[U-Boot] [PATCH 0/5] mmc: uniphier: migrate to CONFIG_DM_MMC_OPS and CONFIG_BLK
Masahiro Yamada (5): mmc: uniphier-sd: migrate to CONFIG_DM_MMC_OPS mmc: uniphier-sd: move uniphier_sd_init() below mmc: uniphier-sd: return error code if unsupported width is given mmc: uniphier-sd: just return if already set to desired clock rate mmc: uniphier-sd: migrate to CONFIG_BLK
arch/arm/Kconfig | 1 + drivers/mmc/Kconfig | 2 + drivers/mmc/uniphier-sd.c | 186 ++++++++++++++++++++++++---------------------- 3 files changed, 99 insertions(+), 90 deletions(-)
Catch up with the DM migration.
As struct dm_mmc_ops does not have .init callback, call the init function directly from the probe function.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
drivers/mmc/Kconfig | 1 + drivers/mmc/uniphier-sd.c | 97 ++++++++++++++++++++++++----------------------- 2 files changed, 51 insertions(+), 47 deletions(-)
diff --git a/drivers/mmc/Kconfig b/drivers/mmc/Kconfig index b820485..4cdd9b1 100644 --- a/drivers/mmc/Kconfig +++ b/drivers/mmc/Kconfig @@ -80,6 +80,7 @@ config ROCKCHIP_SDHCI config MMC_UNIPHIER bool "UniPhier SD/MMC Host Controller support" depends on ARCH_UNIPHIER + select DM_MMC_OPS help This selects support for the SD/MMC Host Controller on UniPhier SoCs.
diff --git a/drivers/mmc/uniphier-sd.c b/drivers/mmc/uniphier-sd.c index f06e737..b8e784f 100644 --- a/drivers/mmc/uniphier-sd.c +++ b/drivers/mmc/uniphier-sd.c @@ -122,7 +122,6 @@ DECLARE_GLOBAL_DATA_PTR; struct uniphier_sd_priv { struct mmc_config cfg; struct mmc *mmc; - struct udevice *dev; void __iomem *regbase; unsigned long mclk; unsigned int version; @@ -152,8 +151,9 @@ static void __dma_unmap_single(dma_addr_t addr, size_t size, invalidate_dcache_range(addr, addr + size); }
-static int uniphier_sd_check_error(struct uniphier_sd_priv *priv) +static int uniphier_sd_check_error(struct udevice *dev) { + struct uniphier_sd_priv *priv = dev_get_priv(dev); u32 info2 = readl(priv->regbase + UNIPHIER_SD_INFO2);
if (info2 & UNIPHIER_SD_INFO2_ERR_RTO) { @@ -166,38 +166,39 @@ static int uniphier_sd_check_error(struct uniphier_sd_priv *priv) }
if (info2 & UNIPHIER_SD_INFO2_ERR_TO) { - dev_err(priv->dev, "timeout error\n"); + dev_err(dev, "timeout error\n"); return -ETIMEDOUT; }
if (info2 & (UNIPHIER_SD_INFO2_ERR_END | UNIPHIER_SD_INFO2_ERR_CRC | UNIPHIER_SD_INFO2_ERR_IDX)) { - dev_err(priv->dev, "communication out of sync\n"); + dev_err(dev, "communication out of sync\n"); return -EILSEQ; }
if (info2 & (UNIPHIER_SD_INFO2_ERR_ILA | UNIPHIER_SD_INFO2_ERR_ILR | UNIPHIER_SD_INFO2_ERR_ILW)) { - dev_err(priv->dev, "illegal access\n"); + dev_err(dev, "illegal access\n"); return -EIO; }
return 0; }
-static int uniphier_sd_wait_for_irq(struct uniphier_sd_priv *priv, - unsigned int reg, u32 flag) +static int uniphier_sd_wait_for_irq(struct udevice *dev, unsigned int reg, + u32 flag) { + struct uniphier_sd_priv *priv = dev_get_priv(dev); long wait = 1000000; int ret;
