[PATCH 1/1] video: fix positioning in TrueType console
With the patch accurate positioning is possible for mono-typed fonts:
Fix the return value of console_truetype_putc_xy(). The current position is passed as parameter x. Some part of x represents a fractional pixel. The return value represents how much the character position must be advanced. This should only comprise the width of the current character and not the preexisting fractional pixel position.
Characters are not square. As all characters of a mono-type font we can take the width of any character. 'W' as one of the widest ANSI characters provides also a good value for variable width fonts.
The character width must be a float.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- drivers/video/console_truetype.c | 27 ++++++++++++++++++++------- include/video_console.h | 2 +- 2 files changed, 21 insertions(+), 8 deletions(-)
diff --git a/drivers/video/console_truetype.c b/drivers/video/console_truetype.c index 318a060926..56939af849 100644 --- a/drivers/video/console_truetype.c +++ b/drivers/video/console_truetype.c @@ -211,7 +211,7 @@ static int console_truetype_putc_xy(struct udevice *dev, uint x, uint y, int width_frac, linenum; struct pos_info *pos; u8 *bits, *data; - int advance; + int advance, kern_adv; void *start, *line, *sync_start, *sync_end; int row, ret; int bg_r, bg_g, bg_b; @@ -226,8 +226,11 @@ static int console_truetype_putc_xy(struct udevice *dev, uint x, uint y, * this character */ xpos = frac(VID_TO_PIXEL((double)x)); if (vc_priv->last_ch) { - xpos += priv->scale * stbtt_GetCodepointKernAdvance(font, - vc_priv->last_ch, ch); + kern_adv = stbtt_GetCodepointKernAdvance(font, vc_priv->last_ch, + ch); + xpos += priv->scale * kern_adv; + } else { + kern_adv = 0; }
/* @@ -238,8 +241,8 @@ static int console_truetype_putc_xy(struct udevice *dev, uint x, uint y, */ x_shift = xpos - (double)tt_floor(xpos); xpos += advance * priv->scale; - width_frac = (int)VID_TO_POS(xpos); - if (x + width_frac >= vc_priv->xsize_frac) + width_frac = VID_TO_POS(priv->scale * (kern_adv + advance)); + if (x + (int)VID_TO_POS(xpos) >= vc_priv->xsize_frac) return -EAGAIN;
/* Write the current cursor position into history */ @@ -591,20 +594,21 @@ static int console_truetype_probe(struct udevice *dev) struct udevice *vid_dev = dev->parent; struct video_priv *vid_priv = dev_get_uclass_priv(vid_dev); stbtt_fontinfo *font = &priv->font; - int ascent; + int advance, ascent, lsb;
debug("%s: start\n", __func__); + if (vid_priv->font_size) priv->font_size = vid_priv->font_size; else priv->font_size = CONFIG_CONSOLE_TRUETYPE_SIZE; + priv->font_data = console_truetype_find_font(); if (!priv->font_data) { debug("%s: Could not find any fonts\n", __func__); return -EBFONT; }
- vc_priv->x_charsize = priv->font_size; vc_priv->y_charsize = priv->font_size; vc_priv->xstart_frac = VID_TO_POS(2); vc_priv->cols = vid_priv->xsize / priv->font_size; @@ -618,6 +622,15 @@ static int console_truetype_probe(struct udevice *dev)
/* Pre-calculate some things we will need regularly */ priv->scale = stbtt_ScaleForPixelHeight(font, priv->font_size); + + /* Assuming that 'W' is the widest character */ + stbtt_GetCodepointHMetrics(font, 'W', &advance, &lsb); + advance += stbtt_GetCodepointKernAdvance(font, 'W', 'W'); + vc_priv->cols = + (int)VID_TO_POS(vid_priv->xsize - 2) / + (int)VID_TO_POS(advance * priv->scale); + vc_priv->x_charsize = advance * priv->scale; + stbtt_GetFontVMetrics(font, &ascent, 0, 0); priv->baseline = (int)(ascent * priv->scale); debug("%s: ready\n", __func__); diff --git a/include/video_console.h b/include/video_console.h index 8747299d61..cf306e5ca2 100644 --- a/include/video_console.h +++ b/include/video_console.h @@ -68,7 +68,7 @@ struct vidconsole_priv { int ycur; int rows; int cols; - int x_charsize; + double x_charsize; int y_charsize; int tab_width_frac; int xsize_frac; -- 2.30.1
Dear Anatolij,
somehow you lost track of this patch since March:
https://patchwork.ozlabs.org/project/uboot/patch/20210203161254.970-1-xypron...
Could you, please, review it and consider it for merging.
Best regards
Heinrich
-- 2.30.1
- int advance;
- int advance, kern_adv; void *start, *line, *sync_start, *sync_end; int row, ret; int bg_r, bg_g, bg_b;
ch);
} else {
kern_adv = 0;
- int ascent;
- /* Assuming that 'W' is the widest character */
- stbtt_GetCodepointHMetrics(font, 'W', &advance, &lsb);
- advance += stbtt_GetCodepointKernAdvance(font, 'W', 'W');
- vc_priv->cols =
- vc_priv->x_charsize = advance * priv->scale;
- stbtt_GetFontVMetrics(font, &ascent, 0, 0); priv->baseline = (int)(ascent * priv->scale); debug("%s: ready\n", __func__);
- int x_charsize;
- double x_charsize; int y_charsize; int tab_width_frac; int xsize_frac;
Hi Heinrich,
On Wed, 27 Oct 2021 20:10:36 +0200 Heinrich Schuchardt xypron.glpk@gmx.de wrote:
Dear Anatolij,
I've applied the patches for build testing and see sandbox test errors:
https://source.denx.de/u-boot/custodians/u-boot-video/-/jobs/342128
Could you please fix them? Thanks!
-- Anatolij
On 10/27/21 9:52 PM, Anatolij Gustschin wrote:
Hi Heinrich,
Dear Anatolij,
Dear Anatolij,
The sandbox test relies on hashing the screen contents and these hash changes. The true test here is running 'u-boot -T -l' and checking the output.
I have sent you a version 2 with adjusted hash values. Gitlab CI is happy now: https://source.denx.de/u-boot/custodians/u-boot-efi/-/pipelines/9633
Best regards
Heinrich
-- Anatolij
Anatolij Gustschin
