE 0xc1f80000 +#define CONFIG_BOARD_EARLY_INIT_F + + +/* + * Memory Info + */ +#define CONFIG_SYS_MALLOC_LEN (0x10000 + 1*1024*1024) /* malloc() len */ +#define PHYS_SDRAM_1 0xc0000000 /* SDRAM Start */ +#define CONFIG_SYS_MEMTEST_START (PHYS_SDRAM_1 + 0x2000000) +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + (32 << 20)) +#define CONFIG_SYS_SDRAM_SIZE (32*1024*1024) +#define CONFIG_NR_DRAM_BANKS 1 /* we have 1 bank of DRAM */ +#define CONFIG_STACKSIZE (256*1024) /* regular stack */ + +/* + * Memory organisation: + * + * RAM start --------------------------- + * | ... | + * --------------------------- + * | Stack | + * --------------------------- + * | Global data | + * --------------------------- + * | Environment | + * --------------------------- + * | Monitor | + * RAM end --------------------------- + */ +/* We're running in RAM */ +#define CONFIG_MONITOR_IS_IN_RAM +#define CONFIG_SYS_MONITOR_LEN 0x80000 /* Reserve 512k */ +#define CONFIG_SYS_MONITOR_BASE (CONFIG_SYS_SDRAM_BASE + \ + CONFIG_SYS_SDRAM_SIZE - \ + CONFIG_SYS_MONITOR_LEN) + +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_MONITOR_BASE - \ + GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_ADDR CONFIG_SYS_GBL_DATA_OFFSET +#define CONFIG_SYS_INIT_SP_ADDR CONFIG_SYS_GBL_DATA_OFFSET +#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET +#define CONFIG_SYS_MALLOC_BASE (CONFIG_SYS_INIT_SP_OFFSET \ + - CONFIG_STACKSIZE \ + - CONFIG_SYS_MALLOC_LEN) + +/* + * Serial Driver info + */ +#define CONFIG_SYS_NS16550 +#define CONFIG_SYS_NS16550_SERIAL +#define CONFIG_SYS_NS16550_REG_SIZE -4 /* NS16550 register size */ +#define CONFIG_SYS_NS16550_COM1 DAVINCI_UART2_BASE /* Base address of UART2 */ +#define CONFIG_SYS_NS16550_CLK clk_get(DAVINCI_UART2_CLKID) +#define CONFIG_CONS_INDEX 1 /* use UART0 for console */ +#define CONFIG_BAUDRATE 115200 /* Default baud rate */ +#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } + +#if 1 +/* + * I2C Configuration + */ +#define CONFIG_HARD_I2C +#define CONFIG_DRIVER_DAVINCI_I2C +#define CONFIG_SYS_I2C_SPEED 25000 /* 100Kbps won't work, H/W bug */ +#define CONFIG_SYS_I2C_SLAVE 10 /* Bogus, master-only in U-Boot */ + + +#define CONFIG_CMD_I2C + +#define CONFIG_CMD_DATE +#define CONFIG_RTC_PCF8563 +#define CONFIG_SYS_I2C_RTC_ADDR 0x51 + +#define CONFIG_CMD_EEPROM +/* EEPROM configuration */ +#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 +#define CONFIG_SYS_EEPROM_SIZE 256 +#define CONFIG_SYS_I2C_EEPROM_ADDR 0x57 + +#endif + +/* + * Network & Ethernet Configuration + */ +#ifdef CONFIG_DRIVER_TI_EMAC +#define CONFIG_EMAC_MDIO_PHY_NUM 1 +#define CONFIG_MII +#define CONFIG_BOOTP_DEFAULT +#define CONFIG_BOOTP_DNS +#define CONFIG_BOOTP_DNS2 +#define CONFIG_BOOTP_SEND_HOSTNAME +#define CONFIG_NET_RETRY_COUNT 10 +#endif + + +/* + * Flash & Environment + */ +#undef CONFIG_ENV_IS_IN_FLASH +#define CONFIG_NAND_DAVINCI +#define CONFIG_SYS_NO_FLASH +#define CONFIG_ENV_IS_IN_NAND /* U-Boot env in NAND Flash */ +#define CONFIG_ENV_OFFSET 0 +#define CONFIG_ENV_SIZE (128*1024) +#define CONFIG_SYS_NAND_4BIT_HW_ECC_OOBFIRST +#define CONFIG_SYS_NAND_CS 3 +#define CONFIG_SYS_NAND_BASE DAVINCI_ASYNC_EMIF_DATA_CE3_BASE +#define CONFIG_SYS_NAND_PAGE_2K +#define CONFIG_SYS_64BIT_VSPRINTF /* needed for nand_util.c */ +#define CONFIG_SYS_CLE_MASK 0x10 +#define CONFIG_SYS_ALE_MASK 0x8 +#define CONFIG_SYS_MAX_NAND_DEVICE 1 /* Max number of NAND devices */ +#define NAND_MAX_CHIPS 1 + +#if 1 +/* + * USB configuration + */ +#define CONFIG_USB_DA8XX /* Platform hookup to MUSB controller */ +#define CONFIG_MUSB_HCD + +#endif + +/* + * U-Boot general configuration + */ +#undef CONFIG_USE_IRQ /* No IRQ/FIQ in U-Boot */ +#undef CONFIG_MISC_INIT_R +#undef CONFIG_BOOTDELAY +#define CONFIG_BOOTFILE "uImage" /* Boot file name */ +#define CONFIG_SYS_PROMPT "c6745-som > " /* Command Prompt */ +#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Args Buffer Size */ +#define CONFIG_SYS_LOAD_ADDR (PHYS_SDRAM_1 + 0x700000) +#define CONFIG_VERSION_VARIABLE +#define CONFIG_AUTO_COMPLETE /* Won't work with hush so far, may be later */ +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " +#define CONFIG_CMDLINE_EDITING +#define CONFIG_SYS_LONGHELP +#define CONFIG_CRC32_VERIFY +#define CONFIG_MX_CYCLIC + +/* + * Linux Information + */ +#define LINUX_BOOT_PARAM_ADDR (PHYS_SDRAM_1 + 0x100) +#define CONFIG_CMDLINE_TAG +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_BOOTARGS "mem=32M console=ttyS2,115200n8 root=/dev/mtdblock/2 rw noinitrd ip=dhcp" +#define CONFIG_BOOTCOMMAND "" +#define CONFIG_BOOTDELAY 3 + +/* + * U-Boot commands + */ +#include <config_cmd_default.h> +#define CONFIG_CMD_ENV +#define CONFIG_CMD_ASKENV + +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_DIAG +#define CONFIG_CMD_MII +#define CONFIG_CMD_PING + +#define CONFIG_CMD_SAVES +#define CONFIG_CMD_MEMORY +#undef CONFIG_CMD_FPGA +#undef CONFIG_CMD_SETGETDCR + +#ifndef CONFIG_DRIVER_TI_EMAC +#undef CONFIG_CMD_NET +#undef CONFIG_CMD_DHCP +#undef CONFIG_CMD_MII +#undef CONFIG_CMD_PING +#endif + +#ifdef CONFIG_USE_NAND +#undef CONFIG_CMD_FLASH +#undef CONFIG_CMD_IMLS +#define CONFIG_CMD_NAND +#define CONFIG_CMD_MTDPARTS +#define CONFIG_MTD_PARTITIONS +#define CONFIG_MTD_DEVICE +#endif + +#ifdef CONFIG_USE_SPIFLASH +#undef CONFIG_CMD_IMLS +#undef CONFIG_CMD_FLASH +#define CONFIG_CMD_SPI +#define CONFIG_CMD_SF +#define CONFIG_CMD_SAVEENV +#endif + +#if !defined(CONFIG_USE_NAND) && \ + !defined(CONFIG_USE_NOR) && \ + !defined(CONFIG_USE_SPIFLASH) +#define CONFIG_ENV_IS_NOWHERE +#define CONFIG_SYS_NO_FLASH +#define CONFIG_ENV_SIZE (16 << 10) +#undef CONFIG_CMD_IMLS +#undef CONFIG_CMD_FLASH +#undef CONFIG_CMD_ENV +#endif + +#ifdef CONFIG_USB_DA8XX + +#ifdef CONFIG_MUSB_HCD /* include support for usb host */ +#define CONFIG_CMD_USB /* include support for usb cmd */ + +#define CONFIG_USB_STORAGE /* MSC class support */ +#define CONFIG_CMD_STORAGE /* inclue support for usb-storage cmd */ +#define CONFIG_CMD_FAT /* inclue support for FAT/storage */ +#define CONFIG_DOS_PARTITION /* inclue support