[U-Boot] [PATCH] MIPS: remove OUTPUT_FORMAT from linker scripts
The OUTPUT_FORMAT command in linker scripts was always misused due to some endianess and toolchain problems.
Use GCC flags to ensure proper output format, and get rid of the OUTPUT_FORMAT commands in the board specific u-boot.lds files.
Signed-off-by: Gabor Juhos juhosg@openwrt.org Cc: Daniel Schwierzeck daniel.schwierzeck@googlemail.com Cc: Stefan Roese sr@denx.de Cc: Wolfgang Denk wd@denx.de Cc: Xiangfu Liu xiangfu@openmobilefree.net --- arch/mips/cpu/mips32/config.mk | 6 ++++++ arch/mips/cpu/xburst/config.mk | 6 ++++++ board/dbau1x00/u-boot.lds | 4 ---- board/incaip/u-boot.lds | 4 ---- board/micronas/vct/u-boot.lds | 1 - board/pb1x00/u-boot.lds | 4 ---- board/qemu-mips/u-boot.lds | 8 -------- board/qi/qi_lb60/u-boot.lds | 2 -- 8 files changed, 12 insertions(+), 23 deletions(-)
diff --git a/arch/mips/cpu/mips32/config.mk b/arch/mips/cpu/mips32/config.mk index 481e984..7399701 100644 --- a/arch/mips/cpu/mips32/config.mk +++ b/arch/mips/cpu/mips32/config.mk @@ -30,5 +30,11 @@ MIPSFLAGS := -march=mips32r2
PLATFORM_CPPFLAGS += $(MIPSFLAGS) +PLATFORM_CPPFLAGS += -mabi=32 -DCONFIG_32BIT +ifdef CONFIG_SYS_BIG_ENDIAN +PLATFORM_LDFLAGS += -m elf32btsmip +else +PLATFORM_LDFLAGS += -m elf32ltsmip +endif
CONFIG_STANDALONE_LOAD_ADDR ?= 0x80200000 -T mips.lds diff --git a/arch/mips/cpu/xburst/config.mk b/arch/mips/cpu/xburst/config.mk index 1536746..cf5fa6a 100644 --- a/arch/mips/cpu/xburst/config.mk +++ b/arch/mips/cpu/xburst/config.mk @@ -21,5 +21,11 @@ #
PLATFORM_CPPFLAGS += -march=mips32 +PLATFORM_CPPFLAGS += -mabi=32 -DCONFIG_32BIT +ifdef CONFIG_SYS_BIG_ENDIAN +PLATFORM_LDFLAGS += -m elf32btsmip +else +PLATFORM_LDFLAGS += -m elf32ltsmip +endif
CONFIG_STANDALONE_LOAD_ADDR ?= 0x80200000 -T mips.lds diff --git a/board/dbau1x00/u-boot.lds b/board/dbau1x00/u-boot.lds index 8a871cf..d9c01af 100644 --- a/board/dbau1x00/u-boot.lds +++ b/board/dbau1x00/u-boot.lds @@ -21,10 +21,6 @@ * MA 02111-1307 USA */
-/* -OUTPUT_FORMAT("elf32-bigmips", "elf32-bigmips", "elf32-bigmips") -*/ -OUTPUT_FORMAT("elf32-tradbigmips", "elf32-tradbigmips", "elf32-tradlittlemips") OUTPUT_ARCH(mips) ENTRY(_start) SECTIONS diff --git a/board/incaip/u-boot.lds b/board/incaip/u-boot.lds index 8a871cf..d9c01af 100644 --- a/board/incaip/u-boot.lds +++ b/board/incaip/u-boot.lds @@ -21,10 +21,6 @@ * MA 02111-1307 USA */
-/* -OUTPUT_FORMAT("elf32-bigmips", "elf32-bigmips", "elf32-bigmips") -*/ -OUTPUT_FORMAT("elf32-tradbigmips", "elf32-tradbigmips", "elf32-tradlittlemips") OUTPUT_ARCH(mips) ENTRY(_start) SECTIONS diff --git a/board/micronas/vct/u-boot.lds b/board/micronas/vct/u-boot.lds index 2ce8d0e..cc7db1b 100644 --- a/board/micronas/vct/u-boot.lds +++ b/board/micronas/vct/u-boot.lds @@ -21,7 +21,6 @@ * MA 02111-1307 USA */
-OUTPUT_FORMAT("elf32-tradbigmips", "elf32-tradbigmips", "elf32-tradlittlemips") OUTPUT_ARCH(mips) ENTRY(_start) SECTIONS diff --git a/board/pb1x00/u-boot.lds b/board/pb1x00/u-boot.lds index 07ddd36..d9c01af 100644 --- a/board/pb1x00/u-boot.lds +++ b/board/pb1x00/u-boot.lds @@ -21,10 +21,6 @@ * MA 02111-1307 USA */
-/* -OUTPUT_FORMAT("elf32-bigmips", "elf32-bigmips", "elf32-bigmips") -*/ -OUTPUT_FORMAT("elf32-tradlittlemips", "elf32-tradbigmips", "elf32-tradlittlemips") OUTPUT_ARCH(mips) ENTRY(_start) SECTIONS diff --git a/board/qemu-mips/u-boot.lds b/board/qemu-mips/u-boot.lds index cb2356f..33b42f3 100644 --- a/board/qemu-mips/u-boot.lds +++ b/board/qemu-mips/u-boot.lds @@ -21,14 +21,6 @@ * MA 02111-1307 USA */
-/* -OUTPUT_FORMAT("elf32-bigmips", "elf32-bigmips", "elf32-bigmips") -*/ -#if defined(CONFIG_64BIT) -OUTPUT_FORMAT("elf64-tradbigmips", "elf64-tradbigmips", "elf64-tradlittlemips") -#else -OUTPUT_FORMAT("elf32-tradbigmips", "elf32-tradbigmips", "elf32-tradlittlemips") -#endif OUTPUT_ARCH(mips) ENTRY(_start) SECTIONS diff --git a/board/qi/qi_lb60/u-boot.lds b/board/qi/qi_lb60/u-boot.lds index b3cb869..d074a27 100644 --- a/board/qi/qi_lb60/u-boot.lds +++ b/board/qi/qi_lb60/u-boot.lds @@ -18,8 +18,6 @@ * MA 02111-1307 USA */
-OUTPUT_FORMAT("elf32-tradlittlemips", "elf32-tradlittlemips", "elf32-tradlittlemips") - OUTPUT_ARCH(mips) ENTRY(_start) SECTIONS
2013/1/30 Gabor Juhos juhosg@openwrt.org:
applied to u-boot-mips/master, thanks
Daniel Schwierzeck
Gabor Juhos
