[PATCH v2] rng: Add Turris Mox rWTM RNG driver
A RNG driver for Armada 3720 boards running the Turris Mox rWTM firmware from CZ.NIC in the secure processor.
Signed-off-by: Max Resch resch.max@gmail.com ---
Changes in v2: - Removed ring buffer implementation
drivers/rng/Kconfig | 8 +++ drivers/rng/Makefile | 1 + drivers/rng/turris_rwtm_rng.c | 122 ++++++++++++++++++++++++++++++++++ 3 files changed, 131 insertions(+) create mode 100644 drivers/rng/turris_rwtm_rng.c
diff --git a/drivers/rng/Kconfig b/drivers/rng/Kconfig index a89c899568..cd72852a47 100644 --- a/drivers/rng/Kconfig +++ b/drivers/rng/Kconfig @@ -105,4 +105,12 @@ config RNG_JH7110 help Enable True Random Number Generator in StarFive JH7110 SoCs.
+config RNG_TURRIS_RWTM + bool "Turris Mox TRNG in Secure Processor" + depends on DM_RNG && ARMADA_3700 + help + Use TRNG in Turris Mox Secure Processor Firmware. Can be used + on other Armada-3700 devices (like EspressoBin) if Secure + Firmware from CZ.NIC is used. + endif diff --git a/drivers/rng/Makefile b/drivers/rng/Makefile index 7e64c4cdfc..ecae1a3da3 100644 --- a/drivers/rng/Makefile +++ b/drivers/rng/Makefile @@ -17,3 +17,4 @@ obj-$(CONFIG_RNG_SMCCC_TRNG) += smccc_trng.o obj-$(CONFIG_RNG_ARM_RNDR) += arm_rndr.o obj-$(CONFIG_TPM_RNG) += tpm_rng.o obj-$(CONFIG_RNG_JH7110) += jh7110_rng.o +obj-$(CONFIG_RNG_TURRIS_RWTM) += turris_rwtm_rng.o diff --git a/drivers/rng/turris_rwtm_rng.c b/drivers/rng/turris_rwtm_rng.c new file mode 100644 index 0000000000..143fe0b47f --- /dev/null +++ b/drivers/rng/turris_rwtm_rng.c @@ -0,0 +1,122 @@ +// SPDX-License-Identifier: GPL-2.0-or-later OR BSD-3-Clause +/* + * Copyright (c) 2024, Max Resch + */ + +#include <dm.h> +#include <malloc.h> +#include <rng.h> +#include <asm/dma-mapping.h> +#include <asm/types.h> +#include <mach/mbox.h> + +/* size of entropy buffer */ +#define RNG_BUFFER_SIZE 128U + +struct turris_rwtm_rng_priv { + phys_addr_t buffer; +}; + +static int turris_rwtm_rng_fill_entropy(phys_addr_t entropy, size_t size) +{ + u32 args[3] = { 1, (u32)entropy, size }; + int ret; + + /* flush data cache */ + flush_dcache_range(entropy, entropy + size); + + /* + * get entropy + * args[0] = 1 copies BYTES array in args[1] of length args[2] + */ + ret = mbox_do_cmd(MBOX_CMD_GET_RANDOM, args, 3, NULL, 0); + if (ret < 0) + return ret; + + /* invalidate data cache */ + invalidate_dcache_range(entropy, entropy + size); + + return 0; +} + +static int turris_rwtm_rng_random_read(struct udevice *dev, void *data, size_t count) +{ + phys_addr_t p; + size_t size; + int ret; + + p = ((struct turris_rwtm_rng_priv *)dev_get_priv(dev))->buffer; + + while (count) { + size = min_t(size_t, RNG_BUFFER_SIZE, count); + + ret = turris_rwtm_rng_fill_entropy(p, size); + + memcpy(data, (void *)p, size); + count -= size; + data = (u8 *)data + size; + } + + return 0; +} + +static int turris_rwtm_rng_probe(struct udevice *dev) +{ + struct turris_rwtm_rng_priv *priv; + u32 args[] = { 0 }; + int ret; + + /* + * check if the random command is supported + * args[0] = 0 would copy 16 DWORDS entropy to out but we ignore them + */ + ret = mbox_do_cmd(MBOX_CMD_GET_RANDOM, args, ARRAY_SIZE(args), NULL, 0); + + if (ret < 0) + return ret; + + /* entropy buffer */ + priv = (struct turris_rwtm_rng_priv *)dev_get_priv(dev); + priv->buffer = 0; + + /* buffer address need to be aligned */ + dma_alloc_coherent(RNG_BUFFER_SIZE, (unsigned long *)&priv->buffer); + if (!priv->buffer) + return -ENOMEM; + + return 0; +} + +static int turris_rwtm_rng_remove(struct udevice *dev) +{ + phys_addr_t p; + + p = ((struct turris_rwtm_rng_priv *)dev_get_priv(dev))->buffer; + dma_free_coherent((void *)p); + + return 0; +} + +static const struct dm_rng_ops turris_rwtm_rng_ops = { + .read = turris_rwtm_rng_random_read, +}; + +/* + * only Turris MOX firmware has the RNG but allow all probable devices to be + * probed the default firmware will just reject the probe + */ +static const struct udevice_id turris_rwtm_rng_match[] = { + { .compatible = "cznic,turris-mox-rwtm" }, + { .compatible = "marvell,armada-3700-rwtm-firmware" }, + {}, +}; + +U_BOOT_DRIVER(turris_rwtm_rng) = { + .name = "turris-rwtm-rng", + .id = UCLASS_RNG, + .of_match = turris_rwtm_rng_match, + .ops = &turris_rwtm_rng_ops, + .probe = turris_rwtm_rng_probe, + .remove = turris_rwtm_rng_remove, + .priv_auto = sizeof(struct turris_rwtm_rng_priv), +};
Hello Max,
Out of curiousity, what is your use case for having these random numbers on this platform in U-Boot?
