[U-Boot] [PATCH v1 0/8] avr32: add generic board
This is the first attempt to add generic board support to avr32 architecture. It has at least one relevant part for other manual reloc architectures.
This series is currently runtime tested on grasshhopper and atstk1002.
Andreas Bießmann
Changes in v1: - new since RFC - new since RFC - add timer_init in board_r - remove extern declaration of mmu_init_r() - new since RFC
Andreas Bießmann (8): avr32: use dlmalloc for DMA buffers avr32: rename cpu_init() -> arch_cpu_init() avr32: factor out cpu_mmc_init() avr32: rename mmu.h definitions common/board_r: manual relocation for cmd table avr32: add generic board support grasshopper: enable generic board atstk1002: enable generic board
arch/avr32/config.mk | 3 ++ arch/avr32/cpu/Makefile | 1 + arch/avr32/cpu/at32ap700x/mmu.c | 8 ++-- arch/avr32/cpu/cpu.c | 2 +- arch/avr32/cpu/mmc.c | 16 +++++++ arch/avr32/cpu/u-boot.lds | 2 + arch/avr32/include/asm/arch-at32ap700x/mmu.h | 6 +-- arch/avr32/include/asm/config.h | 1 + arch/avr32/include/asm/dma-mapping.h | 7 ++- arch/avr32/include/asm/u-boot.h | 9 ++++ arch/avr32/lib/Makefile | 2 + arch/avr32/lib/board.c | 61 +------------------------- arch/avr32/lib/interrupts.c | 5 +++ board/atmel/atngw100/atngw100.c | 12 ++--- board/atmel/atngw100mkii/atngw100mkii.c | 18 ++++---- board/atmel/atstk1000/atstk1000.c | 12 ++--- board/earthlcd/favr-32-ezkit/favr-32-ezkit.c | 12 ++--- board/in-circuit/grasshopper/grasshopper.c | 12 ++--- board/mimc/mimc200/mimc200.c | 18 ++++---- board/miromico/hammerhead/hammerhead.c | 12 ++--- common/board_f.c | 13 ++++-- common/board_r.c | 38 ++++++++++++++-- include/asm-generic/u-boot.h | 4 ++ include/configs/atngw100.h | 1 - include/configs/atngw100mkii.h | 1 - include/configs/atstk1002.h | 5 ++- include/configs/atstk1006.h | 1 - include/configs/favr-32-ezkit.h | 1 - include/configs/grasshopper.h | 5 ++- include/configs/hammerhead.h | 1 - include/configs/mimc200.h | 1 - 31 files changed, 159 insertions(+), 131 deletions(-) create mode 100644 arch/avr32/cpu/mmc.c
Signed-off-by: Andreas Bießmann andreas.devel@googlemail.com ---
Changes in v1: None
arch/avr32/include/asm/dma-mapping.h | 7 ++++- arch/avr32/lib/board.c | 51 ---------------------------------- include/configs/atngw100.h | 1 - include/configs/atngw100mkii.h | 1 - include/configs/atstk1002.h | 1 - include/configs/atstk1006.h | 1 - include/configs/favr-32-ezkit.h | 1 - include/configs/grasshopper.h | 1 - include/configs/hammerhead.h | 1 - include/configs/mimc200.h | 1 - 10 files changed, 6 insertions(+), 60 deletions(-)
diff --git a/arch/avr32/include/asm/dma-mapping.h b/arch/avr32/include/asm/dma-mapping.h index dbdd2fe..1cde827 100644 --- a/arch/avr32/include/asm/dma-mapping.h +++ b/arch/avr32/include/asm/dma-mapping.h @@ -14,7 +14,12 @@ enum dma_data_direction { DMA_TO_DEVICE = 1, DMA_FROM_DEVICE = 2, }; -extern void *dma_alloc_coherent(size_t len, unsigned long *handle); + +static inline void *dma_alloc_coherent(size_t len, unsigned long *handle) +{ + *handle = (unsigned long)memalign(ARCH_DMA_MINALIGN, len); + return (void *)*handle; +}
static inline unsigned long dma_map_single(volatile void *vaddr, size_t len, enum dma_data_direction dir) diff --git a/arch/avr32/lib/board.c b/arch/avr32/lib/board.c index bf0997f..7d13ac5 100644 --- a/arch/avr32/lib/board.c +++ b/arch/avr32/lib/board.c @@ -45,50 +45,6 @@ int cpu_mmc_init(bd_t *bd) return atmel_mci_init((void *)ATMEL_BASE_MMCI); }
-#ifdef CONFIG_SYS_DMA_ALLOC_LEN -#include <asm/arch/cacheflush.h> -#include <asm/io.h> - -static unsigned long dma_alloc_start; -static unsigned long dma_alloc_end; -static unsigned long dma_alloc_brk; - -static void dma_alloc_init(void) -{ - unsigned long monitor_addr; - - monitor_addr = CONFIG_SYS_MONITOR_BASE + gd->reloc_off; - dma_alloc_end = monitor_addr - CONFIG_SYS_MALLOC_LEN; - dma_alloc_start = dma_alloc_end - CONFIG_SYS_DMA_ALLOC_LEN; - dma_alloc_brk = dma_alloc_start; - - printf("DMA: Using memory from 0x%08lx to 0x%08lx\n", - dma_alloc_start, dma_alloc_end); - - invalidate_dcache_range((unsigned long)cached(dma_alloc_start), - dma_alloc_end); -} - -void *dma_alloc_coherent(size_t len, unsigned long *handle) -{ - unsigned long paddr = dma_alloc_brk; - - if (dma_alloc_brk + len > dma_alloc_end) - return NULL; - - dma_alloc_brk = ((paddr + len + CONFIG_SYS_DCACHE_LINESZ - 1) - & ~(CONFIG_SYS_DCACHE_LINESZ - 1)); - - *handle = paddr; - return uncached(paddr); -} -#else -static inline void dma_alloc_init(void) -{ - -} -#endif - static int init_baudrate(void) { gd->baudrate = getenv_ulong("baudrate", 10, CONFIG_BAUDRATE); @@ -180,12 +136,6 @@ void board_init_f(ulong board_type) /* Reserve memory for malloc() */ addr -= CONFIG_SYS_MALLOC_LEN;
