[U-Boot-Users] [PATCH 4/5] 83xx: initialize serdes for MPC837XRDB boards
On the MPC8377ERDB: 2 SATA and 2 PCI-E. On the MPC8378ERDB: 2 PCI-E On the MPC8379ERDB: 4 SATA
Signed-off-by: Anton Vorontsov avorontsov@ru.mvista.com ---
Rebased on top of today's u-boot-mpc83xx.
board/freescale/mpc837xerdb/mpc837xerdb.c | 37 +++++++++++++++++++++++++++++ include/configs/MPC837XERDB.h | 6 ++++ 2 files changed, 43 insertions(+), 0 deletions(-)
diff --git a/board/freescale/mpc837xerdb/mpc837xerdb.c b/board/freescale/mpc837xerdb/mpc837xerdb.c index a3b20b8..d091538 100644 --- a/board/freescale/mpc837xerdb/mpc837xerdb.c +++ b/board/freescale/mpc837xerdb/mpc837xerdb.c @@ -15,6 +15,7 @@ #include <common.h> #include <i2c.h> #include <asm/io.h> +#include <asm/fsl_serdes.h> #include <spd_sdram.h> #include <vsc7385.h>
@@ -132,6 +133,42 @@ int checkboard(void) return 0; }
+int board_early_init_f(void) +{ +#ifdef CONFIG_FSL_SERDES + immap_t *immr = (immap_t *)CFG_IMMR; + u32 spridr = in_be32(&immr->sysconf.spridr); + + /* we check only part num, and don't look for CPU revisions */ + switch (spridr >> 16) { + case SPR_8379E_REV10 >> 16: + case SPR_8379_REV10 >> 16: + fsl_setup_serdes(CONFIG_FSL_SERDES1, FSL_SERDES_PROTO_SATA, + FSL_SERDES_CLK_100, FSL_SERDES_VDD_1V); + fsl_setup_serdes(CONFIG_FSL_SERDES2, FSL_SERDES_PROTO_SATA, + FSL_SERDES_CLK_100, FSL_SERDES_VDD_1V); + break; + case SPR_8378E_REV10 >> 16: + case SPR_8378_REV10 >> 16: + fsl_setup_serdes(CONFIG_FSL_SERDES1, FSL_SERDES_PROTO_PEX, + FSL_SERDES_CLK_100, FSL_SERDES_VDD_1V); + break; + case SPR_8377E_REV10 >> 16: + case SPR_8377_REV10 >> 16: + fsl_setup_serdes(CONFIG_FSL_SERDES1, FSL_SERDES_PROTO_SATA, + FSL_SERDES_CLK_100, FSL_SERDES_VDD_1V); + fsl_setup_serdes(CONFIG_FSL_SERDES2, FSL_SERDES_PROTO_PEX, + FSL_SERDES_CLK_100, FSL_SERDES_VDD_1V); + break; + default: + printf("serdes not configured: unknown CPU part number: " + "%04x\n", spridr >> 16); + break; + } +#endif /* CONFIG_FSL_SERDES */ + return 0; +} + /* * Miscellaneous late-boot configurations * diff --git a/include/configs/MPC837XERDB.h b/include/configs/MPC837XERDB.h index e3cb3c7..c2e7701 100644 --- a/include/configs/MPC837XERDB.h +++ b/include/configs/MPC837XERDB.h @@ -32,6 +32,7 @@
#define CONFIG_PCI 1
+#define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_MISC_INIT_R
/* @@ -323,6 +324,11 @@ #define CFG_NS16550_COM1 (CFG_IMMR+0x4500) #define CFG_NS16550_COM2 (CFG_IMMR+0x4600)
+/* SERDES */ +#define CONFIG_FSL_SERDES +#define CONFIG_FSL_SERDES1 0xe3000 +#define CONFIG_FSL_SERDES2 0xe3100 + /* Use the HUSH parser */ #define CFG_HUSH_PARSER #ifdef CFG_HUSH_PARSER
Anton Vorontsov
