[PATCH 0/5] efi_loader: fix a verification process issue in secure boot
In the commit 4540dabdcaca ("efi_loader: image_loader: support image authentication"), U-Boot implementation of UEFI secure boot was introduced. It was reported by a Siemens engineer, however, that the verification process is not fully compliant with MicroSoft's authenticode specification and it is possible to exploit the code in a signed PE image without deep knowledge.
This patch series fixes this security issue and, in addition, adds a test case.
patch#1-3: preparatory patches patch#4: add a missing step in signature verification process patch#5: a new test case under pytest
AKASHI Takahiro (5): lib: crypto: add mscode_parser efi_loader: signature: export efi_hash_regions() efi_loader: image_loader: replace EFI_PRINT with log macros efi_loader: image_loader: add a missing digest verification for signed PE image test/py: efi_secboot: add a test for a forged signed image
include/crypto/mscode.h | 43 ++++++ include/efi_loader.h | 2 + lib/crypto/Kconfig | 9 ++ lib/crypto/Makefile | 12 ++ lib/crypto/mscode.asn1 | 28 ++++ lib/crypto/mscode_parser.c | 135 ++++++++++++++++++ lib/efi_loader/Kconfig | 1 + lib/efi_loader/efi_image_loader.c | 114 +++++++++++---- lib/efi_loader/efi_signature.c | 4 +- test/py/tests/test_efi_secboot/conftest.py | 3 + test/py/tests/test_efi_secboot/forge_image.sh | 5 + test/py/tests/test_efi_secboot/test_signed.py | 35 +++++ 12 files changed, 361 insertions(+), 30 deletions(-) create mode 100644 include/crypto/mscode.h create mode 100644 lib/crypto/mscode.asn1 create mode 100644 lib/crypto/mscode_parser.c create mode 100644 test/py/tests/test_efi_secboot/forge_image.sh
In MS authenticode, pkcs7 should have data in its contentInfo field. This data is tagged with SpcIndirectData type and, for a signed PE image, provides a image's message digest as SpcPeImageData.
This parser is used in image authentication to parse the field and retrieve a message digest.
Imported from linux v5.19-rc, crypto/asymmetric_keys/mscode*. Checkpatch.pl generates tones of warnings, but those are not fixed for the sake of maintainability (importing from another source).
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org --- include/crypto/mscode.h | 43 ++++++++++++ lib/crypto/Kconfig | 9 +++ lib/crypto/Makefile | 12 ++++ lib/crypto/mscode.asn1 | 28 ++++++++ lib/crypto/mscode_parser.c | 135 +++++++++++++++++++++++++++++++++++++ 5 files changed, 227 insertions(+) create mode 100644 include/crypto/mscode.h create mode 100644 lib/crypto/mscode.asn1 create mode 100644 lib/crypto/mscode_parser.c
diff --git a/include/crypto/mscode.h b/include/crypto/mscode.h new file mode 100644 index 000000000000..551058b96e60 --- /dev/null +++ b/include/crypto/mscode.h @@ -0,0 +1,43 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later */ +/* PE Binary parser bits + * + * Copyright (C) 2014 Red Hat, Inc. All Rights Reserved. + * Written by David Howells (dhowells@redhat.com) + */ + +#include <crypto/pkcs7.h> +#ifndef __UBOOT__ +#include <crypto/hash_info.h> +#endif + +struct pefile_context { +#ifndef __UBOOT__ + unsigned header_size; + unsigned image_checksum_offset; + unsigned cert_dirent_offset; + unsigned n_data_dirents; + unsigned n_sections; + unsigned certs_size; + unsigned sig_offset; + unsigned sig_len; + const struct section_header *secs; +#endif + + /* PKCS#7 MS Individual Code Signing content */ + const void *digest; /* Digest */ + unsigned digest_len; /* Digest length */ + const char *digest_algo; /* Digest algorithm */ +}; + +#ifndef __UBOOT__ +#define kenter(FMT, ...) \ + pr_devel("==> %s("FMT")\n", __func__, ##__VA_ARGS__) +#define kleave(FMT, ...) \ + pr_devel("<== %s()"FMT"\n", __func__, ##__VA_ARGS__) +#endif + +/* + * mscode_parser.c + */ +extern int mscode_parse(void *_ctx, const void *content_data, size_t data_len, + size_t asn1hdrlen); diff --git a/lib/crypto/Kconfig b/lib/crypto/Kconfig index 1c04a7ec5f48..c3f563b2e174 100644 --- a/lib/crypto/Kconfig +++ b/lib/crypto/Kconfig @@ -82,4 +82,13 @@ config PKCS7_MESSAGE_PARSER config PKCS7_VERIFY bool
