[U-Boot-Users] CVS tree broken for MPC8245-based boards
Hello,
It appears that only the first part of Marc Leeman's patch submitted on 11 May, 2004 (subject: [patch] master read fix mpc8245) was applied, resulting in the current CVS tree being broken for MPC8245-based boards. The portion of the patch that was applied requires a new register address to be defined in include/mpc8245.h, which was done in the second part of the patch. Gleb Natapov also raised this issue on 12 July, 2004, but received no reply from the list. I don't mean to sound redundant, but is the second part of the patch going to be applied soon?
Thanks, Matthew
Sorry, missed the mail.
--- u-boot-1.1.1-orig/include/mpc824x.h 2004-07-16 11:46:01.000000000 +0200 +++ u-boot-1.1.1/include/mpc824x.h 2004-07-16 15:13:39.000000000 +0200 @@ -297,6 +297,7 @@ #define PBESR 0x800000c7 /* PCI Bus Error Status Register */ #define PBEAR 0x800000c8 /* Processor/PCI Bus Error Status Register */ #define AMBOR 0x800000e0 /* Address Map B Options Register */ +#define PCMBCR 0x800000e1 /* PCI/Memeory Buffer Configuration */ #define MCCR1 0x800000f0 /* Memory Control Configuration Register 1 */ #define MCCR2 0x800000f4 /* Memory Control Configuration Register 2 */ #define MCCR3 0x800000f8 /* Memory Control Configuration Register 3 */
Hello,
There was one more question in that mail, but if you missed it let me repeat: Where register 0x800000e1 is documented? :)
TIA.
-- Gleb.
Page 4-51, section 4.11 of the MPC8245 Integrated Processor User's Manual.
A slightly more verbose bugreport can be downloaded from: http://scorpius.homelinux.org/~marc/downloads/masterwrite.pdf
It seems to be a known problem inside Motorola.
Thank you! It is not mentioned in revision 1 of this manual, but it is present in rev 2.
-- Gleb.
Just for the record: done.
gleb@nbase.co.il
Marc Leeman
Matthew Karger
