[U-Boot] [PATCH 1/6] mx6: soc: Staticize set_vddsoc()
set_vddsoc() is not used anywhere else, so make it static.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- arch/arm/cpu/armv7/mx6/soc.c | 2 +- arch/arm/include/asm/arch-mx6/sys_proto.h | 2 -- 2 files changed, 1 insertion(+), 3 deletions(-)
diff --git a/arch/arm/cpu/armv7/mx6/soc.c b/arch/arm/cpu/armv7/mx6/soc.c index a390296..6cbade7 100644 --- a/arch/arm/cpu/armv7/mx6/soc.c +++ b/arch/arm/cpu/armv7/mx6/soc.c @@ -101,7 +101,7 @@ void init_aips(void) * Possible values are from 0.725V to 1.450V in steps of * 0.025V (25mV). */ -void set_vddsoc(u32 mv) +static void set_vddsoc(u32 mv) { struct anatop_regs *anatop = (struct anatop_regs *)ANATOP_BASE_ADDR; u32 val, reg = readl(&anatop->reg_core); diff --git a/arch/arm/include/asm/arch-mx6/sys_proto.h b/arch/arm/include/asm/arch-mx6/sys_proto.h index 8c21364..17125a6 100644 --- a/arch/arm/include/asm/arch-mx6/sys_proto.h +++ b/arch/arm/include/asm/arch-mx6/sys_proto.h @@ -29,8 +29,6 @@ u32 get_cpu_rev(void); const char *get_imx_type(u32 imxtype); unsigned imx_ddr_size(void);
-void set_vddsoc(u32 mv); - /* * Initializes on-chip ethernet controllers. * to override, implement board_eth_init()
Since ROM may modify the LDO ramp up time according to fuse setting, it is safer to reset the ramp up field to its default value of 00:
00: 64 cycles of 24MHz clock; 01: 128 cycles of 24MHz clock; 02: 256 cycles of 24MHz clock; 03: 512 cycles of 24MHz clock;
Signed-off-by: Anson Huang b20788@freescale.com Signed-off-by: Jason Liu r64343@freescale.com Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- arch/arm/cpu/armv7/mx6/soc.c | 16 ++++++++++++++++ 1 file changed, 16 insertions(+)
diff --git a/arch/arm/cpu/armv7/mx6/soc.c b/arch/arm/cpu/armv7/mx6/soc.c index 6cbade7..13b9e36 100644 --- a/arch/arm/cpu/armv7/mx6/soc.c +++ b/arch/arm/cpu/armv7/mx6/soc.c @@ -93,6 +93,20 @@ void init_aips(void) writel(0x00000000, &aips2->opacr4); }
+static void clear_ldo_ramp(void) +{ + struct anatop_regs *anatop = (struct anatop_regs *)ANATOP_BASE_ADDR; + int reg; + + /* ROM may modify LDO ramp up time according to fuse setting, so in + * order to be in the safe side we neeed to reset these settings to + * match the reset value: 0'b00 + */ + reg = readl(&anatop->ana_misc2); + reg &= ~(0x3f << 24); + writel(reg, &anatop->ana_misc2); +} + /* * Set the VDDSOC * @@ -113,6 +127,8 @@ static void set_vddsoc(u32 mv) else val = (mv - 700) / 25;
+ clear_ldo_ramp(); + /* * Mask out the REG_CORE[22:18] bits (REG2_TRIG) * and set them to the calculated value (0.7V + val * 0.25V)
mx6 datasheet specifies that the minimum VDDSOC at 792 MHz is 1.15 V. Add a 25 mV margin and set it to 1.175V.
This also matches the VDDSOC voltages for 792MHz operation that the kernel configures: http://git.freescale.com/git/cgit.cgi/imx/linux-2.6-imx.git/tree/arch/arm/ma...