while (!(readl(priv->regbase + reg) & flag)) { if (wait-- < 0) { - dev_err(priv->dev, "timeout\n"); + dev_err(dev, "timeout\n"); return -ETIMEDOUT; }
- ret = uniphier_sd_check_error(priv); + ret = uniphier_sd_check_error(dev); if (ret) return ret;
@@ -207,14 +208,14 @@ static int uniphier_sd_wait_for_irq(struct uniphier_sd_priv *priv, return 0; }
-static int uniphier_sd_pio_read_one_block(struct mmc *mmc, u32 **pbuf, +static int uniphier_sd_pio_read_one_block(struct udevice *dev, u32 **pbuf, uint blocksize) { - struct uniphier_sd_priv *priv = mmc->priv; + struct uniphier_sd_priv *priv = dev_get_priv(dev); int i, ret;
/* wait until the buffer is filled with data */ - ret = uniphier_sd_wait_for_irq(priv, UNIPHIER_SD_INFO2, + ret = uniphier_sd_wait_for_irq(dev, UNIPHIER_SD_INFO2, UNIPHIER_SD_INFO2_BRE); if (ret) return ret; @@ -237,14 +238,14 @@ static int uniphier_sd_pio_read_one_block(struct mmc *mmc, u32 **pbuf, return 0; }
-static int uniphier_sd_pio_write_one_block(struct mmc *mmc, const u32 **pbuf, - uint blocksize) +static int uniphier_sd_pio_write_one_block(struct udevice *dev, + const u32 **pbuf, uint blocksize) { - struct uniphier_sd_priv *priv = mmc->priv; + struct uniphier_sd_priv *priv = dev_get_priv(dev); int i, ret;
/* wait until the buffer becomes empty */ - ret = uniphier_sd_wait_for_irq(priv, UNIPHIER_SD_INFO2, + ret = uniphier_sd_wait_for_irq(dev, UNIPHIER_SD_INFO2, UNIPHIER_SD_INFO2_BWE); if (ret) return ret; @@ -263,7 +264,7 @@ static int uniphier_sd_pio_write_one_block(struct mmc *mmc, const u32 **pbuf, return 0; }
-static int uniphier_sd_pio_xfer(struct mmc *mmc, struct mmc_data *data) +static int uniphier_sd_pio_xfer(struct udevice *dev, struct mmc_data *data) { u32 *dest = (u32 *)data->dest; const u32 *src = (const u32 *)data->src; @@ -271,10 +272,10 @@ static int uniphier_sd_pio_xfer(struct mmc *mmc, struct mmc_data *data)
for (i = 0; i < data->blocks; i++) { if (data->flags & MMC_DATA_READ) - ret = uniphier_sd_pio_read_one_block(mmc, &dest, + ret = uniphier_sd_pio_read_one_block(dev, &dest, data->blocksize); else - ret = uniphier_sd_pio_write_one_block(mmc, &src, + ret = uniphier_sd_pio_write_one_block(dev, &src, data->blocksize); if (ret) return ret; @@ -306,14 +307,15 @@ static void uniphier_sd_dma_start(struct uniphier_sd_priv *priv, writel(UNIPHIER_SD_DMA_CTL_START, priv->regbase + UNIPHIER_SD_DMA_CTL); }
-static int uniphier_sd_dma_wait_for_irq(struct uniphier_sd_priv *priv, u32 flag, +static int uniphier_sd_dma_wait_for_irq(struct udevice *dev, u32 flag, unsigned int blocks) { + struct uniphier_sd_priv *priv = dev_get_priv(dev); long wait = 1000000 + 10 * blocks;
