[U-Boot] [PATCH 1/2] rockchip: sysreset: merge into one common driver
Use a common driver for all Rockchip SOC instead of one for each SoC. Use driver_data for reg offset.
Signed-off-by: Kever Yang kever.yang@rock-chips.com ---
arch/arm/include/asm/arch-rockchip/clock.h | 5 +++ drivers/sysreset/Makefile | 11 +----- drivers/sysreset/sysreset_rk3036.c | 45 ---------------------- drivers/sysreset/sysreset_rk3188.c | 62 ------------------------------ drivers/sysreset/sysreset_rk322x.c | 45 ---------------------- drivers/sysreset/sysreset_rk3288.c | 47 ---------------------- drivers/sysreset/sysreset_rk3328.c | 45 ---------------------- drivers/sysreset/sysreset_rk3368.c | 62 ------------------------------ drivers/sysreset/sysreset_rk3399.c | 45 ---------------------- drivers/sysreset/sysreset_rockchip.c | 48 +++++++++++++++++++++++ drivers/sysreset/sysreset_rv1108.c | 46 ---------------------- 11 files changed, 54 insertions(+), 407 deletions(-) delete mode 100644 drivers/sysreset/sysreset_rk3036.c delete mode 100644 drivers/sysreset/sysreset_rk3188.c delete mode 100644 drivers/sysreset/sysreset_rk322x.c delete mode 100644 drivers/sysreset/sysreset_rk3288.c delete mode 100644 drivers/sysreset/sysreset_rk3328.c delete mode 100644 drivers/sysreset/sysreset_rk3368.c delete mode 100644 drivers/sysreset/sysreset_rk3399.c create mode 100644 drivers/sysreset/sysreset_rockchip.c delete mode 100644 drivers/sysreset/sysreset_rv1108.c
diff --git a/arch/arm/include/asm/arch-rockchip/clock.h b/arch/arm/include/asm/arch-rockchip/clock.h index 641df58..736b260 100644 --- a/arch/arm/include/asm/arch-rockchip/clock.h +++ b/arch/arm/include/asm/arch-rockchip/clock.h @@ -39,6 +39,11 @@ static inline int rk_pll_id(enum rk_clk_id clk_id) return clk_id - 1; }
+struct sysreset_reg { + unsigned int glb_srst_fst_value; + unsigned int glb_srst_snd_value; +}; + /** * clk_get_divisor() - Calculate the required clock divisior * diff --git a/drivers/sysreset/Makefile b/drivers/sysreset/Makefile index 476d361..20f371b 100644 --- a/drivers/sysreset/Makefile +++ b/drivers/sysreset/Makefile @@ -9,18 +9,9 @@ obj-$(CONFIG_SYSRESET_PSCI) += sysreset_psci.o obj-$(CONFIG_SYSRESET_SYSCON) += sysreset_syscon.o obj-$(CONFIG_SYSRESET_WATCHDOG) += sysreset_watchdog.o
-ifndef CONFIG_SPL_BUILD -obj-$(CONFIG_ROCKCHIP_RK3036) += sysreset_rk3036.o -endif -obj-$(CONFIG_ROCKCHIP_RK3188) += sysreset_rk3188.o -obj-$(CONFIG_ROCKCHIP_RK322X) += sysreset_rk322x.o -obj-$(CONFIG_ROCKCHIP_RK3288) += sysreset_rk3288.o -obj-$(CONFIG_ROCKCHIP_RK3328) += sysreset_rk3328.o -obj-$(CONFIG_ROCKCHIP_RK3368) += sysreset_rk3368.o -obj-$(CONFIG_ROCKCHIP_RK3399) += sysreset_rk3399.o -obj-$(CONFIG_ROCKCHIP_RV1108) += sysreset_rv1108.o obj-$(CONFIG_SANDBOX) += sysreset_sandbox.o obj-$(CONFIG_ARCH_SNAPDRAGON) += sysreset_snapdragon.o