-#ifdef CONFIG_SYS_DMA_ALLOC_LEN - /* Reserve DMA memory (must be cache aligned) */ - addr &= ~(CONFIG_SYS_DCACHE_LINESZ - 1); - addr -= CONFIG_SYS_DMA_ALLOC_LEN; -#endif - #ifdef CONFIG_LCD #ifdef CONFIG_FB_ADDR printf("LCD: Frame buffer allocated at preset 0x%08x\n", @@ -264,7 +214,6 @@ void board_init_r(gd_t *new_gd, ulong dest_addr) /* The malloc area is right below the monitor image in RAM */ mem_malloc_init(CONFIG_SYS_MONITOR_BASE + gd->reloc_off - CONFIG_SYS_MALLOC_LEN, CONFIG_SYS_MALLOC_LEN); - dma_alloc_init();
enable_interrupts();
diff --git a/include/configs/atngw100.h b/include/configs/atngw100.h index 9c81e31..540e86a 100644 --- a/include/configs/atngw100.h +++ b/include/configs/atngw100.h @@ -143,7 +143,6 @@ #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_INTRAM_BASE + CONFIG_SYS_INTRAM_SIZE)
#define CONFIG_SYS_MALLOC_LEN (256*1024) -#define CONFIG_SYS_DMA_ALLOC_LEN (16384)
/* Allow 4MB for the kernel run-time image */ #define CONFIG_SYS_LOAD_ADDR (EBI_SDRAM_BASE + 0x00400000) diff --git a/include/configs/atngw100mkii.h b/include/configs/atngw100mkii.h index 7b4f9cf..35eae76 100644 --- a/include/configs/atngw100mkii.h +++ b/include/configs/atngw100mkii.h @@ -164,7 +164,6 @@ #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_INTRAM_BASE + CONFIG_SYS_INTRAM_SIZE)
/* Allow 4MB for the kernel run-time image */ #define CONFIG_SYS_LOAD_ADDR (EBI_SDRAM_BASE + 0x00400000) diff --git a/include/configs/atstk1002.h b/include/configs/atstk1002.h index 8f3fd0b..9e58238 100644 --- a/include/configs/atstk1002.h +++ b/include/configs/atstk1002.h @@ -158,7 +158,6 @@ #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_INTRAM_BASE + CONFIG_SYS_INTRAM_SIZE)
/* Allow 4MB for the kernel run-time image */ #define CONFIG_SYS_LOAD_ADDR (EBI_SDRAM_BASE + 0x00400000) diff --git a/include/configs/atstk1006.h b/include/configs/atstk1006.h index bbe0aea..25090a6 100644 --- a/include/configs/atstk1006.h +++ b/include/configs/atstk1006.h @@ -159,7 +159,6 @@ #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_INTRAM_BASE + CONFIG_SYS_INTRAM_SIZE)
/* Allow 4MB for the kernel run-time image */ #define CONFIG_SYS_LOAD_ADDR (EBI_SDRAM_BASE + 0x00400000) diff --git a/include/configs/favr-32-ezkit.h b/include/configs/favr-32-ezkit.h index 338d3dc..75bff4c 100644 --- a/include/configs/favr-32-ezkit.h +++ b/include/configs/favr-32-ezkit.h @@ -162,7 +162,6 @@ #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_INTRAM_BASE + CONFIG_SYS_INTRAM_SIZE)
/* Allow 4MB for the kernel run-time image */ #define CONFIG_SYS_LOAD_ADDR (EBI_SDRAM_BASE + 0x00400000) diff --git a/include/configs/grasshopper.h b/include/configs/grasshopper.h index 73534ad..83f0ed2 100644 --- a/include/configs/grasshopper.h +++ b/include/configs/grasshopper.h @@ -151,7 +151,6 @@ CONFIG_SYS_INTRAM_SIZE)
/* Allow 4MB for the kernel run-time image */ #define CONFIG_SYS_LOAD_ADDR (EBI_SDRAM_BASE + 0x00400000) diff --git a/include/configs/hammerhead.h b/include/configs/hammerhead.h index 4f0603a..0bc42f1 100644 --- a/include/configs/hammerhead.h +++ b/include/configs/hammerhead.h @@ -137,7 +137,6 @@
/* Allow 4MB for the kernel run-time image */ #define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + 0x00400000) diff --git a/include/configs/mimc200.h b/include/configs/mimc200.h index fc7ecfa..2fd3add 100644 --- a/include/configs/mimc200.h +++ b/include/configs/mimc200.h @@ -157,7 +157,6 @@ #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_INTRAM_BASE + CONFIG_SYS_INTRAM_SIZE)
#define CONFIG_SYS_MALLOC_LEN (1024*1024) -#define CONFIG_SYS_DMA_ALLOC_LEN (16384)
Changes in v1: None
arch/avr32/cpu/cpu.c | 2 +- arch/avr32/include/asm/u-boot.h | 2 ++ arch/avr32/lib/board.c | 2 +- 3 files changed, 4 insertions(+), 2 deletions(-)
diff --git a/arch/avr32/cpu/cpu.c b/arch/avr32/cpu/cpu.c index cef630e..cd226a6 100644 --- a/arch/avr32/cpu/cpu.c +++ b/arch/avr32/cpu/cpu.c @@ -27,7 +27,7 @@
DECLARE_GLOBAL_DATA_PTR;
-int cpu_init(void) +int arch_cpu_init(void) { extern void _evba(void);
diff --git a/arch/avr32/include/asm/u-boot.h b/arch/avr32/include/asm/u-boot.h index 6aef808..2387f8a 100644 --- a/arch/avr32/include/asm/u-boot.h +++ b/arch/avr32/include/asm/u-boot.h @@ -25,4 +25,6 @@ typedef struct bd_info { /* For image.h:image_check_target_arch() */ #define IH_ARCH_DEFAULT IH_ARCH_AVR32
+int arch_cpu_init(void); + #endif /* __ASM_U_BOOT_H__ */ diff --git a/arch/avr32/lib/board.c b/arch/avr32/lib/board.c index 7d13ac5..95f9526 100644 --- a/arch/avr32/lib/board.c +++ b/arch/avr32/lib/board.c @@ -98,7 +98,7 @@ void board_init_f(ulong board_type)
/* Perform initialization sequence */ board_early_init_f(); - cpu_init(); + arch_cpu_init(); board_postclk_init(); env_init(); init_baudrate();
cpu_mmc_init() is required by the init sequence to have a working MMC interface on avr32. This will not be included in the binary if we omit the avr32 board.c when building the generic board.
