[U-Boot-Users] Where to put semi-common files?
Wolfgang,
We are needing to introduce the 8544 DS board soon. It's board is essentially identical to the board in the 8641HPCN. Both boards have an FPGA on them that controls carious system parameters and configuraiton parts, including the reset logic that we've already discussed. That FPGA is called "PIXIS" and has support code for it already added to the 8641hpcn's directory.
Naturally, we need exactly the same code for the 8544 DS board now too. But it can't be in a shared board directory, nor are the two SoC parts even in the same CPU families. One is 85xx, the other is 86xx. The FPGA isn't really a device for which one might think "driver/", so that likely isn't the right directory either. Perhaps lib_ppc/?
Actually, there are other very similar bodies of code that are shared across boards and CPU families (for example, the DDR setup code in spd_sdram.c).
Do you have a good place where you would like to see this sort of shared code? It is easy enough to pick up just the parts that are wanted during compilation due to CONFIG options, but we need a directory from which we can share these sources.
Recommendations?
Thanks, jdl
Hi Jon,
I would suggest to start moving your Freescale boards ports into a freescale directly:
board/freescale/mpc8349itx/ /mpc832xemds/ ...
Then you could add a common freescale directory, as done already for "esd" or "prodrive":
board/esd/common/
If you take a look at this directory you will notice here some common FPGA code (and others stuff too). This is not CPU specific and not a generic driver, so it shouldn't be moved to the cpu/xxx or drivers/xxx directories.
Any other opinions?
spd_sdram should be moved to cpu/xxx/ since it's cpu specific and not really a driver. We have this for cpu/ppc4xx already in plance for all sorts of 4xx SDRAM controllers.
Recommendations?
Please see above. Just my 0.02$.
Best regards, Stefan
===================================================================== DENX Software Engineering GmbH, HRB 165235 Munich, CEO: Wolfgang Denk Office: Kirchenstr. 5, D-82194 Groebenzell, Germany =====================================================================
Stefan/Jon,
board/esd/common/
This seems like the right approach. This is definitely a 'board' thing, not a 'driver' or 'cpu' thing. The important thing to remember is that the Freescale evaluation board ports are used as starting points for many other designs that won't have this particular FPGA, so we need to make it obvious that it's particular to the board. Good initiative on Jon's part in removing duplication.
regards, Ben
Ben Warren
Jon Loeliger
Stefan Roese
