[U-Boot] [PATCH v3.1 03/13] rockchip: dts: rk3399: Create initial rk3399-u-boot.dtsi
u-boot,dm-pre-reloc is required for SDMMC booted rk3399 boards and which is U-Boot specific devicetrees binding.
Move it on global rk3399-u-boot.dtsi file and rest of the U-Boot bindings will move it future based on the requirement.
This would help to sync the devicetrees from Linux whenever required instead of adding specific nodes.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Reviewed-by: Paul Kocialkowski paul.kocialkowski@bootlin.com --- Changes for v3.1: - exclude changes for other dts files, since they handle separately.
arch/arm/dts/rk3399-u-boot.dtsi | 8 ++++++++ 1 file changed, 8 insertions(+) create mode 100644 arch/arm/dts/rk3399-u-boot.dtsi
diff --git a/arch/arm/dts/rk3399-u-boot.dtsi b/arch/arm/dts/rk3399-u-boot.dtsi new file mode 100644 index 0000000000..f533ed95eb --- /dev/null +++ b/arch/arm/dts/rk3399-u-boot.dtsi @@ -0,0 +1,8 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 Jagan Teki jagan@amarulasolutions.com + */ + +&sdmmc { + u-boot,dm-pre-reloc; +};
Since your patch has changed significantly, you can no longer include a Reviewed-by that was given on a previous iteration.
It looks like we are still missing bits to have rk3399-u-boot.dtsi included, so this patch does not get my Reviewed-by tag.
Cheers,
Paul
Changes for v3.1:
- Copyright (C) 2019 Jagan Teki jagan@amarulasolutions.com
+&sdmmc {
- u-boot,dm-pre-reloc;
On Fri, Apr 26, 2019 at 7:04 PM Paul Kocialkowski paul.kocialkowski@bootlin.com wrote:
It will include rockchip-u-boot.dtsi automatically and I made the receptive changes to include other files in this patch [1] and sure I will ask Philipp to remove the reviewed-by tag, thanks.
Most importantly (now that I see the new series), you should certainly have sent that patch as part of your new series because we now have an inter-dependency between both series.
Could you clean that up and make a proper standalone series that creates and populates rk3399-u-boot.dtsi?
Cheers,
Paul
On Fri, Apr 26, 2019 at 7:12 PM Paul Kocialkowski paul.kocialkowski@bootlin.com wrote:
It is not like an inter-dependency the previous rk3399-u-boot.dtsi is not included by these files so they would work as before. and now this series would need this change to include rk3399-u-boot.dtsi since the goal here to add binman node to common for all rk3399 dts files.
Well, what I mean is that the latest series you sent mentions a dependency on the first one, when it really should be the other way round: you need the rework to make things in your first series work at all, since that dm-pre-reloc is necessary.
We don't want to merge one broken series and then the fix for it later, even if it would still build in all cases. Here there is a clear logical dependency, in the reverse ordre to the one you are describing.
In order to get this right, you need to take that v3.1 patch from the first series and stick first in the new one. When that's done, I'll be happy to move on to reviewing the code!
Cheers,
Paul
On Fri, Apr 26, 2019 at 7:28 PM Paul Kocialkowski paul.kocialkowski@bootlin.com wrote:
I don't understand your point, sorry.
This patch [1] will make use of the new boards added on that series it will not effect existing or previous rk3399 boards. in that case why it is broken patch or series could you elaborate? the existing boards are already supported dm-pre-reloc on their respective devicetree files.
On Fri, 2019-04-26 at 18:48 +0530, Jagan Teki wrote: > u-boot,dm-pre-reloc is required for SDMMC booted rk3399 boards and > which is U-Boot specific devicetrees binding. > > Move it on global rk3399-u-boot.dtsi file and rest of the U-Boot > bindings will move it future based on the requirement. > > This would help to sync the devicetrees from Linux whenever required > instead of adding specific nodes. > > Signed-off-by: Jagan Teki jagan@amarulasolutions.com > Reviewed-by: Paul Kocialkowski paul.kocialkowski@bootlin.com
On looks like I still didn't really get what you are trying to do. Let's try and recap the situation:
- Currently, we have rk3399 boards with u-boot,dm-pre-reloc in their shared dtsi; - Your v3.1 adds rk3399-u-boot.dtsi but keeps the u-boot,dm-pre-reloc in each device since rk3399-u-boot won't be included. - Your new series allows rk3399-u-boot.dtsi to be included automatically, so we can move the per-common-device-dts u-boot,dm-pre- reloc to rk3399-u-boot.dtsi
If that's correct, then it indeed makes sense the way it is proposed. Your commit messages just lack a clear explanation of what is going on here, since it's not quite trivial for anyone but you.