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- arch/arm/cpu/armv7/mx6/soc.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/cpu/armv7/mx6/soc.c b/arch/arm/cpu/armv7/mx6/soc.c index 13b9e36..0136eb0 100644 --- a/arch/arm/cpu/armv7/mx6/soc.c +++ b/arch/arm/cpu/armv7/mx6/soc.c @@ -151,7 +151,7 @@ int arch_cpu_init(void) { init_aips();
- set_vddsoc(1200); /* Set VDDSOC to 1.2V */ + set_vddsoc(1175); /* Set VDDSOC to 1.175V */
imx_set_wdog_powerdown(false); /* Disable PDE bit of WMCR register */
Introduce set_ldo_voltage() so that all three LDO regulators can be configured.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- arch/arm/cpu/armv7/mx6/soc.c | 33 ++++++++++++++++++++++++++------- 1 file changed, 26 insertions(+), 7 deletions(-)
diff --git a/arch/arm/cpu/armv7/mx6/soc.c b/arch/arm/cpu/armv7/mx6/soc.c index 0136eb0..ee888ce 100644 --- a/arch/arm/cpu/armv7/mx6/soc.c +++ b/arch/arm/cpu/armv7/mx6/soc.c @@ -19,6 +19,12 @@ #include <asm/arch/mxc_hdmi.h> #include <asm/arch/crm_regs.h>
+enum ldo_reg { + LDO_ARM, + LDO_SOC, + LDO_PU, +}; + struct scu_regs { u32 ctrl; u32 config; @@ -115,10 +121,11 @@ static void clear_ldo_ramp(void) * Possible values are from 0.725V to 1.450V in steps of * 0.025V (25mV). */ -static void set_vddsoc(u32 mv) +static int set_ldo_voltage(enum ldo_reg ldo, u32 mv) { struct anatop_regs *anatop = (struct anatop_regs *)ANATOP_BASE_ADDR; u32 val, reg = readl(&anatop->reg_core); + u8 shift;
if (mv < 725) val = 0x00; /* Power gated off */ @@ -129,12 +136,24 @@ static void set_vddsoc(u32 mv)
clear_ldo_ramp();
- /* - * Mask out the REG_CORE[22:18] bits (REG2_TRIG) - * and set them to the calculated value (0.7V + val * 0.25V) - */ - reg = (reg & ~(0x1F << 18)) | (val << 18); + switch (ldo) { + case LDO_SOC: + shift = 18; + break; + case LDO_PU: + shift = 9; + break; + case LDO_ARM: + shift = 0; + break; + default: + return -EINVAL; + } + + reg = (reg & ~(0x1F << shift)) | (val << shift); writel(reg, &anatop->reg_core); + + return 0; }
static void imx_set_wdog_powerdown(bool enable) @@ -151,7 +170,7 @@ int arch_cpu_init(void) { init_aips();
- set_vddsoc(1175); /* Set VDDSOC to 1.175V */ + set_ldo_voltage(LDO_SOC, 1175); /* Set VDDSOC to 1.175V */
When changing LDO voltages we need to wait for the required amount of time for the voltage to settle.
Also, as the timer is still not available when arch_cpu_init() is called, we need to call it later at board_postclk_init() phase.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- arch/arm/cpu/armv7/mx6/soc.c | 22 +++++++++++++++++++--- include/configs/mx6_common.h | 1 + 2 files changed, 20 insertions(+), 3 deletions(-)
diff --git a/arch/arm/cpu/armv7/mx6/soc.c b/arch/arm/cpu/armv7/mx6/soc.c index ee888ce..3aa3bb0 100644 --- a/arch/arm/cpu/armv7/mx6/soc.c +++ b/arch/arm/cpu/armv7/mx6/soc.c @@ -124,7 +124,7 @@ static void clear_ldo_ramp(void) static int set_ldo_voltage(enum ldo_reg ldo, u32 mv) { struct anatop_regs *anatop = (struct anatop_regs *)ANATOP_BASE_ADDR; - u32 val, reg = readl(&anatop->reg_core); + u32 val, step, old, reg = readl(&anatop->reg_core); u8 shift;
