[PATCH] xilinx: zynqmp: Save multiboot as variable
Save multiboot register as u-boot variable. And use it as primary source for composing dfu_alt_info for capsule update. If variable is not defined
board/xilinx/zynqmp/zynqmp.c | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/board/xilinx/zynqmp/zynqmp.c b/board/xilinx/zynqmp/zynqmp.c index ed6c287df221..5fce74d6085a 100644 --- a/board/xilinx/zynqmp/zynqmp.c +++ b/board/xilinx/zynqmp/zynqmp.c @@ -658,6 +658,8 @@ int board_late_init(void) if (ret) return ret;
+ env_set_hex("multiboot", multi_boot()); + bootmode = zynqmp_get_bootmode();
puts("Bootmode: "); @@ -863,7 +865,7 @@ void set_dfu_alt_info(char *interface, char *devstr)
memset(buf, 0, sizeof(buf));
- multiboot = multi_boot(); + multiboot = env_get_hex("multiboot", multi_boot()); debug("Multiboot: %d\n", multiboot);
switch (zynqmp_get_bootmode()) {
multi_boot() can return error -EINVAL. Probably it would be better to handle this before setting the env variable?
bootmode = zynqmp_get_bootmode(); puts("Bootmode: ");
multiboot = env_get_hex("multiboot", multi_boot()); debug("Multiboot: %d\n", multiboot); switch (zynqmp_get_bootmode()) {
-- 2.33.1
Sent v2 to fix this.
Thanks, Michal
Michal Simek
Oleksandr Suvorov
