[U-Boot] Please pull u-boot-mpc85xx master
Tom,
The following changes since commit 693d4c9f1dc40fcf24ced459bc4d1b46db33298a:
spl: Remove CONFIG_SYS_U_BOOT_MAX_SIZE_SECTORS (2016-11-18 21:20:59 -0500)
git://git.denx.de/u-boot-mpc85xx.git
for you to fetch changes up to e8a390f0189c5868f2fa305004821bcfcd71d32c:
powerpc: Drop default CONFIG_MAX_CPUS (2016-11-23 23:42:17 -0800)
---------------------------------------------------------------- York Sun (97): tools/env: Correct include kconfig powerpc: MPC8548: Move CONFIG_MPC8548 to Kconfig option powerpc: MPC8548CDS: Remove macro CONFIG_MPC8548CDS powerpc: MPC8544: Move CONFIG_MPC8544 to Kconfig option powerpc: MPC8544DS: Remove macro CONFIG_MPC8544DS powerpc: BSC9131/2: Move CONFIG_BSC9131/2 to Kconfig options powerpc: BSC9131RDB: Remove CONFIG_BSC9131RDB macro powerpc: BSC9132QDS: Remove CONFIG_BSC9132QDS macro powerpc: C29X: Move CONFIG_PPC_C29X to Kconfig option powerpc: C29XPCIE: Remove macro CONFIG_C29XPCIE powerpc: MPC8536: Move CONFIG_MPC8536 to Kconfig option powerpc: MPC8536DS: Remove macro CONFIG_MPC8536DS powerpc: mpc8540: Remove macro CONFIG_MPC8540 powerpc: MPC8540ADS: Remove macro CONFIG_MPC8540ADS powerpc: mpc8541: Remove macro CONFIG_MPC8541 powerpc: MPC8541CDS: Remove macro CONFIG_MPC8541CDS powerpc: MPC8555: Remove macro CONFIG_MPC8555 powerpc: MPC8555CDS: Remove macro CONFIG_MPC8555CDS powerpc: MPC8560: Remove macro CONFIG_MPC8560 powerpc: MPC8560ADS: Remove macro CONFIG_MPC8560ADS powerpc: MPC8568: Remove macro CONFIG_MPC8568 powerpc: MPC8568MDS: Remove macro CONFIG_MPC8568MDS powerpc: MPC8569: Remove macro CONFIG_MPC8569 powerpc: MPC8569MDS: Remove macro CONFIG_MPC8569MDS powerpc: MPC8572: Remove macro CONFIG_MPC8572 powerpc: MPC8572DS: Remove macro CONFIG_MPC8572DS powerpc: xpedite: Remove macro CONFIG_XPEDITE5370 powerpc: P1010: Remove macro CONFIG_P1010 powerpc: P1010RDB: Remove macros CONFIG_P1010RDB_PA and CONFIG_P1010RDB_PB powerpc: P1022: Remove macro CONFIG_P1022 powerpc: P1022DS: Remove macro CONFIG_P1022DS powerpc: P1023: Remove macro CONFIG_P1023 powerpc: P1011: Remove macro CONFIG_P1011 powerpc: P1012: Drop configuration for P1012 powerpc: P1013: Drop configuration for P1013 powerpc: P1014: Drop configuration for P1014 powerpc: P1017: Drop configuration for P1017 powerpc: P1020MBG: Separate from P1_P2_RDB_PC in Kconfig powerpc: P1020RDB-PC: Separate from P1_P2_RDB_PC in Kconfig powerpc: P1020RDB-PD: Separate from P1_P2_RDB_PC in Kconfig powerpc: P1020UTM: Separate from P1_P2_RDB_P2 in Kconfig powerpc: P1021RDB: Separate from P1_P2_RDB_PC in Kconfig powerpc: P1024RDB: Separate from P1_P2_RDB_PC in Kconfig