while (!(readl(priv->regbase + UNIPHIER_SD_DMA_INFO1) & flag)) { if (wait-- < 0) { - dev_err(priv->dev, "timeout during DMA\n"); + dev_err(dev, "timeout during DMA\n"); return -ETIMEDOUT; }
@@ -321,16 +323,16 @@ static int uniphier_sd_dma_wait_for_irq(struct uniphier_sd_priv *priv, u32 flag, }
if (readl(priv->regbase + UNIPHIER_SD_DMA_INFO2)) { - dev_err(priv->dev, "error during DMA\n"); + dev_err(dev, "error during DMA\n"); return -EIO; }
return 0; }
-static int uniphier_sd_dma_xfer(struct mmc *mmc, struct mmc_data *data) +static int uniphier_sd_dma_xfer(struct udevice *dev, struct mmc_data *data) { - struct uniphier_sd_priv *priv = mmc->priv; + struct uniphier_sd_priv *priv = dev_get_priv(dev); size_t len = data->blocks * data->blocksize; void *buf; enum dma_data_direction dir; @@ -358,7 +360,7 @@ static int uniphier_sd_dma_xfer(struct mmc *mmc, struct mmc_data *data)
uniphier_sd_dma_start(priv, dma_addr);
- ret = uniphier_sd_dma_wait_for_irq(priv, poll_flag, data->blocks); + ret = uniphier_sd_dma_wait_for_irq(dev, poll_flag, data->blocks);
__dma_unmap_single(dma_addr, len, dir);
@@ -384,15 +386,15 @@ static bool uniphier_sd_addr_is_dmaable(unsigned long addr) return true; }
-static int uniphier_sd_send_cmd(struct mmc *mmc, struct mmc_cmd *cmd, +static int uniphier_sd_send_cmd(struct udevice *dev, struct mmc_cmd *cmd, struct mmc_data *data) { - struct uniphier_sd_priv *priv = mmc->priv; + struct uniphier_sd_priv *priv = dev_get_priv(dev); int ret; u32 tmp;
if (readl(priv->regbase + UNIPHIER_SD_INFO2) & UNIPHIER_SD_INFO2_CBSY) { - dev_err(priv->dev, "command busy\n"); + dev_err(dev, "command busy\n"); return -EBUSY; }
@@ -446,15 +448,15 @@ static int uniphier_sd_send_cmd(struct mmc *mmc, struct mmc_cmd *cmd, tmp |= UNIPHIER_SD_CMD_RSP_R3; break; default: - dev_err(priv->dev, "unknown response type\n"); + dev_err(dev, "unknown response type\n"); return -EINVAL; }
- dev_dbg(priv->dev, "sending CMD%d (SD_CMD=%08x, SD_ARG=%08x)\n", + dev_dbg(dev, "sending CMD%d (SD_CMD=%08x, SD_ARG=%08x)\n", cmd->cmdidx, tmp, cmd->cmdarg); writel(tmp, priv->regbase + UNIPHIER_SD_CMD);
- ret = uniphier_sd_wait_for_irq(priv, UNIPHIER_SD_INFO1, + ret = uniphier_sd_wait_for_irq(dev, UNIPHIER_SD_INFO1, UNIPHIER_SD_INFO1_RSP); if (ret) return ret; @@ -481,11 +483,11 @@ static int uniphier_sd_send_cmd(struct mmc *mmc, struct mmc_cmd *cmd, /* use DMA if the HW supports it and the buffer is aligned */ if (priv->caps & UNIPHIER_SD_CAP_DMA_INTERNAL && uniphier_sd_addr_is_dmaable((long)data->src)) - ret = uniphier_sd_dma_xfer(mmc, data); + ret = uniphier_sd_dma_xfer(dev, data); else - ret = uniphier_sd_pio_xfer(mmc, data); + ret = uniphier_sd_pio_xfer(dev, data);
- ret = uniphier_sd_wait_for_irq(priv, UNIPHIER_SD_INFO1, + ret = uniphier_sd_wait_for_irq(dev, UNIPHIER_SD_INFO1, UNIPHIER_SD_INFO1_CMP); if (ret) return ret; @@ -581,11 +583,12 @@ static void uniphier_sd_set_clk_rate(struct uniphier_sd_priv *priv, writel(tmp, priv->regbase + UNIPHIER_SD_CLKCTL); }