arch/avr32/cpu/Makefile | 1 + arch/avr32/cpu/mmc.c | 16 ++++++++++++++++ arch/avr32/lib/board.c | 8 -------- 3 files changed, 17 insertions(+), 8 deletions(-) create mode 100644 arch/avr32/cpu/mmc.c
diff --git a/arch/avr32/cpu/Makefile b/arch/avr32/cpu/Makefile index 00cede3..e111db3 100644 --- a/arch/avr32/cpu/Makefile +++ b/arch/avr32/cpu/Makefile @@ -16,5 +16,6 @@ obj-y += cache.o obj-y += interrupts.o obj-$(CONFIG_PORTMUX_PIO) += portmux-pio.o obj-$(CONFIG_PORTMUX_GPIO) += portmux-gpio.o +obj-y += mmc.o
obj-$(if $(filter at32ap700x,$(SOC)),y) += at32ap700x/ diff --git a/arch/avr32/cpu/mmc.c b/arch/avr32/cpu/mmc.c new file mode 100644 index 0000000..b7213e4 --- /dev/null +++ b/arch/avr32/cpu/mmc.c @@ -0,0 +1,16 @@ +/* + * Copyright (C) 2004-2006 Atmel Corporation + * Copyright (C) 2015 Andreas Bießmann andreas.devel@googlmail.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ +#include <common.h> +#include <atmel_mci.h> +#include <asm/arch/hardware.h> + +/* provide cpu_mmc_init, to overwrite provide board_mmc_init */ +int cpu_mmc_init(bd_t *bd) +{ + /* This calls the atmel_mci_init in gen_atmel_mci.c */ + return atmel_mci_init((void *)ATMEL_BASE_MMCI); +} diff --git a/arch/avr32/lib/board.c b/arch/avr32/lib/board.c index 95f9526..e86530f 100644 --- a/arch/avr32/lib/board.c +++ b/arch/avr32/lib/board.c @@ -9,7 +9,6 @@ #include <stdio_dev.h> #include <version.h> #include <net.h> -#include <atmel_mci.h>
#ifdef CONFIG_BITBANGMII #include <miiphy.h> @@ -38,13 +37,6 @@ static int __do_nothing(void) int board_postclk_init(void) __attribute__((weak, alias("__do_nothing"))); int board_early_init_r(void) __attribute__((weak, alias("__do_nothing")));
-/* provide cpu_mmc_init, to overwrite provide board_mmc_init */ -int cpu_mmc_init(bd_t *bd) -{ - /* This calls the atmel_mci_init in gen_atmel_mci.c */ - return atmel_mci_init((void *)ATMEL_BASE_MMCI); -} - static int init_baudrate(void) { gd->baudrate = getenv_ulong("baudrate", 10, CONFIG_BAUDRATE);
Prefix mmu.h PAGE_xxx definitions with MMU_ in order to prevent a naming conflict with other definitions.
arch/avr32/cpu/at32ap700x/mmu.c | 8 ++++---- arch/avr32/include/asm/arch-at32ap700x/mmu.h | 6 +++--- board/atmel/atngw100/atngw100.c | 12 ++++++------ board/atmel/atngw100mkii/atngw100mkii.c | 18 +++++++++--------- board/atmel/atstk1000/atstk1000.c | 12 ++++++------ board/earthlcd/favr-32-ezkit/favr-32-ezkit.c | 12 ++++++------ board/in-circuit/grasshopper/grasshopper.c | 12 ++++++------ board/mimc/mimc200/mimc200.c | 18 +++++++++--------- board/miromico/hammerhead/hammerhead.c | 12 ++++++------ 9 files changed, 55 insertions(+), 55 deletions(-)
diff --git a/arch/avr32/cpu/at32ap700x/mmu.c b/arch/avr32/cpu/at32ap700x/mmu.c index 0e28b21..f5e62f2 100644 --- a/arch/avr32/cpu/at32ap700x/mmu.c +++ b/arch/avr32/cpu/at32ap700x/mmu.c @@ -7,7 +7,7 @@ void mmu_init_r(unsigned long dest_addr) uintptr_t vmr_table_addr;
/* Round monitor address down to the nearest page boundary */ - dest_addr &= PAGE_ADDR_MASK; + dest_addr &= MMU_PAGE_ADDR_MASK;
/* Initialize TLB entry 0 to cover the monitor, and lock it */ sysreg_write(TLBEHI, dest_addr | SYSREG_BIT(TLBEHI_V)); @@ -36,7 +36,7 @@ int mmu_handle_tlb_miss(void) unsigned int fault_pgno; int first, last;
- fault_pgno = sysreg_read(TLBEAR) >> PAGE_SHIFT; + fault_pgno = sysreg_read(TLBEAR) >> MMU_PAGE_SHIFT; vmr_table = (const struct mmu_vm_range *)sysreg_read(PTBR);
/* Do a binary search through the VM ranges */ @@ -60,8 +60,8 @@ int mmu_handle_tlb_miss(void) /* Got it; let's slam it into the TLB */ uint32_t tlbelo;
- tlbelo = vmr->phys & ~PAGE_ADDR_MASK; - tlbelo |= fault_pgno << PAGE_SHIFT; + tlbelo = vmr->phys & ~MMU_PAGE_ADDR_MASK; + tlbelo |= fault_pgno << MMU_PAGE_SHIFT; sysreg_write(TLBELO, tlbelo); __builtin_tlbw();
