[U-Boot] [PATCH v3 1/3] armv8: ls1088a: Add NXP LS1088A SoC support
The QorIQ LS1088A processor is built on the Layerscape architecture combining eight ARM A53 processor cores with advanced, high-performance datapath acceleration and networks, peripheral interfaces required for networking, wireless infrastructure, and general-purpose embedded applications.
LS1088A is compliant to the Layerscape Chassis Generation 3.
Features summary: - Eight 32-bit / 64-bit ARM v8 Cortex-A53 CPUs - Cores are in 2 cluster of 4-cores each - Cache coherent interconnect (CCI-400) - One 64-bit DDR4 SDRAM memory controller with ECC - Data path acceleration architecture 2.0 (DPAA2) - Ethernet interfaces: SGMIIs, RGMIIs, QSGMIIs, XFIs - QSPI, IFC, 3 PCIe, 1 SATA, 2 USB, 1 SDXC, 2 DUARTs etc
Signed-off-by: Alison Wang alison.wang@nxp.com Signed-off-by: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com Signed-off-by: Ashish Kumar Ashish.Kumar@nxp.com Signed-off-by: Raghav Dogra raghav.dogra@nxp.com Signed-off-by: Shaohui Xie Shaohui.Xie@nxp.com ---
v2: Fix indentaion in commit msg Separate RDB and Si specific file Move Macros to Kconfig
v3: 1.Re-based on top of commit d529124fdcf941c34074fd1ce600f4b1b4a7dd07 Merge: f0ca30f 6a5691e Author: Tom Rini trini@konsulko.com Date: Tue Aug 8 17:06:19 2017 -0400
Merge git://git.denx.de/u-boot-x86
2.Incorporate review comments on v2 Clean up done
3.Migrate changes from ls1088ardb_stream_id.h to stream_id_lsch3.h
arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 39 ++++++- arch/arm/cpu/armv8/fsl-layerscape/Makefile | 4 + .../cpu/armv8/fsl-layerscape/fsl_lsch3_serdes.c | 10 ++ arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S | 6 +- arch/arm/cpu/armv8/fsl-layerscape/ls1088a_serdes.c | 126 +++++++++++++++++++++ arch/arm/cpu/armv8/fsl-layerscape/soc.c | 5 + arch/arm/dts/fsl-ls1088a.dtsi | 78 +++++++++++++ arch/arm/include/asm/arch-fsl-layerscape/config.h | 62 +++++++++- arch/arm/include/asm/arch-fsl-layerscape/cpu.h | 4 + .../include/asm/arch-fsl-layerscape/fsl_serdes.h | 3 +- .../include/asm/arch-fsl-layerscape/immap_lsch3.h | 11 ++ arch/arm/include/asm/arch-fsl-layerscape/soc.h | 4 + .../asm/arch-fsl-layerscape/stream_id_lsch3.h | 14 +++ drivers/ddr/fsl/util.c | 2 +- drivers/net/ldpaa_eth/Makefile | 1 + drivers/net/ldpaa_eth/ls1088a.c | 87 ++++++++++++++ 16 files changed, 447 insertions(+), 9 deletions(-) create mode 100644 arch/arm/cpu/armv8/fsl-layerscape/ls1088a_serdes.c create mode 100644 arch/arm/dts/fsl-ls1088a.dtsi create mode 100644 drivers/net/ldpaa_eth/ls1088a.c
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig index 1132969..a3c7490 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig +++ b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig @@ -49,6 +49,29 @@ config ARCH_LS1046A select BOARD_EARLY_INIT_F imply SCSI
+config ARCH_LS1088A + bool + select ARMV8_SET_SMPEN + select FSL_LSCH3 + select SYS_FSL_DDR + select SYS_FSL_DDR_LE + select SYS_FSL_DDR_VER_50 + select SYS_FSL_ERRATUM_A009803 + select SYS_FSL_ERRATUM_A009942 + select SYS_FSL_ERRATUM_A010165 + select SYS_FSL_ERRATUM_A008511 + select SYS_FSL_ERRATUM_A008850 + select SYS_FSL_HAS_CCI400 + select SYS_FSL_HAS_DDR4 + select SYS_FSL_HAS_SEC + select SYS_FSL_SEC_COMPAT_5 + select SYS_FSL_SEC_LE + select SYS_FSL_SRDS_1 + select SYS_FSL_SRDS_2 + select FSL_TZASC_1 + select ARCH_EARLY_INIT_R + select BOARD_EARLY_INIT_F + config ARCH_LS2080A bool select ARMV8_SET_SMPEN @@ -60,6 +83,7 @@ config ARCH_LS2080A select SYS_FSL_DDR select SYS_FSL_DDR_LE select SYS_FSL_DDR_VER_50 + select SYS_FSL_HAS_CCN504 select SYS_FSL_HAS_DP_DDR select SYS_FSL_HAS_SEC select SYS_FSL_HAS_DDR4 @@ -98,7 +122,7 @@ config FSL_LSCH3
config FSL_MC_ENET bool "Management Complex network" - depends on ARCH_LS2080A + depends on ARCH_LS2080A || ARCH_LS1088A default y select RESV_RAM help @@ -114,6 +138,7 @@ config FSL_PCIE_COMPAT default "fsl,ls1043a-pcie" if ARCH_LS1043A default "fsl,ls1046a-pcie" if ARCH_LS1046A default "fsl,ls2080a-pcie" if ARCH_LS2080A + default "fsl,ls1080a-pcie" if ARCH_LS1088A help This compatible is used to find pci controller node in Kernel DT to complete fixup. @@ -228,6 +253,7 @@ config MAX_CPUS default 4 if ARCH_LS1043A default 4 if ARCH_LS1046A default 16 if ARCH_LS2080A + default 8 if ARCH_LS1088A default 1 help Set this number to the maximum number of possible CPUs in the SoC. @@ -259,14 +285,17 @@ config SYS_CCI400_OFFSET
config SYS_FSL_IFC_BANK_COUNT int "Maximum banks of Integrated flash controller" - depends on ARCH_LS1043A || ARCH_LS1046A || ARCH_LS2080A + depends on ARCH_LS1043A || ARCH_LS1046A || ARCH_LS2080A || ARCH_LS1088A default 4 if ARCH_LS1043A default 4 if ARCH_LS1046A - default 8 if ARCH_LS2080A + default 8 if ARCH_LS2080A || ARCH_LS1088A
config SYS_FSL_HAS_CCI400 bool
+config SYS_FSL_HAS_CCN504 + bool + config SYS_FSL_HAS_DP_DDR bool
@@ -308,6 +337,7 @@ config SYS_FSL_PCLK_DIV int "Platform clock divider" default 1 if ARCH_LS1043A default 1 if ARCH_LS1046A + default 1 if ARCH_LS1088A default 2 help This is the divider that is used to derive Platform clock from @@ -401,7 +431,8 @@ config SYS_FSL_ERRATUM_A009929 config SYS_MC_RSV_MEM_ALIGN hex "Management Complex reserved memory alignment" depends on RESV_RAM - default 0x20000000 + default 0x20000000 if ARCH_LS2080A + default 0x70000000 if ARCH_LS1088A help Reserved memory needs to be aligned for MC to use. Default value is 512MB. diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Makefile b/arch/arm/cpu/armv8/fsl-layerscape/Makefile index e3ce018..115c3fc 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Makefile +++ b/arch/arm/cpu/armv8/fsl-layerscape/Makefile @@ -38,3 +38,7 @@ endif ifneq ($(CONFIG_ARCH_LS1046A),) obj-$(CONFIG_SYS_HAS_SERDES) += ls1046a_serdes.o endif + +ifneq ($(CONFIG_ARCH_LS1088A),) +obj-$(CONFIG_SYS_HAS_SERDES) += ls1088a_serdes.o +endif diff --git a/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_serdes.c b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_serdes.c index ef97556..13def18 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_serdes.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_serdes.c @@ -28,6 +28,11 @@ __weak void wriop_init_dpmac_qsgmii(int sd, int lane_prtcl) return; }
+__weak int serdes_get_number(int serdes, int cfg) +{ + return cfg; +} + int is_serdes_configured(enum srds_prtcl device) { int ret = 0; @@ -73,6 +78,9 @@ int serdes_get_first_lane(u32 sd, enum srds_prtcl device) printf("invalid SerDes%d\n", sd); break; } + + cfg = serdes_get_number(sd, cfg); + /* Is serdes enabled at all? */ if (cfg == 0) return -ENODEV; @@ -99,6 +107,8 @@ void serdes_init(u32 sd, u32 sd_addr, u32 rcwsr, u32 sd_prctl_mask,
cfg = gur_in32(&gur->rcwsr[rcwsr - 1]) & sd_prctl_mask; cfg >>= sd_prctl_shift; + + cfg = serdes_get_number(sd, cfg); printf("Using SERDES%d Protocol: %d (0x%x)\n", sd + 1, cfg, cfg);
if (!is_serdes_prtcl_valid(sd, cfg)) diff --git a/arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S b/arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S index 3136e3f..d943f84 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S +++ b/arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S @@ -76,7 +76,7 @@ ENTRY(lowlevel_init) switch_el x1, 1f, 100f, 100f /* skip if not in EL3 */ 1:
-#ifdef CONFIG_FSL_LSCH3 +#if defined(CONFIG_FSL_LSCH3) && defined (CONFIG_SYS_FSL_HAS_CCN504)
/* Set Wuo bit for RN-I 20 */ #ifdef CONFIG_ARCH_LS2080A @@ -338,7 +338,9 @@ get_svr: ldr x1, =FSL_LSCH3_SVR ldr w0, [x1] ret +#endif
+#ifdef CONFIG_SYS_FSL_HAS_CCN504 hnf_pstate_poll: /* x0 has the desired status, return 0 for success, 1 for timeout * clobber x1, x2, x3, x4, x6, x7 @@ -420,7 +422,7 @@ ENTRY(__asm_flush_l3_dcache) mov lr, x29 ret ENDPROC(__asm_flush_l3_dcache) -#endif +#endif /* CONFIG_SYS_FSL_HAS_CCN504 */
#ifdef CONFIG_MP /* Keep literals not used by the secondary boot code outside it */ diff --git a/arch/arm/cpu/armv8/fsl-layerscape/ls1088a_serdes.c b/arch/arm/cpu/armv8/fsl-layerscape/ls1088a_serdes.c new file mode 100644 index 0000000..9f5cdd5 --- /dev/null +++ b/arch/arm/cpu/armv8/fsl-layerscape/ls1088a_serdes.c @@ -0,0 +1,126 @@ +/* + * Copyright 2017 NXP + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/arch/fsl_serdes.h> + +struct serdes_config { + u8 ip_protocol; + u8 lanes[SRDS_MAX_LANES]; + u8 rcw_lanes[SRDS_MAX_LANES]; +}; + +static struct serdes_config serdes1_cfg_tbl[] = { + /* SerDes 1 */ + {0x12, {SGMII3, SGMII7, SGMII1, SGMII2 }, {3, 3, 3, 3 } }, + {0x15, {SGMII3, SGMII7, XFI1, XFI2 }, {3, 3, 1, 1 } }, + {0x16, {SGMII3, SGMII7, SGMII1, XFI2 }, {3, 3, 3, 1 } }, + {0x17, {SGMII3, SGMII7, SGMII1, SGMII2 }, {3, 3, 3, 2 } }, + {0x18, {SGMII3, SGMII7, SGMII1, SGMII2 }, {3, 3, 2, 2 } }, + {0x19, {SGMII3, QSGMII_B, XFI1, XFI2}, {3, 4, 1, 1 } }, + {0x1A, {SGMII3, QSGMII_B, SGMII1, XFI2 }, {3, 4, 3, 1 } }, + {0x1B, {SGMII3, QSGMII_B, SGMII1, SGMII2 }, {3, 4, 3, 2 } }, + {0x1C, {SGMII3, QSGMII_B, SGMII1, SGMII2 }, {3, 4, 2, 2 } }, + {0x1D, {QSGMII_A, QSGMII_B, XFI1, XFI2 }, {4, 4, 1, 1 } }, + {0x1E, {QSGMII_A, QSGMII_B, SGMII1, XFI2 }, {4, 4, 3, 1 } }, + {0x1F, {QSGMII_A, QSGMII_B, SGMII1, SGMII2 }, {4, 4, 3, 2 } }, + {0x20, {QSGMII_A, QSGMII_B, SGMII1, SGMII2 }, {4, 4, 2, 2 } }, + {0x35, {SGMII3, QSGMII_B, SGMII1, SGMII2 }, {3, 4, 3, 3 } }, + {0x36, {QSGMII_A, QSGMII_B, SGMII1, SGMII2 }, {4, 4, 3, 3 } }, + {0x3A, {SGMII3, PCIE1, SGMII1, SGMII2 }, {3, 5, 3, 3 } }, + {} +}; +static struct serdes_config serdes2_cfg_tbl[] = { + /* SerDes 2 */ + {0x0C, {PCIE1, PCIE1, PCIE1, PCIE1 }, {8, 8, 8, 8 } }, + {0x0D, {PCIE1, PCIE2, PCIE3, SATA1 }, {5, 5, 5, 9 } }, + {0x0E, {PCIE1, PCIE1, PCIE2, SATA1 }, {7, 7, 6, 9 } }, + {0x13, {PCIE1, PCIE1, PCIE3, PCIE3 }, {7, 7, 7, 7 } }, + {0x14, {PCIE1, PCIE2, PCIE3, PCIE3 }, {5, 5, 7, 7 } }, + {0x3C, {NONE, PCIE2, NONE, PCIE3 }, {0, 5, 0, 6 } }, + {} +}; + +static struct serdes_config *serdes_cfg_tbl[] = { + serdes1_cfg_tbl, + serdes2_cfg_tbl, +}; + +int serdes_get_number(int serdes, int cfg) +{ + struct serdes_config *ptr; + int i, j, index, lnk; + int is_found, max_lane = SRDS_MAX_LANES; + + if (serdes >= ARRAY_SIZE(serdes_cfg_tbl)) + return 0; + + ptr = serdes_cfg_tbl[serdes]; + + while (ptr->ip_protocol) { + is_found = 1; + for (i = 0, j = max_lane - 1; i < max_lane; i++, j--) { + lnk = cfg & (0xf << 4 * i); + lnk = lnk >> (4 * i); + + index = (serdes == FSL_SRDS_1) ? j : i; + + if (ptr->rcw_lanes[index] == lnk && is_found) + is_found = 1; + else + is_found = 0; + } + + if (is_found) + return ptr->ip_protocol; + ptr++; + } + + return 0; +} + +enum srds_prtcl serdes_get_prtcl(int serdes, int cfg, int lane) +{ + struct serdes_config *ptr; + + if (serdes >= ARRAY_SIZE(serdes_cfg_tbl)) + return 0; + + ptr = serdes_cfg_tbl[serdes]; + while (ptr->ip_protocol) { + if (ptr->ip_protocol == cfg) + return ptr->lanes[lane]; + ptr++; + } + + return 0; +} + +int is_serdes_prtcl_valid(int serdes, u32 prtcl) +{ + int i; + struct serdes_config *ptr; + + if (serdes >= ARRAY_SIZE(serdes_cfg_tbl)) + return 0; + + ptr = serdes_cfg_tbl[serdes]; + while (ptr->ip_protocol) { + if (ptr->ip_protocol == prtcl) + break; + ptr++; + } + + if (!ptr->ip_protocol) + return 0; + + for (i = 0; i < SRDS_MAX_LANES; i++) { + if (ptr->lanes[i] != NONE) + return 1; + } + + return 0; +} diff --git a/arch/arm/cpu/armv8/fsl-layerscape/soc.c b/arch/arm/cpu/armv8/fsl-layerscape/soc.c index ddb7d82..18820f6 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/soc.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/soc.c @@ -24,6 +24,7 @@ #ifdef CONFIG_CHAIN_OF_TRUST #include <fsl_validate.h> #endif +#include <fsl_immap.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -215,11 +216,14 @@ int sata_init(void) { struct ccsr_ahci __iomem *ccsr_ahci;