+config MSCODE_PARSER + bool "MS authenticode parser" + select ASN1_DECODER + select ASN1_COMPILER + select OID_REGISTRY + help + This option provides support for parsing MicroSoft's Authenticode + in pkcs7 message. + endif # ASYMMETRIC_KEY_TYPE diff --git a/lib/crypto/Makefile b/lib/crypto/Makefile index 6792b1d4f007..bec1bc95a658 100644 --- a/lib/crypto/Makefile +++ b/lib/crypto/Makefile @@ -55,3 +55,15 @@ obj-$(CONFIG_$(SPL_)PKCS7_VERIFY) += pkcs7_verify.o
$(obj)/pkcs7_parser.o: $(obj)/pkcs7.asn1.h $(obj)/pkcs7.asn1.o: $(obj)/pkcs7.asn1.c $(obj)/pkcs7.asn1.h + +# +# Signed PE binary-wrapped key handling +# +obj-$(CONFIG_$(SPL_)MSCODE_PARSER) += mscode.o + +mscode-y := \ + mscode_parser.o \ + mscode.asn1.o + +$(obj)/mscode_parser.o: $(obj)/mscode.asn1.h $(obj)/mscode.asn1.h +$(obj)/mscode.asn1.o: $(obj)/mscode.asn1.c $(obj)/mscode.asn1.h diff --git a/lib/crypto/mscode.asn1 b/lib/crypto/mscode.asn1 new file mode 100644 index 000000000000..6d09ba48c41c --- /dev/null +++ b/lib/crypto/mscode.asn1 @@ -0,0 +1,28 @@ +--- Microsoft individual code signing data blob parser +--- +--- Copyright (C) 2012 Red Hat, Inc. All Rights Reserved. +--- Written by David Howells (dhowells@redhat.com) +--- +--- This program is free software; you can redistribute it and/or +--- modify it under the terms of the GNU General Public Licence +--- as published by the Free Software Foundation; either version +--- 2 of the Licence, or (at your option) any later version. +--- + +MSCode ::= SEQUENCE { + type SEQUENCE { + contentType ContentType, + parameters ANY + }, + content SEQUENCE { + digestAlgorithm DigestAlgorithmIdentifier, + digest OCTET STRING ({ mscode_note_digest }) + } +} + +ContentType ::= OBJECT IDENTIFIER ({ mscode_note_content_type }) + +DigestAlgorithmIdentifier ::= SEQUENCE { + algorithm OBJECT IDENTIFIER ({ mscode_note_digest_algo }), + parameters ANY OPTIONAL +} diff --git a/lib/crypto/mscode_parser.c b/lib/crypto/mscode_parser.c new file mode 100644 index 000000000000..90d5b37a6cf2 --- /dev/null +++ b/lib/crypto/mscode_parser.c @@ -0,0 +1,135 @@ +// SPDX-License-Identifier: GPL-2.0-or-later +/* Parse a Microsoft Individual Code Signing blob + * + * Copyright (C) 2014 Red Hat, Inc. All Rights Reserved. + * Written by David Howells (dhowells@redhat.com) + */ + +#define pr_fmt(fmt) "MSCODE: "fmt +#include <linux/kernel.h> +#ifndef __UBOOT__ +#include <linux/slab.h> +#endif +#include <linux/err.h> +#include <linux/oid_registry.h> +#include <crypto/pkcs7.h> +#ifdef __UBOOT__ +#include <crypto/mscode.h> +#else +#include "verify_pefile.h" +#endif +#include "mscode.asn1.h" + +/* + * Parse a Microsoft Individual Code Signing blob + */ +int mscode_parse(void *_ctx, const void *content_data, size_t data_len, + size_t asn1hdrlen) +{ + struct pefile_context *ctx = _ctx; + + content_data -= asn1hdrlen; + data_len += asn1hdrlen; + pr_devel("Data: %zu [%*ph]\n", data_len, (unsigned)(data_len), + content_data); + + return asn1_ber_decoder(&mscode_decoder, ctx, content_data, data_len); +} + +/* + * Check the content type OID + */ +int mscode_note_content_type(void *context, size_t hdrlen, + unsigned char tag, + const void *value, size_t vlen) +{ + enum OID oid; + + oid = look_up_OID(value, vlen); + if (oid == OID__NR) { + char buffer[50]; + + sprint_oid(value, vlen, buffer, sizeof(buffer)); + pr_err("Unknown OID: %s\n", buffer); + return -EBADMSG; + } + + /* + * pesign utility had a bug where it was putting + * OID_msIndividualSPKeyPurpose instead of OID_msPeImageDataObjId + * So allow both OIDs. + */ + if (oid != OID_msPeImageDataObjId && + oid != OID_msIndividualSPKeyPurpose) { + pr_err("Unexpected content type OID %u\n", oid); + return -EBADMSG; + } + + return 0; +} + +/* + * Note the digest algorithm OID + */ +int mscode_note_digest_algo(void *context, size_t hdrlen, + unsigned char tag, + const void *value, size_t vlen) +{ + struct pefile_context *ctx = context; + char buffer[50]; + enum OID oid; + + oid = look_up_OID(value, vlen); + switch (oid) { + case OID_md4: + ctx->digest_algo = "md4"; + break; + case OID_md5: + ctx->digest_algo = "md5"; + break; + case OID_sha1: + ctx->digest_algo = "sha1"; + break; + case OID_sha256: + ctx->digest_algo = "sha256"; + break; + case OID_sha384: + ctx->digest_algo = "sha384"; + break; + case OID_sha512: + ctx->digest_algo = "sha512"; + break; + case OID_sha224: + ctx->digest_algo = "sha224"; + break; + + case OID__NR: + sprint_oid(value, vlen, buffer, sizeof(buffer)); + pr_err("Unknown OID: %s\n", buffer); + return -EBADMSG; + + default: + pr_err("Unsupported content type: %u\n", oid); + return -ENOPKG; + } + + return 0; +} + +/* + * Note the digest we're guaranteeing with this certificate + */ +int mscode_note_digest(void *context, size_t hdrlen, + unsigned char tag, + const void *value, size_t vlen) +{ + struct pefile_context *ctx = context; + + ctx->digest = kmemdup(value, vlen, GFP_KERNEL); + if (!ctx->digest) + return -ENOMEM; + + ctx->digest_len = vlen; + + return 0; +}
in pkcs7 message.
I chuckled when I saw "MicroSoft" in the cover letter, thinking it was a wink, but here too... haha ummm. We could change it to "MikeRoweSoft" instead in honor of the Belmont High School student. But... I think "Microsoft" is what you're after here.
- pr_devel("Data: %zu [%*ph]\n", data_len, (unsigned)(data_len),
content_data);
That's a weird cast around (data_len), but are you sure you want to keep that print line in there?
Jason
in pkcs7 message.
I have never heard of his name, but
If so, yes.
content_data);
My basic policy in importing a file form Linux, as far as lib/crypto/*.c is concerned, is not to modify the original code unless it's harmful but to add "#ifndef __UBOOT__" to exclude useless or never-used code so that someone else other than me can easily synchronize files again in the future.
So even if it looks weird (and checkpatch.pl, which ironically comes from Linux as well, might raise warnings), I'd like to leave it as it is.
Having said that, if maintainers have a different policy, I don't hesitate to follow it.
Thanks, -Takahiro Akashi
Jason
This function is used to calculate a message digest as part of authentication process in a later patch.
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org --- include/efi_loader.h | 2 ++ lib/efi_loader/efi_signature.c | 4 ++-- 2 files changed, 4 insertions(+), 2 deletions(-)
diff --git a/include/efi_loader.h b/include/efi_loader.h index c1e00ebac398..11930fbea838 100644 --- a/include/efi_loader.h +++ b/include/efi_loader.h @@ -931,6 +931,8 @@ struct efi_signature_store { struct x509_certificate; struct pkcs7_message;
+bool efi_hash_regions(struct image_region *regs, int count, + void **hash, const char *hash_algo, int *len); bool efi_signature_lookup_digest(struct efi_image_regions *regs, struct efi_signature_store *db, bool dbx); diff --git a/lib/efi_loader/efi_signature.c b/lib/efi_loader/efi_signature.c index ddac751d128e..742d8919402c 100644 --- a/lib/efi_loader/efi_signature.c +++ b/lib/efi_loader/efi_signature.c @@ -125,8 +125,8 @@ struct pkcs7_message *efi_parse_pkcs7_header(const void *buf, * * Return: true on success, false on error */ -static bool efi_hash_regions(struct image_region *regs, int count, - void **hash, const char *hash_algo, int *len) +bool efi_hash_regions(struct image_region *regs, int count, + void **hash, const char *hash_algo, int *len) { int ret, hash_len;
Now We are migrating from EFI_PRINT() to log macro's.