-static void uniphier_sd_set_ios(struct mmc *mmc) +static int uniphier_sd_set_ios(struct udevice *dev) { - struct uniphier_sd_priv *priv = mmc->priv; + struct uniphier_sd_priv *priv = dev_get_priv(dev); + struct mmc *mmc = mmc_get_mmc_dev(dev);
- dev_dbg(priv->dev, "clock %uHz, DDRmode %d, width %u\n", + dev_dbg(dev, "clock %uHz, DDRmode %d, width %u\n", mmc->clock, mmc->ddr_mode, mmc->bus_width);
uniphier_sd_set_bus_width(priv, mmc); @@ -593,11 +596,12 @@ static void uniphier_sd_set_ios(struct mmc *mmc) uniphier_sd_set_clk_rate(priv, mmc);
udelay(1000); + + return 0; }
-static int uniphier_sd_init(struct mmc *mmc) +static int uniphier_sd_init(struct uniphier_sd_priv *priv) { - struct uniphier_sd_priv *priv = mmc->priv; u32 tmp;
/* soft reset of the host */ @@ -628,9 +632,9 @@ static int uniphier_sd_init(struct mmc *mmc) return 0; }
-static int uniphier_sd_getcd(struct mmc *mmc) +static int uniphier_sd_get_cd(struct udevice *dev) { - struct uniphier_sd_priv *priv = mmc->priv; + struct uniphier_sd_priv *priv = dev_get_priv(dev);
if (priv->caps & UNIPHIER_SD_CAP_NONREMOVABLE) return 1; @@ -639,11 +643,10 @@ static int uniphier_sd_getcd(struct mmc *mmc) UNIPHIER_SD_INFO1_CD); }
-static const struct mmc_ops uniphier_sd_ops = { +static const struct dm_mmc_ops uniphier_sd_ops = { .send_cmd = uniphier_sd_send_cmd, .set_ios = uniphier_sd_set_ios, - .init = uniphier_sd_init, - .getcd = uniphier_sd_getcd, + .get_cd = uniphier_sd_get_cd, };
static int uniphier_sd_probe(struct udevice *dev) @@ -654,8 +657,6 @@ static int uniphier_sd_probe(struct udevice *dev) struct clk clk; int ret;
- priv->dev = dev; - base = dev_get_addr(dev); if (base == FDT_ADDR_T_NONE) return -EINVAL; @@ -686,7 +687,6 @@ static int uniphier_sd_probe(struct udevice *dev) }
priv->cfg.name = dev->name; - priv->cfg.ops = &uniphier_sd_ops; priv->cfg.host_caps = MMC_MODE_HS_52MHz | MMC_MODE_HS;
switch (fdtdec_get_int(gd->fdt_blob, dev->of_offset, "bus-width", 1)) { @@ -715,6 +715,8 @@ static int uniphier_sd_probe(struct udevice *dev) priv->caps |= UNIPHIER_SD_CAP_DIV1024; }
+ uniphier_sd_init(priv); + priv->cfg.voltages = MMC_VDD_165_195 | MMC_VDD_32_33 | MMC_VDD_33_34; priv->cfg.f_min = priv->mclk / (priv->caps & UNIPHIER_SD_CAP_DIV1024 ? 1024 : 512); @@ -752,4 +754,5 @@ U_BOOT_DRIVER(uniphier_mmc) = { .probe = uniphier_sd_probe, .remove = uniphier_sd_remove, .priv_auto_alloc_size = sizeof(struct uniphier_sd_priv), + .ops = &uniphier_sd_ops, };
On 24 August 2016 at 23:52, Masahiro Yamada yamada.masahiro@socionext.com wrote:
No more reason to define this function above the ops structure. Move it near the caller. Also, change its return type to void because it never fails.
