[U-Boot] [PATCH] eth: remove usb-ethernet devices before re-enumerating them
Fix the crash when running several times usb_init() with a USB ethernet device plugged.
Signed-off-by: Vincent Palatin vpalatin@chromium.org Tested-by: Wolfgang Grandegger wg@denx.de --- drivers/usb/eth/usb_ether.c | 7 +++++-- include/net.h | 1 + net/eth.c | 29 +++++++++++++++++++++++++++++ 3 files changed, 35 insertions(+), 2 deletions(-)
diff --git a/drivers/usb/eth/usb_ether.c b/drivers/usb/eth/usb_ether.c index 6565ea5..73a0790 100644 --- a/drivers/usb/eth/usb_ether.c +++ b/drivers/usb/eth/usb_ether.c @@ -127,8 +127,11 @@ int usb_host_eth_scan(int mode)
old_async = usb_disable_asynch(1); /* asynch transfer not allowed */
- for (i = 0; i < USB_MAX_ETH_DEV; i++) - memset(&usb_eth[i], 0, sizeof(usb_eth[i])); + /* unregister a previously detected device */ + for (i = 0; i < usb_max_eth_dev; i++) + eth_unregister(&usb_eth[i].eth_dev); + + memset(usb_eth, 0, sizeof(usb_eth));
for (i = 0; prob_dev[i].probe; i++) { if (prob_dev[i].before_probe) diff --git a/include/net.h b/include/net.h index e4d42c2..1707a7f 100644 --- a/include/net.h +++ b/include/net.h @@ -96,6 +96,7 @@ struct eth_device {
extern int eth_initialize(bd_t *bis); /* Initialize network subsystem */ extern int eth_register(struct eth_device* dev);/* Register network device */ +extern int eth_unregister(struct eth_device *dev);/* Remove network device */ extern void eth_try_another(int first_restart); /* Change the device */ extern void eth_set_current(void); /* set nterface to ethcur var */ extern struct eth_device *eth_get_dev(void); /* get the current device MAC */ diff --git a/net/eth.c b/net/eth.c index b4b9b43..3fb5fb6 100644 --- a/net/eth.c +++ b/net/eth.c @@ -224,6 +224,35 @@ int eth_register(struct eth_device *dev) return 0; }
+int eth_unregister(struct eth_device *dev) +{ + struct eth_device *cur; + + /* No device */ + if (!eth_devices) + return -1; + + for (cur = eth_devices; cur->next != eth_devices && cur->next != dev; + cur = cur->next) + ; + + /* Device not found */ + if (cur->next != dev) + return -1; + + cur->next = dev->next; + + if (eth_devices == dev) + eth_devices = dev->next == eth_devices ? NULL : dev->next; + + if (eth_current == dev) { + eth_current = eth_devices; + eth_current_changed(); + } + + return 0; +} + int eth_initialize(bd_t *bis) { int num_devices = 0;
ethcur
- struct eth_device *cur;
- /* No device */
- if (!eth_devices)
return -1;
- for (cur = eth_devices; cur->next != eth_devices && cur->next != dev;
cur = cur->next)
- /* Device not found */
- if (cur->next != dev)
return -1;
- cur->next = dev->next;
- if (eth_devices == dev)
- if (eth_current == dev) {
Looks sane. On what hardware did this happen (just for the record)?
M
- /* unregister a previously detected device */
- for (i = 0; i < usb_max_eth_dev; i++)
- eth_unregister(&usb_eth[i].eth_dev);
- memset(usb_eth, 0, sizeof(usb_eth));
ethcur
- /* No device */
- if (!eth_devices)
- return -1;
- cur = cur->next)
- return -1;
- eth_devices = dev->next == eth_devices ? NULL : dev->next;
- eth_current = eth_devices;
- eth_current_changed();
I got it on x86 and ARM (tegra2) platforms (both with an EHCI controller). I did most of my testing with ASIX-based USB-ethernet dongle, but the issue seems pretty generic.
memset(usb_eth, 0, sizeof(usb_eth)); for (i = 0; prob_dev[i].probe; i++) { if (prob_dev[i].before_probe)
ethcur
/* No device */
if (!eth_devices)
return -1;
cur = cur->next)
return -1;
It happens with *any* hardware calling eth_register() more than once because "struct eth_device *dev*" is memset 0 before calling eth_register() resulting in an endless loop when scanning the devices.
Viele Grüße,
Wolfgang
ethcur
/* No device */
if (!eth_devices)
return -1;
return -1;
dev->next; +
Yes, I'll try to remember to test this in the evening.
M
Viele Grüße,
Wolfgang
2012/1/9 Vincent Palatin vpalatin@chromium.org:
Applied to u-boot-usb. Thanks.
Kind regards,
Remy
what's the status of this patch/patchset?
Thanks M
Hi Marek,
I believe it should be applied.
Thanks M _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Dear Simon Glass,
Hi Marek,
Should be applied to linux-usb now, thanks!
Best regards, Marek Vasut
participants (6)
Remy Bohmer
Vincent Palatin
Wolfgang Grandegger