+#ifdef CONFIG_SYS_SATA2 ccsr_ahci = (void *)CONFIG_SYS_SATA2; out_le32(&ccsr_ahci->ppcfg, AHCI_PORT_PHY_1_CFG); out_le32(&ccsr_ahci->ptc, AHCI_PORT_TRANS_CFG); out_le32(&ccsr_ahci->axicc, AHCI_PORT_AXICC_CFG); +#endif
+#ifdef CONFIG_SYS_SATA1 ccsr_ahci = (void *)CONFIG_SYS_SATA1; out_le32(&ccsr_ahci->ppcfg, AHCI_PORT_PHY_1_CFG); out_le32(&ccsr_ahci->ptc, AHCI_PORT_TRANS_CFG); @@ -227,6 +231,7 @@ int sata_init(void)
ahci_init((void __iomem *)CONFIG_SYS_SATA1); scsi_scan(false); +#endif
return 0; } diff --git a/arch/arm/dts/fsl-ls1088a.dtsi b/arch/arm/dts/fsl-ls1088a.dtsi new file mode 100644 index 0000000..421d2de --- /dev/null +++ b/arch/arm/dts/fsl-ls1088a.dtsi @@ -0,0 +1,78 @@ +/* + * NXP ls1088a SOC common device tree source + * + * Copyright 2017 NXP + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/ { + compatible = "fsl,ls1088a"; + interrupt-parent = <&gic>; + #address-cells = <2>; + #size-cells = <2>; + + memory@80000000 { + device_type = "memory"; + reg = <0x00000000 0x80000000 0 0x80000000>; + /* DRAM space - 1, size : 2 GB DRAM */ + }; + + gic: interrupt-controller@6000000 { + compatible = "arm,gic-v3"; + reg = <0x0 0x06000000 0 0x10000>, /* GIC Dist */ + <0x0 0x06100000 0 0x100000>; /* GICR (RD_base + SGI_base) */ + #interrupt-cells = <3>; + interrupt-controller; + interrupts = <1 9 0x4>; + }; + + timer { + compatible = "arm,armv8-timer"; + interrupts = <1 13 0x8>, /* Physical Secure PPI, active-low */ + <1 14 0x8>, /* Physical Non-Secure PPI, active-low */ + <1 11 0x8>, /* Virtual PPI, active-low */ + <1 10 0x8>; /* Hypervisor PPI, active-low */ + }; + + serial0: serial@21c0500 { + device_type = "serial"; + compatible = "fsl,ns16550", "ns16550a"; + reg = <0x0 0x21c0500 0x0 0x100>; + clock-frequency = <0>; /* Updated by bootloader */ + interrupts = <0 32 0x1>; /* edge triggered */ + }; + + serial1: serial@21c0600 { + device_type = "serial"; + compatible = "fsl,ns16550", "ns16550a"; + reg = <0x0 0x21c0600 0x0 0x100>; + clock-frequency = <0>; /* Updated by bootloader */ + interrupts = <0 32 0x1>; /* edge triggered */ + }; + + fsl_mc: fsl-mc@80c000000 { + compatible = "fsl,qoriq-mc"; + reg = <0x00000008 0x0c000000 0 0x40>, /* MC portal base */ + <0x00000000 0x08340000 0 0x40000>; /* MC control reg */ + }; + + dspi: dspi@2100000 { + compatible = "fsl,vf610-dspi"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0x0 0x2100000 0x0 0x10000>; + interrupts = <0 26 0x4>; /* Level high type */ + num-cs = <6>; + }; + + qspi: quadspi@1550000 { + compatible = "fsl,vf610-qspi"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0x0 0x20c0000 0x0 0x10000>, + <0x0 0x20000000 0x0 0x10000000>; + reg-names = "QuadSPI", "QuadSPI-memory"; + num-cs = <4>; + }; +}; diff --git a/arch/arm/include/asm/arch-fsl-layerscape/config.h b/arch/arm/include/asm/arch-fsl-layerscape/config.h index 79e94f9..a7098be 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/config.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/config.h @@ -116,6 +116,67 @@ #define CONFIG_SYS_FSL_ERRATUM_A008751
#define CONFIG_SYS_FSL_MAX_NUM_OF_SEC 1 + +#elif defined(CONFIG_ARCH_LS1088A) +#define CONFIG_SYS_FSL_NUM_CC_PLLS 3 +#define CONFIG_SYS_FSL_CLUSTER_CLOCKS { 1, 1 } +#define CONFIG_GICV3 +#define CONFIG_FSL_TZPC_BP147 +#define CONFIG_FSL_TZASC_400 +#define CONFIG_SYS_PAGE_SIZE 0x10000 + +#define SRDS_MAX_LANES 4 + +/* TZ Protection Controller Definitions */ +#define TZPC_BASE 0x02200000 +#define TZPCR0SIZE_BASE (TZPC_BASE) +#define TZPCDECPROT_0_STAT_BASE (TZPC_BASE + 0x800) +#define TZPCDECPROT_0_SET_BASE (TZPC_BASE + 0x804) +#define TZPCDECPROT_0_CLR_BASE (TZPC_BASE + 0x808) +#define TZPCDECPROT_1_STAT_BASE (TZPC_BASE + 0x80C) +#define TZPCDECPROT_1_SET_BASE (TZPC_BASE + 0x810) +#define TZPCDECPROT_1_CLR_BASE (TZPC_BASE + 0x814) +#define TZPCDECPROT_2_STAT_BASE (TZPC_BASE + 0x818) +#define TZPCDECPROT_2_SET_BASE (TZPC_BASE + 0x81C) +#define TZPCDECPROT_2_CLR_BASE (TZPC_BASE + 0x820) + +/* Generic Interrupt Controller Definitions */ +#define GICD_BASE 0x06000000 +#define GICR_BASE 0x06100000 + +/* SMMU Defintions */ +#define SMMU_BASE 0x05000000 /* GR0 Base */ + +/* DDR */ +#define CONFIG_SYS_DDR_BLOCK1_SIZE ((phys_size_t)2 << 30) +#define CONFIG_MAX_MEM_MAPPED CONFIG_SYS_DDR_BLOCK1_SIZE + +#define CONFIG_SYS_FSL_CCSR_GUR_LE +#define CONFIG_SYS_FSL_CCSR_SCFG_LE +#define CONFIG_SYS_FSL_ESDHC_LE +#define CONFIG_SYS_FSL_IFC_LE +#define CONFIG_SYS_FSL_PEX_LUT_LE + +#define CONFIG_SYS_MEMAC_LITTLE_ENDIAN + +/* SFP */ +#define CONFIG_SYS_FSL_SFP_VER_3_4 +#define CONFIG_SYS_FSL_SFP_LE +#define CONFIG_SYS_FSL_SRK_LE + +/* Security Monitor */ +#define CONFIG_SYS_FSL_SEC_MON_LE + +/* Secure Boot */ +#define CONFIG_ESBC_HDR_LS + +/* DCFG - GUR */ +#define CONFIG_SYS_FSL_CCSR_GUR_LE +#define CONFIG_SYS_FSL_MAX_NUM_OF_SEC 1 +#define CONFIG_SYS_FSL_OCRAM_BASE 0x18000000 /* initial RAM */ +#define SYS_FSL_OCRAM_SPACE_SIZE 0x00200000 /* 2M space */ +#define CONFIG_SYS_FSL_OCRAM_SIZE 0x00020000 /* Real size 128K */ + #elif defined(CONFIG_FSL_LSCH2) #define CONFIG_SYS_FSL_OCRAM_BASE 0x10000000 /* initial RAM */ #define SYS_FSL_OCRAM_SPACE_SIZE 0x00200000 /* 2M space */ @@ -218,7 +279,6 @@ #define GICC_BASE 0x01420000
#define CONFIG_SYS_FSL_MAX_NUM_OF_SEC 1 - #else #error SoC not defined #endif diff --git a/arch/arm/include/asm/arch-fsl-layerscape/cpu.h b/arch/arm/include/asm/arch-fsl-layerscape/cpu.h index c4e5ecc..0126783 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/cpu.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/cpu.h @@ -24,6 +24,10 @@ static struct cpu_type cpu_type_list[] = { CPU_TYPE_ENTRY(LS1026A, LS1026A, 2), CPU_TYPE_ENTRY(LS2040A, LS2040A, 4), CPU_TYPE_ENTRY(LS1012A, LS1012A, 1), + CPU_TYPE_ENTRY(LS1088A, LS1088A, 8), + CPU_TYPE_ENTRY(LS1084A, LS1084A, 8), + CPU_TYPE_ENTRY(LS1048A, LS1048A, 4), + CPU_TYPE_ENTRY(LS1044A, LS1044A, 4), };
#ifndef CONFIG_SYS_DCACHE_OFF diff --git a/arch/arm/include/asm/arch-fsl-layerscape/fsl_serdes.h b/arch/arm/include/asm/arch-fsl-layerscape/fsl_serdes.h index a8f9a50..a2c7578 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/fsl_serdes.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/fsl_serdes.h @@ -9,7 +9,7 @@
#include <config.h>
-#ifdef CONFIG_ARCH_LS2080A +#ifdef CONFIG_FSL_LSCH3 enum srds_prtcl { /* * Nobody will check whether the device 'NONE' has been configured, @@ -158,6 +158,7 @@ void fsl_serdes_init(void); int serdes_get_first_lane(u32 sd, enum srds_prtcl device); enum srds_prtcl serdes_get_prtcl(int serdes, int cfg, int lane); int is_serdes_prtcl_valid(int serdes, u32 prtcl); +int serdes_get_number(int serdes, int cfg);
#ifdef CONFIG_FSL_LSCH2 const char *serdes_clock_to_string(u32 clock); diff --git a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h index 59410aa..99a7413 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h @@ -246,6 +246,17 @@ struct ccsr_gur { #define FSL_CHASSIS3_SRDS2_PRTCL_SHIFT FSL_CHASSIS3_RCWSR28_SRDS2_PRTCL_SHIFT #define FSL_CHASSIS3_SRDS1_REGSR 29 #define FSL_CHASSIS3_SRDS2_REGSR 29 +#elif defined(CONFIG_ARCH_LS1088A) +#define FSL_CHASSIS3_RCWSR29_SRDS1_PRTCL_MASK 0xFFFF0000 +#define FSL_CHASSIS3_RCWSR29_SRDS1_PRTCL_SHIFT 16 +#define FSL_CHASSIS3_RCWSR30_SRDS2_PRTCL_MASK 0x0000FFFF +#define FSL_CHASSIS3_RCWSR30_SRDS2_PRTCL_SHIFT 0 +#define FSL_CHASSIS3_SRDS1_PRTCL_MASK FSL_CHASSIS3_RCWSR29_SRDS1_PRTCL_MASK +#define FSL_CHASSIS3_SRDS1_PRTCL_SHIFT FSL_CHASSIS3_RCWSR29_SRDS1_PRTCL_SHIFT +#define FSL_CHASSIS3_SRDS2_PRTCL_MASK FSL_CHASSIS3_RCWSR30_SRDS2_PRTCL_MASK +#define FSL_CHASSIS3_SRDS2_PRTCL_SHIFT FSL_CHASSIS3_RCWSR30_SRDS2_PRTCL_SHIFT +#define FSL_CHASSIS3_SRDS1_REGSR 29 +#define FSL_CHASSIS3_SRDS2_REGSR 30 #endif #define RCW_SB_EN_REG_INDEX 9 #define RCW_SB_EN_MASK 0x00000400 diff --git a/arch/arm/include/asm/arch-fsl-layerscape/soc.h b/arch/arm/include/asm/arch-fsl-layerscape/soc.h index aeb1273..ea8aced 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/soc.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/soc.h @@ -57,6 +57,10 @@ struct cpu_type { #define SVR_LS1023A 0x879208 #define SVR_LS1046A 0x870700 #define SVR_LS1026A 0x870708 +#define SVR_LS1048A 0x870320 +#define SVR_LS1084A 0x870302 +#define SVR_LS1088A 0x870300 +#define SVR_LS1044A 0x870322 #define SVR_LS2045A 0x870120 #define SVR_LS2080A 0x870110 #define SVR_LS2085A 0x870100 diff --git a/arch/arm/include/asm/arch-fsl-layerscape/stream_id_lsch3.h b/arch/arm/include/asm/arch-fsl-layerscape/stream_id_lsch3.h index d7d527d..d1891c4 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/stream_id_lsch3.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/stream_id_lsch3.h @@ -66,12 +66,26 @@ #define FSL_USB2_STREAM_ID 2 #define FSL_SDMMC_STREAM_ID 3 #define FSL_SATA1_STREAM_ID 4 + +#if defined(CONFIG_ARCH_LS2080A) #define FSL_SATA2_STREAM_ID 5 +#endif + +#if defined(CONFIG_ARCH_LS2080A) #define FSL_DMA_STREAM_ID 6 +#elif defined(CONFIG_ARCH_LS1088A) +#define FSL_DMA_STREAM_ID 5 +#endif
/* PCI - programmed in PEXn_LUT */ #define FSL_PEX_STREAM_ID_START 7 + +#if defined(CONFIG_ARCH_LS2080A) #define FSL_PEX_STREAM_ID_END 22 +#elif defined(CONFIG_ARCH_LS1088A) +#define FSL_PEX_STREAM_ID_END 18 +#endif +