powerpc: P1025RDB: Separate from P1_P2_RDB_PC in Kconfig powerpc: P2020RDB-PC: Separate from P1_P2_RDB_PC in Kconfig powerpc: P1_P2_RDB_PC: Drop TARGET_P1_P2_RDB_PC powerpc: P1020: Remove macro CONFIG_P1020 powerpc: P1021: Remove macro CONFIG_P1021 powerpc: P1024: Remove CONFIG_P1024 powerpc: P1025: Remove macro CONFIG_P1025 powerpc: P2020: Remove macro CONFIG_P2020 powerpc: P2010: Drop configuration for P2010 powerpc: P2041: Remove macro CONFIG_PPC_P2041 powerpc: P2041RDB: Remove macro CONFIG_P2041RDB powerpc: P3041: Remove macro CONFIG_PPC_P3041 powerpc: P3041DS: Remove macro CONFIG_P3041DS powerpc: P4080: Remove macro CONFIG_PPC_P4080 powerpc: P4080DS: Remove macro CONFIG_P4080DS powerpc: P5020: Remove macro CONFIG_PPC_P5020 powerpc: P5020DS: Remove macro CONFIG_P5020DS powerpc: P5040: Remove macro CONFIG_P5040 powerpc: P5040DS: Remove macro CONFIG_P5040DS powerpc: B4420QDS: Split from B4860QDS in Kconfig powerpc: B4860: Remove macro CONFIG_PPC_B4860 powerpc: B4860QDS: Remove macro CONFIG_B4860QDS powerpc: B4420: Remove macro CONFIG_PPC_B4420 powerpc: QEMU_E500: Remove macro CONFIG_QEMU_E500 powerpc: T102xRDB: Split as T1023RDB and T1024RDB powerpc: T1023: Remove macro CONFIG_PPC_T1023 powerpc: T1024QDS: Rename Kconfig option to match the name powerpc: T1024: Remove macro CONFIG_PPC_T1024 powerpc: T104XRDB: Split to T1040RDB and T1042RDB in Kconfig powerpc: T1040: Remove macro CONFIG_PPC_T1040 powerpc: T1040D4RDB: Separate from T1040RDB in Kconfig powerpc: T1040RDB: Remove macro CONFIG_T1040RDB powerpc: T1042: Remove macro CONFIG_PPC_T1042 powerpc: T1042RDB_PI: Split from T1042RDB in Kconfig powerpc: T1042D4RDB: Separate from T1042RDB in Kconfig powerpc: T1042RDB: Remove macro CONFIG_T1042RDB powerpc: T104xRDB: Remove macro CONFIG_T104xRDB and T104xD4RDB powerpc: T208XQDS: Split as T2080QDS and T2081QDS powerpc: T2080RDB: Rename from T208XRDB in Kconfig powerpc: T2080, T2081: Remove macro CONFIG_PPC_T2080 and CONFIG_PPC_T2081 powerpc: T4160QDS: Separate from T4240QDS in Kconfig powerpc: T4240QDS: Remove macro CONFIG_T4240QDS powerpc: T4160RDB: Separate from T4240RDB in Kconfig powerpc: T4240RDB: Remove macro CONFIG_T4240RDB powerpc: T4160: Remove macro CONFIG_PPC_T4160 powerpc: T4240: Remove macro CONFIG_PPC_T4240 powerpc: T4080: Drop configuration for T4080 powerpc: mpc85xx: Move CONFIG_MAX_CPUS to Kconfig powerpc: MPC8610: Remove macro CONFIG_MPC8610 powerpc: MPC8610HPCD: Remove macro CONFIG_MPC8610HPCD powerpc: MPC8641: Remove macro CONFIG_MPC8641 powerpc: MPC8641HPCN: Remove macro CONFIG_MPC8641HPCN powerpc: mpc86xx: Remove macro CONFIG_MAX_CPUS powerpc: Drop default CONFIG_MAX_CPUS