if (mv < 725) @@ -150,9 +150,20 @@ static int set_ldo_voltage(enum ldo_reg ldo, u32 mv) return -EINVAL; }
+ old = (reg & (0x1F << shift)) >> shift; + step = abs(val - old); + if (step == 0) + return 0; + reg = (reg & ~(0x1F << shift)) | (val << shift); writel(reg, &anatop->reg_core);
+ /* + * The LDO ramp-up is based on 64 clock cycles of 24 MHz = 2.6 us per + * step + */ + udelay(3 * step); + return 0; }
@@ -170,8 +181,6 @@ int arch_cpu_init(void) { init_aips();
- set_ldo_voltage(LDO_SOC, 1175); /* Set VDDSOC to 1.175V */ - imx_set_wdog_powerdown(false); /* Disable PDE bit of WMCR register */
#ifdef CONFIG_APBH_DMA @@ -182,6 +191,13 @@ int arch_cpu_init(void) return 0; }
+int board_postclk_init(void) +{ + set_ldo_voltage(LDO_SOC, 1175); /* Set VDDSOC to 1.175V */ + + return 0; +} + #ifndef CONFIG_SYS_DCACHE_OFF void enable_caches(void) { diff --git a/include/configs/mx6_common.h b/include/configs/mx6_common.h index 674bcd3..514d634 100644 --- a/include/configs/mx6_common.h +++ b/include/configs/mx6_common.h @@ -20,5 +20,6 @@ #define CONFIG_ARM_ERRATA_742230 #define CONFIG_ARM_ERRATA_743622 #define CONFIG_ARM_ERRATA_751472 +#define CONFIG_BOARD_POSTCLK_INIT
#endif
As U-boot does not use GPU/VPU peripherals, shutdown the VDDPU regulator in order to save power.
Signed-off-by: Anson Huang b20788@freescale.com Signed-off-by: Jason Liu r64343@freescale.com Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- arch/arm/cpu/armv7/mx6/soc.c | 23 +++++++++++++++++++++++ arch/arm/include/asm/arch-mx6/imx-regs.h | 23 +++++++++++++++++++++++ 2 files changed, 46 insertions(+)
diff --git a/arch/arm/cpu/armv7/mx6/soc.c b/arch/arm/cpu/armv7/mx6/soc.c index 9dc30ba..243226e 100644 --- a/arch/arm/cpu/armv7/mx6/soc.c +++ b/arch/arm/cpu/armv7/mx6/soc.c @@ -19,6 +19,8 @@ #include <asm/arch/mxc_hdmi.h> #include <asm/arch/crm_regs.h>
+#define VDDPU_MASK (0x1f << 9) + enum ldo_reg { LDO_ARM, LDO_SOC, @@ -177,11 +179,32 @@ static void imx_set_wdog_powerdown(bool enable) writew(enable, &wdog2->wmcr); }
+static void imx_set_vddpu_power_down(void) +{ + struct anatop_regs *anatop = (struct anatop_regs *)ANATOP_BASE_ADDR; + struct gpc_regs *gpc = (struct gpc_regs *)GPC_BASE_ADDR; + + u32 val; + + /* need to power down xPU in GPC before turning off PU LDO */ + val = readl(&gpc->gpu_ctrl); + writel(val | 0x1, &gpc->gpu_ctrl); + + val = readl(&gpc->ctrl); + writel(val | 0x1, &gpc->ctrl); + while (readl(&gpc->ctrl) & 0x1) + ; + + /* disable VDDPU */ + writel(VDDPU_MASK, &anatop->reg_core_clr); +} + int arch_cpu_init(void) { init_aips();
imx_set_wdog_powerdown(false); /* Disable PDE bit of WMCR register */ + imx_set_vddpu_power_down();