/* DPAA2 - set in MC DPC and alloced by MC */ #define FSL_DPAA2_STREAM_ID_START 23 diff --git a/drivers/ddr/fsl/util.c b/drivers/ddr/fsl/util.c index 0a305b3..d6e6e78 100644 --- a/drivers/ddr/fsl/util.c +++ b/drivers/ddr/fsl/util.c @@ -390,7 +390,7 @@ void fsl_ddr_sync_memctl_refresh(unsigned int first_ctrl,
void remove_unused_controllers(fsl_ddr_info_t *info) { -#ifdef CONFIG_FSL_LSCH3 +#ifdef CONFIG_SYS_FSL_HAS_CCN504 int i; u64 nodeid; void *hnf_sam_ctrl = (void *)(CCI_HN_F_0_BASE + CCN_HN_F_SAM_CTL); diff --git a/drivers/net/ldpaa_eth/Makefile b/drivers/net/ldpaa_eth/Makefile index 08675ec..13ecd38 100644 --- a/drivers/net/ldpaa_eth/Makefile +++ b/drivers/net/ldpaa_eth/Makefile @@ -7,3 +7,4 @@ obj-y += ldpaa_wriop.o obj-y += ldpaa_eth.o obj-$(CONFIG_ARCH_LS2080A) += ls2080a.o +obj-$(CONFIG_ARCH_LS1088A) += ls1088a.o diff --git a/drivers/net/ldpaa_eth/ls1088a.c b/drivers/net/ldpaa_eth/ls1088a.c new file mode 100644 index 0000000..703945c --- /dev/null +++ b/drivers/net/ldpaa_eth/ls1088a.c @@ -0,0 +1,87 @@ +/* + * Copyright 2017 NXP + * + * SPDX-License-Identifier: GPL-2.0+ + */ +#include <common.h> +#include <phy.h> +#include <fsl-mc/ldpaa_wriop.h> +#include <asm/io.h> +#include <asm/arch/fsl_serdes.h> + +u32 dpmac_to_devdisr[] = { + [WRIOP1_DPMAC1] = FSL_CHASSIS3_DEVDISR2_DPMAC1, + [WRIOP1_DPMAC2] = FSL_CHASSIS3_DEVDISR2_DPMAC2, + [WRIOP1_DPMAC3] = FSL_CHASSIS3_DEVDISR2_DPMAC3, + [WRIOP1_DPMAC4] = FSL_CHASSIS3_DEVDISR2_DPMAC4, + [WRIOP1_DPMAC5] = FSL_CHASSIS3_DEVDISR2_DPMAC5, + [WRIOP1_DPMAC6] = FSL_CHASSIS3_DEVDISR2_DPMAC6, + [WRIOP1_DPMAC7] = FSL_CHASSIS3_DEVDISR2_DPMAC7, + [WRIOP1_DPMAC8] = FSL_CHASSIS3_DEVDISR2_DPMAC8, + [WRIOP1_DPMAC9] = FSL_CHASSIS3_DEVDISR2_DPMAC9, + [WRIOP1_DPMAC10] = FSL_CHASSIS3_DEVDISR2_DPMAC10, +}; + +static int is_device_disabled(int dpmac_id) +{ + struct ccsr_gur __iomem *gur = (void *)CONFIG_SYS_FSL_GUTS_ADDR; + u32 devdisr2 = in_le32(&gur->devdisr2); + + return dpmac_to_devdisr[dpmac_id] & devdisr2; +} + +void wriop_dpmac_disable(int dpmac_id) +{ + struct ccsr_gur __iomem *gur = (void *)CONFIG_SYS_FSL_GUTS_ADDR; + + setbits_le32(&gur->devdisr2, dpmac_to_devdisr[dpmac_id]); +} + +void wriop_dpmac_enable(int dpmac_id) +{ + struct ccsr_gur __iomem *gur = (void *)CONFIG_SYS_FSL_GUTS_ADDR; + + clrbits_le32(&gur->devdisr2, dpmac_to_devdisr[dpmac_id]); +} + +phy_interface_t wriop_dpmac_enet_if(int dpmac_id, int lane_prtcl) +{ + enum srds_prtcl; + + if (is_device_disabled(dpmac_id + 1)) + return PHY_INTERFACE_MODE_NONE; + + switch (lane_prtcl) { + case SGMII1: + case SGMII2: + case SGMII3: + case SGMII7: + return PHY_INTERFACE_MODE_SGMII; + } + + if (lane_prtcl >= XFI1 && lane_prtcl <= XFI2) + return PHY_INTERFACE_MODE_XGMII; + + if (lane_prtcl >= QSGMII_A && lane_prtcl <= QSGMII_B) + return PHY_INTERFACE_MODE_QSGMII; + + return PHY_INTERFACE_MODE_NONE; +} + +void wriop_init_dpmac_qsgmii(int sd, int lane_prtcl) +{ + switch (lane_prtcl) { + case QSGMII_A: + wriop_init_dpmac(sd, 3, (int)lane_prtcl); + wriop_init_dpmac(sd, 4, (int)lane_prtcl); + wriop_init_dpmac(sd, 5, (int)lane_prtcl); + wriop_init_dpmac(sd, 6, (int)lane_prtcl); + break; + case QSGMII_B: + wriop_init_dpmac(sd, 7, (int)lane_prtcl); + wriop_init_dpmac(sd, 8, (int)lane_prtcl); + wriop_init_dpmac(sd, 9, (int)lane_prtcl); + wriop_init_dpmac(sd, 10, (int)lane_prtcl); + break; + } +}
LS1088A is an ARMv8 implementation. The LS1088ARDB is an evaluatoin platform that supports the LS1088A family SoCs. This patch add basic support of the platform.
Signed-off-by: Alison Wang alison.wang@nxp.com Signed-off-by: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com Signed-off-by: Ashish Kumar Ashish.Kumar@nxp.com Signed-off-by: Raghav Dogra raghav.dogra@nxp.com Signed-off-by: Shaohui Xie Shaohui.Xie@nxp.com --- v2: Fix indentaion in commit msg Separate RDB and Si specific file
2.Incorporate review comments on v2 Remove EMU support Remove RAW timings Disable default enabled CONFIG_DISPLAY_BOARDINFO and enable LATE_CONFIG_DISPLAY_BOARDINFO
3.Include PPA support
arch/arm/Kconfig | 12 ++ arch/arm/cpu/armv8/Kconfig | 1 + arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 1 + arch/arm/dts/Makefile | 3 +- arch/arm/dts/fsl-ls1088a-rdb.dts | 40 ++++ board/freescale/ls1088a/Kconfig | 15 ++ board/freescale/ls1088a/MAINTAINERS | 9 + board/freescale/ls1088a/Makefile | 9 + board/freescale/ls1088a/ddr.c | 106 ++++++++++ board/freescale/ls1088a/ddr.h | 44 ++++ board/freescale/ls1088a/eth_ls1088ardb.c | 102 +++++++++ board/freescale/ls1088a/ls1088a.c | 340 ++++++++++++++++++++++++++++++ board/freescale/ls1088a/ls1088a_qixis.h | 34 +++ configs/ls1088ardb_qspi_defconfig | 35 +++ include/configs/ls1088a_common.h | 204 ++++++++++++++++++ include/configs/ls1088ardb.h | 335 +++++++++++++++++++++++++++++ 16 files changed, 1289 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/fsl-ls1088a-rdb.dts create mode 100644 board/freescale/ls1088a/Kconfig create mode 100644 board/freescale/ls1088a/MAINTAINERS create mode 100644 board/freescale/ls1088a/Makefile create mode 100644 board/freescale/ls1088a/ddr.c create mode 100644 board/freescale/ls1088a/ddr.h create mode 100644 board/freescale/ls1088a/eth_ls1088ardb.c create mode 100644 board/freescale/ls1088a/ls1088a.c create mode 100644 board/freescale/ls1088a/ls1088a_qixis.h create mode 100644 configs/ls1088ardb_qspi_defconfig create mode 100644 include/configs/ls1088a_common.h create mode 100644 include/configs/ls1088ardb.h
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 9cfeede..dcff602 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -892,6 +892,17 @@ config TARGET_LS1012AFRDM development platform that supports the QorIQ LS1012A Layerscape Architecture processor.
+config TARGET_LS1088ARDB + bool "Support ls1088ardb" + select ARCH_LS1088A + select ARM64 + select ARMV8_MULTIENTRY + help + Support for NXP LS1088ARDB platform. + The LS1088AA Reference design board (RDB) is a high-performance + development platform that supports the QorIQ LS1088A + Layerscape Architecture processor. + config TARGET_LS1021AQDS bool "Support ls1021aqds" select BOARD_LATE_INIT @@ -1174,6 +1185,7 @@ source "board/creative/xfi3/Kconfig" source "board/freescale/ls2080a/Kconfig" source "board/freescale/ls2080aqds/Kconfig" source "board/freescale/ls2080ardb/Kconfig" +source "board/freescale/ls1088a/Kconfig" source "board/freescale/ls1021aqds/Kconfig" source "board/freescale/ls1043aqds/Kconfig" source "board/freescale/ls1021atwr/Kconfig" diff --git a/arch/arm/cpu/armv8/Kconfig b/arch/arm/cpu/armv8/Kconfig index 8e4c3dd..aecdf81 100644 --- a/arch/arm/cpu/armv8/Kconfig +++ b/arch/arm/cpu/armv8/Kconfig @@ -88,6 +88,7 @@ config PSCI_RESET depends on !ARCH_EXYNOS7 && !ARCH_BCM283X && !TARGET_LS2080A_EMU && \ !TARGET_LS2080A_SIMU && !TARGET_LS2080AQDS && \ !TARGET_LS2080ARDB && !TARGET_LS1012AQDS && \ + !TARGET_LS1088ARDB && \ !TARGET_LS1012ARDB && !TARGET_LS1012AFRDM && \ !TARGET_LS1043ARDB && !TARGET_LS1043AQDS && \ !TARGET_LS1046ARDB && !TARGET_LS1046AQDS && \ diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig index a3c7490..35f3118 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig +++ b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig @@ -207,6 +207,7 @@ config SYS_LS_PPA_FW_ADDR default 0x20400000 if SYS_LS_PPA_FW_IN_XIP && QSPI_BOOT && ARCH_LS2080A default 0x40400000 if SYS_LS_PPA_FW_IN_XIP && QSPI_BOOT default 0x580400000 if SYS_LS_PPA_FW_IN_XIP && ARCH_LS2080A + default 0x20400000 if SYS_LS_PPA_FW_IN_XIP && ARCH_LS1088A default 0x60400000 if SYS_LS_PPA_FW_IN_XIP default 0x400000 if SYS_LS_PPA_FW_IN_MMC default 0x400000 if SYS_LS_PPA_FW_IN_NAND diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index c2dc240..6f03a3f 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -188,7 +188,8 @@ dtb-$(CONFIG_ARCH_LS1021A) += ls1021a-qds-duart.dtb \ dtb-$(CONFIG_FSL_LSCH3) += fsl-ls2080a-qds.dtb \ fsl-ls2080a-rdb.dtb \ fsl-ls2081a-rdb.dtb \ - fsl-ls2088a-rdb-qspi.dtb + fsl-ls2088a-rdb-qspi.dtb \ + fsl-ls1088a-rdb.dtb dtb-$(CONFIG_FSL_LSCH2) += fsl-ls1043a-qds-duart.dtb \ fsl-ls1043a-qds-lpuart.dtb \ fsl-ls1043a-rdb.dtb \ diff --git a/arch/arm/dts/fsl-ls1088a-rdb.dts b/arch/arm/dts/fsl-ls1088a-rdb.dts new file mode 100644 index 0000000..30ceed8 --- /dev/null +++ b/arch/arm/dts/fsl-ls1088a-rdb.dts @@ -0,0 +1,40 @@ +/* + * NXP ls1088a RDB board device tree source + * + * Copyright 2017 NXP + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/dts-v1/; + +#include "fsl-ls1088a.dtsi" + +/ { + model = "NXP Layerscape 1088a RDB Board"; + compatible = "fsl,ls1088a-rdb", "fsl,ls1088a"; + aliases { + spi0 = &qspi; + }; +}; + +&qspi { + bus-num = <0>; + status = "okay"; + + qflash0: s25fs512s@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "spi-flash"; + spi-max-frequency = <50000000>; + reg = <0>; + }; + + qflash1: s25fs512s@1 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "spi-flash"; + spi-max-frequency = <50000000>; + reg = <1>; + }; +}; diff --git a/board/freescale/ls1088a/Kconfig b/board/freescale/ls1088a/Kconfig new file mode 100644 index 0000000..a4d8223 --- /dev/null +++ b/board/freescale/ls1088a/Kconfig @@ -0,0 +1,15 @@ +if TARGET_LS1088ARDB + +config SYS_BOARD + default "ls1088a" + +config SYS_VENDOR + default "freescale" + +config SYS_SOC + default "fsl-layerscape" + +config SYS_CONFIG_NAME + default "ls1088ardb" + +endif diff --git a/board/freescale/ls1088a/MAINTAINERS b/board/freescale/ls1088a/MAINTAINERS new file mode 100644 index 0000000..1abbf91 --- /dev/null +++ b/board/freescale/ls1088a/MAINTAINERS @@ -0,0 +1,9 @@ +LS1088ARDB BOARD +M: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com +M: Ashish Kumar Ashish.Kumar@nxp.com +S: Maintained +F: board/freescale/ls1088a/ +F: include/configs/ls1088ardb.h +F: configs/ls1088ardb_qspi_defconfig +F: configs/ls1088ardb_sdcard_defconfig +F: configs/ls1088ardb_sdcard_qspi_defconfig diff --git a/board/freescale/ls1088a/Makefile b/board/freescale/ls1088a/Makefile new file mode 100644 index 0000000..e997cf1 --- /dev/null +++ b/board/freescale/ls1088a/Makefile @@ -0,0 +1,9 @@ +# +# Copyright 2017 NXP +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += ls1088a.o +obj-$(CONFIG_TARGET_LS1088ARDB) += eth_ls1088ardb.o +obj-y += ddr.o diff --git a/board/freescale/ls1088a/ddr.c b/board/freescale/ls1088a/ddr.c new file mode 100644 index 0000000..f37cea0 --- /dev/null +++ b/board/freescale/ls1088a/ddr.c @@ -0,0 +1,106 @@ +/* + * Copyright 2017 NXP + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <fsl_ddr_sdram.h> +#include <fsl_ddr_dimm_params.h> +#include <asm/arch/soc.h> +#include <asm/arch/clock.h> +#include "ddr.h" + +DECLARE_GLOBAL_DATA_PTR; + +void fsl_ddr_board_options(memctl_options_t *popts, + dimm_params_t *pdimm, + unsigned int ctrl_num) +{ + const struct board_specific_parameters *pbsp, *pbsp_highest = NULL; + ulong ddr_freq; + + if (ctrl_num > 1) { + printf("Not supported controller number %d\n", ctrl_num); + return; + } + if (!pdimm->n_ranks) + return; + + /* + * we use identical timing for all slots. If needed, change the code + * to pbsp = rdimms[ctrl_num] or pbsp = udimms[ctrl_num]; + */ + pbsp = udimms[0]; + + /* Get clk_adjust, wrlvl_start, wrlvl_ctl, according to the board ddr + * freqency and n_banks specified in board_specific_parameters table. + */ + ddr_freq = get_ddr_freq(0) / 1000000; + while (pbsp->datarate_mhz_high) { + if (pbsp->n_ranks == pdimm->n_ranks) { + if (ddr_freq <= pbsp->datarate_mhz_high) { + popts->clk_adjust = pbsp->clk_adjust; + popts->wrlvl_start = pbsp->wrlvl_start; + popts->wrlvl_ctl_2 = pbsp->wrlvl_ctl_2; + popts->wrlvl_ctl_3 = pbsp->wrlvl_ctl_3; + goto found; + } + pbsp_highest = pbsp; + } + pbsp++; + } + + if (pbsp_highest) { + printf("Error: board specific timing not found for %lu MT/s\n", + ddr_freq); + printf("Trying to use the highest speed (%u) parameters\n", + pbsp_highest->datarate_mhz_high); + popts->clk_adjust = pbsp_highest->clk_adjust; + popts->wrlvl_start = pbsp_highest->wrlvl_start; + popts->wrlvl_ctl_2 = pbsp->wrlvl_ctl_2; + popts->wrlvl_ctl_3 = pbsp->wrlvl_ctl_3; + } else { + panic("DIMM is not supported by this board"); + } +found: + debug("Found timing match: n_ranks %d, data rate %d, rank_gb %d\n" + "\tclk_adjust %d, wrlvl_start %d, wrlvl_ctrl_2 0x%x, wrlvl_ctrl_3 0x%x\n", + pbsp->n_ranks, pbsp->datarate_mhz_high, pbsp->rank_gb, + pbsp->clk_adjust, pbsp->wrlvl_start, pbsp->wrlvl_ctl_2, + pbsp->wrlvl_ctl_3); + + + + popts->half_strength_driver_enable = 0; + /* + * Write leveling override + */ + popts->wrlvl_override = 1; + popts->wrlvl_sample = 0xf; + + + /* Enable ZQ calibration */ + popts->zq_en = 1; + + /* Enable DDR hashing */ + popts->addr_hash = 1; + + popts->ddr_cdr1 = DDR_CDR1_DHC_EN | DDR_CDR1_ODT(DDR_CDR_ODT_60ohm); + popts->ddr_cdr2 = DDR_CDR2_ODT(DDR_CDR_ODT_60ohm) | + DDR_CDR2_VREF_TRAIN_EN | DDR_CDR2_VREF_RANGE_2; + +} + + +int fsl_initdram() +{ + + + puts("Initializing DDR....using SPD\n"); + + gd->ram_size = fsl_ddr_sdram(); + + + return 0; +} diff --git a/board/freescale/ls1088a/ddr.h b/board/freescale/ls1088a/ddr.h new file mode 100644 index 0000000..dfcfc1f --- /dev/null +++ b/board/freescale/ls1088a/ddr.h @@ -0,0 +1,44 @@ +/* + * Copyright 2017 NXP + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __LS1088A_DDR_H__ +#define __LS1088A_DDR_H__ +struct board_specific_parameters { + u32 n_ranks; + u32 datarate_mhz_high; + u32 rank_gb; + u32 clk_adjust; + u32 wrlvl_start; + u32 wrlvl_ctl_2; + u32 wrlvl_ctl_3; +}; + +/* + * These tables contain all valid speeds we want to override with board + * specific parameters. datarate_mhz_high values need to be in ascending order + * for each n_ranks group. + */ + +static const struct board_specific_parameters udimm0[] = { + /* + * memory controller 0 + * num| hi| rank| clk| wrlvl | wrlvl | wrlvl + * ranks| mhz| GB |adjst| start | ctl2 | ctl3 + */ +#if defined(CONFIG_TARGET_LS1088ARDB) + + {2, 1666, 0, 8, 8, 0x090A0B0E, 0x0F10110D,}, + {2, 1900, 0, 4, 7, 0x09090B0D, 0x0E10120B,}, + {2, 2300, 0, 8, 9, 0x0A0C0E11, 0x1214160F,}, + {} + +#endif +}; + +static const struct board_specific_parameters *udimms[] = { + udimm0, +}; +#endif diff --git a/board/freescale/ls1088a/eth_ls1088ardb.c b/board/freescale/ls1088a/eth_ls1088ardb.c new file mode 100644 index 0000000..91f1b45 --- /dev/null +++ b/board/freescale/ls1088a/eth_ls1088ardb.c @@ -0,0 +1,102 @@ +/* + * Copyright 2017 NXP + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <command.h> +#include <netdev.h> +#include <malloc.h> +#include <fsl_mdio.h> +#include <miiphy.h> +#include <phy.h> +#include <fm_eth.h> +#include <asm/io.h> +#include <exports.h> +#include <asm/arch/fsl_serdes.h> +#include <fsl-mc/ldpaa_wriop.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define MC_BOOT_ENV_VAR "mcinitcmd" +int board_eth_init(bd_t *bis) +{ +#if defined(CONFIG_FSL_MC_ENET) + char *mc_boot_env_var; + int i, interface; + struct memac_mdio_info mdio_info; + struct mii_dev *dev; + struct ccsr_gur *gur = (void *)(CONFIG_SYS_FSL_GUTS_ADDR); + struct memac_mdio_controller *reg; + u32 srds_s1, cfg; + + cfg = in_le32(&gur->rcwsr[FSL_CHASSIS3_SRDS1_REGSR - 1]) & + FSL_CHASSIS3_SRDS1_PRTCL_MASK; + cfg >>= FSL_CHASSIS3_SRDS1_PRTCL_SHIFT; + + srds_s1 = serdes_get_number(FSL_SRDS_1, cfg); + + reg = (struct memac_mdio_controller *)CONFIG_SYS_FSL_WRIOP1_MDIO1; + mdio_info.regs = reg; + mdio_info.name = DEFAULT_WRIOP_MDIO1_NAME; + + /* Register the EMI 1 */ + fm_memac_mdio_init(bis, &mdio_info); + + reg = (struct memac_mdio_controller *)CONFIG_SYS_FSL_WRIOP1_MDIO2; + mdio_info.regs = reg; + mdio_info.name = DEFAULT_WRIOP_MDIO2_NAME; + + /* Register the EMI 2 */ + fm_memac_mdio_init(bis, &mdio_info); + + switch (srds_s1) { + case 0x1D: + /* + * XFI does not need a PHY to work, but to avoid U-boot use + * default PHY address which is zero to a MAC when it found + * a MAC has no PHY address, we give a PHY address to XFI + * MAC error. + */ + wriop_set_phy_address(WRIOP1_DPMAC1, 0x0a); + wriop_set_phy_address(WRIOP1_DPMAC2, AQ_PHY_ADDR1); + wriop_set_phy_address(WRIOP1_DPMAC3, QSGMII1_PORT1_PHY_ADDR); + wriop_set_phy_address(WRIOP1_DPMAC4, QSGMII1_PORT2_PHY_ADDR); + wriop_set_phy_address(WRIOP1_DPMAC5, QSGMII1_PORT3_PHY_ADDR); + wriop_set_phy_address(WRIOP1_DPMAC6, QSGMII1_PORT4_PHY_ADDR); + wriop_set_phy_address(WRIOP1_DPMAC7, QSGMII2_PORT1_PHY_ADDR); + wriop_set_phy_address(WRIOP1_DPMAC8, QSGMII2_PORT2_PHY_ADDR); + wriop_set_phy_address(WRIOP1_DPMAC9, QSGMII2_PORT3_PHY_ADDR); + wriop_set_phy_address(WRIOP1_DPMAC10, QSGMII2_PORT4_PHY_ADDR); + + break; + default: + printf("SerDes1 protocol 0x%x is not supported on LS1088ARDB\n", + srds_s1); + break; + } + + for (i = WRIOP1_DPMAC3; i <= WRIOP1_DPMAC10; i++) { + interface = wriop_get_enet_if(i); + switch (interface) { + case PHY_INTERFACE_MODE_QSGMII: + dev = miiphy_get_dev_by_name(DEFAULT_WRIOP_MDIO1_NAME); + wriop_set_mdio(i, dev); + break; + default: + break; + } + } + + dev = miiphy_get_dev_by_name(DEFAULT_WRIOP_MDIO2_NAME); + wriop_set_mdio(WRIOP1_DPMAC2, dev); + + mc_boot_env_var = getenv(MC_BOOT_ENV_VAR); + if (mc_boot_env_var) + run_command_list(mc_boot_env_var, -1, 0); + cpu_eth_init(bis); +#endif /* CONFIG_FMAN_ENET */ + + return pci_eth_init(bis); +} diff --git a/board/freescale/ls1088a/ls1088a.c b/board/freescale/ls1088a/ls1088a.c new file mode 100644 index 0000000..05de514 --- /dev/null +++ b/board/freescale/ls1088a/ls1088a.c @@ -0,0 +1,340 @@ +/* + * Copyright 2017 NXP + * + * SPDX-License-Identifier: GPL-2.0+ + */ +#include <common.h> +#include <i2c.h> +#include <malloc.h> +#include <errno.h> +#include <netdev.h> +#include <fsl_ifc.h> +#include <fsl_ddr.h> +#include <fsl_sec.h> +#include <asm/io.h> +#include <fdt_support.h> +#include <libfdt.h> +#include <fsl-mc/fsl_mc.h> +#include <environment.h> +#include <asm/arch-fsl-layerscape/soc.h> +#include <asm/arch/ppa.h> + +#include "../common/qixis.h" +#include "ls1088a_qixis.h" + +DECLARE_GLOBAL_DATA_PTR; + +unsigned long long get_qixis_addr(void) +{ + unsigned long long addr; + + if (gd->flags & GD_FLG_RELOC) + addr = QIXIS_BASE_PHYS; + else + addr = QIXIS_BASE_PHYS_EARLY; + + /* + * IFC address under 256MB is mapped to 0x30000000, any address above + * is mapped to 0x5_10000000 up to 4GB. + */ + addr = addr > 0x10000000 ? addr + 0x500000000ULL : addr + 0x30000000; + + return addr; +} + +int checkboard(void) +{ + char buf[64]; + u8 sw; + static const char *const freq[] = {"100", "125", "156.25", + "100 separate SSCG"}; + int clock; + + printf("Board: LS1088A-RDB, "); + + sw = QIXIS_READ(arch); + printf("Board Arch: V%d, ", sw >> 4); + printf("Board version: %c, boot from ", (sw & 0xf) + 'A' - 1); + + memset((u8 *)buf, 0x00, ARRAY_SIZE(buf)); + + sw = QIXIS_READ(brdcfg[0]); + sw = (sw & QIXIS_LBMAP_MASK) >> QIXIS_LBMAP_SHIFT; + +#ifdef CONFIG_SD_BOOT + puts("SD card\n"); +#endif + switch (sw) { + case 0: + puts("QSPI:"); + sw = QIXIS_READ(brdcfg[0]); + sw = (sw & QIXIS_QMAP_MASK) >> QIXIS_QMAP_SHIFT; + if (sw == 0 || sw == 4) + puts("0\n"); + else if (sw == 1) + puts("1\n"); + else + puts("EMU\n"); + break; + + default: + printf("invalid setting of SW%u\n", QIXIS_LBMAP_SWITCH); + break; + } + + printf("FPGA: v%d (%s), build %d", + (int)QIXIS_READ(scver), qixis_read_tag(buf), + (int)qixis_read_minor()); + /* the timestamp string contains "\n" at the end */ + printf(" on %s", qixis_read_time(buf)); + + /* + * Display the actual SERDES reference clocks as configured by the + * dip switches on the board. Note that the SWx registers could + * technically be set to force the reference clocks to match the + * values that the SERDES expects (or vice versa). For now, however, + * we just display both values and hope the user notices when they + * don't match. + */ + puts("SERDES1 Reference : "); + sw = QIXIS_READ(brdcfg[2]); + clock = (sw >> 6) & 3; + printf("Clock1 = %sMHz ", freq[clock]); + clock = (sw >> 4) & 3; + printf("Clock2 = %sMHz", freq[clock]); + + puts("\nSERDES2 Reference : "); + clock = (sw >> 2) & 3; + printf("Clock1 = %sMHz ", freq[clock]); + clock = (sw >> 0) & 3; + printf("Clock2 = %sMHz\n", freq[clock]); + + return 0; +} + +bool if_board_diff_clk(void) +{ + u8 diff_conf = QIXIS_READ(dutcfg[11]); + + return diff_conf & 0x80; +} + +unsigned long get_board_sys_clk(void) +{ + u8 sysclk_conf = QIXIS_READ(brdcfg[1]); + + switch (sysclk_conf & 0x0f) { + case QIXIS_SYSCLK_83: + return 83333333; + case QIXIS_SYSCLK_100: + return 100000000; + case QIXIS_SYSCLK_125: + return 125000000; + case QIXIS_SYSCLK_133: + return 133333333; + case QIXIS_SYSCLK_150: + return 150000000; + case QIXIS_SYSCLK_160: + return 160000000; + case QIXIS_SYSCLK_166: + return 166666666; + } + + return 66666666; +} + +unsigned long get_board_ddr_clk(void) +{ + u8 ddrclk_conf = QIXIS_READ(brdcfg[1]); + + if (if_board_diff_clk()) + return get_board_sys_clk(); + switch ((ddrclk_conf & 0x30) >> 4) { + case QIXIS_DDRCLK_100: + return 100000000; + case QIXIS_DDRCLK_125: + return 