[U-Boot] [PATCH] x86: minnowmax: use the correct NOR in the configuration
The SPI NOR on the minnowboard max is a MICRON N25Q064A
Signed-off-by: Gabriel Huau contact@huau-gabriel.fr --- include/configs/minnowmax.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/configs/minnowmax.h b/include/configs/minnowmax.h index 3c7b266..72393fa 100644 --- a/include/configs/minnowmax.h +++ b/include/configs/minnowmax.h @@ -43,7 +43,7 @@
#define CONFIG_SCSI_DEV_LIST \ {PCI_VENDOR_ID_INTEL, PCI_DEVICE_ID_INTEL_VALLEYVIEW_SATA} -#define CONFIG_SPI_FLASH_SST +#define CONFIG_SPI_FLASH_STMICRO
#define CONFIG_MMC #define CONFIG_SDHCI
--- Added to GNATS database as unassigned-patches/141
Responsible: patch-coord Message-Id: 1429805814-1892-1-git-send-email-contact@huau-gabriel.fr In-Reply-To: References: Patch-Date: Thu Apr 23 18:16:54 +0200 2015
Hi Gabriel,
On Fri, Apr 24, 2015 at 12:16 AM, Gabriel Huau contact@huau-gabriel.fr wrote:
#define CONFIG_MMC
I think you need also update minnowmax.dts file to change the compatible string.
Regards, Bin
Hi Bin,
On 04/23/2015 08:20 PM, Bin Meng wrote:
Hi Gabriel,
#define CONFIG_MMC
Regards, Bin
Well ... I didn't see that as the NOR was still working on the board, I didn't find any reference except in the device tree for this compatible string, do you know if this is really used or not? I'll do the modification anyway, it's always better to put the correct information.
Regards, Gabriel
Hi Gabriel,
On Fri, Apr 24, 2015 at 10:42 PM, Gabriel Huau contact@huau-gabriel.fr wrote:
Hi Bin,
Hi Gabriel,
#define CONFIG_MMC
Regards, Bin
The spi flash compatible string is not used by the spi flash driver.
Yep, it is a hint for someone else to figure out what spi flash is mounted on the board.
Regards, Bin
Signed-off-by: Gabriel Huau contact@huau-gabriel.fr --- Changes for v2: - Update the dts to put the correct flash name
arch/x86/dts/minnowmax.dts | 2 +- include/configs/minnowmax.h | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/x86/dts/minnowmax.dts b/arch/x86/dts/minnowmax.dts index 3936e21..dd20b2c 100644 --- a/arch/x86/dts/minnowmax.dts +++ b/arch/x86/dts/minnowmax.dts @@ -94,7 +94,7 @@ compatible = "intel,ich"; spi-flash@0 { reg = <0>; - compatible = "sst,25vf016b", "spi-flash"; + compatible = "stmicro,n25q064a", "spi-flash"; memory-map = <0xff800000 0x00800000>; }; }; diff --git a/include/configs/minnowmax.h b/include/configs/minnowmax.h index 3c7b266..72393fa 100644 --- a/include/configs/minnowmax.h +++ b/include/configs/minnowmax.h @@ -43,7 +43,7 @@
On Sat, Apr 25, 2015 at 11:13 PM, Gabriel Huau contact@huau-gabriel.fr wrote:
#define CONFIG_MMC
#define CONFIG_MMC
#define CONFIG_MMC
Applied to u-boot-x86, thanks!
Wrong command ... I sent a duplicate patch v2, you can ignore this one, sorry.
Regards, Gabriel
Changes for v2:
}; };compatible = "stmicro,n25q064a", "spi-flash"; memory-map = <0xff800000 0x00800000>;
participants (5)
Bin Meng
Gabriel Huau
gabriel huau
u-boot@bugs.denx.de
