[U-Boot] [PATCH] arch-kirkwood: Ethernet port macro returning incorrect address
Modified the arch-kirkwood header so KWGBE_PORT_SERIAL_CONTROL1_REG(x) returns the correct address.
Originally calling KWGBE_PORT_SERIAL_CONTROL1_REG(1) returned the address for port 0 and vice versa.
Doesn't have any knock on effects to the u-boot code as the only time they're used is to do the same function to both addresses
Signed-off-by: Luke Lowrey luke@chamsys.co.uk --- arch/arm/include/asm/arch-kirkwood/cpu.h | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/arch/arm/include/asm/arch-kirkwood/cpu.h b/arch/arm/include/asm/arch-kirkwood/cpu.h index d28c51a..784ba87 100644 --- a/arch/arm/include/asm/arch-kirkwood/cpu.h +++ b/arch/arm/include/asm/arch-kirkwood/cpu.h @@ -33,7 +33,7 @@ | (attr << 8) | (kw_winctrl_calcsize(size) << 16))
#define KWGBE_PORT_SERIAL_CONTROL1_REG(_x) \ - ((_x ? KW_EGIGA0_BASE : KW_EGIGA1_BASE) + 0x44c) + ((_x ? KW_EGIGA1_BASE : KW_EGIGA0_BASE) + 0x44c)
#define KW_REG_PCIE_DEVID (KW_REG_PCIE_BASE + 0x00) #define KW_REG_PCIE_REVID (KW_REG_PCIE_BASE + 0x08)
-----Original Message----- From: u-boot-bounces@lists.denx.de [mailto:u-boot- bounces@lists.denx.de] On Behalf Of Luke Lowrey Sent: 25 June 2012 22:07 To: u-boot@lists.denx.de Subject: [U-Boot] [PATCH] arch-kirkwood: Ethernet port macro returning incorrect address
Acked-by: Prafulla Wadaskar Prafulla@marvell.com
Regards.. Prafulla . . .
Hello Luke,
Signed-off-by: Luke Lowreyluke@chamsys.co.uk
Acked-by: Heiko Schocher hs@denx.de
bye, Heiko
Heiko Schocher
Luke Lowrey
Prafulla Wadaskar