125000000; + case QIXIS_DDRCLK_133: + return 133333333; + } + + return 66666666; +} + +int select_i2c_ch_pca9547(u8 ch) +{ + int ret; + + ret = i2c_write(I2C_MUX_PCA_ADDR_PRI, 0, 1, &ch, 1); + if (ret) { + puts("PCA: failed to select proper channel\n"); + return ret; + } + + return 0; +} + +void board_retimer_init(void) +{ + u8 reg; + + /* Retimer is connected to I2C1_CH7_CH5 */ + select_i2c_ch_pca9547(I2C_MUX_CH5); + + /* Access to Control/Shared register */ + reg = 0x0; + i2c_write(I2C_RETIMER_ADDR, 0xff, 1, ®, 1); + + /* Read device revision and ID */ + i2c_read(I2C_RETIMER_ADDR, 1, 1, ®, 1); + debug("Retimer version id = 0x%x\n", reg); + + /* Enable Broadcast. All writes target all channel register sets */ + reg = 0x0c; + i2c_write(I2C_RETIMER_ADDR, 0xff, 1, ®, 1); + + /* Reset Channel Registers */ + i2c_read(I2C_RETIMER_ADDR, 0, 1, ®, 1); + reg |= 0x4; + i2c_write(I2C_RETIMER_ADDR, 0, 1, ®, 1); + + /* Enable override divider select and Enable Override Output Mux */ + i2c_read(I2C_RETIMER_ADDR, 9, 1, ®, 1); + reg |= 0x24; + i2c_write(I2C_RETIMER_ADDR, 9, 1, ®, 1); + + /* Select VCO Divider to full rate (000) */ + i2c_read(I2C_RETIMER_ADDR, 0x18, 1, ®, 1); + reg &= 0x8f; + i2c_write(I2C_RETIMER_ADDR, 0x18, 1, ®, 1); + + /* Selects active PFD MUX Input as Re-timed Data (001) */ + i2c_read(I2C_RETIMER_ADDR, 0x1e, 1, ®, 1); + reg &= 0x3f; + reg |= 0x20; + i2c_write(I2C_RETIMER_ADDR, 0x1e, 1, ®, 1); + + /* Set data rate as 10.3125 Gbps */ + reg = 0x0; + i2c_write(I2C_RETIMER_ADDR, 0x60, 1, ®, 1); + reg = 0xb0; + i2c_write(I2C_RETIMER_ADDR, 0x61, 1, ®, 1); + reg = 0x90; + i2c_write(I2C_RETIMER_ADDR, 0x62, 1, ®, 1); + reg = 0xb3; + i2c_write(I2C_RETIMER_ADDR, 0x63, 1, ®, 1); + reg = 0xcd; + i2c_write(I2C_RETIMER_ADDR, 0x64, 1, ®, 1); + + /*return the default channel*/ + select_i2c_ch_pca9547(I2C_MUX_CH_DEFAULT); +} + +int board_init(void) +{ + init_final_memctl_regs(); +#if defined(CONFIG_TARGET_LS1088ARDB) && defined(CONFIG_FSL_MC_ENET) + u32 __iomem *irq_ccsr = (u32 __iomem *)ISC_BASE; +#endif + + select_i2c_ch_pca9547(I2C_MUX_CH_DEFAULT); + board_retimer_init(); + +#ifdef CONFIG_ENV_IS_NOWHERE + gd->env_addr = (ulong)&default_environment[0]; +#endif + +#if defined(CONFIG_TARGET_LS1088ARDB) && defined(CONFIG_FSL_MC_ENET) + /* invert AQR105 IRQ pins polarity */ + out_le32(irq_ccsr + IRQCR_OFFSET / 4, AQR105_IRQ_MASK); +#endif + +#ifdef CONFIG_FSL_LS_PPA + ppa_init(); +#endif + return 0; +} + +int board_early_init_f(void) +{ + fsl_lsch3_early_init_f(); + return 0; +} + +void detail_board_ddr_info(void) +{ + puts("\nDDR "); + print_size(gd->bd->bi_dram[0].size + gd->bd->bi_dram[1].size, ""); + print_ddr_info(0); +} + +#if defined(CONFIG_ARCH_MISC_INIT) +int arch_misc_init(void) +{ +#ifdef CONFIG_FSL_CAAM + sec_init(); +#endif + return 0; +} +#endif + +#ifdef CONFIG_FSL_MC_ENET +void fdt_fixup_board_enet(void *fdt) +{ + int offset; + + offset = fdt_path_offset(fdt, "/fsl-mc"); + + if (offset < 0) + offset = fdt_path_offset(fdt, "/fsl,dprc@0"); + + if (offset < 0) { + printf("%s: ERROR: fsl-mc node not found in device tree (error %d)\n", + __func__, offset); + return; + } + + if (get_mc_boot_status() == 0) + fdt_status_okay(fdt, offset); + else + fdt_status_fail(fdt, offset); +} +#endif + +#ifdef CONFIG_OF_BOARD_SETUP +int ft_board_setup(void *blob, bd_t *bd) +{ + int err, i; + u64 base[CONFIG_NR_DRAM_BANKS]; + u64 size[CONFIG_NR_DRAM_BANKS]; + + ft_cpu_setup(blob, bd); + + /* fixup DT for the two GPP DDR banks */ + for (i = 0; i < CONFIG_NR_DRAM_BANKS; i++) { + base[i] = gd->bd->bi_dram[i].start; + size[i] = gd->bd->bi_dram[i].size; + } + +#ifdef CONFIG_RESV_RAM + /* reduce size if reserved memory is within this bank */ + if (gd->arch.resv_ram >= base[0] && + gd->arch.resv_ram < base[0] + size[0]) + size[0] = gd->arch.resv_ram - base[0]; + else if (gd->arch.resv_ram >= base[1] && + gd->arch.resv_ram < base[1] + size[1]) + size[1] = gd->arch.resv_ram - base[1]; +#endif + + fdt_fixup_memory_banks(blob, base, size, CONFIG_NR_DRAM_BANKS); + +#ifdef CONFIG_FSL_MC_ENET + fdt_fixup_board_enet(blob); + err = fsl_mc_ldpaa_exit(bd); + if (err) + return err; +#endif + + return 0; +} +#endif diff --git a/board/freescale/ls1088a/ls1088a_qixis.h b/board/freescale/ls1088a/ls1088a_qixis.h new file mode 100644 index 0000000..9757d1b --- /dev/null +++ b/board/freescale/ls1088a/ls1088a_qixis.h @@ -0,0 +1,34 @@ +/* + * Copyright 2017 NXP + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __LS1088AQDS_QIXIS_H__ +#define __LS1088AQDS_QIXIS_H__ + +/* Definitions of QIXIS Registers for LS1088AQDS */ + +/* SYSCLK */ +#define QIXIS_SYSCLK_66 0x0 +#define QIXIS_SYSCLK_83 0x1 +#define QIXIS_SYSCLK_100 0x2 +#define QIXIS_SYSCLK_125 0x3 +#define QIXIS_SYSCLK_133 0x4 +#define QIXIS_SYSCLK_150 0x5 +#define QIXIS_SYSCLK_160 0x6 +#define QIXIS_SYSCLK_166 0x7 + +/* DDRCLK */ +#define QIXIS_DDRCLK_66 0x0 +#define QIXIS_DDRCLK_100 0x1 +#define QIXIS_DDRCLK_125 0x2 +#define QIXIS_DDRCLK_133 0x3 + +/* BRDCFG2 - SD clock*/ +#define QIXIS_SDCLK1_100 0x0 +#define QIXIS_SDCLK1_125 0x1 +#define QIXIS_SDCLK1_165 0x2 +#define QIXIS_SDCLK1_100_SP 0x3 + +#endif diff --git a/configs/ls1088ardb_qspi_defconfig b/configs/ls1088ardb_qspi_defconfig new file mode 100644 index 0000000..42e0203 --- /dev/null +++ b/configs/ls1088ardb_qspi_defconfig @@ -0,0 +1,35 @@ +CONFIG_ARM=y +CONFIG_TARGET_LS1088ARDB=y +# CONFIG_SYS_MALLOC_F is not set +CONFIG_DM_SPI=y +CONFIG_DM_SPI_FLASH=y +CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1088a-rdb" +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4, QSPI_BOOT" +CONFIG_BOOTDELAY=10 +CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_DM=y +CONFIG_SPI_FLASH=y +CONFIG_NETDEVICES=y +CONFIG_E1000=y +CONFIG_SYS_NS16550=y +CONFIG_FSL_DSPI=y +CONFIG_EFI_LOADER_BOUNCE_BUFFER=y +# CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_FSL_LS_PPA=y diff --git a/include/configs/ls1088a_common.h b/include/configs/ls1088a_common.h new file mode 100644 index 0000000..442a446 --- /dev/null +++ b/include/configs/ls1088a_common.h @@ -0,0 +1,204 @@ +/* + * Copyright 2017 NXP + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __LS1088_COMMON_H +#define __LS1088_COMMON_H + + +#define CONFIG_REMAKE_ELF +#define CONFIG_FSL_LAYERSCAPE +#define CONFIG_MP + +#include <asm/arch/stream_id_lsch3.h> +#include <asm/arch/config.h> +#include <asm/arch/soc.h> + +/* Link Definitions */ +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_FSL_OCRAM_BASE + 0xfff0) + +/* We need architecture specific misc initializations */ +#define CONFIG_ARCH_MISC_INIT + +/* Link Definitions */ +#ifdef CONFIG_QSPI_BOOT +#define CONFIG_SYS_TEXT_BASE 0x20100000 +#else +#define CONFIG_SYS_TEXT_BASE 0x30100000 +#endif + +#define CONFIG_SUPPORT_RAW_INITRD + +#define CONFIG_SPI_FLASH_BAR +#define CONFIG_SKIP_LOWLEVEL_INIT + +/* Flat Device Tree Definitions */ +/* #define CONFIG_OF_LIBFDT */ + +#define CONFIG_FSL_DDR_INTERACTIVE /* Interactive debugging */ + +#define CONFIG_VERY_BIG_RAM +#define CONFIG_SYS_DDR_SDRAM_BASE 0x80000000UL +#define CONFIG_SYS_FSL_DDR_SDRAM_BASE_PHY 0 +#define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_DDR_SDRAM_BASE +#define CONFIG_SYS_DDR_BLOCK2_BASE 0x8080000000ULL +#define CONFIG_SYS_FSL_DDR_MAIN_NUM_CTRLS 1 +#define CONFIG_BOARD_LATE_INIT +/* + * SMP Definitinos + */ +#define CPU_RELEASE_ADDR secondary_boot_func + +/* Size of malloc() pool */ +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 2048 * 1024) + +/* I2C */ +#define CONFIG_SYS_I2C +#define CONFIG_SYS_I2C_MXC +#define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ +#define CONFIG_SYS_I2C_MXC_I2C2 /* enable I2C bus 2 */ +#define CONFIG_SYS_I2C_MXC_I2C3 /* enable I2C bus 3 */ +#define CONFIG_SYS_I2C_MXC_I2C4 /* enable I2C bus 4 */ + +/* Serial Port */ +#define CONFIG_CONS_INDEX 1 +#define CONFIG_SYS_NS16550_SERIAL +#define CONFIG_SYS_NS16550_REG_SIZE 1 +#define CONFIG_SYS_NS16550_CLK (get_bus_freq(0) / 2) + +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } + +/* IFC */ +#define CONFIG_FSL_IFC + +/* + * During booting, IFC is mapped at the region of 0x30000000. + * But this region is limited to 256MB. To accommodate NOR, promjet + * and FPGA. This region is divided as below: + * 0x30000000 - 0x37ffffff : 128MB : NOR flash + * 0x38000000 - 0x3BFFFFFF : 64MB : Promjet + * 0x3C000000 - 0x40000000 : 64MB : FPGA etc + * + * To accommodate bigger NOR flash and other devices, we will map IFC + * chip selects to as below: + * 0x5_1000_0000..0x5_1fff_ffff Memory Hole + * 0x5_2000_0000..0x5_3fff_ffff IFC CSx (FPGA, NAND and others 512MB) + * 0x5_4000_0000..0x5_7fff_ffff ASIC or others 1GB + * 0x5_8000_0000..0x5_bfff_ffff IFC CS0 1GB (NOR/Promjet) + * 0x5_C000_0000..0x5_ffff_ffff IFC CS1 1GB (NOR/Promjet) + * + * For e.g. NOR flash at CS0 will be mapped to 0x580000000 after relocation. + * CONFIG_SYS_FLASH_BASE has the final address (core view) + * CONFIG_SYS_FLASH_BASE_PHYS has the final address (IFC view) + * CONFIG_SYS_FLASH_BASE_PHYS_EARLY has the temporary IFC address + * CONFIG_SYS_TEXT_BASE is linked to 0x30000000 for booting + */ + +#define CONFIG_SYS_FLASH_BASE 0x580000000ULL +#define CONFIG_SYS_FLASH_BASE_PHYS 0x80000000 +#define CONFIG_SYS_FLASH_BASE_PHYS_EARLY 0x00000000 + +#define CONFIG_SYS_FLASH1_BASE_PHYS 0xC0000000 +#define CONFIG_SYS_FLASH1_BASE_PHYS_EARLY 0x8000000 + +#ifndef __ASSEMBLY__ +unsigned long long get_qixis_addr(void); +#endif + +#define QIXIS_BASE get_qixis_addr() +#define QIXIS_BASE_PHYS 0x20000000 +#define QIXIS_BASE_PHYS_EARLY 0xC000000 + + +#define CONFIG_SYS_NAND_BASE 0x530000000ULL +#define CONFIG_SYS_NAND_BASE_PHYS 0x30000000 + + +/* MC firmware */ +/* TODO Actual DPL max length needs to be confirmed with the MC FW team */ +#define CONFIG_SYS_LS_MC_DPC_MAX_LENGTH 0x20000 +#define CONFIG_SYS_LS_MC_DRAM_DPC_OFFSET 0x00F00000 +#define CONFIG_SYS_LS_MC_DPL_MAX_LENGTH 0x20000 +#define CONFIG_SYS_LS_MC_DRAM_DPL_OFFSET 0x00F20000 +#define CONFIG_SYS_LS_MC_AIOP_IMG_MAX_LENGTH 0x200000 +#define CONFIG_SYS_LS_MC_DRAM_AIOP_IMG_OFFSET 0x07000000 +/* + * Carve out a DDR region which will not be used by u-boot/Linux + * + * It will be used by MC and Debug Server. The MC region must be + * 512MB aligned, so the min size to hide is 512MB. + */ + +#if defined(CONFIG_FSL_MC_ENET) +#define CONFIG_SYS_LS_MC_DRAM_BLOCK_MIN_SIZE (512UL * 1024 * 1024) +#endif + +#define CONFIG_FSL_CAAM /* Enable SEC/CAAM */ + + +/* Miscellaneous configurable options */ +#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_DDR_SDRAM_BASE + 0x10000000) + +/* Physical Memory Map */ +#define CONFIG_CHIP_SELECTS_PER_CTRL 4 + +#define CONFIG_NR_DRAM_BANKS 2 + +#define CONFIG_HWCONFIG +#define HWCONFIG_BUFFER_SIZE 128 + +/* #define CONFIG_DISPLAY_CPUINFO */ + +/* Allow to overwrite serial and ethaddr */ +#define CONFIG_ENV_OVERWRITE + +/* Initial environment variables */ +#define CONFIG_EXTRA_ENV_SETTINGS \ + "hwconfig=fsl_ddr:bank_intlv=auto\0" \ + "loadaddr=0x80100000\0" \ + "kernel_addr=0x100000\0" \ + "ramdisk_addr=0x800000\0" \ + "ramdisk_size=0x2000000\0" \ + "fdt_high=0xa0000000\0" \ + "initrd_high=0xffffffffffffffff\0" \ + "kernel_start=0x581000000\0" \ + "kernel_load=0xa0000000\0" \ + "kernel_size=0x2800000\0" \ + "console=ttyAMA0,38400n8\0" \ + "mcinitcmd=fsl_mc start mc 0x580a00000" \ + " 0x580e00000 \0" + +#define CONFIG_BOOTARGS "console=ttyS0,115200 root=/dev/ram0 " \ + "earlycon=uart8250,mmio,0x21c0500 " \ + "ramdisk_size=0x3000000 default_hugepagesz=2m" \ + " hugepagesz=2m hugepages=256" +#if defined(CONFIG_QSPI_BOOT) +#define CONFIG_BOOTCOMMAND "sf probe 0:0;sf read 0x80200000 0xd00000 0x100000;"\ + " fsl_mc apply dpl 0x80200000 &&" \ + " sf read $kernel_load $kernel_start" \ + " $kernel_size && bootm $kernel_load" +#else /* NOR BOOT*/ +#define CONFIG_BOOTCOMMAND "fsl_mc apply dpl 0x580d00000 &&" \ + " cp.b $kernel_start $kernel_load" \ + " $kernel_size && bootm $kernel_load" +#endif + +/* Monitor Command Prompt */ +#define CONFIG_SYS_CBSIZE 512 /* Console I/O Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot args buffer */ +#define CONFIG_SYS_LONGHELP +#define CONFIG_CMDLINE_EDITING 1 +#define CONFIG_AUTO_COMPLETE +#define CONFIG_SYS_MAXARGS 64 /* max command args */ + +#define CONFIG_PANIC_HANG /* do not reset board on panic */ + +#define CONFIG_SYS_BOOTM_LEN (64 << 20) /* Increase max gunzip size */ + +#endif /* __LS1088_COMMON_H */ diff --git a/include/configs/ls1088ardb.h b/include/configs/ls1088ardb.h new file mode 100644 index 0000000..254dfaa --- /dev/null +++ b/include/configs/ls1088ardb.h @@ -0,0 +1,335 @@ +/* + * Copyright 2017 NXP + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __LS1088A_RDB_H +#define __LS1088A_RDB_H + +#include "ls1088a_common.h" + +#define CONFIG_DISPLAY_BOARDINFO_LATE + +#if defined(CONFIG_QSPI_BOOT) +#define CONFIG_ENV_IS_IN_SPI_FLASH +#define CONFIG_ENV_SIZE 0x2000 /* 8KB */ +#define CONFIG_ENV_OFFSET 0x300000 /* 3MB */ +#define CONFIG_ENV_SECT_SIZE 0x40000 +#else +#define CONFIG_ENV_IS_IN_FLASH +#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x300000) +#define CONFIG_ENV_SECT_SIZE 0x20000 +#define CONFIG_ENV_SIZE 0x20000 +#endif + +#if defined(CONFIG_QSPI_BOOT) +#define CONFIG_QIXIS_I2C_ACCESS +#define SYS_NO_FLASH +#undef CONFIG_CMD_IMLS +#endif + +#define CONFIG_SYS_CLK_FREQ 100000000 +#define CONFIG_DDR_CLK_FREQ 100000000 +#define COUNTER_FREQUENCY_REAL 25000000 /* 25MHz */ +#define COUNTER_FREQUENCY 25000000 /* 25MHz */ + +#define CONFIG_DDR_SPD +#ifdef CONFIG_EMU +#define CONFIG_SYS_FSL_DDR_EMU +#define CONFIG_SYS_MXC_I2C1_SPEED 40000000 +#define CONFIG_SYS_MXC_I2C2_SPEED 40000000 +#else +#define CONFIG_DDR_ECC +#define CONFIG_ECC_INIT_VIA_DDRCONTROLLER +#define CONFIG_MEM_INIT_VALUE 0xdeadbeef +#endif +#define SPD_EEPROM_ADDRESS 0x51 +#define CONFIG_SYS_SPD_BUS_NUM 0 /* SPD on I2C bus 0 */ +#define CONFIG_DIMM_SLOTS_PER_CTLR 1 + + +#if !defined(CONFIG_QSPI_BOOT) && !defined(CONFIG_SD_BOOT_QSPI) +#define CONFIG_SYS_NOR0_CSPR_EXT (0x0) +#define CONFIG_SYS_NOR_AMASK IFC_AMASK(128 * 1024 * 1024) +#define CONFIG_SYS_NOR_AMASK_EARLY IFC_AMASK(64 * 1024 * 1024) + +#define CONFIG_SYS_NOR0_CSPR \ + (CSPR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE_PHYS) | \ + CSPR_PORT_SIZE_16 | \ + CSPR_MSEL_NOR | \ + CSPR_V) +#define CONFIG_SYS_NOR0_CSPR_EARLY \ + (CSPR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE_PHYS_EARLY) | \ + CSPR_PORT_SIZE_16 | \ + CSPR_MSEL_NOR | \ + CSPR_V) +#define CONFIG_SYS_NOR_CSOR CSOR_NOR_ADM_SHIFT(6) +#define CONFIG_SYS_NOR_FTIM0 (FTIM0_NOR_TACSE(0x1) | \ + FTIM0_NOR_TEADC(0x1) | \ + FTIM0_NOR_TEAHC(0x1)) +#define CONFIG_SYS_NOR_FTIM1 (FTIM1_NOR_TACO(0x1) | \ + FTIM1_NOR_TRAD_NOR(0x1)) +#define CONFIG_SYS_NOR_FTIM2 (FTIM2_NOR_TCS(0x0) | \ + FTIM2_NOR_TCH(0x0) | \ + FTIM2_NOR_TWP(0x1)) +#define CONFIG_SYS_NOR_FTIM3 0x04000000 +#define CONFIG_SYS_IFC_CCR 0x01000000 + +#ifndef SYS_NO_FLASH +#define CONFIG_FLASH_CFI_DRIVER +#define CONFIG_SYS_FLASH_CFI +#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE +#define CONFIG_SYS_FLASH_QUIET_TEST +#define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */ + +#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* number of banks */ +#define CONFIG_SYS_MAX_FLASH_SECT 1024 /* sectors per device */ +#define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ +#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */ + +#define CONFIG_SYS_FLASH_EMPTY_INFO +#define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE } +#endif +#endif +#define CONFIG_NAND_FSL_IFC +#define CONFIG_SYS_NAND_MAX_ECCPOS 256 +#define CONFIG_SYS_NAND_MAX_OOBFREE 2 + +#define CONFIG_SYS_NAND_CSPR_EXT (0x0) +#define CONFIG_SYS_NAND_CSPR (CSPR_PHYS_ADDR(CONFIG_SYS_NAND_BASE_PHYS) \ + | CSPR_PORT_SIZE_8 /* Port Size = 8 bit */ \ + | CSPR_MSEL_NAND /* MSEL = NAND */ \ + | CSPR_V) +#define CONFIG_SYS_NAND_AMASK IFC_AMASK(64 * 1024) + +#define CONFIG_SYS_NAND_CSOR (CSOR_NAND_ECC_ENC_EN /* ECC on encode */ \ + | CSOR_NAND_ECC_DEC_EN /* ECC on decode */ \ + | CSOR_NAND_ECC_MODE_4 /* 4-bit ECC */ \ + | CSOR_NAND_RAL_3 /* RAL = 3Byes */ \ + | CSOR_NAND_PGS_2K /* Page Size = 2K */ \ + | CSOR_NAND_SPRZ_64/* Spare size = 64 */ \ + | CSOR_NAND_PB(64)) /*Pages Per Block = 64*/ + +#define CONFIG_SYS_NAND_ONFI_DETECTION + +/* ONFI NAND Flash mode0 Timing Params */ +#define CONFIG_SYS_NAND_FTIM0 (FTIM0_NAND_TCCST(0x07) | \ + FTIM0_NAND_TWP(0x18) | \ + FTIM0_NAND_TWCHT(0x07) | \ + FTIM0_NAND_TWH(0x0a)) +#define CONFIG_SYS_NAND_FTIM1 (FTIM1_NAND_TADLE(0x32) | \ + FTIM1_NAND_TWBE(0x39) | \ + FTIM1_NAND_TRR(0x0e) | \ + FTIM1_NAND_TRP(0x18)) +#define CONFIG_SYS_NAND_FTIM2 (FTIM2_NAND_TRAD(0x0f) | \ + FTIM2_NAND_TREH(0x0a) | \ + FTIM2_NAND_TWHRE(0x1e)) +#define CONFIG_SYS_NAND_FTIM3 0x0 + +#define CONFIG_SYS_NAND_BASE_LIST { CONFIG_SYS_NAND_BASE } +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_MTD_NAND_VERIFY_WRITE +#define CONFIG_CMD_NAND + +#define CONFIG_SYS_NAND_BLOCK_SIZE (128 * 1024) + +#define CONFIG_FSL_QIXIS +#define CONFIG_SYS_I2C_FPGA_ADDR 0x66 +#define QIXIS_LBMAP_SWITCH 2 +#define QIXIS_QMAP_MASK 0xe0 +#define QIXIS_QMAP_SHIFT 5 +#define QIXIS_LBMAP_MASK 0x1f +#define QIXIS_LBMAP_SHIFT 5 +#define QIXIS_LBMAP_DFLTBANK 0x00 +#define QIXIS_LBMAP_ALTBANK 0x20 +#define QIXIS_LBMAP_SD 0x00 +#define QIXIS_LBMAP_SD_QSPI 0x00 +#define QIXIS_LBMAP_QSPI 0x00 +#define QIXIS_RCW_SRC_SD 0x40 +#define QIXIS_RCW_SRC_QSPI 0x62 +#define QIXIS_RST_CTL_RESET 0x31 +#define QIXIS_RCFG_CTL_RECONFIG_IDLE 0x20 +#define QIXIS_RCFG_CTL_RECONFIG_START 0x21 +#define QIXIS_RCFG_CTL_WATCHDOG_ENBLE 0x08 +#define QIXIS_RST_FORCE_MEM 0x01 + +#define CONFIG_SYS_FPGA_CSPR_EXT (0x0) +#define CONFIG_SYS_FPGA_CSPR (CSPR_PHYS_ADDR(QIXIS_BASE_PHYS_EARLY) \ + | CSPR_PORT_SIZE_8 \ + | CSPR_MSEL_GPCM \ + | CSPR_V) +#define SYS_FPGA_CSPR_FINAL (CSPR_PHYS_ADDR(QIXIS_BASE_PHYS) \ + | CSPR_PORT_SIZE_8 \ + | CSPR_MSEL_GPCM \ + | CSPR_V) + +#define CONFIG_SYS_FPGA_AMASK IFC_AMASK(64*1024) +#define CONFIG_SYS_FPGA_CSOR CSOR_GPCM_ADM_SHIFT(0) +/* QIXIS Timing parameters*/ +#define SYS_FPGA_CS_FTIM0 (FTIM0_GPCM_TACSE(0x0e) | \ + FTIM0_GPCM_TEADC(0x0e) | \ + FTIM0_GPCM_TEAHC(0x0e)) +#define SYS_FPGA_CS_FTIM1 (FTIM1_GPCM_TACO(0xff) | \ + FTIM1_GPCM_TRAD(0x3f)) +#define SYS_FPGA_CS_FTIM2 (FTIM2_GPCM_TCS(0xf) | \ + FTIM2_GPCM_TCH(0xf) | \ + FTIM2_GPCM_TWP(0x3E)) +#define SYS_FPGA_CS_FTIM3 0x0 + +#if defined(CONFIG_QSPI_BOOT) || defined(CONFIG_SD_BOOT_QSPI) +#define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NAND_CSPR_EXT +#define CONFIG_SYS_CSPR0 CONFIG_SYS_NAND_CSPR +#define CONFIG_SYS_AMASK0 CONFIG_SYS_NAND_AMASK +#define CONFIG_SYS_CSOR0 CONFIG_SYS_NAND_CSOR +#define CONFIG_SYS_CS0_FTIM0 CONFIG_SYS_NAND_FTIM0 +#define CONFIG_SYS_CS0_FTIM1 CONFIG_SYS_NAND_FTIM1 +#define CONFIG_SYS_CS0_FTIM2 CONFIG_SYS_NAND_FTIM2 +#define CONFIG_SYS_CS0_FTIM3 CONFIG_SYS_NAND_FTIM3 +#define CONFIG_SYS_CSPR2_EXT CONFIG_SYS_FPGA_CSPR_EXT +#define CONFIG_SYS_CSPR2 CONFIG_SYS_FPGA_CSPR +#define CONFIG_SYS_CSPR2_FINAL SYS_FPGA_CSPR_FINAL +#define CONFIG_SYS_AMASK2 CONFIG_SYS_FPGA_AMASK +#define CONFIG_SYS_CSOR2 CONFIG_SYS_FPGA_CSOR +#define CONFIG_SYS_CS2_FTIM0 SYS_FPGA_CS_FTIM0 +#define CONFIG_SYS_CS2_FTIM1 SYS_FPGA_CS_FTIM1 +#define CONFIG_SYS_CS2_FTIM2 SYS_FPGA_CS_FTIM2 +#define CONFIG_SYS_CS2_FTIM3 SYS_FPGA_CS_FTIM3 +#else +#define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NOR0_CSPR_EXT +#define CONFIG_SYS_CSPR0 CONFIG_SYS_NOR0_CSPR_EARLY +#define CONFIG_SYS_CSPR0_FINAL CONFIG_SYS_NOR0_CSPR +#define CONFIG_SYS_AMASK0 CONFIG_SYS_NOR_AMASK +#define CONFIG_SYS_CSOR0 CONFIG_SYS_NOR_CSOR +#define CONFIG_SYS_CS0_FTIM0 CONFIG_SYS_NOR_FTIM0 +#define CONFIG_SYS_CS0_FTIM1 CONFIG_SYS_NOR_FTIM1 +#define CONFIG_SYS_CS0_FTIM2 CONFIG_SYS_NOR_FTIM2 +#define CONFIG_SYS_CS0_FTIM3 CONFIG_SYS_NOR_FTIM3 +#endif + + +/* Debug Server firmware */ +#define CONFIG_SYS_DEBUG_SERVER_FW_IN_NOR +#define CONFIG_SYS_DEBUG_SERVER_FW_ADDR 0x580D00000ULL + +#define CONFIG_SYS_LS_MC_BOOT_TIMEOUT_MS 5000 + +/* + * I2C bus multiplexer + */ +#define I2C_MUX_PCA_ADDR_PRI 0x77 +#define I2C_MUX_PCA_ADDR_SEC 0x76 /* Secondary multiplexer */ +#define I2C_RETIMER_ADDR 0x18 +#define I2C_MUX_CH_DEFAULT 0x8 +#define I2C_MUX_CH5 0xD +/* +* RTC configuration +*/ +#define RTC +#define CONFIG_RTC_PCF8563 1 +#define CONFIG_SYS_I2C_RTC_ADDR 0x51 /* Channel 3*/ +#define CONFIG_CMD_DATE + +/* EEPROM */ +#define CONFIG_ID_EEPROM +#define CONFIG_SYS_I2C_EEPROM_NXID +#define CONFIG_SYS_EEPROM_BUS_NUM 0 +#define CONFIG_SYS_I2C_EEPROM_ADDR 0x57 +#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 +#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 3 +#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 5 + +/* QSPI device */ +#if defined(CONFIG_QSPI_BOOT) +#define CONFIG_FSL_QSPI +#define CONFIG_SPI_FLASH_SPANSION +#define FSL_QSPI_FLASH_SIZE (1 << 26) +#define FSL_QSPI_FLASH_NUM 2 +/*#define CONFIG_SYS_FSL_ERRATUM_A009282 // move to layersacpe kconfig*/ +#endif + +#define