[U-Boot] [PATCH] arm64: fix arm64 Linux boot image header field sizes
The arm64 Linux boot protocol [1] describes the fields in the Image header as being 64-bit little endian values. So fix the endianess conversion to use 64-bit sized operations, for both image_size and text_offset. Also we use a local variable for the image_size to avoid both writing to the header and also accessing it after we actually unmapped it.
Signed-off-by: Andre Przywara andre.przywara@arm.com
[1] https://git.kernel.org/cgit/linux/kernel/git/torvalds/linux.git/tree/Documen... --- cmd/bootm.c | 9 ++++++--- 1 file changed, 6 insertions(+), 3 deletions(-)
diff --git a/cmd/bootm.c b/cmd/bootm.c index 1bca6fa..ee3b460 100644 --- a/cmd/bootm.c +++ b/cmd/bootm.c @@ -655,6 +655,7 @@ static int booti_setup(bootm_headers_t *images) { struct Image_header *ih; uint64_t dst; + uint64_t image_size;
ih = (struct Image_header *)map_sysmem(images->ep, 0);
@@ -665,14 +666,16 @@ static int booti_setup(bootm_headers_t *images) if (ih->image_size == 0) { puts("Image lacks image_size field, assuming 16MiB\n"); - ih->image_size = (16 << 20); + image_size = 16 << 20; + } else { + image_size = le64_to_cpu(ih->image_size); }
/* * If we are not at the correct run-time location, set the new * correct location and then move the image there. */ - dst = gd->bd->bi_dram[0].start + le32_to_cpu(ih->text_offset); + dst = gd->bd->bi_dram[0].start + le64_to_cpu(ih->text_offset);
unmap_sysmem(ih);
@@ -683,7 +686,7 @@ static int booti_setup(bootm_headers_t *images)
src = (void *)images->ep; images->ep = dst; - memmove((void *)dst, src, le32_to_cpu(ih->image_size)); + memmove((void *)dst, src, image_size); }
Andre Przywara
