[U-Boot] [PATCH] powerpc/85xx: Don't set FT_FSL_PCI_SETUP if CONFIG_PCI is not set
A lot of boards set FT_FSL_PCI_SETUP directly in their board code and don't check to see if CONFIG_PCI is actually defined. This will cause the board compilation to fail if CONFIG_PCI is not defined. The p1022ds board is one such example.
Instead of fixing every board this patch wraps FT_FSL_PCI_SETUP around CONFIG_PCI so we can remove CONFIG_PCI and boards will still build properly.
cc: Kumar Gala kumar.gala@freescale.com Signed-off-by: Matthew McClintock msm@freescale.com --- arch/powerpc/include/asm/fsl_pci.h | 4 +++- 1 files changed, 3 insertions(+), 1 deletions(-)
diff --git a/arch/powerpc/include/asm/fsl_pci.h b/arch/powerpc/include/asm/fsl_pci.h index 82d75be..fc47a9f 100644 --- a/arch/powerpc/include/asm/fsl_pci.h +++ b/arch/powerpc/include/asm/fsl_pci.h @@ -230,7 +230,9 @@ int fsl_pcie_init_board(int busno); #define FT_FSL_PCIE3_SETUP __FT_FSL_PCIE_SETUP(blob, FSL_PCIE_COMPAT, 3) #define FT_FSL_PCIE4_SETUP __FT_FSL_PCIE_SETUP(blob, FSL_PCIE_COMPAT, 4)
-#if defined(CONFIG_FSL_CORENET) +#if !defined(CONFIG_PCI) +#define FT_FSL_PCI_SETUP +#elif defined(CONFIG_FSL_CORENET) #define FSL_PCIE_COMPAT "fsl,p4080-pcie" #define FT_FSL_PCI_SETUP \ FT_FSL_PCIE1_SETUP; \
applied to 85xx
- k
Kumar Gala
Matthew McClintock
