[U-Boot] [PATCH] x86: kconfig: Imply CMD_PCI
Let's imply the 'pci' command to access the de facto interconnect bus in an x86 system.
Signed-off-by: Bin Meng bmeng.cn@gmail.com ---
arch/Kconfig | 1 + configs/bayleybay_defconfig | 1 - configs/chromebook_link64_defconfig | 1 - configs/chromebook_link_defconfig | 1 - configs/chromebook_samus_defconfig | 1 - configs/chromebox_panther_defconfig | 1 - configs/conga-qeval20-qa3-e3845-internal-uart_defconfig | 1 - configs/conga-qeval20-qa3-e3845_defconfig | 1 - configs/coreboot-x86_defconfig | 1 - configs/cougarcanyon2_defconfig | 1 - configs/crownbay_defconfig | 1 - configs/dfi-bt700-q7x-151_defconfig | 1 - configs/edison_defconfig | 1 + configs/efi-x86_defconfig | 1 - configs/galileo_defconfig | 1 - configs/minnowmax_defconfig | 1 - configs/qemu-x86_64_defconfig | 1 - configs/qemu-x86_defconfig | 1 - configs/qemu-x86_efi_payload32_defconfig | 1 - configs/qemu-x86_efi_payload64_defconfig | 1 - configs/som-db5800-som-6867_defconfig | 1 - configs/theadorable-x86-dfi-bt700_defconfig | 1 - 22 files changed, 2 insertions(+), 20 deletions(-)
diff --git a/arch/Kconfig b/arch/Kconfig index 78532f5..3fc3c57 100644 --- a/arch/Kconfig +++ b/arch/Kconfig @@ -112,6 +112,7 @@ config X86 imply CMD_GETTIME imply CMD_IO imply CMD_IRQ + imply CMD_PCI imply CMD_SF_TEST imply CMD_ZBOOT
diff --git a/configs/bayleybay_defconfig b/configs/bayleybay_defconfig index b17113f..58a5931 100644 --- a/configs/bayleybay_defconfig +++ b/configs/bayleybay_defconfig @@ -23,7 +23,6 @@ CONFIG_CMD_CPU=y CONFIG_CMD_GPIO=y CONFIG_CMD_MMC=y CONFIG_CMD_PART=y -CONFIG_CMD_PCI=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y diff --git a/configs/chromebook_link64_defconfig b/configs/chromebook_link64_defconfig index f058e56..da24715 100644 --- a/configs/chromebook_link64_defconfig +++ b/configs/chromebook_link64_defconfig @@ -35,7 +35,6 @@ CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y -CONFIG_CMD_PCI=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y diff --git a/configs/chromebook_link_defconfig b/configs/chromebook_link_defconfig index 7fcddba..aaabb22 100644 --- a/configs/chromebook_link_defconfig +++ b/configs/chromebook_link_defconfig @@ -19,7 +19,6 @@ CONFIG_CMD_CPU=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y CONFIG_CMD_PART=y -CONFIG_CMD_PCI=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y diff --git a/configs/chromebook_samus_defconfig b/configs/chromebook_samus_defconfig index 2c294bd..8df2c4c 100644 --- a/configs/chromebook_samus_defconfig +++ b/configs/chromebook_samus_defconfig @@ -19,7 +19,6 @@ CONFIG_CMD_CPU=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y CONFIG_CMD_PART=y -CONFIG_CMD_PCI=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y diff --git a/configs/chromebox_panther_defconfig b/configs/chromebox_panther_defconfig index a81a9cc..2eb30bd 100644 --- a/configs/chromebox_panther_defconfig +++ b/configs/chromebox_panther_defconfig @@ -15,7 +15,6 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y CONFIG_CMD_PART=y -CONFIG_CMD_PCI=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y diff --git a/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig b/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig index 89ba0b6..9575c53 100644 --- a/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig +++ b/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig @@ -25,7 +25,6 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_PART=y -CONFIG_CMD_PCI=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y diff --git a/configs/conga-qeval20-qa3-e3845_defconfig b/configs/conga-qeval20-qa3-e3845_defconfig index 0edacb8..b12be65 100644 --- a/configs/conga-qeval20-qa3-e3845_defconfig +++ b/configs/conga-qeval20-qa3-e3845_defconfig @@ -25,7 +25,6 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_PART=y -CONFIG_CMD_PCI=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y diff --git a/configs/coreboot-x86_defconfig b/configs/coreboot-x86_defconfig index badfbfb..9f3bc3f 100644 --- a/configs/coreboot-x86_defconfig +++ b/configs/coreboot-x86_defconfig @@ -12,7 +12,6 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_IDE=y CONFIG_CMD_PART=y -CONFIG_CMD_PCI=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y diff --git a/configs/cougarcanyon2_defconfig b/configs/cougarcanyon2_defconfig index f7eca76..2d8ebae 100644 --- a/configs/cougarcanyon2_defconfig +++ b/configs/cougarcanyon2_defconfig @@ -11,7 +11,6 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y