drivers/mmc/uniphier-sd.c | 40 +++++++++++++++++++--------------------- 1 file changed, 19 insertions(+), 21 deletions(-)
diff --git a/drivers/mmc/uniphier-sd.c b/drivers/mmc/uniphier-sd.c index b8e784f..b254c70 100644 --- a/drivers/mmc/uniphier-sd.c +++ b/drivers/mmc/uniphier-sd.c @@ -600,7 +600,24 @@ static int uniphier_sd_set_ios(struct udevice *dev) return 0; }
-static int uniphier_sd_init(struct uniphier_sd_priv *priv) +static int uniphier_sd_get_cd(struct udevice *dev) +{ + struct uniphier_sd_priv *priv = dev_get_priv(dev); + + if (priv->caps & UNIPHIER_SD_CAP_NONREMOVABLE) + return 1; + + return !!(readl(priv->regbase + UNIPHIER_SD_INFO1) & + UNIPHIER_SD_INFO1_CD); +} + +static const struct dm_mmc_ops uniphier_sd_ops = { + .send_cmd = uniphier_sd_send_cmd, + .set_ios = uniphier_sd_set_ios, + .get_cd = uniphier_sd_get_cd, +}; + +static void uniphier_sd_host_init(struct uniphier_sd_priv *priv) { u32 tmp;
@@ -628,27 +645,8 @@ static int uniphier_sd_init(struct uniphier_sd_priv *priv) tmp |= UNIPHIER_SD_DMA_MODE_ADDR_INC; writel(tmp, priv->regbase + UNIPHIER_SD_DMA_MODE); } - - return 0; -} - -static int uniphier_sd_get_cd(struct udevice *dev) -{ - struct uniphier_sd_priv *priv = dev_get_priv(dev); - - if (priv->caps & UNIPHIER_SD_CAP_NONREMOVABLE) - return 1; - - return !!(readl(priv->regbase + UNIPHIER_SD_INFO1) & - UNIPHIER_SD_INFO1_CD); }
-static const struct dm_mmc_ops uniphier_sd_ops = { - .send_cmd = uniphier_sd_send_cmd, - .set_ios = uniphier_sd_set_ios, - .get_cd = uniphier_sd_get_cd, -}; - static int uniphier_sd_probe(struct udevice *dev) { struct uniphier_sd_priv *priv = dev_get_priv(dev); @@ -715,7 +713,7 @@ static int uniphier_sd_probe(struct udevice *dev) priv->caps |= UNIPHIER_SD_CAP_DIV1024; }
- uniphier_sd_init(priv); + uniphier_sd_host_init(priv);
With the CONFIG_DM_MMC_OPS migration, the .set_ios callback can return an integer now. Return an appropriate error value rather than sudden death by BUG().
drivers/mmc/uniphier-sd.c | 14 +++++++++----- 1 file changed, 9 insertions(+), 5 deletions(-)
diff --git a/drivers/mmc/uniphier-sd.c b/drivers/mmc/uniphier-sd.c index b254c70..40a5c85 100644 --- a/drivers/mmc/uniphier-sd.c +++ b/drivers/mmc/uniphier-sd.c @@ -496,8 +496,8 @@ static int uniphier_sd_send_cmd(struct udevice *dev, struct mmc_cmd *cmd, return ret; }
-static void uniphier_sd_set_bus_width(struct uniphier_sd_priv *priv, - struct mmc *mmc) +static int uniphier_sd_set_bus_width(struct uniphier_sd_priv *priv, + struct mmc *mmc) { u32 val, tmp;
@@ -512,14 +512,15 @@ static void uniphier_sd_set_bus_width(struct uniphier_sd_priv *priv, val = UNIPHIER_SD_OPTION_WIDTH_8; break; default: - BUG(); - break; + return -EINVAL; }
tmp = readl(priv->regbase + UNIPHIER_SD_OPTION); tmp &= ~UNIPHIER_SD_OPTION_WIDTH_MASK; tmp |= val; writel(tmp, priv->regbase + UNIPHIER_SD_OPTION); + + return 0; }
static void uniphier_sd_set_ddr_mode(struct uniphier_sd_priv *priv, @@ -587,11 +588,14 @@ static int uniphier_sd_set_ios(struct udevice *dev) { struct uniphier_sd_priv *priv = dev_get_priv(dev); struct mmc *mmc = mmc_get_mmc_dev(dev); + int ret;
- uniphier_sd_set_bus_width(priv, mmc); + ret = uniphier_sd_set_bus_width(priv, mmc); + if (ret) + return ret; uniphier_sd_set_ddr_mode(priv, mmc); uniphier_sd_set_clk_rate(priv, mmc);
With this, we can save unnecessary udelay().