Below are a few more things to change and then you I'll give my Reviewed-by tag.
Changes in v2:
- bool "Turris Mox TRNG in Secure Processor"
- depends on DM_RNG && ARMADA_3700
- help
- Copyright (c) 2024, Max Resch
- phys_addr_t buffer;
- u32 args[3] = { 1, (u32)entropy, size };
- int ret;
- /* flush data cache */
- flush_dcache_range(entropy, entropy + size);
* get entropy
- ret = mbox_do_cmd(MBOX_CMD_GET_RANDOM, args, 3, NULL, 0);
- if (ret < 0)
return ret;
- /* invalidate data cache */
- invalidate_dcache_range(entropy, entropy + size);
- phys_addr_t p;
- size_t size;
- int ret;
- p = ((struct turris_rwtm_rng_priv *)dev_get_priv(dev))->buffer;
Please declare
struct turris_rwtm_rng_priv *priv = dev_get_priv(dev); phys_addr_t phys; size_t size; int ret;
and then do
phys = priv->buffer;
- while (count) {
count -= size;
- struct turris_rwtm_rng_priv *priv;
- u32 args[] = { 0 };
- int ret;
- ret = mbox_do_cmd(MBOX_CMD_GET_RANDOM, args, ARRAY_SIZE(args), NULL, 0);
- if (ret < 0)
return ret;
- /* entropy buffer */
- priv = (struct turris_rwtm_rng_priv *)dev_get_priv(dev);
no need here, do it at the beginning
- priv->buffer = 0;
- /* buffer address need to be aligned */
- dma_alloc_coherent(RNG_BUFFER_SIZE, (unsigned long *)&priv->buffer);
- if (!priv->buffer)
return -ENOMEM;
- phys_addr_t p;
rename this to phys, and please do it as I described above.
- dma_free_coherent((void *)p);
Marek
Date: Mon, 5 Feb 2024 12:40:14 +0100 From: Marek Behún kabel@kernel.org
Hello Max,
It means that U-Boot will implement the EFI RNG protocol. The OpenBSD bootloader will use that to fill an initial pool of random numbers for the kernel. And the Linux kernel EFI stub uses it to do kernel address space randomization.
Cheers,
Mark
Changes in v2:
- help
- int ret;
* get entropy
- if (ret < 0)
return ret;
- phys_addr_t p;
- size_t size;
- int ret;
Please declare
and then do
- while (count) {
count -= size;
- int ret;
- if (ret < 0)
return ret;
- priv->buffer = 0;
return -ENOMEM;
- phys_addr_t p;
Marek
So you're using A3720 with OpenBSD? Can I ask which A3720 boards do you use?
Marek
On Mon, 05 Feb 2024 14:46:24 +0100 Mark Kettenis mark.kettenis@xs4all.nl wrote:
Hello Max,
Cheers,
Mark
Changes in v2:
- help
- int ret;
* get entropy
- if (ret < 0)
return ret;
- phys_addr_t p;
- size_t size;
- int ret;
Please declare
and then do
- while (count) {
count -= size;
- int ret;
- if (ret < 0)
return ret;
- priv->buffer = 0;
return -ENOMEM;
- phys_addr_t p;
Marek
Date: Mon, 5 Feb 2024 15:54:12 +0100 From: Marek Behún kabel@kernel.org
Hi Marek,
I have a Turris Mox.
Some folks run OpenBSD on the ESPRESSObin and GL.iNet Brume as well (those are A3700 of course).
Cheers,
Mark
Hello Max,
Cheers,
Mark
Changes in v2:
- help
- int ret;
* get entropy
- if (ret < 0)
return ret;
- phys_addr_t p;
- size_t size;
- int ret;
Please declare
and then do
- while (count) {
count -= size;
- int ret;
- if (ret < 0)
return ret;
- priv->buffer = 0;
return -ENOMEM;
- phys_addr_t p;
Marek
Hi there Marek,
Am 05/02/2024 um 12.40 schrieb Marek Behún:
Hello Max,
I use 2 EspressoBin (Armada 3720) as routers, both of them use the TurrisMox firmware. RNG enables the EFI RNG protocol which inturn allows systemd-boot to populate the Linux RNG EFI seed config table which enables ealy initialization of the kernel prng. The kernel also then allows the use of KASLR. When the kernel is booted up a module is available to interface with the Firmware to use the RNG directly.
Also, I'm not sure if this should be part of the patch, this could be enabled on some default configurations for the Armada 3700.
-- Max
Changes in v2:
- help
- endif
- int ret;
* get entropy
- if (ret < 0)
return ret;
- phys_addr_t p;
- size_t size;
- int ret;
Please declare
and then do
- while (count) {
count -= size;
- int ret;
- if (ret < 0)
return ret;
- priv->buffer = 0;
return -ENOMEM;
- phys_addr_t p;
Marek
Marek Behún
Mark Kettenis
Max Resch
