[PATCH 1/4] rockchip: rk3308: fix board_debug_uart_init
Definition of function board_debug_uart_init() must be under CONFIG_DEBUG_UART_BOARD_INIT and not under CONFIG_DEBUG_UART, as it was: see debug_uart.h. In this way the debug uart can be used but its board-specific initialization skipped by configuration, if useless.
Signed-off-by: Massimo Pegorer massimo.pegorer@vimar.com --- arch/arm/mach-rockchip/rk3308/rk3308.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/mach-rockchip/rk3308/rk3308.c b/arch/arm/mach-rockchip/rk3308/rk3308.c index dd9109b7c3..5763604dc3 100644 --- a/arch/arm/mach-rockchip/rk3308/rk3308.c +++ b/arch/arm/mach-rockchip/rk3308/rk3308.c @@ -174,7 +174,7 @@ int rk_board_init(void) return 0; }
-#if defined(CONFIG_DEBUG_UART) +#ifdef CONFIG_DEBUG_UART_BOARD_INIT __weak void board_debug_uart_init(void) { static struct rk3308_grf * const grf = (void *)GRF_BASE;
Pegorer Massimo