diff --git a/arch/avr32/include/asm/arch-at32ap700x/mmu.h b/arch/avr32/include/asm/arch-at32ap700x/mmu.h index fcd9a05..4736312 100644 --- a/arch/avr32/include/asm/arch-at32ap700x/mmu.h +++ b/arch/avr32/include/asm/arch-at32ap700x/mmu.h @@ -13,9 +13,9 @@
#include <asm/sysreg.h>
-#define PAGE_SHIFT 20 -#define PAGE_SIZE (1UL << PAGE_SHIFT) -#define PAGE_ADDR_MASK (~(PAGE_SIZE - 1)) +#define MMU_PAGE_SHIFT 20 +#define MMU_PAGE_SIZE (1UL << MMU_PAGE_SHIFT) +#define MMU_PAGE_ADDR_MASK (~(MMU_PAGE_SIZE - 1))
#define MMU_VMR_CACHE_NONE \ (SYSREG_BF(AP, 3) | SYSREG_BF(SZ, 3) | SYSREG_BIT(TLBELO_D)) diff --git a/board/atmel/atngw100/atngw100.c b/board/atmel/atngw100/atngw100.c index 03d767a..ed09c8c 100644 --- a/board/atmel/atngw100/atngw100.c +++ b/board/atmel/atngw100/atngw100.c @@ -18,14 +18,14 @@ DECLARE_GLOBAL_DATA_PTR;
struct mmu_vm_range mmu_vmr_table[CONFIG_SYS_NR_VM_REGIONS] = { { - .virt_pgno = CONFIG_SYS_FLASH_BASE >> PAGE_SHIFT, - .nr_pages = CONFIG_SYS_FLASH_SIZE >> PAGE_SHIFT, - .phys = (CONFIG_SYS_FLASH_BASE >> PAGE_SHIFT) + .virt_pgno = CONFIG_SYS_FLASH_BASE >> MMU_PAGE_SHIFT, + .nr_pages = CONFIG_SYS_FLASH_SIZE >> MMU_PAGE_SHIFT, + .phys = (CONFIG_SYS_FLASH_BASE >> MMU_PAGE_SHIFT) | MMU_VMR_CACHE_NONE, }, { - .virt_pgno = CONFIG_SYS_SDRAM_BASE >> PAGE_SHIFT, - .nr_pages = EBI_SDRAM_SIZE >> PAGE_SHIFT, - .phys = (CONFIG_SYS_SDRAM_BASE >> PAGE_SHIFT) + .virt_pgno = CONFIG_SYS_SDRAM_BASE >> MMU_PAGE_SHIFT, + .nr_pages = EBI_SDRAM_SIZE >> MMU_PAGE_SHIFT, + .phys = (CONFIG_SYS_SDRAM_BASE >> MMU_PAGE_SHIFT) | MMU_VMR_CACHE_WRBACK, }, }; diff --git a/board/atmel/atngw100mkii/atngw100mkii.c b/board/atmel/atngw100mkii/atngw100mkii.c index 72d19e4..912ea10 100644 --- a/board/atmel/atngw100mkii/atngw100mkii.c +++ b/board/atmel/atngw100mkii/atngw100mkii.c @@ -23,21 +23,21 @@ DECLARE_GLOBAL_DATA_PTR; struct mmu_vm_range mmu_vmr_table[CONFIG_SYS_NR_VM_REGIONS] = { { /* Atmel AT49BV640D 8 MiB x16 NOR flash on NCS0 */ - .virt_pgno = CONFIG_SYS_FLASH_BASE >> PAGE_SHIFT, - .nr_pages = CONFIG_SYS_FLASH_SIZE >> PAGE_SHIFT, - .phys = (CONFIG_SYS_FLASH_BASE >> PAGE_SHIFT) + .virt_pgno = CONFIG_SYS_FLASH_BASE >> MMU_PAGE_SHIFT, + .nr_pages = CONFIG_SYS_FLASH_SIZE >> MMU_PAGE_SHIFT, + .phys = (CONFIG_SYS_FLASH_BASE >> MMU_PAGE_SHIFT) | MMU_VMR_CACHE_NONE, }, { /* Micron MT29F2G16AAD 256 MiB x16 NAND flash on NCS3 */ - .virt_pgno = EBI_SRAM_CS3_BASE >> PAGE_SHIFT, - .nr_pages = EBI_SRAM_CS3_SIZE >> PAGE_SHIFT, - .phys = (EBI_SRAM_CS3_BASE >> PAGE_SHIFT) + .virt_pgno = EBI_SRAM_CS3_BASE >> MMU_PAGE_SHIFT, + .nr_pages = EBI_SRAM_CS3_SIZE >> MMU_PAGE_SHIFT, + .phys = (EBI_SRAM_CS3_BASE >> MMU_PAGE_SHIFT) | MMU_VMR_CACHE_NONE, }, { /* 2x16-bit ISSI IS42S16320B 64 MiB SDRAM (128 MiB total) */ - .virt_pgno = CONFIG_SYS_SDRAM_BASE >> PAGE_SHIFT, - .nr_pages = EBI_SDRAM_SIZE >> PAGE_SHIFT, - .phys = (CONFIG_SYS_SDRAM_BASE >> PAGE_SHIFT) + .virt_pgno = CONFIG_SYS_SDRAM_BASE >> MMU_PAGE_SHIFT, + .nr_pages = EBI_SDRAM_SIZE >> MMU_PAGE_SHIFT, + .phys = (CONFIG_SYS_SDRAM_BASE >> MMU_PAGE_SHIFT) | MMU_VMR_CACHE_WRBACK, }, }; diff --git a/board/atmel/atstk1000/atstk1000.c b/board/atmel/atstk1000/atstk1000.c index 4b6b90f..f354694 100644 --- a/board/atmel/atstk1000/atstk1000.c +++ b/board/atmel/atstk1000/atstk1000.c @@ -17,14 +17,14 @@ DECLARE_GLOBAL_DATA_PTR;