drivers/mmc/uniphier-sd.c | 7 +++++-- 1 file changed, 5 insertions(+), 2 deletions(-)
diff --git a/drivers/mmc/uniphier-sd.c b/drivers/mmc/uniphier-sd.c index 40a5c85..701b26f 100644 --- a/drivers/mmc/uniphier-sd.c +++ b/drivers/mmc/uniphier-sd.c @@ -571,6 +571,9 @@ static void uniphier_sd_set_clk_rate(struct uniphier_sd_priv *priv, val = UNIPHIER_SD_CLKCTL_DIV1024;
tmp = readl(priv->regbase + UNIPHIER_SD_CLKCTL); + if (tmp & UNIPHIER_SD_CLKCTL_SCLKEN && + (tmp & UNIPHIER_SD_CLKCTL_DIV_MASK) == val) + return;
/* stop the clock before changing its rate to avoid a glitch signal */ tmp &= ~UNIPHIER_SD_CLKCTL_SCLKEN; @@ -582,6 +585,8 @@ static void uniphier_sd_set_clk_rate(struct uniphier_sd_priv *priv,
tmp |= UNIPHIER_SD_CLKCTL_SCLKEN; writel(tmp, priv->regbase + UNIPHIER_SD_CLKCTL); + + udelay(1000); }
static int uniphier_sd_set_ios(struct udevice *dev) @@ -599,8 +604,6 @@ static int uniphier_sd_set_ios(struct udevice *dev) uniphier_sd_set_ddr_mode(priv, mmc); uniphier_sd_set_clk_rate(priv, mmc);
- udelay(1000); - return 0; }
This is the state-of-the-art MMC driver implementation.
arch/arm/Kconfig | 1 + drivers/mmc/Kconfig | 1 + drivers/mmc/uniphier-sd.c | 50 +++++++++++++++++++++++------------------------ 3 files changed, 26 insertions(+), 26 deletions(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 61b86ce..1ebd968 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -825,6 +825,7 @@ config TARGET_COLIBRI_PXA270
config ARCH_UNIPHIER bool "Socionext UniPhier SoCs" + select BLK select CLK_UNIPHIER select SUPPORT_SPL select SPL diff --git a/drivers/mmc/Kconfig b/drivers/mmc/Kconfig index 4cdd9b1..068845a 100644 --- a/drivers/mmc/Kconfig +++ b/drivers/mmc/Kconfig @@ -80,6 +80,7 @@ config ROCKCHIP_SDHCI config MMC_UNIPHIER bool "UniPhier SD/MMC Host Controller support" depends on ARCH_UNIPHIER + depends on BLK select DM_MMC_OPS help This selects support for the SD/MMC Host Controller on UniPhier SoCs. diff --git a/drivers/mmc/uniphier-sd.c b/drivers/mmc/uniphier-sd.c index 701b26f..4af7fdb 100644 --- a/drivers/mmc/uniphier-sd.c +++ b/drivers/mmc/uniphier-sd.c @@ -119,9 +119,12 @@ DECLARE_GLOBAL_DATA_PTR; /* alignment required by the DMA engine of this controller */ #define UNIPHIER_SD_DMA_MINALIGN 0x10
-struct uniphier_sd_priv { +struct uniphier_sd_plat { struct mmc_config cfg; - struct mmc *mmc; + struct mmc mmc; +}; + +struct uniphier_sd_priv { void __iomem *regbase; unsigned long mclk; unsigned int version; @@ -654,8 +657,16 @@ static void uniphier_sd_host_init(struct uniphier_sd_priv *priv) } }
