[PATCH] arm: dts: imx8mp-beacon-kit: Resync DTS with Linux 6.8
The device tree has evolved over time, so re-sync. This also partial reverts one change on the PCIe, because U-Boot doesn't have a proper driver. However, since the clock is configured to generate a 100MHz reference clock by default, a proper driver isn't really necessary.
Signed-off-by: Adam Ford aford173@gmail.com
diff --git a/arch/arm/dts/imx8mp-beacon-kit-u-boot.dtsi b/arch/arm/dts/imx8mp-beacon-kit-u-boot.dtsi index 393fd8ec2e..ed183f83a7 100644 --- a/arch/arm/dts/imx8mp-beacon-kit-u-boot.dtsi +++ b/arch/arm/dts/imx8mp-beacon-kit-u-boot.dtsi @@ -6,6 +6,13 @@ #include "imx8mp-u-boot.dtsi"
/ { + /* U-Boot does not yet have a proper PCIe clk driver */ + pcie0_refclk: clock-pcie { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <100000000>; + }; + wdt-reboot { compatible = "wdt-reboot"; wdt = <&wdog1>; @@ -13,6 +20,10 @@ }; };
+&pcie_phy { + clocks = <&pcie0_refclk>; +}; + &{/soc@0/bus@30800000/i2c@30a20000/pmic@25} { bootph-pre-ram; }; diff --git a/arch/arm/dts/imx8mp-beacon-kit.dts b/arch/arm/dts/imx8mp-beacon-kit.dts index cdae45a48c..a08057410b 100644 --- a/arch/arm/dts/imx8mp-beacon-kit.dts +++ b/arch/arm/dts/imx8mp-beacon-kit.dts @@ -23,6 +23,12 @@ stdout-path = &uart2; };
+ clk_xtal25: clock-xtal25 { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <25000000>; + }; + connector { compatible = "usb-c-connector"; label = "USB-C"; @@ -49,6 +55,12 @@ }; };
+ dmic_codec: dmic-codec { + compatible = "dmic-codec"; + num-channels = <1>; + #sound-dai-cells = <0>; + }; + gpio-keys { compatible = "gpio-keys"; autorepeat; @@ -82,6 +94,17 @@ }; };
+ bridge-connector { + compatible = "hdmi-connector"; + type = "a"; + + port { + hdmi_con: endpoint { + remote-endpoint = <&adv7535_out>; + }; + }; + }; + leds { compatible = "gpio-leds"; pinctrl-names = "default"; @@ -112,10 +135,13 @@ }; };
- pcie0_refclk: clock-pcie { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <100000000>; + reg_audio: regulator-wm8962 { + compatible = "regulator-fixed"; + regulator-name = "3v3_aud"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + gpio = <&pca6416_1 11 GPIO_ACTIVE_HIGH>; + enable-active-high; };
reg_usdhc2_vmmc: regulator-usdhc2 { @@ -137,6 +163,68 @@ gpio = <&pca6416_1 0 GPIO_ACTIVE_HIGH>; enable-active-high; }; + + sound-adv7535 { + compatible = "simple-audio-card"; + simple-audio-card,name = "sound-adv7535"; + simple-audio-card,format = "i2s"; + + simple-audio-card,cpu { + sound-dai = <&sai5>; + system-clock-direction-out; + }; + + simple-audio-card,codec { + sound-dai = <&adv_bridge>; + }; + }; + + sound-dmic { + compatible = "simple-audio-card"; + simple-audio-card,name = "sound-pdm"; + simple-audio-card,format = "i2s"; + simple-audio-card,bitclock-master = <&dailink_master>; + simple-audio-card,frame-master = <&dailink_master>; + + dailink_master: simple-audio-card,cpu { + sound-dai = <&micfil>; + }; + + simple-audio-card,codec { + sound-dai = <&dmic_codec>; + }; + }; + + sound-wm8962 { + compatible = "simple-audio-card"; + simple-audio-card,name = "wm8962"; + simple-audio-card,format = "i2s"; + simple-audio-card,widgets = "Headphone", "Headphones", + "Microphone", "Headset Mic", + "Speaker", "Speaker"; + simple-audio-card,routing = "Headphones", "HPOUTL", + "Headphones", "HPOUTR", + "Speaker", "SPKOUTL", + "Speaker", "SPKOUTR", + "Headset Mic", "MICBIAS", + "IN3R", "Headset Mic"; + + simple-audio-card,cpu { + sound-dai = <&sai3>; + }; + + simple-audio-card,codec { + sound-dai = <&wm8962>; + clocks = <&clk IMX8MP_CLK_IPP_DO_CLKO1>; + frame-master; + bitclock-master; + }; + }; +}; + +&audio_blk_ctrl { + assigned-clocks = <&clk IMX8MP_AUDIO_PLL1>, <&clk IMX8MP_AUDIO_PLL2>; + assigned-clock-rates = <393216000>, <135475200>; };
&ecspi2 { @@ -146,7 +234,7 @@ status = "okay";
tpm: tpm@0 { - compatible = "infineon,slb9670"; + compatible = "infineon,slb9670", "tcg,tpm_tis-spi"; reg = <0>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_tpm>; @@ -211,6 +299,42 @@ interrupt-controller; #interrupt-cells = <2>; }; + + adv_bridge: hdmi@3d { + compatible = "adi,adv7535"; + reg = <0x3d>, <0x3c>, <0x3e>, <0x3f>; + reg-names = "main", "cec", "edid", "packet"; + adi,dsi-lanes = <4>; + #sound-dai-cells = <0>; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + + adv7535_in: endpoint { + remote-endpoint = <&dsi_out>; + }; + }; + + port@1 { + reg = <1>; + + adv7535_out: endpoint { + remote-endpoint = <&hdmi_con>; + }; + }; + }; + }; + + pcieclk: clock-generator@68 { + compatible = "renesas,9fgv0241"; + reg = <0x68>; + clocks = <&clk_xtal25>; + #clock-cells = <1>; + }; };
&i2c3 { @@ -239,6 +363,34 @@ clock-frequency = <384000>; status = "okay";
+ wm8962: audio-codec@1a { + compatible = "wlf,wm8962"; + reg = <0x1a>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_wm8962>; + clocks = <&clk IMX8MP_CLK_IPP_DO_CLKO1>; + assigned-clocks = <&clk IMX8MP_CLK_IPP_DO_CLKO1>; + assigned-clock-parents = <&clk IMX8MP_AUDIO_PLL2_OUT>; + assigned-clock-rates = <22576000>; + DCVDD-supply = <®_audio>; + DBVDD-supply = <®_audio>; + AVDD-supply = <®_audio>; + CPVDD-supply = <®_audio>; + MICVDD-supply = <®_audio>; + PLLVDD-supply = <®_audio>; + SPKVDD1-supply = <®_audio>; + SPKVDD2-supply = <®_audio>; + gpio-cfg = < + 0x0000 /* 0:Default */ + 0x0000 /* 1:Default */ + 0x0000 /* 2:FN_DMICCLK */ + 0x0000 /* 3:Default */ + 0x0000 /* 4:FN_DMICCDAT */ + 0x0000 /* 5:Default */ + >; + #sound-dai-cells = <0>; + }; + pca6416: gpio@20 { compatible = "nxp,pcal6416"; reg = <0x20>; @@ -301,6 +453,34 @@ }; };
+&lcdif1 { + status = "okay"; +}; + +&micfil { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_pdm>; + assigned-clocks = <&clk IMX8MP_CLK_PDM>; + assigned-clock-parents = <&clk IMX8MP_AUDIO_PLL1_OUT>; + assigned-clock-rates = <49152000>; + status = "okay"; +}; + +&mipi_dsi { + samsung,esc-clock-frequency = <10000000>; + status = "okay"; + + ports { + port@1 { + reg = <1>; + + dsi_out: endpoint { + remote-endpoint = <&adv7535_in>; + }; + }; + }; +}; + &pcie { pinctrl-names = "default"; pinctrl-0 = <&pinctrl_pcie>; @@ -309,12 +489,34 @@ };
&pcie_phy { + fsl,clkreq-unsupported; fsl,refclk-pad-mode = <IMX8_PCIE_REFCLK_PAD_INPUT>; - clocks = <&pcie0_refclk>; + clocks = <&pcieclk 1>; clock-names = "ref"; status = "okay"; };