struct mmu_vm_range mmu_vmr_table[CONFIG_SYS_NR_VM_REGIONS] = { { - .virt_pgno = CONFIG_SYS_FLASH_BASE >> PAGE_SHIFT, - .nr_pages = CONFIG_SYS_FLASH_SIZE >> PAGE_SHIFT, - .phys = (CONFIG_SYS_FLASH_BASE >> PAGE_SHIFT) + .virt_pgno = CONFIG_SYS_FLASH_BASE >> MMU_PAGE_SHIFT, + .nr_pages = CONFIG_SYS_FLASH_SIZE >> MMU_PAGE_SHIFT, + .phys = (CONFIG_SYS_FLASH_BASE >> MMU_PAGE_SHIFT) | MMU_VMR_CACHE_NONE, }, { - .virt_pgno = CONFIG_SYS_SDRAM_BASE >> PAGE_SHIFT, - .nr_pages = EBI_SDRAM_SIZE >> PAGE_SHIFT, - .phys = (CONFIG_SYS_SDRAM_BASE >> PAGE_SHIFT) + .virt_pgno = CONFIG_SYS_SDRAM_BASE >> MMU_PAGE_SHIFT, + .nr_pages = EBI_SDRAM_SIZE >> MMU_PAGE_SHIFT, + .phys = (CONFIG_SYS_SDRAM_BASE >> MMU_PAGE_SHIFT) | MMU_VMR_CACHE_WRBACK, }, }; diff --git a/board/earthlcd/favr-32-ezkit/favr-32-ezkit.c b/board/earthlcd/favr-32-ezkit/favr-32-ezkit.c index a74547b..f9fde79 100644 --- a/board/earthlcd/favr-32-ezkit/favr-32-ezkit.c +++ b/board/earthlcd/favr-32-ezkit/favr-32-ezkit.c @@ -17,14 +17,14 @@ DECLARE_GLOBAL_DATA_PTR;
struct mmu_vm_range mmu_vmr_table[CONFIG_SYS_NR_VM_REGIONS] = { { - .virt_pgno = CONFIG_SYS_FLASH_BASE >> PAGE_SHIFT, - .nr_pages = CONFIG_SYS_FLASH_SIZE >> PAGE_SHIFT, - .phys = (CONFIG_SYS_FLASH_BASE >> PAGE_SHIFT) + .virt_pgno = CONFIG_SYS_FLASH_BASE >> MMU_PAGE_SHIFT, + .nr_pages = CONFIG_SYS_FLASH_SIZE >> MMU_PAGE_SHIFT, + .phys = (CONFIG_SYS_FLASH_BASE >> MMU_PAGE_SHIFT) | MMU_VMR_CACHE_NONE, }, { - .virt_pgno = CONFIG_SYS_SDRAM_BASE >> PAGE_SHIFT, - .nr_pages = EBI_SDRAM_SIZE >> PAGE_SHIFT, - .phys = (CONFIG_SYS_SDRAM_BASE >> PAGE_SHIFT) + .virt_pgno = CONFIG_SYS_SDRAM_BASE >> MMU_PAGE_SHIFT, + .nr_pages = EBI_SDRAM_SIZE >> MMU_PAGE_SHIFT, + .phys = (CONFIG_SYS_SDRAM_BASE >> MMU_PAGE_SHIFT) | MMU_VMR_CACHE_WRBACK, }, }; diff --git a/board/in-circuit/grasshopper/grasshopper.c b/board/in-circuit/grasshopper/grasshopper.c index 340b713..2ac54db 100644 --- a/board/in-circuit/grasshopper/grasshopper.c +++ b/board/in-circuit/grasshopper/grasshopper.c @@ -18,14 +18,14 @@ DECLARE_GLOBAL_DATA_PTR;
struct mmu_vm_range mmu_vmr_table[CONFIG_SYS_NR_VM_REGIONS] = { { - .virt_pgno = CONFIG_SYS_FLASH_BASE >> PAGE_SHIFT, - .nr_pages = CONFIG_SYS_FLASH_SIZE >> PAGE_SHIFT, - .phys = (CONFIG_SYS_FLASH_BASE >> PAGE_SHIFT) + .virt_pgno = CONFIG_SYS_FLASH_BASE >> MMU_PAGE_SHIFT, + .nr_pages = CONFIG_SYS_FLASH_SIZE >> MMU_PAGE_SHIFT, + .phys = (CONFIG_SYS_FLASH_BASE >> MMU_PAGE_SHIFT) | MMU_VMR_CACHE_NONE, }, { - .virt_pgno = CONFIG_SYS_SDRAM_BASE >> PAGE_SHIFT, - .nr_pages = EBI_SDRAM_SIZE >> PAGE_SHIFT, - .phys = (CONFIG_SYS_SDRAM_BASE >> PAGE_SHIFT) + .virt_pgno = CONFIG_SYS_SDRAM_BASE >> MMU_PAGE_SHIFT, + .nr_pages = EBI_SDRAM_SIZE >> MMU_PAGE_SHIFT, + .phys = (CONFIG_SYS_SDRAM_BASE >> MMU_PAGE_SHIFT) | MMU_VMR_CACHE_WRBACK, }, }; diff --git a/board/mimc/mimc200/mimc200.c b/board/mimc/mimc200/mimc200.c index 2ad53ec..186ac7d 100644 --- a/board/mimc/mimc200/mimc200.c +++ b/board/mimc/mimc200/mimc200.c @@ -20,19 +20,19 @@
struct mmu_vm_range mmu_vmr_table[CONFIG_SYS_NR_VM_REGIONS] = { { - .virt_pgno = CONFIG_SYS_FLASH_BASE >> PAGE_SHIFT, - .nr_pages = CONFIG_SYS_FLASH_SIZE >> PAGE_SHIFT, - .phys = (CONFIG_SYS_FLASH_BASE >> PAGE_SHIFT) + .virt_pgno = CONFIG_SYS_FLASH_BASE >> MMU_PAGE_SHIFT, + .nr_pages = CONFIG_SYS_FLASH_SIZE >> MMU_PAGE_SHIFT, + .phys = (CONFIG_SYS_FLASH_BASE >> MMU_PAGE_SHIFT) | MMU_VMR_CACHE_NONE, }, { - .virt_pgno = EBI_SRAM_CS2_BASE >> PAGE_SHIFT, - .nr_pages = EBI_SRAM_CS2_SIZE >> PAGE_SHIFT, - .phys = (EBI_SRAM_CS2_BASE >> PAGE_SHIFT) + .virt_pgno = EBI_SRAM_CS2_BASE >> MMU_PAGE_SHIFT, + .nr_pages = EBI_SRAM_CS2_SIZE >> MMU_PAGE_SHIFT, + .phys = (EBI_SRAM_CS2_BASE >> MMU_PAGE_SHIFT) | MMU_VMR_CACHE_NONE, }, { - .virt_pgno = CONFIG_SYS_SDRAM_BASE >> PAGE_SHIFT, - .nr_pages = EBI_SDRAM_SIZE >> PAGE_SHIFT, - .phys = (CONFIG_SYS_SDRAM_BASE >> PAGE_SHIFT) + .virt_pgno = CONFIG_SYS_SDRAM_BASE >> MMU_PAGE_SHIFT, + .nr_pages = EBI_SDRAM_SIZE >> MMU_PAGE_SHIFT, + .phys = (CONFIG_SYS_SDRAM_BASE >> MMU_PAGE_SHIFT) | MMU_VMR_CACHE_WRBACK, }, }; diff --git a/board/miromico/hammerhead/hammerhead.c b/board/miromico/hammerhead/hammerhead.c index d82fee7..e9a9e4b 100644 --- a/board/miromico/hammerhead/hammerhead.c +++ b/board/miromico/hammerhead/hammerhead.c @@ -21,14 +21,14 @@ DECLARE_GLOBAL_DATA_PTR;