CONFIG_CMD_MEMINFO +#define CONFIG_CMD_MEMTEST +#define CONFIG_SYS_MEMTEST_START 0x80000000 +#define CONFIG_SYS_MEMTEST_END 0x9fffffff +#define CONFIG_FSL_MEMAC + +/* Initial environment variables */ +#if defined(CONFIG_QSPI_BOOT) +#undef CONFIG_EXTRA_ENV_SETTINGS +#define CONFIG_EXTRA_ENV_SETTINGS \ + "hwconfig=fsl_ddr:bank_intlv=auto\0" \ + "loadaddr=0x90100000\0" \ + "kernel_addr=0x100000\0" \ + "ramdisk_addr=0x800000\0" \ + "ramdisk_size=0x2000000\0" \ + "fdt_high=0xa0000000\0" \ + "initrd_high=0xffffffffffffffff\0" \ + "kernel_start=0x1000000\0" \ + "kernel_load=0xa0000000\0" \ + "kernel_size=0x2800000\0" \ + "mcinitcmd=sf probe 0:0;sf read 0x80000000 0xA00000 0x100000;" \ + "sf read 0x80100000 0xE00000 0x100000;" \ + "fsl_mc start mc 0x80000000 0x80100000\0" \ + "mcmemsize=0x70000000 \0" +#else /* NOR_BOOT remove this for RDB*/ +#undef CONFIG_EXTRA_ENV_SETTINGS +#define CONFIG_EXTRA_ENV_SETTINGS \ + "hwconfig=fsl_ddr:bank_intlv=auto\0" \ + "loadaddr=0x90100000\0" \ + "kernel_addr=0x100000\0" \ + "ramdisk_addr=0x800000\0" \ + "ramdisk_size=0x2000000\0" \ + "fdt_high=0xa0000000\0" \ + "initrd_high=0xffffffffffffffff\0" \ + "kernel_start=0x1000000\0" \ + "kernel_load=0xa0000000\0" \ + "kernel_size=0x2800000\0" \ + "mcinitcmd=fsl_mc start mc 0x580A00000 0x580E00000\0" \ + "mcmemsize=0x70000000 \0" +#endif + +/* MAC/PHY configuration */ +#ifdef CONFIG_FSL_MC_ENET +#define CONFIG_PHYLIB_10G +#define CONFIG_PHY_GIGE +#define CONFIG_PHYLIB + +#define CONFIG_PHY_VITESSE +#define CONFIG_PHY_AQUANTIA +#define AQ_PHY_ADDR1 0x00 +#define AQR105_IRQ_MASK 0x00000004 + +#define QSGMII1_PORT1_PHY_ADDR 0x0c +#define QSGMII1_PORT2_PHY_ADDR 0x0d +#define QSGMII1_PORT3_PHY_ADDR 0x0e +#define QSGMII1_PORT4_PHY_ADDR 0x0f +#define QSGMII2_PORT1_PHY_ADDR 0x1c +#define QSGMII2_PORT2_PHY_ADDR 0x1d +#define QSGMII2_PORT3_PHY_ADDR 0x1e +#define QSGMII2_PORT4_PHY_ADDR 0x1f + +#define CONFIG_MII +#define CONFIG_ETHPRIME "DPMAC1@xgmii" +#define CONFIG_PHY_GIGE +#endif + +/* MMC */ +#ifdef CONFIG_MMC +#define CONFIG_FSL_ESDHC +#define CONFIG_SYS_FSL_MMC_HAS_CAPBLT_VS33 +#endif + +#undef CONFIG_CMDLINE_EDITING /* REMOVE this */ +#include <config_distro_defaults.h> + +#define BOOT_TARGET_DEVICES(func) \ + func(USB, usb, 0) \ + func(MMC, mmc, 0) \ + func(SCSI, scsi, 0) \ + func(DHCP, dhcp, na) +#include <config_distro_bootcmd.h> + +#include <asm/fsl_secure_boot.h> + +#endif /* __LS1088A_RDB_H */
Hi Ashish,
-----Original Message----- From: Ashish Kumar [mailto:Ashish.Kumar@nxp.com] Sent: Friday, August 11, 2017 12:54 PM To: u-boot@lists.denx.de Cc: York Sun york.sun@nxp.com; Ashish Kumar ashish.kumar@nxp.com; Alison Wang alison.wang@nxp.com; Prabhakar Kushwaha prabhakar.kushwaha@nxp.com; Raghav Dogra raghav.dogra@nxp.com; Shaohui Xie Shaohui.Xie@nxp.com Subject: [PATCH v3 2/3] armv8: ls1088ardb: Add support for LS1088ARDB platform
v3: 1.Re-based on top of commit d529124fdcf941c34074fd1ce600f4b1b4a7dd07 Merge: f0ca30f 6a5691e Author: Tom Rini trini@konsulko.com Date: Tue Aug 8 17:06:19 2017 -0400
Merge git://git.denx.de/u-boot-x86
Please add REAdME file in ls1088a providing details of board (default switch settings, boot method + xqsgmii riser card (its port vs DPMAC mapping)
--prabhakar
On 08/11/2017 12:25 AM, Ashish Kumar wrote:
The QorIQ LS1088A processor is built on the Layerscape architecture combining eight ARM A53 processor cores with advanced, high-performance datapath acceleration and networks, peripheral interfaces required for networking, wireless infrastructure, and general-purpose embedded applications.
LS1088A is compliant to the Layerscape Chassis Generation 3.
s/compliant to/compliant with/
Features summary:
- Eight 32-bit / 64-bit ARM v8 Cortex-A53 CPUs
- Cores are in 2 cluster of 4-cores each
- Cache coherent interconnect (CCI-400)
- One 64-bit DDR4 SDRAM memory controller with ECC
- Data path acceleration architecture 2.0 (DPAA2)
- Ethernet interfaces: SGMIIs, RGMIIs, QSGMIIs, XFIs
- QSPI, IFC, 3 PCIe, 1 SATA, 2 USB, 1 SDXC, 2 DUARTs etc
v2: Fix indentaion in commit msg Separate RDB and Si specific file Move Macros to Kconfig
2.Incorporate review comments on v2 Clean up done
3.Migrate changes from ls1088ardb_stream_id.h to stream_id_lsch3.h
arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 39 ++++++- arch/arm/cpu/armv8/fsl-layerscape/Makefile | 4 + .../cpu/armv8/fsl-layerscape/fsl_lsch3_serdes.c | 10 ++ arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S | 6 +- arch/arm/cpu/armv8/fsl-layerscape/ls1088a_serdes.c | 126 +++++++++++++++++++++ arch/arm/cpu/armv8/fsl-layerscape/soc.c | 5 + arch/arm/dts/fsl-ls1088a.dtsi | 78 +++++++++++++ arch/arm/include/asm/arch-fsl-layerscape/config.h | 62 +++++++++- arch/arm/include/asm/arch-fsl-layerscape/cpu.h | 4 + .../include/asm/arch-fsl-layerscape/fsl_serdes.h | 3 +- .../include/asm/arch-fsl-layerscape/immap_lsch3.h | 11 ++ arch/arm/include/asm/arch-fsl-layerscape/soc.h | 4 + .../asm/arch-fsl-layerscape/stream_id_lsch3.h | 14 +++ drivers/ddr/fsl/util.c | 2 +- drivers/net/ldpaa_eth/Makefile | 1 + drivers/net/ldpaa_eth/ls1088a.c | 87 ++++++++++++++ 16 files changed, 447 insertions(+), 9 deletions(-) create mode 100644 arch/arm/cpu/armv8/fsl-layerscape/ls1088a_serdes.c create mode 100644 arch/arm/dts/fsl-ls1088a.dtsi create mode 100644 drivers/net/ldpaa_eth/ls1088a.c
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig index 1132969..a3c7490 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig +++ b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig @@ -49,6 +49,29 @@ config ARCH_LS1046A select BOARD_EARLY_INIT_F imply SCSI
+config ARCH_LS1088A
- bool
- select ARMV8_SET_SMPEN
- select FSL_LSCH3
- select SYS_FSL_DDR
- select SYS_FSL_DDR_LE
- select SYS_FSL_DDR_VER_50
- select SYS_FSL_ERRATUM_A009803
- select SYS_FSL_ERRATUM_A009942
- select SYS_FSL_ERRATUM_A010165
- select SYS_FSL_ERRATUM_A008511
- select SYS_FSL_ERRATUM_A008850
- select SYS_FSL_HAS_CCI400
- select SYS_FSL_HAS_DDR4
- select SYS_FSL_HAS_SEC
- select SYS_FSL_SEC_COMPAT_5
- select SYS_FSL_SEC_LE
- select SYS_FSL_SRDS_1
- select SYS_FSL_SRDS_2
- select FSL_TZASC_1
- select ARCH_EARLY_INIT_R
- select BOARD_EARLY_INIT_F
- config ARCH_LS2080A bool select ARMV8_SET_SMPEN
@@ -60,6 +83,7 @@ config ARCH_LS2080A select SYS_FSL_DDR select SYS_FSL_DDR_LE select SYS_FSL_DDR_VER_50
- select SYS_FSL_HAS_CCN504 select SYS_FSL_HAS_DP_DDR select SYS_FSL_HAS_SEC select SYS_FSL_HAS_DDR4
@@ -98,7 +122,7 @@ config FSL_LSCH3
config FSL_MC_ENET bool "Management Complex network"
- depends on ARCH_LS2080A
- depends on ARCH_LS2080A || ARCH_LS1088A default y select RESV_RAM help
@@ -114,6 +138,7 @@ config FSL_PCIE_COMPAT default "fsl,ls1043a-pcie" if ARCH_LS1043A default "fsl,ls1046a-pcie" if ARCH_LS1046A default "fsl,ls2080a-pcie" if ARCH_LS2080A
- default "fsl,ls1080a-pcie" if ARCH_LS1088A
Did you intentionally use "ls1080a-pcie" here?
help This compatible is used to find pci controller node in Kernel DT to complete fixup. @@ -228,6 +253,7 @@ config MAX_CPUS default 4 if ARCH_LS1043A default 4 if ARCH_LS1046A default 16 if ARCH_LS2080A
- default 8 if ARCH_LS1088A default 1 help Set this number to the maximum number of possible CPUs in the SoC.
@@ -259,14 +285,17 @@ config SYS_CCI400_OFFSET
config SYS_FSL_IFC_BANK_COUNT int "Maximum banks of Integrated flash controller"
- depends on ARCH_LS1043A || ARCH_LS1046A || ARCH_LS2080A
- depends on ARCH_LS1043A || ARCH_LS1046A || ARCH_LS2080A || ARCH_LS1088A default 4 if ARCH_LS1043A default 4 if ARCH_LS1046A
- default 8 if ARCH_LS2080A
default 8 if ARCH_LS2080A || ARCH_LS1088A
config SYS_FSL_HAS_CCI400 bool
+config SYS_FSL_HAS_CCN504
- bool
- config SYS_FSL_HAS_DP_DDR bool
@@ -308,6 +337,7 @@ config SYS_FSL_PCLK_DIV int "Platform clock divider" default 1 if ARCH_LS1043A default 1 if ARCH_LS1046A
- default 1 if ARCH_LS1088A default 2 help This is the divider that is used to derive Platform clock from
@@ -401,7 +431,8 @@ config SYS_FSL_ERRATUM_A009929 config SYS_MC_RSV_MEM_ALIGN hex "Management Complex reserved memory alignment" depends on RESV_RAM
- default 0x20000000
- default 0x20000000 if ARCH_LS2080A
- default 0x70000000 if ARCH_LS1088A
That's an odd alignment, isn't it? Are you sure about this?
help Reserved memory needs to be aligned for MC to use. Default value is 512MB. diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Makefile b/arch/arm/cpu/armv8/fsl-layerscape/Makefile index e3ce018..115c3fc 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Makefile +++ b/arch/arm/cpu/armv8/fsl-layerscape/Makefile @@ -38,3 +38,7 @@ endif ifneq ($(CONFIG_ARCH_LS1046A),) obj-$(CONFIG_SYS_HAS_SERDES) += ls1046a_serdes.o endif
+ifneq ($(CONFIG_ARCH_LS1088A),) +obj-$(CONFIG_SYS_HAS_SERDES) += ls1088a_serdes.o +endif diff --git a/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_serdes.c b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_serdes.c index ef97556..13def18 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_serdes.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_serdes.c @@ -28,6 +28,11 @@ __weak void wriop_init_dpmac_qsgmii(int sd, int lane_prtcl) return; }
+__weak int serdes_get_number(int serdes, int cfg) +{
- return cfg;
What number does this function return? Can you put some comments here, especially you will override it somewhere later?
int is_serdes_configured(enum srds_prtcl device) { int ret = 0; @@ -73,6 +78,9 @@ int serdes_get_first_lane(u32 sd, enum srds_prtcl device) printf("invalid SerDes%d\n", sd); break; }
- cfg = serdes_get_number(sd, cfg);
- /* Is serdes enabled at all? */ if (cfg == 0) return -ENODEV;
@@ -99,6 +107,8 @@ void serdes_init(u32 sd, u32 sd_addr, u32 rcwsr, u32 sd_prctl_mask,
cfg = gur_in32(&gur->rcwsr[rcwsr - 1]) & sd_prctl_mask; cfg >>= sd_prctl_shift;
cfg = serdes_get_number(sd, cfg); printf("Using SERDES%d Protocol: %d (0x%x)\n", sd + 1, cfg, cfg);
if (!is_serdes_prtcl_valid(sd, cfg))
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S b/arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S index 3136e3f..d943f84 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S +++ b/arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S @@ -76,7 +76,7 @@ ENTRY(lowlevel_init) switch_el x1, 1f, 100f, 100f /* skip if not in EL3 */ 1:
-#ifdef CONFIG_FSL_LSCH3 +#if defined(CONFIG_FSL_LSCH3) && defined (CONFIG_SYS_FSL_HAS_CCN504)
With the new CONFIG_SYS_FSL_HAS_CCN504, we don't need to check CONFIG_FSL_LSCH3. The code below is to deal with CCN504.