CONFIG_CMD_PART=y -CONFIG_CMD_PCI=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y diff --git a/configs/crownbay_defconfig b/configs/crownbay_defconfig index 93f96b0..a46dd66 100644 --- a/configs/crownbay_defconfig +++ b/configs/crownbay_defconfig @@ -18,7 +18,6 @@ CONFIG_CMD_CPU=y CONFIG_CMD_GPIO=y CONFIG_CMD_MMC=y CONFIG_CMD_PART=y -CONFIG_CMD_PCI=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y diff --git a/configs/dfi-bt700-q7x-151_defconfig b/configs/dfi-bt700-q7x-151_defconfig index 6dcc2fe..2aaac6e 100644 --- a/configs/dfi-bt700-q7x-151_defconfig +++ b/configs/dfi-bt700-q7x-151_defconfig @@ -23,7 +23,6 @@ CONFIG_CMD_CPU=y CONFIG_CMD_GPIO=y CONFIG_CMD_MMC=y CONFIG_CMD_PART=y -CONFIG_CMD_PCI=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y diff --git a/configs/edison_defconfig b/configs/edison_defconfig index b55cc78..f4d66e1 100644 --- a/configs/edison_defconfig +++ b/configs/edison_defconfig @@ -16,6 +16,7 @@ CONFIG_CMD_DFU=y CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y CONFIG_CMD_PART=y +# CONFIG_CMD_PCI is not set # CONFIG_CMD_NFS is not set CONFIG_CMD_TIMER=y CONFIG_CMD_HASH=y diff --git a/configs/efi-x86_defconfig b/configs/efi-x86_defconfig index 218b838..f397bfd 100644 --- a/configs/efi-x86_defconfig +++ b/configs/efi-x86_defconfig @@ -13,7 +13,6 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_GPIO=y CONFIG_CMD_PART=y -CONFIG_CMD_PCI=y CONFIG_CMD_SF=y # CONFIG_CMD_SF_TEST is not set CONFIG_CMD_SPI=y diff --git a/configs/galileo_defconfig b/configs/galileo_defconfig index 6ad7f1b..514e3c5 100644 --- a/configs/galileo_defconfig +++ b/configs/galileo_defconfig @@ -18,7 +18,6 @@ CONFIG_CMD_CPU=y CONFIG_CMD_GPIO=y CONFIG_CMD_MMC=y CONFIG_CMD_PART=y -CONFIG_CMD_PCI=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y diff --git a/configs/minnowmax_defconfig b/configs/minnowmax_defconfig index ad97ad0..7b237ab 100644 --- a/configs/minnowmax_defconfig +++ b/configs/minnowmax_defconfig @@ -25,7 +25,6 @@ CONFIG_CMD_CPU=y CONFIG_CMD_GPIO=y CONFIG_CMD_MMC=y CONFIG_CMD_PART=y -CONFIG_CMD_PCI=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y diff --git a/configs/qemu-x86_64_defconfig b/configs/qemu-x86_64_defconfig index 3f7bbe4..67e9a45 100644 --- a/configs/qemu-x86_64_defconfig +++ b/configs/qemu-x86_64_defconfig @@ -34,7 +34,6 @@ CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_IDE=y -CONFIG_CMD_PCI=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y diff --git a/configs/qemu-x86_defconfig b/configs/qemu-x86_defconfig index aba7f1e..7ce97ff 100644 --- a/configs/qemu-x86_defconfig +++ b/configs/qemu-x86_defconfig @@ -17,7 +17,6 @@ CONFIG_CMD_CPU=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_IDE=y CONFIG_CMD_PART=y -CONFIG_CMD_PCI=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y diff --git a/configs/qemu-x86_efi_payload32_defconfig b/configs/qemu-x86_efi_payload32_defconfig index 5c0f129..11a4a9e 100644 --- a/configs/qemu-x86_efi_payload32_defconfig +++ b/configs/qemu-x86_efi_payload32_defconfig @@ -14,7 +14,6 @@ CONFIG_CMD_CPU=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_IDE=y CONFIG_CMD_PART=y -CONFIG_CMD_PCI=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y diff --git a/configs/qemu-x86_efi_payload64_defconfig b/configs/qemu-x86_efi_payload64_defconfig index 8a2e243..d123de2 100644 --- a/configs/qemu-x86_efi_payload64_defconfig +++ b/configs/qemu-x86_efi_payload64_defconfig @@ -15,7 +15,6 @@ CONFIG_CMD_CPU=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_IDE=y CONFIG_CMD_PART=y -CONFIG_CMD_PCI=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y diff --git a/configs/som-db5800-som-6867_defconfig b/configs/som-db5800-som-6867_defconfig index fdb83e1..4489ddf 100644 --- a/configs/som-db5800-som-6867_defconfig +++ b/configs/som-db5800-som-6867_defconfig @@ -22,7 +22,6 @@ CONFIG_CMD_CPU=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y CONFIG_CMD_PART=y -CONFIG_CMD_PCI=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y diff --git a/configs/theadorable-x86-dfi-bt700_defconfig b/configs/theadorable-x86-dfi-bt700_defconfig index 8ccb957..45cd74d 100644 --- a/configs/theadorable-x86-dfi-bt700_defconfig +++ b/configs/theadorable-x86-dfi-bt700_defconfig @@ -22,7 +22,6 @@ CONFIG_CMD_CPU=y CONFIG_CMD_GPIO=y CONFIG_CMD_MMC=y CONFIG_CMD_PART=y -CONFIG_CMD_PCI=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y
Thanks, Stefan
- imply CMD_PCI imply CMD_SF_TEST imply CMD_ZBOOT
Viele Grüße, Stefan
applied to u-boot-x86, thanks!
Bin Meng
Stefan Roese