+static int uniphier_sd_bind(struct udevice *dev) +{ + struct uniphier_sd_plat *plat = dev_get_platdata(dev); + + return mmc_bind(dev, &plat->mmc, &plat->cfg); +} + static int uniphier_sd_probe(struct udevice *dev) { + struct uniphier_sd_plat *plat = dev_get_platdata(dev); struct uniphier_sd_priv *priv = dev_get_priv(dev); struct mmc_uclass_priv *upriv = dev_get_uclass_priv(dev); fdt_addr_t base; @@ -691,15 +702,15 @@ static int uniphier_sd_probe(struct udevice *dev) return ret; }
- priv->cfg.name = dev->name; - priv->cfg.host_caps = MMC_MODE_HS_52MHz | MMC_MODE_HS; + plat->cfg.name = dev->name; + plat->cfg.host_caps = MMC_MODE_HS_52MHz | MMC_MODE_HS;
switch (fdtdec_get_int(gd->fdt_blob, dev->of_offset, "bus-width", 1)) { case 8: - priv->cfg.host_caps |= MMC_MODE_8BIT; + plat->cfg.host_caps |= MMC_MODE_8BIT; break; case 4: - priv->cfg.host_caps |= MMC_MODE_4BIT; + plat->cfg.host_caps |= MMC_MODE_4BIT; break; case 1: break; @@ -722,27 +733,13 @@ static int uniphier_sd_probe(struct udevice *dev)
- priv->cfg.voltages = MMC_VDD_165_195 | MMC_VDD_32_33 | MMC_VDD_33_34; - priv->cfg.f_min = priv->mclk / + plat->cfg.voltages = MMC_VDD_165_195 | MMC_VDD_32_33 | MMC_VDD_33_34; + plat->cfg.f_min = priv->mclk / (priv->caps & UNIPHIER_SD_CAP_DIV1024 ? 1024 : 512); - priv->cfg.f_max = priv->mclk; - priv->cfg.b_max = U32_MAX; /* max value of UNIPHIER_SD_SECCNT */ - - priv->mmc = mmc_create(&priv->cfg, priv); - if (!priv->mmc) - return -EIO; - - upriv->mmc = priv->mmc; - priv->mmc->dev = dev; - - return 0; -} - -static int uniphier_sd_remove(struct udevice *dev) -{ - struct uniphier_sd_priv *priv = dev_get_priv(dev); + plat->cfg.f_max = priv->mclk; + plat->cfg.b_max = U32_MAX; /* max value of UNIPHIER_SD_SECCNT */
- mmc_destroy(priv->mmc); + upriv->mmc = &plat->mmc;
return 0; } @@ -756,8 +753,9 @@ U_BOOT_DRIVER(uniphier_mmc) = { .name = "uniphier-mmc", .id = UCLASS_MMC, .of_match = uniphier_sd_match, + .bind = uniphier_sd_bind, .probe = uniphier_sd_probe, - .remove = uniphier_sd_remove, .priv_auto_alloc_size = sizeof(struct uniphier_sd_priv), + .platdata_auto_alloc_size = sizeof(struct uniphier_sd_plat), .ops = &uniphier_sd_ops, };
2016-08-25 14:52 GMT+09:00 Masahiro Yamada yamada.masahiro@socionext.com:
Series except 05, Applied to u-boot-uniphier/master. 05 has been deferred until USB is converted to CONFIG_BLK.
Masahiro Yamada