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org --- lib/efi_loader/efi_image_loader.c | 54 +++++++++++++++---------------- 1 file changed, 27 insertions(+), 27 deletions(-)
diff --git a/lib/efi_loader/efi_image_loader.c b/lib/efi_loader/efi_image_loader.c index 961139888504..fe8e4a89082c 100644 --- a/lib/efi_loader/efi_image_loader.c +++ b/lib/efi_loader/efi_image_loader.c @@ -238,7 +238,7 @@ efi_status_t efi_image_region_add(struct efi_image_regions *regs, int i, j;
if (regs->num >= regs->max) { - EFI_PRINT("%s: no more room for regions\n", __func__); + log_err("%s: no more room for regions\n", __func__); return EFI_OUT_OF_RESOURCES; }
@@ -263,7 +263,7 @@ efi_status_t efi_image_region_add(struct efi_image_regions *regs, }
/* new data overlapping registered region */ - EFI_PRINT("%s: new region already part of another\n", __func__); + log_err("%s: new region already part of another\n", __func__); return EFI_INVALID_PARAMETER; }
@@ -434,8 +434,8 @@ bool efi_image_parse(void *efi, size_t len, struct efi_image_regions **regp, bytes_hashed = opt->SizeOfHeaders; align = opt->FileAlignment; } else { - EFI_PRINT("%s: Invalid optional header magic %x\n", __func__, - nt->OptionalHeader.Magic); + log_err("%s: Invalid optional header magic %x\n", __func__, + nt->OptionalHeader.Magic); goto err; }
@@ -445,7 +445,7 @@ bool efi_image_parse(void *efi, size_t len, struct efi_image_regions **regp, nt->FileHeader.SizeOfOptionalHeader); sorted = calloc(sizeof(IMAGE_SECTION_HEADER *), num_sections); if (!sorted) { - EFI_PRINT("%s: Out of memory\n", __func__); + log_err("%s: Out of memory\n", __func__); goto err; }
@@ -464,7 +464,7 @@ bool efi_image_parse(void *efi, size_t len, struct efi_image_regions **regp, efi_image_region_add(regs, efi + sorted[i]->PointerToRawData, efi + sorted[i]->PointerToRawData + size, 0); - EFI_PRINT("section[%d](%s): raw: 0x%x-0x%x, virt: %x-%x\n", + log_debug("section[%d](%s): raw: 0x%x-0x%x, virt: %x-%x\n", i, sorted[i]->Name, sorted[i]->PointerToRawData, sorted[i]->PointerToRawData + size, @@ -478,7 +478,7 @@ bool efi_image_parse(void *efi, size_t len, struct efi_image_regions **regp,
/* 3. Extra data excluding Certificates Table */ if (bytes_hashed + authsz < len) { - EFI_PRINT("extra data for hash: %zu\n", + log_debug("extra data for hash: %zu\n", len - (bytes_hashed + authsz)); efi_image_region_add(regs, efi + bytes_hashed, efi + len - authsz, 0); @@ -487,18 +487,18 @@ bool efi_image_parse(void *efi, size_t len, struct efi_image_regions **regp, /* Return Certificates Table */ if (authsz) { if (len < authoff + authsz) { - EFI_PRINT("%s: Size for auth too large: %u >= %zu\n", - __func__, authsz, len - authoff); + log_err("%s: Size for auth too large: %u >= %zu\n", + __func__, authsz, len - authoff); goto err; } if (authsz < sizeof(*auth)) { - EFI_PRINT("%s: Size for auth too small: %u < %zu\n", - __func__, authsz, sizeof(*auth)); + log_err("%s: Size for auth too small: %u < %zu\n", + __func__, authsz, sizeof(*auth)); goto err; } *auth = efi + authoff; *auth_len = authsz; - EFI_PRINT("WIN_CERTIFICATE: 0x%x, size: 0x%x\n", authoff, + log_debug("WIN_CERTIFICATE: 0x%x, size: 0x%x\n", authoff, authsz); } else { *auth = NULL; @@ -549,7 +549,7 @@ static bool efi_image_authenticate(void *efi, size_t efi_size) size_t auth_size; bool ret = false;
- EFI_PRINT("%s: Enter, %d\n", __func__, ret); + log_debug("%s: Enter, %d\n", __func__, ret);
