[U-Boot] [PATCH] arm: zimage: add other-bootloader image magic number
For chainboot configurations or test environments, this patch allows booting other-bootloader images by using command bootz.
Signed-off-by: Christoph Fritz chf.fritz@googlemail.com --- arch/arm/lib/zimage.c | 6 ++++-- 1 file changed, 4 insertions(+), 2 deletions(-)
diff --git a/arch/arm/lib/zimage.c b/arch/arm/lib/zimage.c index 09ab331..bc2768b 100644 --- a/arch/arm/lib/zimage.c +++ b/arch/arm/lib/zimage.c @@ -9,6 +9,7 @@ #include <common.h>
#define LINUX_ARM_ZIMAGE_MAGIC 0x016f2818 +#define BAREBOX_IMAGE_MAGIC 0x00786f62
struct arm_z_header { uint32_t code[9]; @@ -21,9 +22,10 @@ int bootz_setup(ulong image, ulong *start, ulong *end) { struct arm_z_header *zi = (struct arm_z_header *)image;
- if (zi->zi_magic != LINUX_ARM_ZIMAGE_MAGIC) { + if (zi->zi_magic != LINUX_ARM_ZIMAGE_MAGIC && + zi->zi_magic != BAREBOX_IMAGE_MAGICE) { #ifndef CONFIG_SPL_FRAMEWORK - puts("Bad Linux ARM zImage magic!\n"); + puts("zimage: Bad magic!\n"); #endif return 1; }
- if (zi->zi_magic != LINUX_ARM_ZIMAGE_MAGIC &&
#endif return 1; }
Please re-word the commit to be clear you're adding the barebox magic number, but this is otherwise fine. Thanks!
For chainboot configurations or test environments, this patch allows booting barebox images by using command bootz.
Signed-off-by: Christoph Fritz chf.fritz@googlemail.com --- Changes since v1: - s/other-bootloader/barebox/
Christoph Fritz