Cheers,
Paul
On Fri, Apr 26, 2019 at 7:46 PM Paul Kocialkowski paul.kocialkowski@bootlin.com wrote:
On Fri, Apr 26, 2019 at 7:04 PM Paul Kocialkowski paul.kocialkowski@bootlin.com wrote: > Hi, > > On Fri, 2019-04-26 at 18:48 +0530, Jagan Teki wrote: > > u-boot,dm-pre-reloc is required for SDMMC booted rk3399 boards and > > which is U-Boot specific devicetrees binding. > > > > Move it on global rk3399-u-boot.dtsi file and rest of the U-Boot > > bindings will move it future based on the requirement. > > > > This would help to sync the devicetrees from Linux whenever required > > instead of adding specific nodes. > > > > Signed-off-by: Jagan Teki jagan@amarulasolutions.com > > Reviewed-by: Paul Kocialkowski paul.kocialkowski@bootlin.com > > Since your patch has changed significantly, you can no longer include a > Reviewed-by that was given on a previous iteration. > > It looks like we are still missing bits to have rk3399-u-boot.dtsi > included, so this patch does not get my Reviewed-by tag.
shared dtsi;
No, the existing boards don't have shared dtsi that have u-boot,dm-pre-reloc instead they included on respective dts files.
This would keep sdmmc node only which is included by the new boards on that series only.
No, automatically I'm explicit including on respective -u-boot.dtsi
Please don't through stone, explain where it lacks. thanks.
Look like you seems confusing or unclear, here is bit more explanation. The existing boards have u-boot,dm-pre-reloc for sdmmc on their individual dts(i) files, my series add added initial rk3399-u-boot.dtsi by including sdmmc node to use u-boot,dm-pre-reloc which is what in v3.1 and the same included by board dts files which I added on next patches.
Jagan.
On Fri, 2019-04-26 at 19:07 +0530, Jagan Teki wrote: > On Fri, Apr 26, 2019 at 7:04 PM Paul Kocialkowski > paul.kocialkowski@bootlin.com wrote: > > Hi, > > > > On Fri, 2019-04-26 at 18:48 +0530, Jagan Teki wrote: > > > u-boot,dm-pre-reloc is required for SDMMC booted rk3399 boards and > > > which is U-Boot specific devicetrees binding. > > > > > > Move it on global rk3399-u-boot.dtsi file and rest of the U-Boot > > > bindings will move it future based on the requirement. > > > > > > This would help to sync the devicetrees from Linux whenever required > > > instead of adding specific nodes. > > > > > > Signed-off-by: Jagan Teki jagan@amarulasolutions.com > > > Reviewed-by: Paul Kocialkowski paul.kocialkowski@bootlin.com > > > > Since your patch has changed significantly, you can no longer include a > > Reviewed-by that was given on a previous iteration. > > > > It looks like we are still missing bits to have rk3399-u-boot.dtsi > > included, so this patch does not get my Reviewed-by tag. > > It will include rockchip-u-boot.dtsi automatically and I made the > receptive changes to include other files in this patch [1] and sure I > will ask Philipp to remove the reviewed-by tag, thanks.
shared dtsi;
I mean shared with Linux, so respective per-device dts files yes. Sorry, that was definitely unclear wording on my side.
Yes you're right, though the result is the same.
It's the same issue as before, you are not putting enough context in the descriptions and they are only clear to someone who has already understood the issue. You need to make sure that someone who did not know about the issue has a clear idea of it after reading the commit log.
I'm already trying to help by discussing the issue and presenting my understanding so you can get an idea of what point where unclear, but it's ultimately up to you to provide understandable commit messages for reviewers.
Okay so I think I have a clear idea of what is going on now.
Cheers,
Paul
Jagan Teki
Paul Kocialkowski