+&sai3 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_sai3>; + assigned-clocks = <&clk IMX8MP_CLK_SAI3>, + <&clk IMX8MP_AUDIO_PLL2> ; + assigned-clock-parents = <&clk IMX8MP_AUDIO_PLL2_OUT>; + assigned-clock-rates = <12288000>, <361267200>; + fsl,sai-mclk-direction-output; + status = "okay"; +}; + +&sai5 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_sai5>; + assigned-clocks = <&clk IMX8MP_CLK_SAI5>; + assigned-clock-parents = <&clk IMX8MP_AUDIO_PLL1_OUT>; + assigned-clock-rates = <12288000>; + fsl,sai-mclk-direction-output; + status = "okay"; +}; + &snvs_pwrkey { status = "okay"; }; @@ -471,12 +673,37 @@ >; };
+ pinctrl_pdm: pdmgrp { + fsl,pins = < + MX8MP_IOMUXC_SAI5_RXC__AUDIOMIX_PDM_CLK 0xd6 + MX8MP_IOMUXC_SAI5_RXD0__AUDIOMIX_PDM_BIT_STREAM00 0xd6 + >; + }; + pinctrl_reg_usdhc2_vmmc: regusdhc2vmmcgrp { fsl,pins = < MX8MP_IOMUXC_SD2_RESET_B__GPIO2_IO19 0x40 >; };
+ pinctrl_sai3: sai3grp { + fsl,pins = < + MX8MP_IOMUXC_SAI3_TXFS__AUDIOMIX_SAI3_TX_SYNC 0xd6 + MX8MP_IOMUXC_SAI3_TXC__AUDIOMIX_SAI3_TX_BCLK 0xd6 + MX8MP_IOMUXC_SAI3_RXD__AUDIOMIX_SAI3_RX_DATA00 0xd6 + MX8MP_IOMUXC_SAI3_TXD__AUDIOMIX_SAI3_TX_DATA00 0xd6 + MX8MP_IOMUXC_SAI3_MCLK__AUDIOMIX_SAI3_MCLK 0xd6 + >; + }; + + pinctrl_sai5: sai5grp { + fsl,pins = < + MX8MP_IOMUXC_SAI5_RXD3__AUDIOMIX_SAI5_TX_DATA00 0xd6 + MX8MP_IOMUXC_SAI5_RXD2__AUDIOMIX_SAI5_TX_BCLK 0xd6 + MX8MP_IOMUXC_SAI5_RXD1__AUDIOMIX_SAI5_TX_SYNC 0xd6 + >; + }; + pinctrl_tpm: tpmgrp { fsl,pins = < MX8MP_IOMUXC_SAI1_RXFS__GPIO4_IO00 0x19 /* Reset */ @@ -547,4 +774,10 @@ MX8MP_IOMUXC_SD2_CD_B__GPIO2_IO12 0x1c4 >; }; + + pinctrl_wm8962: wm8962grp { + fsl,pins = < + MX8MP_IOMUXC_GPIO1_IO14__CCM_CLKO1 0x59 + >; + }; }; diff --git a/arch/arm/dts/imx8mp-beacon-som.dtsi b/arch/arm/dts/imx8mp-beacon-som.dtsi index e5da908047..8be251b693 100644 --- a/arch/arm/dts/imx8mp-beacon-som.dtsi +++ b/arch/arm/dts/imx8mp-beacon-som.dtsi @@ -50,6 +50,8 @@ phy-mode = "rgmii-id"; phy-handle = <ðphy0>; snps,force_thresh_dma_mode; + snps,mtl-rx-config = <&mtl_rx_setup>; + snps,mtl-tx-config = <&mtl_tx_setup>; status = "okay";
mdio { @@ -66,6 +68,71 @@ interrupts = <10 IRQ_TYPE_LEVEL_LOW>; }; }; + + mtl_rx_setup: rx-queues-config { + snps,rx-queues-to-use = <5>; + snps,rx-sched-sp; + + queue0 { + snps,dcb-algorithm; + snps,priority = <0x1>; + snps,map-to-dma-channel = <0>; + }; + + queue1 { + snps,dcb-algorithm; + snps,priority = <0x2>; + snps,map-to-dma-channel = <1>; + }; + + queue2 { + snps,dcb-algorithm; + snps,priority = <0x4>; + snps,map-to-dma-channel = <2>; + }; + + queue3 { + snps,dcb-algorithm; + snps,priority = <0x8>; + snps,map-to-dma-channel = <3>; + }; + + queue4 { + snps,dcb-algorithm; + snps,priority = <0xf0>; + snps,map-to-dma-channel = <4>; + }; + }; + + mtl_tx_setup: tx-queues-config { + snps,tx-queues-to-use = <5>; + snps,tx-sched-sp; + + queue0 { + snps,dcb-algorithm; + snps,priority = <0x1>; + }; + + queue1 { + snps,dcb-algorithm; + snps,priority = <0x2>; + }; + + queue2 { + snps,dcb-algorithm; + snps,priority = <0x4>; + }; + + queue3 { + snps,dcb-algorithm; + snps,priority = <0x8>; + }; + + queue4 { + snps,dcb-algorithm; + snps,priority = <0xf0>; + }; + }; };
&flexspi { @@ -206,6 +273,10 @@ assigned-clock-parents = <&clk IMX8MP_SYS_PLL1_80M>; uart-has-rtscts; status = "okay"; + + bluetooth { + compatible = "nxp,88w8997-bt"; + }; };
&usdhc1 {
Subject: [PATCH] arm: dts: imx8mp-beacon-kit: Resync DTS with Linux 6.8
Acked-by: Peng Fan peng.fan@nxp.com
- /* U-Boot does not yet have a proper PCIe clk driver */