This is required for architectures still need manual relocation like avr32, m68k microblaze and maybe others.
Signed-off-by: Andreas Bießmann andreas.devel@googlemail.com Reviewed-by: Simon Glass sjg@chromium.org Tested-by: Michal Simek michal.simek@xilinx.com ---
Changes in v1: None
common/board_r.c | 12 ++++++++++++ 1 file changed, 12 insertions(+)
diff --git a/common/board_r.c b/common/board_r.c index a301cc2..e712902 100644 --- a/common/board_r.c +++ b/common/board_r.c @@ -294,6 +294,15 @@ static int initr_announce(void) return 0; }
+#ifdef CONFIG_NEEDS_MANUAL_RELOC +static int initr_manual_reloc_cmdtable(void) +{ + fixup_cmdtable(ll_entry_start(cmd_tbl_t, cmd), + ll_entry_count(cmd_tbl_t, cmd)); + return 0; +} +#endif + #if !defined(CONFIG_SYS_NO_FLASH) static int initr_flash(void) { @@ -718,6 +727,9 @@ init_fnc_t init_sequence_r[] = { initr_serial, initr_announce, INIT_FUNC_WATCHDOG_RESET +#ifdef CONFIG_NEEDS_MANUAL_RELOC + initr_manual_reloc_cmdtable, +#endif #ifdef CONFIG_PPC initr_trap, #endif
Changes in v1: - add timer_init in board_r - remove extern declaration of mmu_init_r()
arch/avr32/config.mk | 3 +++ arch/avr32/cpu/u-boot.lds | 2 ++ arch/avr32/include/asm/config.h | 1 + arch/avr32/include/asm/u-boot.h | 7 +++++++ arch/avr32/lib/Makefile | 2 ++ arch/avr32/lib/interrupts.c | 5 +++++ common/board_f.c | 13 ++++++++++--- common/board_r.c | 26 +++++++++++++++++++++++--- include/asm-generic/u-boot.h | 4 ++++ 9 files changed, 57 insertions(+), 6 deletions(-)
diff --git a/arch/avr32/config.mk b/arch/avr32/config.mk index 469185e..8252f59 100644 --- a/arch/avr32/config.mk +++ b/arch/avr32/config.mk @@ -9,6 +9,9 @@ ifeq ($(CROSS_COMPILE),) CROSS_COMPILE := avr32-linux- endif
+# avr32 has generic board support +__HAVE_ARCH_GENERIC_BOARD := y + CONFIG_STANDALONE_LOAD_ADDR ?= 0x00000000
PLATFORM_RELFLAGS += -ffixed-r5 -fPIC -mno-init-got -mrelax diff --git a/arch/avr32/cpu/u-boot.lds b/arch/avr32/cpu/u-boot.lds index cb29a22..b0180e3 100644 --- a/arch/avr32/cpu/u-boot.lds +++ b/arch/avr32/cpu/u-boot.lds @@ -48,9 +48,11 @@ SECTIONS _edata = .;
.bss (NOLOAD) : { + __bss_start = .; *(.bss) *(.bss.*) } . = ALIGN(8); __bss_end = .; + __init_end = .; } diff --git a/arch/avr32/include/asm/config.h b/arch/avr32/include/asm/config.h index 63056a4..529fe22 100644 --- a/arch/avr32/include/asm/config.h +++ b/arch/avr32/include/asm/config.h @@ -8,5 +8,6 @@ #define _ASM_CONFIG_H_
#define CONFIG_NEEDS_MANUAL_RELOC +#define CONFIG_SYS_GENERIC_GLOBAL_DATA
#endif diff --git a/arch/avr32/include/asm/u-boot.h b/arch/avr32/include/asm/u-boot.h index 2387f8a..0f7dddd 100644 --- a/arch/avr32/include/asm/u-boot.h +++ b/arch/avr32/include/asm/u-boot.h @@ -6,6 +6,11 @@ #ifndef __ASM_U_BOOT_H__ #define __ASM_U_BOOT_H__ 1
+#ifdef CONFIG_SYS_GENERIC_BOARD +/* Use the generic board which requires a unified bd_info */ +#include <asm-generic/u-boot.h> +#else + typedef struct bd_info { unsigned char bi_phy_id[4]; unsigned long bi_board_number; @@ -22,6 +27,8 @@ typedef struct bd_info { #define bi_memstart bi_dram[0].start #define bi_memsize bi_dram[0].size
+#endif + /* For image.h:image_check_target_arch() */ #define IH_ARCH_DEFAULT IH_ARCH_AVR32
diff --git a/arch/avr32/lib/Makefile b/arch/avr32/lib/Makefile index bb45cbe..d5cb8b2 100644 --- a/arch/avr32/lib/Makefile +++ b/arch/avr32/lib/Makefile @@ -8,6 +8,8 @@ #
obj-y += memset.o +ifndef CONFIG_SYS_GENERIC_BOARD obj-y += board.o +endif obj-$(CONFIG_CMD_BOOTM) += bootm.o obj-y += interrupts.o diff --git a/arch/avr32/lib/interrupts.c b/arch/avr32/lib/interrupts.c index bacb2d1..5f3a49e 100644 --- a/arch/avr32/lib/interrupts.c +++ b/arch/avr32/lib/interrupts.c @@ -7,6 +7,11 @@