if (!efi_secure_boot_enabled()) return true; @@ -560,7 +560,7 @@ static bool efi_image_authenticate(void *efi, size_t efi_size)
if (!efi_image_parse(new_efi, efi_size, ®s, &wincerts, &wincerts_len)) { - EFI_PRINT("Parsing PE executable image failed\n"); + log_err("Parsing PE executable image failed\n"); goto out; }
@@ -569,18 +569,18 @@ static bool efi_image_authenticate(void *efi, size_t efi_size) */ db = efi_sigstore_parse_sigdb(u"db"); if (!db) { - EFI_PRINT("Getting signature database(db) failed\n"); + log_err("Getting signature database(db) failed\n"); goto out; }
dbx = efi_sigstore_parse_sigdb(u"dbx"); if (!dbx) { - EFI_PRINT("Getting signature database(dbx) failed\n"); + log_err("Getting signature database(dbx) failed\n"); goto out; }
if (efi_signature_lookup_digest(regs, dbx, true)) { - EFI_PRINT("Image's digest was found in "dbx"\n"); + log_debug("Image's digest was found in "dbx"\n"); goto out; }
@@ -602,12 +602,12 @@ static bool efi_image_authenticate(void *efi, size_t efi_size) break;
if (wincert->dwLength <= sizeof(*wincert)) { - EFI_PRINT("dwLength too small: %u < %zu\n", + log_debug("dwLength too small: %u < %zu\n", wincert->dwLength, sizeof(*wincert)); continue; }
- EFI_PRINT("WIN_CERTIFICATE_TYPE: 0x%x\n", + log_debug("WIN_CERTIFICATE_TYPE: 0x%x\n", wincert->wCertificateType);
auth = (u8 *)wincert + sizeof(*wincert); @@ -617,12 +617,12 @@ static bool efi_image_authenticate(void *efi, size_t efi_size) break;
if (auth_size <= sizeof(efi_guid_t)) { - EFI_PRINT("dwLength too small: %u < %zu\n", + log_debug("dwLength too small: %u < %zu\n", wincert->dwLength, sizeof(*wincert)); continue; } if (guidcmp(auth, &efi_guid_cert_type_pkcs7)) { - EFI_PRINT("Certificate type not supported: %pUs\n", + log_debug("Certificate type not supported: %pUs\n", auth); ret = false; goto out; @@ -632,14 +632,14 @@ static bool efi_image_authenticate(void *efi, size_t efi_size) auth_size -= sizeof(efi_guid_t); } else if (wincert->wCertificateType != WIN_CERT_TYPE_PKCS_SIGNED_DATA) { - EFI_PRINT("Certificate type not supported\n"); + log_debug("Certificate type not supported\n"); ret = false; goto out; }
msg = pkcs7_parse_message(auth, auth_size); if (IS_ERR(msg)) { - EFI_PRINT("Parsing image's signature failed\n"); + log_err("Parsing image's signature failed\n"); msg = NULL; continue; } @@ -666,13 +666,13 @@ static bool efi_image_authenticate(void *efi, size_t efi_size) /* try black-list first */ if (efi_signature_verify_one(regs, msg, dbx)) { ret = false; - EFI_PRINT("Signature was rejected by "dbx"\n"); + log_debug("Signature was rejected by "dbx"\n"); goto out; }
if (!efi_signature_check_signers(msg, dbx)) { ret = false; - EFI_PRINT("Signer(s) in "dbx"\n"); + log_debug("Signer(s) in "dbx"\n"); goto out; }
@@ -682,7 +682,7 @@ static bool efi_image_authenticate(void *efi, size_t efi_size) continue; }
- EFI_PRINT("Signature was not verified by "db"\n"); + log_debug("Signature was not verified by "db"\n"); }
@@ -698,7 +698,7 @@ out: if (new_efi != efi) free(new_efi);
- EFI_PRINT("%s: Exit, %d\n", __func__, ret); + log_debug("%s: Exit, %d\n", __func__, ret); return ret; } #else
I don't understand your logic:
log_err("Parsing image's signature failed\n"); log_debug("Signature was rejected by "dbx"\n");
Shouldn't everything leading to a signature being rejected be treated the same (i.e. use log_err())?