/* Set Wuo bit for RN-I 20 */ #ifdef CONFIG_ARCH_LS2080A @@ -338,7 +338,9 @@ get_svr: ldr x1, =FSL_LSCH3_SVR ldr w0, [x1] ret +#endif
+#ifdef CONFIG_SYS_FSL_HAS_CCN504 hnf_pstate_poll: /* x0 has the desired status, return 0 for success, 1 for timeout * clobber x1, x2, x3, x4, x6, x7 @@ -420,7 +422,7 @@ ENTRY(__asm_flush_l3_dcache) mov lr, x29 ret ENDPROC(__asm_flush_l3_dcache) -#endif +#endif /* CONFIG_SYS_FSL_HAS_CCN504 */
#ifdef CONFIG_MP /* Keep literals not used by the secondary boot code outside it */
York
-----Original Message----- From: Ashish Kumar [mailto:Ashish.Kumar@nxp.com] Sent: Friday, August 11, 2017 12:54 PM To: u-boot@lists.denx.de Cc: York Sun york.sun@nxp.com; Ashish Kumar ashish.kumar@nxp.com; Alison Wang alison.wang@nxp.com; Prabhakar Kushwaha prabhakar.kushwaha@nxp.com; Raghav Dogra raghav.dogra@nxp.com; Shaohui Xie Shaohui.Xie@nxp.com Subject: [PATCH v3 1/3] armv8: ls1088a: Add NXP LS1088A SoC support
Features summary:
Add SoC details in arch/arm/cpu/armv8/fsl-layerscape/doc/README.soc
- bool
- select FSL_LSCH3
config ARCH_LS2080A bool select ARMV8_SET_SMPEN @@ -60,6 +83,7 @@ config ARCH_LS2080A select SYS_FSL_DDR select SYS_FSL_DDR_LE select SYS_FSL_DDR_VER_50
- default "fsl,ls1080a-pcie" if ARCH_LS1088A help This compatible is used to find pci controller node in Kernel DT to complete fixup.
- default 8 if ARCH_LS2080A || ARCH_LS1088A
- bool
- default 0x70000000 if ARCH_LS1088A help Reserved memory needs to be aligned for MC to use. Default value is 512MB.
- return cfg;
Is it possible to put patch having CONFIG_SYS_FSL_HAS_CCN504 defined and then SoC patch
#ifdef CONFIG_MP /* Keep literals not used by the secondary boot code outside it */ diff --git a/arch/arm/cpu/armv8/fsl-layerscape/ls1088a_serdes.c b/arch/arm/cpu/armv8/fsl-layerscape/ls1088a_serdes.c new file mode 100644 index 0000000..9f5cdd5 --- /dev/null +++ b/arch/arm/cpu/armv8/fsl-layerscape/ls1088a_serdes.c @@ -0,0 +1,126 @@ +/*
- Copyright 2017 NXP
+#include <common.h> +#include <asm/arch/fsl_serdes.h>
+struct serdes_config {
- u8 ip_protocol;
- u8 lanes[SRDS_MAX_LANES];
- u8 rcw_lanes[SRDS_MAX_LANES];
+static struct serdes_config serdes1_cfg_tbl[] = {
- /* SerDes 1 */
- {0x12, {SGMII3, SGMII7, SGMII1, SGMII2 }, {3, 3, 3, 3 } },
- {0x15, {SGMII3, SGMII7, XFI1, XFI2 }, {3, 3, 1, 1 } },
- {0x16, {SGMII3, SGMII7, SGMII1, XFI2 }, {3, 3, 3, 1 } },
- {0x17, {SGMII3, SGMII7, SGMII1, SGMII2 }, {3, 3, 3, 2 } },
- {0x18, {SGMII3, SGMII7, SGMII1, SGMII2 }, {3, 3, 2, 2 } },
- {0x19, {SGMII3, QSGMII_B, XFI1, XFI2}, {3, 4, 1, 1 } },
- {0x1A, {SGMII3, QSGMII_B, SGMII1, XFI2 }, {3, 4, 3, 1 } },
- {0x1B, {SGMII3, QSGMII_B, SGMII1, SGMII2 }, {3, 4, 3, 2 } },
- {0x1C, {SGMII3, QSGMII_B, SGMII1, SGMII2 }, {3, 4, 2, 2 } },
- {0x1D, {QSGMII_A, QSGMII_B, XFI1, XFI2 }, {4, 4, 1, 1 } },
- {0x1E, {QSGMII_A, QSGMII_B, SGMII1, XFI2 }, {4, 4, 3, 1 } },
- {0x1F, {QSGMII_A, QSGMII_B, SGMII1, SGMII2 }, {4, 4, 3, 2 } },
- {0x20, {QSGMII_A, QSGMII_B, SGMII1, SGMII2 }, {4, 4, 2, 2 } },
- {0x35, {SGMII3, QSGMII_B, SGMII1, SGMII2 }, {3, 4, 3, 3 } },
- {0x36, {QSGMII_A, QSGMII_B, SGMII1, SGMII2 }, {4, 4, 3, 3 } },
- {0x3A, {SGMII3, PCIE1, SGMII1, SGMII2 }, {3, 5, 3, 3 } },
+}; +static struct serdes_config serdes2_cfg_tbl[] = {
- /* SerDes 2 */
- {0x0C, {PCIE1, PCIE1, PCIE1, PCIE1 }, {8, 8, 8, 8 } },
- {0x0D, {PCIE1, PCIE2, PCIE3, SATA1 }, {5, 5, 5, 9 } },
- {0x0E, {PCIE1, PCIE1, PCIE2, SATA1 }, {7, 7, 6, 9 } },
- {0x13, {PCIE1, PCIE1, PCIE3, PCIE3 }, {7, 7, 7, 7 } },
- {0x14, {PCIE1, PCIE2, PCIE3, PCIE3 }, {5, 5, 7, 7 } },
- {0x3C, {NONE, PCIE2, NONE, PCIE3 }, {0, 5, 0, 6 } },
+static struct serdes_config *serdes_cfg_tbl[] = {
- serdes1_cfg_tbl,
- serdes2_cfg_tbl,
+int serdes_get_number(int serdes, int cfg) +{
- struct serdes_config *ptr;
- int i, j, index, lnk;
- int is_found, max_lane = SRDS_MAX_LANES;
- if (serdes >= ARRAY_SIZE(serdes_cfg_tbl))
- ptr = serdes_cfg_tbl[serdes];
- while (ptr->ip_protocol) {
is_found = 1;
for (i = 0, j = max_lane - 1; i < max_lane; i++, j--) {
lnk = cfg & (0xf << 4 * i);
lnk = lnk >> (4 * i);
index = (serdes == FSL_SRDS_1) ? j : i;
if (ptr->rcw_lanes[index] == lnk && is_found)
is_found = 1;
else
is_found = 0;
if (is_found)
return ptr->ip_protocol;
ptr++;
+enum srds_prtcl serdes_get_prtcl(int serdes, int cfg, int lane) +{
if (ptr->ip_protocol == cfg)
return ptr->lanes[lane];
ptr++;
+int is_serdes_prtcl_valid(int serdes, u32 prtcl) +{
- int i;
if (ptr->ip_protocol == prtcl)
break;
ptr++;
- if (!ptr->ip_protocol)
- for (i = 0; i < SRDS_MAX_LANES; i++) {
if (ptr->lanes[i] != NONE)
return 1;
+} diff --git a/arch/arm/cpu/armv8/fsl-layerscape/soc.c b/arch/arm/cpu/armv8/fsl-layerscape/soc.c index ddb7d82..18820f6 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/soc.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/soc.c @@ -24,6 +24,7 @@ #ifdef CONFIG_CHAIN_OF_TRUST #include <fsl_validate.h> #endif +#include <fsl_immap.h>
@@ -215,11 +216,14 @@ int sata_init(void) { struct ccsr_ahci __iomem *ccsr_ahci;
+#ifdef CONFIG_SYS_SATA2 ccsr_ahci = (void *)CONFIG_SYS_SATA2; out_le32(&ccsr_ahci->ppcfg, AHCI_PORT_PHY_1_CFG); out_le32(&ccsr_ahci->ptc, AHCI_PORT_TRANS_CFG); out_le32(&ccsr_ahci->axicc, AHCI_PORT_AXICC_CFG); +#endif
+#ifdef CONFIG_SYS_SATA1 ccsr_ahci = (void *)CONFIG_SYS_SATA1; out_le32(&ccsr_ahci->ppcfg, AHCI_PORT_PHY_1_CFG); out_le32(&ccsr_ahci->ptc, AHCI_PORT_TRANS_CFG); @@ -227,6 +231,7 @@ int sata_init(void)
ahci_init((void __iomem *)CONFIG_SYS_SATA1); scsi_scan(false); +#endif
CONFIG_SYS_SATA2, CONFIG_SYS_SATA1 should be separate patch. It should not part of SoC patch set.
return 0; } diff --git a/arch/arm/dts/fsl-ls1088a.dtsi b/arch/arm/dts/fsl-ls1088a.dtsi new file mode 100644 index 0000000..421d2de --- /dev/null +++ b/arch/arm/dts/fsl-ls1088a.dtsi @@ -0,0 +1,78 @@ +/*
- NXP ls1088a SOC common device tree source
- compatible = "fsl,ls1088a";
- interrupt-parent = <&gic>;
- #address-cells = <2>;
- #size-cells = <2>;
- memory@80000000 {
device_type = "memory";
reg = <0x00000000 0x80000000 0 0x80000000>;
/* DRAM space - 1, size : 2 GB DRAM */
- gic: interrupt-controller@6000000 {
compatible = "arm,gic-v3";
reg = <0x0 0x06000000 0 0x10000>, /* GIC Dist */
<0x0 0x06100000 0 0x100000>; /* GICR (RD_base +
SGI_base) */
#interrupt-cells = <3>;
interrupt-controller;
interrupts = <1 9 0x4>;
- timer {
compatible = "arm,armv8-timer";
interrupts = <1 13 0x8>, /* Physical Secure PPI, active-low */
<1 14 0x8>, /* Physical Non-Secure PPI, active-low
<1 11 0x8>, /* Virtual PPI, active-low */
<1 10 0x8>; /* Hypervisor PPI, active-low */
- serial0: serial@21c0500 {
device_type = "serial";
compatible = "fsl,ns16550", "ns16550a";
reg = <0x0 0x21c0500 0x0 0x100>;
clock-frequency = <0>; /* Updated by bootloader */
interrupts = <0 32 0x1>; /* edge triggered */
- serial1: serial@21c0600 {
reg = <0x0 0x21c0600 0x0 0x100>;
- fsl_mc: fsl-mc@80c000000 {
compatible = "fsl,qoriq-mc";
reg = <0x00000008 0x0c000000 0 0x40>, /* MC portal base */
<0x00000000 0x08340000 0 0x40000>; /* MC control reg */
- dspi: dspi@2100000 {
compatible = "fsl,vf610-dspi";
#size-cells = <0>;
reg = <0x0 0x2100000 0x0 0x10000>;
interrupts = <0 26 0x4>; /* Level high type */
num-cs = <6>;
- qspi: quadspi@1550000 {
compatible = "fsl,vf610-qspi";
#size-cells = <0>;
reg = <0x0 0x20c0000 0x0 0x10000>,
<0x0 0x20000000 0x0 0x10000000>;
reg-names = "QuadSPI", "QuadSPI-memory";
num-cs = <4>;
+}; diff --git a/arch/arm/include/asm/arch-fsl-layerscape/config.h b/arch/arm/include/asm/arch-fsl-layerscape/config.h index 79e94f9..a7098be 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/config.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/config.h @@ -116,6 +116,67 @@ #define CONFIG_SYS_FSL_ERRATUM_A008751
#define CONFIG_SYS_FSL_MAX_NUM_OF_SEC 1
+#elif defined(CONFIG_ARCH_LS1088A) +#define CONFIG_SYS_FSL_NUM_CC_PLLS 3 +#define CONFIG_SYS_FSL_CLUSTER_CLOCKS { 1, 1 } +#define CONFIG_GICV3 +#define CONFIG_FSL_TZPC_BP147 +#define CONFIG_FSL_TZASC_400 +#define CONFIG_SYS_PAGE_SIZE 0x10000
+#define SRDS_MAX_LANES 4
+/* TZ Protection Controller Definitions */ +#define TZPC_BASE 0x02200000 +#define TZPCR0SIZE_BASE (TZPC_BASE) +#define TZPCDECPROT_0_STAT_BASE (TZPC_BASE + 0x800) +#define TZPCDECPROT_0_SET_BASE (TZPC_BASE + 0x804) +#define TZPCDECPROT_0_CLR_BASE (TZPC_BASE + 0x808) +#define TZPCDECPROT_1_STAT_BASE (TZPC_BASE + 0x80C) +#define TZPCDECPROT_1_SET_BASE (TZPC_BASE + 0x810) +#define TZPCDECPROT_1_CLR_BASE (TZPC_BASE + 0x814) +#define TZPCDECPROT_2_STAT_BASE (TZPC_BASE + 0x818) +#define TZPCDECPROT_2_SET_BASE (TZPC_BASE + 0x81C) +#define TZPCDECPROT_2_CLR_BASE (TZPC_BASE + 0x820)
+/* Generic Interrupt Controller Definitions */ +#define GICD_BASE 0x06000000 +#define GICR_BASE 0x06100000
+/* SMMU Defintions */ +#define SMMU_BASE 0x05000000 /* GR0 Base */
+/* DDR */ +#define CONFIG_SYS_DDR_BLOCK1_SIZE ((phys_size_t)2 << 30) +#define CONFIG_MAX_MEM_MAPPED CONFIG_SYS_DDR_BLOCK1_SIZE
+#define CONFIG_SYS_FSL_CCSR_GUR_LE +#define CONFIG_SYS_FSL_CCSR_SCFG_LE +#define CONFIG_SYS_FSL_ESDHC_LE +#define CONFIG_SYS_FSL_IFC_LE +#define CONFIG_SYS_FSL_PEX_LUT_LE
+#define CONFIG_SYS_MEMAC_LITTLE_ENDIAN
+/* SFP */ +#define CONFIG_SYS_FSL_SFP_VER_3_4 +#define CONFIG_SYS_FSL_SFP_LE +#define CONFIG_SYS_FSL_SRK_LE
+/* Security Monitor */ +#define CONFIG_SYS_FSL_SEC_MON_LE
+/* Secure Boot */ +#define CONFIG_ESBC_HDR_LS
+/* DCFG - GUR */ +#define CONFIG_SYS_FSL_CCSR_GUR_LE +#define CONFIG_SYS_FSL_MAX_NUM_OF_SEC 1 +#define CONFIG_SYS_FSL_OCRAM_BASE 0x18000000 /* initial RAM */ +#define SYS_FSL_OCRAM_SPACE_SIZE 0x00200000 /* 2M space */ +#define CONFIG_SYS_FSL_OCRAM_SIZE 0x00020000 /* Real size 128K */
Are these offset different than LS2080A, if not move these definition to common place to avoid repetition. .
--prabhakar
Ashish Kumar
Prabhakar Kushwaha
York Sun
