[PATCH] arm: dts: imx8mn-u-boot: use versioned ddr4 firmware
NXP tested imx8mn-ddr4 with firmware version 201810 only. Use this version for all imx8mn targets with DRAM DDR4.
Fixes: 93c4c0e4dd1 ("arm: dts: imx8mn-u-boot: Create common imx8mn-u-boot.dtsi")
Signed-off-by: Oleksandr Suvorov oleksandr.suvorov@foundries.io ---
arch/arm/dts/imx8mn-u-boot.dtsi | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/arch/arm/dts/imx8mn-u-boot.dtsi b/arch/arm/dts/imx8mn-u-boot.dtsi index 95f45ad2522..4e3818ec2b8 100644 --- a/arch/arm/dts/imx8mn-u-boot.dtsi +++ b/arch/arm/dts/imx8mn-u-boot.dtsi @@ -85,7 +85,7 @@ #ifdef CONFIG_IMX8M_LPDDR4 filename = "lpddr4_pmu_train_1d_imem.bin"; #elif CONFIG_IMX8M_DDR4 - filename = "ddr4_imem_1d.bin"; + filename = "ddr4_imem_1d_201810.bin"; #else filename = "ddr3_imem_1d.bin"; #endif @@ -97,7 +97,7 @@ #ifdef CONFIG_IMX8M_LPDDR4 filename = "lpddr4_pmu_train_1d_dmem.bin"; #elif CONFIG_IMX8M_DDR4 - filename = "ddr4_dmem_1d.bin"; + filename = "ddr4_dmem_1d_201810.bin"; #else filename = "ddr3_dmem_1d.bin"; #endif @@ -109,7 +109,7 @@ #ifdef CONFIG_IMX8M_LPDDR4 filename = "lpddr4_pmu_train_2d_imem.bin"; #elif CONFIG_IMX8M_DDR4 - filename = "ddr4_imem_2d.bin"; + filename = "ddr4_imem_2d_201810.bin"; #endif type = "blob-ext"; align-end = <4>; @@ -119,7 +119,7 @@ #ifdef CONFIG_IMX8M_LPDDR4 filename = "lpddr4_pmu_train_2d_dmem.bin"; #elif CONFIG_IMX8M_DDR4 - filename = "ddr4_dmem_2d.bin"; + filename = "ddr4_dmem_2d_201810.bin"; #endif type = "blob-ext"; align-end = <4>;
Hi Oleksandr,
On Mon, Jan 16, 2023 at 12:21 PM Oleksandr Suvorov oleksandr.suvorov@foundries.io wrote:
Thanks for your patch:
Reviewed-by: Fabio Estevam festevam@denx.de
NXP tested imx8mn-ddr4 with firmware version 201810 only. Use this version for all imx8mn targets with DRAM DDR4. Fixes: 93c4c0e4dd1 ("arm: dts: imx8mn-u-boot: Create common imx8mn-u-boot.dtsi") Signed-off-by: Oleksandr Suvorov oleksandr.suvorov@foundries.io Reviewed-by: Fabio Estevam festevam@denx.de
Best regards, Stefano Babic
Fabio Estevam
Oleksandr Suvorov
sbabic@denx.de