arch/powerpc/cpu/mpc85xx/Kconfig | 321 ++++++++++++++++++++- arch/powerpc/cpu/mpc85xx/Makefile | 103 +++---- arch/powerpc/cpu/mpc85xx/b4860_ids.c | 4 +- arch/powerpc/cpu/mpc85xx/b4860_serdes.c | 4 +- arch/powerpc/cpu/mpc85xx/cmd_errata.c | 11 +- arch/powerpc/cpu/mpc85xx/cpu.c | 6 +- arch/powerpc/cpu/mpc85xx/cpu_init.c | 4 +- arch/powerpc/cpu/mpc85xx/cpu_init_early.c | 2 +- arch/powerpc/cpu/mpc85xx/fdt.c | 13 +- arch/powerpc/cpu/mpc85xx/fsl_corenet2_serdes.c | 2 +- arch/powerpc/cpu/mpc85xx/fsl_corenet_serdes.c | 6 +- arch/powerpc/cpu/mpc85xx/pci.c | 2 +- arch/powerpc/cpu/mpc85xx/speed.c | 36 ++- arch/powerpc/cpu/mpc85xx/start.S | 6 +- arch/powerpc/cpu/mpc85xx/t2080_serdes.c | 4 +- arch/powerpc/cpu/mpc85xx/t4240_serdes.c | 4 +- arch/powerpc/cpu/mpc86xx/Kconfig | 10 + arch/powerpc/cpu/mpc86xx/Makefile | 4 +- arch/powerpc/cpu/mpc86xx/cpu.c | 6 +- arch/powerpc/cpu/mpc86xx/speed.c | 2 +- arch/powerpc/include/asm/config.h | 4 - arch/powerpc/include/asm/config_mpc85xx.h | 205 +++---------- arch/powerpc/include/asm/config_mpc86xx.h | 6 +- arch/powerpc/include/asm/cpm_85xx.h | 2 +- arch/powerpc/include/asm/fsl_law.h | 12 +- arch/powerpc/include/asm/fsl_lbc.h | 6 +- arch/powerpc/include/asm/fsl_secure_boot.h | 39 +-- arch/powerpc/include/asm/immap_85xx.h | 98 +++---- arch/powerpc/include/asm/immap_86xx.h | 2 +- arch/powerpc/include/asm/processor.h | 2 +- board/freescale/b4860qds/Kconfig | 2 +- board/freescale/b4860qds/Makefile | 3 +- board/freescale/b4860qds/b4860qds.c | 6 +- board/freescale/b4860qds/b4860qds_crossbar_con.h | 4 +- board/freescale/b4860qds/eth_b4860qds.c | 2 +- board/freescale/common/Makefile | 30 +- board/freescale/common/pixis.h | 10 +- board/freescale/common/pq-mds-pib.c | 2 +- board/freescale/corenet_ds/Makefile | 16 +- board/freescale/corenet_ds/corenet_ds.c | 14 +- board/freescale/p1010rdb/Kconfig | 2 +- board/freescale/p1010rdb/p1010rdb.c | 20 +- board/freescale/p1010rdb/spl.c | 2 +- board/freescale/p1_p2_rdb_pc/Kconfig | 9 +- board/freescale/p1_p2_rdb_pc/ddr.c | 14 +- board/freescale/p1_p2_rdb_pc/p1_p2_rdb_pc.c | 18 +- board/freescale/p1_p2_rdb_pc/tlb.c | 4 +- board/freescale/t102xqds/Kconfig | 2 +- board/freescale/t102xqds/spl.c | 2 +- board/freescale/t102xqds/t102xqds.c | 4 +- board/freescale/t102xrdb/Kconfig | 2 +- board/freescale/t104xrdb/Kconfig | 4 +- board/freescale/t104xrdb/cpld.c | 2 +- board/freescale/t104xrdb/cpld.h | 2 +- board/freescale/t104xrdb/eth.c | 6 +- board/freescale/t104xrdb/t104xrdb.c | 4 +- board/freescale/t208xqds/Kconfig | 2 +- board/freescale/t208xrdb/Kconfig | 2 +- board/freescale/t4qds/Kconfig | 2 +- board/freescale/t4qds/Makefile | 3 +- board/freescale/t4rdb/Kconfig | 2 +- board/freescale/t4rdb/Makefile | 3 +- board/varisys/cyrus/eth.c | 4 +- board/xes/common/Makefile | 4 +- board/xes/common/fsl_8xxx_clk.c | 4 +- board/xes/common/fsl_8xxx_pci.c | 2 +- common/env_embedded.c | 2 + configs/B4420QDS_NAND_defconfig | 4 +- configs/B4420QDS_SPIFLASH_defconfig | 4 +- configs/B4420QDS_defconfig | 3 +- configs/B4860QDS_NAND_defconfig | 2 +- configs/B4860QDS_SECURE_BOOT_defconfig | 2 +- configs/B4860QDS_SPIFLASH_defconfig | 2 +- configs/B4860QDS_SRIO_PCIE_BOOT_defconfig | 2 +- configs/B4860QDS_defconfig | 1 - configs/BSC9131RDB_NAND_SYSCLK100_defconfig | 2 +- configs/BSC9131RDB_NAND_defconfig | 2 +- configs/BSC9131RDB_SPIFLASH_SYSCLK100_defconfig | 2 +- configs/BSC9131RDB_SPIFLASH_defconfig | 2 +- configs/BSC9132QDS_NAND_DDRCLK100_SECURE_defconfig | 2 +- configs/BSC9132QDS_NAND_DDRCLK100_defconfig | 2 +- configs/BSC9132QDS_NAND_DDRCLK133_SECURE_defconfig | 2 +- configs/BSC9132QDS_NAND_DDRCLK133_defconfig | 2 +- configs/BSC9132QDS_NOR_DDRCLK100_SECURE_defconfig | 2 +- configs/BSC9132QDS_NOR_DDRCLK100_defconfig | 2 +- configs/BSC9132QDS_NOR_DDRCLK133_SECURE_defconfig | 2 +- configs/BSC9132QDS_NOR_DDRCLK133_defconfig | 2 +- .../BSC9132QDS_SDCARD_DDRCLK100_SECURE_defconfig | 2 +- configs/BSC9132QDS_SDCARD_DDRCLK100_defconfig | 2 +- .../BSC9132QDS_SDCARD_DDRCLK133_SECURE_defconfig | 2 +- configs/BSC9132QDS_SDCARD_DDRCLK133_defconfig | 2 +- .../BSC9132QDS_SPIFLASH_DDRCLK100_SECURE_defconfig | 2 +- configs/BSC9132QDS_SPIFLASH_DDRCLK100_defconfig | 2 +- .../BSC9132QDS_SPIFLASH_DDRCLK133_SECURE_defconfig | 2 +- configs/BSC9132QDS_SPIFLASH_DDRCLK133_defconfig | 2 +- configs/C29XPCIE_NAND_defconfig | 2 +- configs/C29XPCIE_NOR_SECBOOT_defconfig | 2 +- configs/C29XPCIE_SPIFLASH_SECBOOT_defconfig | 2 +- configs/C29XPCIE_SPIFLASH_defconfig | 2 +- configs/C29XPCIE_defconfig | 1 - configs/Cyrus_P5020_defconfig | 2 +- configs/Cyrus_P5040_defconfig | 2 +- configs/P1010RDB-PA_36BIT_NAND_SECBOOT_defconfig | 4 +- configs/P1010RDB-PA_36BIT_NAND_defconfig | 4 +- configs/P1010RDB-PA_36BIT_NOR_SECBOOT_defconfig | 4 +- configs/P1010RDB-PA_36BIT_NOR_defconfig | 3 +- configs/P1010RDB-PA_36BIT_SDCARD_defconfig | 4 +- .../P1010RDB-PA_36BIT_SPIFLASH_SECBOOT_defconfig | 4 +- configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig | 4 +- configs/P1010RDB-PA_NAND_SECBOOT_defconfig | 4 +- configs/P1010RDB-PA_NAND_defconfig | 4 +- configs/P1010RDB-PA_NOR_SECBOOT_defconfig | 4 +- configs/P1010RDB-PA_NOR_defconfig | 3 +- configs/P1010RDB-PA_SDCARD_defconfig | 4 +- configs/P1010RDB-PA_SPIFLASH_SECBOOT_defconfig | 4 +- configs/P1010RDB-PA_SPIFLASH_defconfig | 4 +- configs/P1010RDB-PB_36BIT_NAND_SECBOOT_defconfig | 4 +- configs/P1010RDB-PB_36BIT_NAND_defconfig | 4 +- configs/P1010RDB-PB_36BIT_NOR_SECBOOT_defconfig | 4 +- configs/P1010RDB-PB_36BIT_NOR_defconfig | 3 +- configs/P1010RDB-PB_36BIT_SDCARD_defconfig | 4 +- .../P1010RDB-PB_36BIT_SPIFLASH_SECBOOT_defconfig | 4 +- configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig | 4 +- configs/P1010RDB-PB_NAND_SECBOOT_defconfig | 4 +- configs/P1010RDB-PB_NAND_defconfig | 4 +- configs/P1010RDB-PB_NOR_SECBOOT_defconfig | 4 +- configs/P1010RDB-PB_NOR_defconfig | 3 +- configs/P1010RDB-PB_SDCARD_defconfig | 4 +- configs/P1010RDB-PB_SPIFLASH_SECBOOT_defconfig | 4 +- configs/P1010RDB-PB_SPIFLASH_defconfig | 4 +- configs/P1020MBG-PC_36BIT_SDCARD_defconfig | 4 +- configs/P1020MBG-PC_36BIT_defconfig | 3 +- configs/P1020MBG-PC_SDCARD_defconfig | 4 +- configs/P1020MBG-PC_defconfig | 3 +- configs/P1020RDB-PC_36BIT_NAND_defconfig | 4 +- configs/P1020RDB-PC_36BIT_SDCARD_defconfig | 4 +- configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig | 4 +- configs/P1020RDB-PC_36BIT_defconfig | 3 +- configs/P1020RDB-PC_NAND_defconfig | 4 +- configs/P1020RDB-PC_SDCARD_defconfig | 4 +- configs/P1020RDB-PC_SPIFLASH_defconfig | 4 +- configs/P1020RDB-PC_defconfig | 3 +- configs/P1020RDB-PD_NAND_defconfig | 4 +- configs/P1020RDB-PD_SDCARD_defconfig | 4 +- configs/P1020RDB-PD_SPIFLASH_defconfig | 4 +- configs/P1020RDB-PD_defconfig | 3 +- configs/P1020UTM-PC_36BIT_SDCARD_defconfig | 4 +- configs/P1020UTM-PC_36BIT_defconfig | 3 +- configs/P1020UTM-PC_SDCARD_defconfig | 4 +- configs/P1020UTM-PC_defconfig | 3 +- configs/P1021RDB-PC_36BIT_NAND_defconfig | 4 +- configs/P1021RDB-PC_36BIT_SDCARD_defconfig | 4 +- configs/P1021RDB-PC_36BIT_SPIFLASH_defconfig | 4 +- configs/P1021RDB-PC_36BIT_defconfig | 3 +- configs/P1021RDB-PC_NAND_defconfig | 4 +- configs/P1021RDB-PC_SDCARD_defconfig | 4 +- configs/P1021RDB-PC_SPIFLASH_defconfig | 4 +- configs/P1021RDB-PC_defconfig | 3 +- configs/P1024RDB_36BIT_defconfig | 3 +- configs/P1024RDB_NAND_defconfig | 4 +- configs/P1024RDB_SDCARD_defconfig | 4 +- configs/P1024RDB_SPIFLASH_defconfig | 4 +- configs/P1024RDB_defconfig | 3 +- configs/P1025RDB_36BIT_defconfig | 3 +- configs/P1025RDB_NAND_defconfig | 4 +- configs/P1025RDB_SDCARD_defconfig | 4 +- configs/P1025RDB_SPIFLASH_defconfig | 4 +- configs/P1025RDB_defconfig | 3 +- configs/P2020RDB-PC_36BIT_NAND_defconfig | 4 +- configs/P2020RDB-PC_36BIT_SDCARD_defconfig | 4 +- configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig | 4 +- configs/P2020RDB-PC_36BIT_defconfig | 3 +- configs/P2020RDB-PC_NAND_defconfig | 4 +- configs/P2020RDB-PC_SDCARD_defconfig | 4 +- configs/P2020RDB-PC_SPIFLASH_defconfig | 4 +- configs/P2020RDB-PC_defconfig | 3 +- configs/T1023RDB_NAND_defconfig | 4 +- configs/T1023RDB_SDCARD_defconfig | 4 +- configs/T1023RDB_SECURE_BOOT_defconfig | 4 +- configs/T1023RDB_SPIFLASH_defconfig | 4 +- configs/T1023RDB_defconfig | 4 +- configs/T1024QDS_DDR4_SECURE_BOOT_defconfig | 4 +- configs/T1024QDS_DDR4_defconfig | 4 +- configs/T1024QDS_NAND_defconfig | 4 +- configs/T1024QDS_SDCARD_defconfig | 4 +- configs/T1024QDS_SECURE_BOOT_defconfig | 4 +- configs/T1024QDS_SPIFLASH_defconfig | 4 +- configs/T1024QDS_defconfig | 3 +- configs/T1024RDB_NAND_defconfig | 4 +- configs/T1024RDB_SDCARD_defconfig | 4 +- configs/T1024RDB_SECURE_BOOT_defconfig | 4 +- configs/T1024RDB_SPIFLASH_defconfig | 4 +- configs/T1024RDB_defconfig | 4 +- configs/T1040D4RDB_NAND_defconfig | 4 +- configs/T1040D4RDB_SDCARD_defconfig | 4 +- configs/T1040D4RDB_SECURE_BOOT_defconfig | 4 +- configs/T1040D4RDB_SPIFLASH_defconfig | 4 +- configs/T1040D4RDB_defconfig | 4 +- configs/T1040QDS_DDR4_defconfig | 2 +- configs/T1040QDS_SECURE_BOOT_defconfig | 2 +- configs/T1040QDS_defconfig | 1 - configs/T1040RDB_NAND_defconfig | 4 +- configs/T1040RDB_SDCARD_defconfig | 4 +- configs/T1040RDB_SECURE_BOOT_defconfig | 4 +- configs/T1040RDB_SPIFLASH_defconfig | 4 +- configs/T1040RDB_defconfig | 3 +- configs/T1042D4RDB_NAND_defconfig | 4 +- configs/T1042D4RDB_SDCARD_defconfig | 4 +- configs/T1042D4RDB_SECURE_BOOT_defconfig | 4 +- configs/T1042D4RDB_SPIFLASH_defconfig | 4 +- configs/T1042D4RDB_defconfig | 4 +- configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig | 4 +- configs/T1042RDB_PI_NAND_defconfig | 4 +- configs/T1042RDB_PI_SDCARD_defconfig | 4 +- configs/T1042RDB_PI_SPIFLASH_defconfig | 4 +- configs/T1042RDB_PI_defconfig | 3 +- configs/T1042RDB_SECURE_BOOT_defconfig | 4 +- configs/T1042RDB_defconfig | 3 +- configs/T2080QDS_NAND_defconfig | 4 +- configs/T2080QDS_SDCARD_defconfig | 4 +- configs/T2080QDS_SECURE_BOOT_defconfig | 4 +- configs/T2080QDS_SPIFLASH_defconfig | 4 +- configs/T2080QDS_SRIO_PCIE_BOOT_defconfig | 4 +- configs/T2080QDS_defconfig | 3 +- configs/T2080RDB_NAND_defconfig | 4 +- configs/T2080RDB_SDCARD_defconfig | 4 +- configs/T2080RDB_SECURE_BOOT_defconfig | 4 +- configs/T2080RDB_SPIFLASH_defconfig | 4 +- configs/T2080RDB_SRIO_PCIE_BOOT_defconfig | 4 +- configs/T2080RDB_defconfig | 3 +- configs/T2081QDS_NAND_defconfig | 4 +- configs/T2081QDS_SDCARD_defconfig | 4 +- configs/T2081QDS_SPIFLASH_defconfig | 4 +- configs/T2081QDS_SRIO_PCIE_BOOT_defconfig | 4 +- configs/T2081QDS_defconfig | 3 +- configs/T4160QDS_NAND_defconfig | 4 +- configs/T4160QDS_SDCARD_defconfig | 4 +- configs/T4160QDS_SECURE_BOOT_defconfig | 4 +- configs/T4160QDS_defconfig | 3 +- configs/T4160RDB_defconfig | 3 +- configs/T4240QDS_NAND_defconfig | 2 +- configs/T4240QDS_SDCARD_defconfig | 2 +- configs/T4240QDS_SECURE_BOOT_defconfig | 2 +- configs/T4240QDS_SRIO_PCIE_BOOT_defconfig | 2 +- configs/T4240QDS_defconfig | 1 - configs/T4240RDB_SDCARD_defconfig | 2 +- configs/T4240RDB_defconfig | 1 - doc/README.mpc85xx-sd-spi-boot | 6 - doc/README.mpc85xxads | 4 +- drivers/crypto/fsl/jr.c | 2 +- drivers/ddr/fsl/ctrl_regs.c | 2 +- drivers/ddr/fsl/mpc85xx_ddr_gen1.c | 2 +- drivers/input/keyboard.c | 4 +- drivers/net/fm/Makefile | 34 +-- drivers/net/fm/b4860.c | 7 +- drivers/net/fm/fm.h | 2 +- drivers/qe/uec.c | 10 +- include/configs/B4860QDS.h | 6 +- include/configs/BSC9131RDB.h | 3 - include/configs/BSC9132QDS.h | 4 - include/configs/C29XPCIE.h | 4 - include/configs/MPC8536DS.h | 2 - include/configs/MPC8540ADS.h | 2 - include/configs/MPC8541CDS.h | 2 - include/configs/MPC8544DS.h | 2 - include/configs/MPC8548CDS.h | 2 - include/configs/MPC8555CDS.h | 2 - include/configs/MPC8560ADS.h | 2 - include/configs/MPC8568MDS.h | 2 - include/configs/MPC8569MDS.h | 2 - include/configs/MPC8572DS.h | 2 - include/configs/MPC8610HPCD.h | 2 - include/configs/MPC8641HPCN.h | 2 - include/configs/P1010RDB.h | 23 +- include/configs/P1022DS.h | 2 - include/configs/P1023RDB.h | 1 - include/configs/P2041RDB.h | 3 - include/configs/P3041DS.h | 3 - include/configs/P4080DS.h | 3 - include/configs/P5020DS.h | 3 - include/configs/P5040DS.h | 3 - include/configs/T102xQDS.h | 2 +- include/configs/T102xRDB.h | 6 +- include/configs/T104xRDB.h | 74 +++-- include/configs/T208xQDS.h | 16 +- include/configs/T4240QDS.h | 4 +- include/configs/T4240RDB.h | 4 +- include/configs/UCP1020.h | 2 - include/configs/controlcenterd.h | 1 - include/configs/corenet_ds.h | 10 +- include/configs/cyrus.h | 8 +- include/configs/km/kmp204x-common.h | 2 - include/configs/p1_p2_rdb_pc.h | 48 ++- include/configs/p1_twr.h | 1 - include/configs/qemu-ppce500.h | 1 - include/configs/sbc8548.h | 1 - include/configs/sbc8641d.h | 1 - include/configs/socrates.h | 1 - include/configs/xpedite517x.h | 1 - include/configs/xpedite520x.h | 1 - include/configs/xpedite537x.h | 2 - include/configs/xpedite550x.h | 1 - include/fsl_sec.h | 2 +- include/keyboard.h | 4 +- scripts/config_whitelist.txt | 81 ------ tools/envcrc.c | 2 + 306 files changed, 1071 insertions(+), 1104 deletions(-)
Thanks.
York
On Tue, Nov 29, 2016 at 10:18:14PM +0000, york sun wrote:
Tom,
Thanks for doing all that Kconfig lifting, applied to u-boot/master, thanks!
york sun