+int interrupt_init(void) +{ + return 0; +} + void enable_interrupts(void) { asm volatile("csrf %0" : : "n"(SYSREG_GM_OFFSET)); diff --git a/common/board_f.c b/common/board_f.c index 215108b..1a735ae 100644 --- a/common/board_f.c +++ b/common/board_f.c @@ -174,7 +174,7 @@ static int announce_dram_init(void) return 0; }
-#if defined(CONFIG_MIPS) || defined(CONFIG_PPC) +#if defined(CONFIG_MIPS) || defined(CONFIG_PPC) || defined(CONFIG_AVR32) static int init_func_ram(void) { #ifdef CONFIG_BOARD_TYPES @@ -268,6 +268,8 @@ static int setup_mon_len(void) gd->mon_len = (ulong)&_end - (ulong)_init; #elif defined(CONFIG_BLACKFIN) || defined(CONFIG_NIOS2) gd->mon_len = CONFIG_SYS_MONITOR_LEN; +#elif defined(CONFIG_AVR32) + gd->mon_len = (ulong)&__bss_end - (ulong)&_text; #else /* TODO: use (ulong)&__bss_end - (ulong)&__text_start; ? */ gd->mon_len = (ulong)&__bss_end - CONFIG_SYS_MONITOR_BASE; @@ -581,7 +583,7 @@ static int reserve_stacks(void) gd->irq_sp = gd->start_addr_sp; # endif #else -# ifdef CONFIG_PPC +# if defined(CONFIG_PPC) || defined(CONFIG_AVR32) ulong *s; # endif
@@ -611,6 +613,11 @@ static int reserve_stacks(void) s = (ulong *) gd->start_addr_sp; *s = 0; /* Terminate back chain */ *++s = 0; /* NULL return address */ +# elif defined(CONFIG_AVR32) + gd->arch.stack_end = gd->start_addr_sp; + s = (ulong *)gd->start_addr_sp; + *s = 0; + *--s = 0; # endif /* Architecture specific code */
return 0; @@ -912,7 +919,7 @@ static init_fnc_t init_sequence_f[] = { #if defined(CONFIG_ARM) || defined(CONFIG_X86) dram_init, /* configure available RAM banks */ #endif -#if defined(CONFIG_MIPS) || defined(CONFIG_PPC) +#if defined(CONFIG_MIPS) || defined(CONFIG_PPC) || defined(CONFIG_AVR32) init_func_ram, #endif #ifdef CONFIG_POST diff --git a/common/board_r.c b/common/board_r.c index e712902..3620438 100644 --- a/common/board_r.c +++ b/common/board_r.c @@ -55,6 +55,9 @@ #include <dm/root.h> #include <linux/compiler.h> #include <linux/err.h> +#ifdef CONFIG_AVR32 +#include <asm/arch/mmu.h> +#endif
@@ -459,6 +462,16 @@ static int initr_env(void) return 0; }
+#ifdef CONFIG_SYS_BOOTPARAMS_LEN +static int initr_malloc_bootparams(void) +{ + gd->bd->bi_boot_params = (ulong)malloc(CONFIG_SYS_BOOTPARAMS_LEN); + if (!gd->bd->bi_boot_params) + puts("WARNING: Cannot allocate space for boot parameters\n"); + return 0; +} +#endif + #ifdef CONFIG_SC3 /* TODO: with new initcalls, move this into the driver */ extern void sc3_read_eeprom(void); @@ -502,7 +515,7 @@ static int show_model_r(void) #endif
/* enable exceptions */ -#ifdef CONFIG_ARM +#if defined(CONFIG_ARM) || defined(CONFIG_AVR32) static int initr_enable_interrupts(void) { enable_interrupts(); @@ -791,6 +804,9 @@ init_fnc_t init_sequence_r[] = { initr_dataflash, #endif initr_env, +#ifdef CONFIG_SYS_BOOTPARAMS_LEN + initr_malloc_bootparams, +#endif INIT_FUNC_WATCHDOG_RESET initr_secondary_cpu, #ifdef CONFIG_SC3 @@ -826,10 +842,10 @@ init_fnc_t init_sequence_r[] = { initr_kgdb, #endif interrupt_init, -#if defined(CONFIG_ARM) +#if defined(CONFIG_ARM) || defined(CONFIG_AVR32) initr_enable_interrupts, #endif -#ifdef CONFIG_X86 +#if defined(CONFIG_X86) || defined(CONFIG_AVR32) timer_init, /* initialize timer */ #endif #if defined(CONFIG_STATUS_LED) && defined(STATUS_LED_BOOT) @@ -894,6 +910,10 @@ void board_init_r(gd_t *new_gd, ulong dest_addr) int i; #endif