Best regards
Heinrich
return EFI_OUT_OF_RESOURCES; }log_err("%s: no more room for regions\n", __func__);
return EFI_INVALID_PARAMETER; }log_err("%s: new region already part of another\n", __func__);
goto err; }nt->OptionalHeader.Magic);
goto err; }log_err("%s: Out of memory\n", __func__);
efi_image_region_add(regs, efi + bytes_hashed, efi + len - authsz, 0);log_debug("extra data for hash: %zu\n", len - (bytes_hashed + authsz));
} if (authsz < sizeof(*auth)) {__func__, authsz, len - authoff); goto err;
} *auth = efi + authoff; *auth_len = authsz;__func__, authsz, sizeof(*auth)); goto err;
} else { *auth = NULL;log_debug("WIN_CERTIFICATE: 0x%x, size: 0x%x\n", authoff, authsz);
goto out; }log_err("Parsing PE executable image failed\n");
goto out; }
goto out; }
EFI_PRINT("Image's digest was found in \"dbx\"\n");
goto out; }log_debug("Image's digest was found in \"dbx\"\n");
}log_debug("dwLength too small: %u < %zu\n", wincert->dwLength, sizeof(*wincert)); continue;
}log_err("Parsing image's signature failed\n"); msg = NULL; continue;
EFI_PRINT("Signature was rejected by \"dbx\"\n");
log_debug("Signature was rejected by \"dbx\"\n"); goto out;
EFI_PRINT("Signer(s) in \"dbx\"\n");
}log_debug("Signer(s) in \"dbx\"\n"); goto out;
EFI_PRINT("Signature was not verified by \"db\"\n");
}log_debug("Signature was not verified by \"db\"\n");
- log_debug("%s: Exit, %d\n", __func__, ret); return ret; } #else
Heinrich,
I distinctively use those two macro's. I use log_err() when such an error is *normally* NOT expected. I think that users should always be notified of these cases. (Say, a signing tool generates a incompatible format of image, or a image itself is corrupted.)
On the other hand, I use log_debug() to show the detailed reason of why the signature verification process failed. I always enable those messages when I debug image authentication code.
Please note there is always log_err("Image not authenticated\n") if efi_image_authenticate() fails.
-Takahiro Akashi
Best regards
Heinrich
goto out; }
goto out; }
At the last step of PE image authentication, an image's hash value must be compared with a message digest stored as the content (of SpcPeImageData type) of pkcs7's contentInfo.
Fixes: commit 4540dabdcaca ("efi_loader: image_loader: support image authentication") Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org --- lib/efi_loader/Kconfig | 1 + lib/efi_loader/efi_image_loader.c | 62 ++++++++++++++++++++++++++++++- 2 files changed, 61 insertions(+), 2 deletions(-)
diff --git a/lib/efi_loader/Kconfig b/lib/efi_loader/Kconfig index e2a1a5a69a24..e3f2402d0e8e 100644 --- a/lib/efi_loader/Kconfig +++ b/lib/efi_loader/Kconfig @@ -366,6 +366,7 @@ config EFI_SECURE_BOOT select X509_CERTIFICATE_PARSER select PKCS7_MESSAGE_PARSER select PKCS7_VERIFY + select MSCODE_PARSER select EFI_SIGNATURE_SUPPORT help Select this option to enable EFI secure boot support. diff --git a/lib/efi_loader/efi_image_loader.c b/lib/efi_loader/efi_image_loader.c index fe8e4a89082c..eaf75a5803d4 100644 --- a/lib/efi_loader/efi_image_loader.c +++ b/lib/efi_loader/efi_image_loader.c @@ -16,6 +16,7 @@ #include <malloc.h> #include <pe.h> #include <sort.h> +#include <crypto/mscode.h> #include <crypto/pkcs7_parser.h> #include <linux/err.h>
@@ -516,6 +517,51 @@ err: }
#ifdef CONFIG_EFI_SECURE_BOOT +/** + * efi_image_verify_digest - verify image's message digest + * @regs: Array of memory regions to digest + * @msg: Signature in pkcs7 structure + * + * @regs contains all the data in a PE image to digest. Calculate + * a hash value based on @regs and compare it with a messaged digest + * in the content (SpcPeImageData) of @msg's contentInfo. + * + * Return: true if verified, false if not + */ +static bool efi_image_verify_digest(struct efi_image_regions *regs, + struct pkcs7_message *msg) +{ + struct pefile_context ctx; + void *hash; + int hash_len, ret; + + const void *data; + size_t