#clock-cells = <0>;
- wdt-reboot { compatible = "wdt-reboot"; wdt = <&wdog1>;
+&pcie_phy {
&{/soc@0/bus@30800000/i2c@30a20000/pmic@25} { bootph-pre-ram; }; diff --git a/arch/arm/dts/imx8mp-beacon-kit.dts b/arch/arm/dts/imx8mp- beacon-kit.dts index cdae45a48c..a08057410b 100644 --- a/arch/arm/dts/imx8mp-beacon-kit.dts +++ b/arch/arm/dts/imx8mp-beacon-kit.dts @@ -23,6 +23,12 @@ stdout-path = &uart2; };
- clk_xtal25: clock-xtal25 {
#clock-cells = <0>;
- connector { compatible = "usb-c-connector"; label = "USB-C";
- dmic_codec: dmic-codec {
num-channels = <1>;
- gpio-keys { compatible = "gpio-keys"; autorepeat;
- bridge-connector {
type = "a";
port {
- leds { compatible = "gpio-leds"; pinctrl-names = "default";
#clock-cells = <0>;
enable-active-high;
- sound-adv7535 {
- sound-dmic {
- sound-wm8962 {
frame-master;
bitclock-master;
+&audio_blk_ctrl {
- assigned-clocks = <&clk IMX8MP_AUDIO_PLL1>, <&clk
IMX8MP_AUDIO_PLL2>;
- assigned-clock-rates = <393216000>, <135475200>;
tpm: tpm@0 {
reg = <0>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_tpm>;compatible = "infineon,slb9670", "tcg,tpm_tis-spi";
- adv_bridge: hdmi@3d {
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
port@1 {
reg = <1>;
- pcieclk: clock-generator@68 {
reg = <0x68>;
#clock-cells = <1>;
- wm8962: audio-codec@1a {
reg = <0x1a>;
gpio-cfg = <
- pca6416: gpio@20 { compatible = "nxp,pcal6416"; reg = <0x20>;
+&lcdif1 {
- status = "okay";
+&micfil {
- pinctrl-names = "default";
- pinctrl-0 = <&pinctrl_pdm>;
- assigned-clocks = <&clk IMX8MP_CLK_PDM>;
- assigned-clock-parents = <&clk IMX8MP_AUDIO_PLL1_OUT>;
- assigned-clock-rates = <49152000>;
- status = "okay";
+&mipi_dsi {
- samsung,esc-clock-frequency = <10000000>;
- status = "okay";
- ports {
port@1 {
reg = <1>;
dsi_out: endpoint {
&pcie_phy {
- fsl,clkreq-unsupported; fsl,refclk-pad-mode = <IMX8_PCIE_REFCLK_PAD_INPUT>;
- clocks = <&pcieclk 1>; clock-names = "ref"; status = "okay";
+&sai3 {
- pinctrl-0 = <&pinctrl_sai3>;
- assigned-clocks = <&clk IMX8MP_CLK_SAI3>,
- assigned-clock-parents = <&clk IMX8MP_AUDIO_PLL2_OUT>;
- assigned-clock-rates = <12288000>, <361267200>;
- fsl,sai-mclk-direction-output;
- status = "okay";
+&sai5 {
- pinctrl-0 = <&pinctrl_sai5>;
- assigned-clocks = <&clk IMX8MP_CLK_SAI5>;
- assigned-clock-rates = <12288000>;
- status = "okay";
fsl,pins = <
0xd6
fsl,pins = <
fsl,pins = <
- pinctrl_wm8962: wm8962grp {
fsl,pins = <
0x59MX8MP_IOMUXC_GPIO1_IO14__CCM_CLKO1
}; diff --git a/arch/arm/dts/imx8mp-beacon-som.dtsi b/arch/arm/dts/imx8mp- beacon-som.dtsi index e5da908047..8be251b693 100644 --- a/arch/arm/dts/imx8mp-beacon-som.dtsi +++ b/arch/arm/dts/imx8mp-beacon-som.dtsi @@ -50,6 +50,8 @@ phy-mode = "rgmii-id"; phy-handle = <ðphy0>; snps,force_thresh_dma_mode;
mdio {
- mtl_rx_setup: rx-queues-config {
snps,rx-sched-sp;
queue0 {
snps,dcb-algorithm;
queue1 {
snps,dcb-algorithm;
queue2 {
snps,dcb-algorithm;
queue3 {
snps,dcb-algorithm;
queue4 {
snps,dcb-algorithm;
- mtl_tx_setup: tx-queues-config {
snps,tx-sched-sp;
queue0 {
snps,dcb-algorithm;
queue1 {
snps,dcb-algorithm;
queue2 {
snps,dcb-algorithm;
queue3 {
snps,dcb-algorithm;
queue4 {
snps,dcb-algorithm;
- bluetooth {
&usdhc1 {
2.43.0
Applied, thanks.
Adam Ford
Fabio Estevam
Peng Fan