for FAT/storage */ + +#ifdef CONFIG_USB_KEYBOARD /* HID class support */ +#define CONFIG_SYS_USB_EVENT_POLL +#define CONFIG_PREBOOT "usb start" +#endif /* CONFIG_USB_KEYBOARD */ + +#endif /* CONFIG_MUSB_HCD */ + +#ifdef CONFIG_MUSB_UDC +/* USB device configuration */ +#define CONFIG_USB_DEVICE 1 +#define CONFIG_USB_TTY 1 +#define CONFIG_SYS_CONSOLE_IS_IN_ENV 1 +/* Change these to suit your needs */ +#define CONFIG_USBD_VENDORID 0x0451 +#define CONFIG_USBD_PRODUCTID 0x5678 +#define CONFIG_USBD_MANUFACTURER "InMys" +#define CONFIG_USBD_PRODUCT_NAME "c6745-som" +#endif /* CONFIG_MUSB_UDC */ + +#endif /* CONFIG_USB_DA8XX */ + +#ifdef CONFIG_MTD_PARTITIONS +#define MTDIDS_DEFAULT "nand0=davinci_nand.1" +#define PART_BOOT "512k(bootloader)ro," +#define PART_PARAMS "512k(params)ro," +#define PART_KERNEL "4m(kernel)," +#define PART_REST "-(filesystem)" +#define MTDPARTS_DEFAULT \ + "mtdparts=davinci_nand.1:" PART_BOOT PART_PARAMS PART_KERNEL PART_REST +#endif + +#define CONFIG_MAX_RAM_BANK_SIZE (512 << 20) /* max size from SPRS586*/ + +/* additions for new relocation code, must be added to all boards */ +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 + +#undef CONFIG_CMD_NFS +#undef CONFIG_CMD_BOOTD +#undef CONFIG_RESET_TO_RETRY + +#define CONFIG_STANDALONE_LOAD_ADDR 0xc1f80000 + +#endif /* __CONFIG_H */
[snip]
sacsng MPC8260
- c6745-som c674x
gw8260 MPC8260
Note that the file is sorted by architecture, so you get to add in a new C6000 section.
We should only be here on this board, yes? So just: COBJS-y<tab>:= c6745-som.o
This seems a little complicated, and should just be: COBJS<tab>:= $(sort $(COBJS-y)) SRCS<tab>:= $(COBJS:.o=.c) OBJS<tab>:= $(addprefix $(obj),$(COBJS))
[snip]
- Parts are shamelessly stolen from various TI sources, original copyright
- follows:
- Copyright (C) 2004 Texas Instruments.
Please drop both of the extra-long '-..-' lines.
+#if 1
- /* configure pinmux settings */
- if (davinci_configure_pin_mux_items(pinmuxes, ARRAY_SIZE(pinmuxes)))
return 1;
I'm fond of '#if 1' when debugging code myself but please remove when posting, thanks!
[snip]
Unused.
Please just add a comment saying SPI flash support is still missing instead of this
Just '#define CONFIG_C6X'.
[snip]
There's a default now, don't need this line.
+#if 1
See above :) (And there's a few of these).
Also not needed now.
+int board_init()
(void)
- u_int8_t mac_addr[6];
uchar
- /* Read Ethernet MAC address from EEPROM */
- if (dvevm_read_mac_address(mac_addr))
- /* read the address back from env */
- if (!eth_getenv_enetaddr("ethaddr", mac_addr))
return -1;
i think logic here is incorrect. usually it's: if (!eth_getenv_enetaddr("ethaddr", mac_addr)) /* read mac from hardware */
- dev = eth_get_dev();
- /* provide the resulting addr to the driver */
- memcpy(dev->enetaddr, mac_addr, 6);
- dev->write_hwaddr(dev);
err, this should be in the driver, not the board init
missing intro comment block -mike
Dear Dmitry Bondar,
WARNING: line over 80 characters
Please fix.
Dmitry Bondar
Mike Frysinger