data_len; + size_t asn1hdrlen; + + /* get pkcs7's contentInfo */ + ret = pkcs7_get_content_data(msg, &data, &data_len, &asn1hdrlen); + if (ret < 0 || !data) + return false; + + /* parse data and retrieve a message digest into ctx */ + ret = mscode_parse(&ctx, data, data_len, asn1hdrlen); + if (ret < 0) + return false; + + /* calculate a hash value of PE image */ + hash = NULL; + if (!efi_hash_regions(regs->reg, regs->num, &hash, ctx.digest_algo, + &hash_len)) + return false; + + /* match the digest */ + if (ctx.digest_len != hash_len || memcmp(ctx.digest, hash, hash_len)) + return false; + + return true; +} + /** * efi_image_authenticate() - verify a signature of signed image * @efi: Pointer to image @@ -645,6 +691,9 @@ static bool efi_image_authenticate(void *efi, size_t efi_size) }
/* + * verify signatures in pkcs7's signedInfos which are + * to authenticate the integrity of pkcs7's contentInfo. + * * NOTE: * UEFI specification defines two signature types possible * in signature database: @@ -677,12 +726,21 @@ static bool efi_image_authenticate(void *efi, size_t efi_size) }
/* try white-list */ - if (efi_signature_verify(regs, msg, db, dbx)) { + if (!efi_signature_verify(regs, msg, db, dbx)) { + log_debug("Signature was not verified by "db"\n"); + continue; + } + + /* + * now calculate an image's hash value and compare it with + * a messaged digest embedded in pkcs7's contentInfo + */ + if (efi_image_verify_digest(regs, msg)) { ret = true; continue; }
- log_debug("Signature was not verified by "db"\n"); + log_debug("Message digest doesn't match\n"); }
- select MSCODE_PARSER select EFI_SIGNATURE_SUPPORT help Select this option to enable EFI secure boot support.
- efi_image_verify_digest - verify image's message digest
- @regs: Array of memory regions to digest
- @msg: Signature in pkcs7 structure
- @regs contains all the data in a PE image to digest. Calculate
- a hash value based on @regs and compare it with a messaged digest
- in the content (SpcPeImageData) of @msg's contentInfo.
- Return: true if verified, false if not
- struct pefile_context ctx;
- void *hash;
- int hash_len, ret;
- const void *data;
- size_t data_len;
- size_t asn1hdrlen;
- /* get pkcs7's contentInfo */
- ret = pkcs7_get_content_data(msg, &data, &data_len, &asn1hdrlen);
- if (ret < 0 || !data)
return false;
- /* parse data and retrieve a message digest into ctx */
- ret = mscode_parse(&ctx, data, data_len, asn1hdrlen);
- if (ret < 0)
return false;
- /* calculate a hash value of PE image */
- hash = NULL;
- if (!efi_hash_regions(regs->reg, regs->num, &hash, ctx.digest_algo,
&hash_len))
return false;
- /* match the digest */
- if (ctx.digest_len != hash_len || memcmp(ctx.digest, hash, hash_len))
return false;
- return true;
- efi_image_authenticate() - verify a signature of signed image
- @efi: Pointer to image
- NOTE:
- UEFI specification defines two signature types possible
- in signature database:
Shouldn't this be log_err()?
continue;
}if (efi_image_verify_digest(regs, msg)) { ret = true; continue;
ditto?
Or does the caller write an error message somewhere?
Best regards
Heinrich
}log_debug("Message digest doesn't match\n");
Heinrich,
- void *hash;
- const void *data;
- size_t data_len;
return false;
- if (ret < 0)
return false;
- hash = NULL;
&hash_len))
return false;
return false;
- return true;
- NOTE:
I think that I have already explained my idea behind here in my previous reply.
continue;
ditto?
Yes: efi_load_pe() ... /* Authenticate an image */ if (efi_image_authenticate(efi, efi_size)) { handle->auth_status = EFI_IMAGE_AUTH_PASSED; } else { handle->auth_status = EFI_IMAGE_AUTH_FAILED; log_err("Image not authenticated\n"); }
-Takahiro Akashi
Best regards
Heinrich
In this test case, a image binary, helloworld.efi.signed, is willfully modified to print a corrupted message while the signature itself is unchanged.
This binary must be rejected under secure boot mode.
