[U-Boot] [PATCH 1/2] fdt: Add fdt_fixup_nor_flash_size() to fixup NOR FLASH size in dtb
This function can be used to update the size in the "reg" property of the NOR FLASH device nodes. This is necessary for boards with non-fixed NOR FLASH sizes.
Signed-off-by: Stefan Roese sr@denx.de Cc: Wolfgang Denk wd@denx.de Cc: Gerald Van Baren vanbaren@cideas.com --- common/fdt_support.c | 44 ++++++++++++++++++++++++++++++++++++++++++++ include/fdt_support.h | 2 ++ 2 files changed, 46 insertions(+), 0 deletions(-)
diff --git a/common/fdt_support.c b/common/fdt_support.c index 89164a1..40ff00a 100644 --- a/common/fdt_support.c +++ b/common/fdt_support.c @@ -692,3 +692,47 @@ int fdt_pci_dma_ranges(void *blob, int phb_off, struct pci_controller *hose) { return 0; } #endif + +#ifdef CONFIG_FDT_FIXUP_NOR_FLASH_SIZE +/* + * This function can be used to update the size in the "reg" property + * of the NOR FLASH device nodes. This is necessary for boards with + * non-fixed NOR FLASH sizes. + */ +int fdt_fixup_nor_flash_size(void *blob, int cs, u32 size) +{ + char compat[][16] = { "cfi-flash", "jedec-flash" }; + int off; + int len; + struct fdt_property *prop; + u32 *reg; + int i; + + for (i = 0; i < 2; i++) { + off = fdt_node_offset_by_compatible(blob, -1, compat[i]); + while (off != -FDT_ERR_NOTFOUND) { + /* + * Found one compatible node, now check if this one + * has the correct CS + */ + prop = fdt_get_property_w(blob, off, "reg", &len); + if (prop) { + reg = (u32 *)&prop->data[0]; + if (reg[0] == cs) { + reg[2] = size; + fdt_setprop(blob, off, "reg", reg, + 3 * sizeof(u32)); + + return 0; + } + } + + /* Move to next compatible node */ + off = fdt_node_offset_by_compatible(blob, off, + compat[i]); + } + } + + return -1; +} +#endif diff --git a/include/fdt_support.h b/include/fdt_support.h index 16734c5..0a9dd0d 100644 --- a/include/fdt_support.h +++ b/include/fdt_support.h @@ -79,5 +79,7 @@ void ft_pci_setup(void *blob, bd_t *bd); void set_working_fdt_addr(void *addr); int fdt_resize(void *blob);
+int fdt_fixup_nor_flash_size(void *blob, int cs, u32 size); + #endif /* ifdef CONFIG_OF_LIBFDT */ #endif /* ifndef __FDT_SUPPORT_H */
Hi Stefan, Wolfgang,
Looking at the code, I'm OK with it.
Are you looking to get this into the current release (v2009.11) as a bugfix or the next release (v2010.02)?
If you need it in the v2009.11 release, you have my Acked-by Gerald Van Baren vanbaren@cideas.com and I suggest you run it through the ppc4xx repository with its sister patch.
Thanks, gvb
Dear Jerry Van Baren,
I consider it a bug fix, as failing to adjust the flash size prevents booting on some boards where the real flash size deviates from the entry in the default DT in the Linux kernel.
Thanks.
Stefan - also
Acked-by: Wolfgang Denk wd@denx.de
Thanks.
Stefan - also
Thanks. I'll integrate this and other patches into the ppc4xx repository and send a pull request later today.
Cheers, Stefan
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-0 Fax: (+49)-8142-66989-80 Email: office@denx.de
Applied to u-boot-ppc4xx/master. Thanks.
Cheers, Stefan
Jerry Van Baren
Stefan Roese