+#ifdef CONFIG_AVR32 + mmu_init_r(dest_addr); +#endif + #if !defined(CONFIG_X86) && !defined(CONFIG_ARM) && !defined(CONFIG_ARM64) gd = new_gd; #endif diff --git a/include/asm-generic/u-boot.h b/include/asm-generic/u-boot.h index aef39d7..a63a87a 100644 --- a/include/asm-generic/u-boot.h +++ b/include/asm-generic/u-boot.h @@ -32,6 +32,10 @@ typedef struct bd_info { unsigned long bi_flashoffset; /* reserved area for startup monitor */ unsigned long bi_sramstart; /* start of SRAM memory */ unsigned long bi_sramsize; /* size of SRAM memory */ +#ifdef CONFIG_AVR32 + unsigned char bi_phy_id[4]; /* PHY address for ATAG_ETHERNET */ + unsigned long bi_board_number;/* ATAG_BOARDINFO */ +#endif #ifdef CONFIG_ARM unsigned long bi_arm_freq; /* arm frequency */ unsigned long bi_dsp_freq; /* dsp core frequency */
On 27 January 2015 at 17:16, Andreas Bießmann andreas.devel@googlemail.com wrote:
Changes in v1:
.bss (NOLOAD) : {
__init_end = .;
Would we be able to unify the symbols here rather than having a special case for AVR32?
*s = 0;
*--s = 0;
Can we create an arch_reserve_stacks() function to handle this, and put it in the AVR32 code?
Can you use dram_init() instead?
What needs this? Let's move it into AVR32 code.
Shouldn't this be an error? If so:
return -ENOMEM
What does this do? It feels like it shold perhaps happen in the init sequence. See x86 which has a similar requirement, or at least I think it is similar.
The objective ultimately is to remove all #ifdefs from board_f/r.c.
+#endif #ifdef CONFIG_ARM unsigned long bi_arm_freq; /* arm frequency */ unsigned long bi_dsp_freq; /* dsp core frequency */ -- 1.7.10.4
Hi Simon,
Changes in v1:
well, I'm not __ARM__ nor CONFIG_SANDBOX, CONFIG_BLACKFIN or CONFIG_NIOS2. The else path may fit, I'll check that.
*s = 0;
*--s = 0;
I'll do so.
I have to check that. Can we do that later when we convert mips/ppc? I fear it is a bit complex.
The mmu_init_r needs this. I dunno where to place it. ARM has the TLB setup before activating d-caches (in initr_caches). This is not required for avr32 and therefore not the right place.
can you point me to the x86 code?
That's clear to me. I thought we can first gather all the stuff in common/board_* and in a second turn we clean it up. Obvious things cleaned up before, but questionnaire things are cleaned up in a second turn. At least this was my objective ;)
Best regards
Andreas Bießmann
Hi Andreas,
On 28 January 2015 at 03:04, Andreas Bießmann andreas.devel@googlemail.com wrote:
Hi Simon,
Changes in v1:
*s = 0;
*--s = 0;
I'll do so.
Later is fine if this doesn't work. But if every arch uses another arch as an excuse not to clean up no one will get there :-)
OK, then maybe we need to add this as a new method that any arch can use?
I'm wondering whether we should (later) have the concept of an arch 'driver', with methods for all of these things.
I was thinking of init_cache_f_r(). Is that similar to what you want?
Sounds good. I suppose the immediate objective is to get everything in generic board, but we should clean it up soon.
Changes in v1: None
include/configs/grasshopper.h | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/include/configs/grasshopper.h b/include/configs/grasshopper.h index 83f0ed2..54eb977 100644 --- a/include/configs/grasshopper.h +++ b/include/configs/grasshopper.h @@ -62,6 +62,10 @@ #define CONFIG_USART_BASE ATMEL_BASE_USART1 #define CONFIG_USART_ID 1
+#define CONFIG_SYS_GENERIC_BOARD +#define CONFIG_BOARD_EARLY_INIT_F +#define CONFIG_BOARD_EARLY_INIT_R + /* User serviceable stuff */ #define CONFIG_CMDLINE_TAG #define CONFIG_SETUP_MEMORY_TAGS
include/configs/atstk1002.h | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/include/configs/atstk1002.h b/include/configs/atstk1002.h index 9e58238..a9c064a 100644 --- a/include/configs/atstk1002.h +++ b/include/configs/atstk1002.h @@ -104,6 +104,10 @@ #define CONFIG_BOOTP_SUBNETMASK #define CONFIG_BOOTP_GATEWAY
+/* generic board */ +#define CONFIG_SYS_GENERIC_BOARD +#define CONFIG_BOARD_EARLY_INIT_F +#define CONFIG_BOARD_EARLY_INIT_R
/* * Command line configuration.
Andreas Bießmann