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org --- test/py/tests/test_efi_secboot/conftest.py | 3 ++ test/py/tests/test_efi_secboot/forge_image.sh | 5 +++ test/py/tests/test_efi_secboot/test_signed.py | 35 +++++++++++++++++++ 3 files changed, 43 insertions(+) create mode 100644 test/py/tests/test_efi_secboot/forge_image.sh
diff --git a/test/py/tests/test_efi_secboot/conftest.py b/test/py/tests/test_efi_secboot/conftest.py index 8a53dabe5414..db6b8d301f85 100644 --- a/test/py/tests/test_efi_secboot/conftest.py +++ b/test/py/tests/test_efi_secboot/conftest.py @@ -105,6 +105,9 @@ def efi_boot_env(request, u_boot_config): # Sign already-signed image with another key check_call('cd %s; sbsign --key db1.key --cert db1.crt --output helloworld.efi.signed_2sigs helloworld.efi.signed' % mnt_point, shell=True) + # Create a corrupted signed image + check_call('cd %s; sh %s/test/py/tests/test_efi_secboot/forge_image.sh helloworld.efi.signed helloworld_forged.efi.signed' + % (mnt_point, u_boot_config.source_dir), shell=True) # Digest image check_call('cd %s; %shash-to-efi-sig-list helloworld.efi db_hello.hash; %ssign-efi-sig-list -t "2020-04-07" -c KEK.crt -k KEK.key db db_hello.hash db_hello.auth' % (mnt_point, EFITOOLS_PATH, EFITOOLS_PATH), diff --git a/test/py/tests/test_efi_secboot/forge_image.sh b/test/py/tests/test_efi_secboot/forge_image.sh new file mode 100644 index 000000000000..2465d10fa7b8 --- /dev/null +++ b/test/py/tests/test_efi_secboot/forge_image.sh @@ -0,0 +1,5 @@ +# SPDX-License-Identifier: GPL-2.0-or-later +#!/bin/sh + +replace_exp="s/H\0e\0l\0l\0o\0/h\0E\0L\0L\0O\0/g" +perl -p -e ${replace_exp} < $1 > $2 diff --git a/test/py/tests/test_efi_secboot/test_signed.py b/test/py/tests/test_efi_secboot/test_signed.py index 30b3fa4e701e..ca52e853d8f8 100644 --- a/test/py/tests/test_efi_secboot/test_signed.py +++ b/test/py/tests/test_efi_secboot/test_signed.py @@ -334,3 +334,38 @@ class TestEfiSignedImage(object): 'efidebug test bootmgr']) assert ''HELLO' failed' in ''.join(output) assert 'efi_start_image() returned: 26' in ''.join(output) + + def test_efi_signed_image_auth8(self, u_boot_console, efi_boot_env): + """ + Test Case 8 - Secure boot is in force, + Same as Test Case 2 but the image binary to be loaded + was willfully modified (forged) + Must be rejected. + """ + u_boot_console.restart_uboot() + disk_img = efi_boot_env + with u_boot_console.log.section('Test Case 8a'): + # Test Case 8a, Secure boot is not yet forced + output = u_boot_console.run_command_list([ + 'host bind 0 %s' % disk_img, + 'efidebug boot add -b 1 HELLO1 host 0:1 /helloworld_forged.efi.signed -s ""', + 'efidebug boot next 1', + 'efidebug test bootmgr']) + assert('hELLO, world!' in ''.join(output)) + + with u_boot_console.log.section('Test Case 8b'): + # Test Case 8b, Install signature database and verify the image + output = u_boot_console.run_command_list([ + 'fatload host 0:1 4000000 db.auth', + 'setenv -e -nv -bs -rt -at -i 4000000:$filesize db', + 'fatload host 0:1 4000000 KEK.auth', + 'setenv -e -nv -bs -rt -at -i 4000000:$filesize KEK', + 'fatload host 0:1 4000000 PK.auth', + 'setenv -e -nv -bs -rt -at -i 4000000:$filesize PK']) + assert 'Failed to set EFI variable' not in ''.join(output) + output = u_boot_console.run_command_list([ + 'efidebug boot next 1', + 'efidebug test bootmgr']) + assert(not 'hELLO, world!' in ''.join(output)) + assert(''HELLO1' failed' in ''.join(output)) + assert('efi_start_image() returned: 26' in ''.join(output))
AKASHI Takahiro
Jason A. Donenfeld