#ifdef CONFIG_APBH_DMA /* Start APBH DMA */ diff --git a/arch/arm/include/asm/arch-mx6/imx-regs.h b/arch/arm/include/asm/arch-mx6/imx-regs.h index 7ef7152..fb0c4c7 100644 --- a/arch/arm/include/asm/arch-mx6/imx-regs.h +++ b/arch/arm/include/asm/arch-mx6/imx-regs.h @@ -659,5 +659,28 @@ struct wdog_regs { u16 wmcr; /* Miscellaneous Control */ };
+struct gpc_regs { + u32 ctrl; /* 0x000 */ + u32 pgr; /* 0x004 */ + u32 imr1; /* 0x008 */ + u32 imr2; /* 0x00c */ + u32 imr3; /* 0x010 */ + u32 imr4; /* 0x014 */ + u32 isr1; /* 0x018 */ + u32 isr2; /* 0x01c */ + u32 isr3; /* 0x020 */ + u32 isr4; /* 0x024 */ + u32 reserved1[0x86]; + u32 gpu_ctrl; /* 0x260 */ + u32 gpu_pupscr; /* 0x264 */ + u32 gpu_pdnscr; /* 0x268 */ + u32 gpu_sr; /* 0x26c */ + u32 reserved2[0xc]; + u32 cpu_ctrl; /* 0x2a0 */ + u32 cpu_pupscr; /* 0x2a4 */ + u32 cpu_pdnscr; /* 0x2a8 */ + u32 cpu_sr; /* 0x2ac */ +}; + #endif /* __ASSEMBLER__*/ #endif /* __ASM_ARCH_MX6_IMX_REGS_H__ */
Hi Fabio,
The PU power-up/power-down sequence has specific steps, includes some clock management. Please refer to the kernel code for the sequence.
Thanks, Ranjani
-----Original Message----- From: Fabio Estevam [mailto:festevam@gmail.com] Sent: Wednesday, December 18, 2013 9:16 PM To: sbabic@denx.de Cc: Huang Yongcai-B20788; Liu Hui-R64343; Vaidyanathan Ranjani-RA5478; eric.nelson@boundarydevices.com; troy.kisky@boundarydevices.com; u-boot@lists.denx.de; Estevam Fabio-R49496 Subject: [PATCH 6/6] mx6: soc: Disable VDDPU regulator
+static void imx_set_vddpu_power_down(void) { + struct anatop_regs *anatop = (struct anatop_regs *)ANATOP_BASE_ADDR; + struct gpc_regs *gpc = (struct gpc_regs *)GPC_BASE_ADDR; + + u32 val; + + /* need to power down xPU in GPC before turning off PU LDO */ + val = readl(&gpc->gpu_ctrl); + writel(val | 0x1, &gpc->gpu_ctrl); + + val = readl(&gpc->ctrl); + writel(val | 0x1, &gpc->ctrl); + while (readl(&gpc->ctrl) & 0x1) + ; + + /* disable VDDPU */ + writel(VDDPU_MASK, &anatop->reg_core_clr); } + int arch_cpu_init(void) { init_aips();
+struct gpc_regs { + u32 ctrl; /* 0x000 */ + u32 pgr; /* 0x004 */ + u32 imr1; /* 0x008 */ + u32 imr2; /* 0x00c */ + u32 imr3; /* 0x010 */ + u32 imr4; /* 0x014 */ + u32 isr1; /* 0x018 */ + u32 isr2; /* 0x01c */ + u32 isr3; /* 0x020 */ + u32 isr4; /* 0x024 */ + u32 reserved1[0x86]; + u32 gpu_ctrl; /* 0x260 */ + u32 gpu_pupscr; /* 0x264 */ + u32 gpu_pdnscr; /* 0x268 */ + u32 gpu_sr; /* 0x26c */ + u32 reserved2[0xc]; + u32 cpu_ctrl; /* 0x2a0 */ + u32 cpu_pupscr; /* 0x2a4 */ + u32 cpu_pdnscr; /* 0x2a8 */ + u32 cpu_sr; /* 0x2ac */ +}; + #endif /* __ASSEMBLER__*/ #endif /* __ASM_ARCH_MX6_IMX_REGS_H__ */ -- 1.8.1.2
On Tue, Dec 24, 2013 at 1:30 PM, Ranjani.Vaidyanathan@freescale.com Ranjani.Vaidyanathan@freescale.com wrote:
Hi Fabio,
Thanks for the review, Ranjani.
Just sent v2 that disables vddpu in the same way as in kernel.
Regards,
Fabio Estevam
Fabio Estevam