obj-$(CONFIG_ARCH_STI) += sysreset_sti.o obj-$(CONFIG_TARGET_XTFPGA) += sysreset_xtfpga.o obj-$(CONFIG_ARCH_ASPEED) += sysreset_ast.o +obj-$(CONFIG_ARCH_ROCKCHIP) += sysreset_rockchip.o diff --git a/drivers/sysreset/sysreset_rk3036.c b/drivers/sysreset/sysreset_rk3036.c deleted file mode 100644 index b3d2113..0000000 --- a/drivers/sysreset/sysreset_rk3036.c +++ /dev/null @@ -1,45 +0,0 @@ -/* - * (C) Copyright 2015 Rockchip Electronics Co., Ltd - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <dm.h> -#include <errno.h> -#include <sysreset.h> -#include <asm/io.h> -#include <asm/arch/clock.h> -#include <asm/arch/cru_rk3036.h> -#include <asm/arch/hardware.h> -#include <linux/err.h> - -int rk3036_sysreset_request(struct udevice *dev, enum sysreset_t type) -{ - struct rk3036_cru *cru = rockchip_get_cru(); - - if (IS_ERR(cru)) - return PTR_ERR(cru); - switch (type) { - case SYSRESET_WARM: - writel(0xeca8, &cru->cru_glb_srst_snd_value); - break; - case SYSRESET_COLD: - writel(0xfdb9, &cru->cru_glb_srst_fst_value); - break; - default: - return -EPROTONOSUPPORT; - } - - return -EINPROGRESS; -} - -static struct sysreset_ops rk3036_sysreset = { - .request = rk3036_sysreset_request, -}; - -U_BOOT_DRIVER(sysreset_rk3036) = { - .name = "rk3036_sysreset", - .id = UCLASS_SYSRESET, - .ops = &rk3036_sysreset, -}; diff --git a/drivers/sysreset/sysreset_rk3188.c b/drivers/sysreset/sysreset_rk3188.c deleted file mode 100644 index 053a634..0000000 --- a/drivers/sysreset/sysreset_rk3188.c +++ /dev/null @@ -1,62 +0,0 @@ -/* - * (C) Copyright 2015 Google, Inc - * - * SPDX-License-Identifier: GPL-2.0 - */ - -#include <common.h> -#include <dm.h> -#include <errno.h> -#include <syscon.h> -#include <sysreset.h> -#include <asm/io.h> -#include <asm/arch/clock.h> -#include <asm/arch/cru_rk3188.h> -#include <asm/arch/grf_rk3188.h> -#include <asm/arch/hardware.h> -#include <linux/err.h> - -int rk3188_sysreset_request(struct udevice *dev, enum sysreset_t type) -{ - struct rk3188_cru *cru = rockchip_get_cru(); - struct rk3188_grf *grf; - - if (IS_ERR(cru)) - return PTR_ERR(cru); - switch (type) { - case SYSRESET_WARM: - grf = syscon_get_first_range(ROCKCHIP_SYSCON_GRF); - if (IS_ERR(grf)) - return -EPROTONOSUPPORT; - - /* - * warm-reset keeps the remap value, - * so make sure it's disabled. - */ - rk_clrsetreg(&grf->soc_con0, - NOC_REMAP_MASK << NOC_REMAP_SHIFT, - 0 << NOC_REMAP_SHIFT); - - rk_clrreg(&cru->cru_mode_con, 0xffff); - writel(0xeca8, &cru->cru_glb_srst_snd_value); - break; - case SYSRESET_COLD: - rk_clrreg(&cru->cru_mode_con, 0xffff); - writel(0xfdb9, &cru->cru_glb_srst_fst_value); - break; - default: - return -EPROTONOSUPPORT; - } - - return -EINPROGRESS; -} - -static struct sysreset_ops rk3188_sysreset = { - .request = rk3188_sysreset_request, -}; - -U_BOOT_DRIVER(sysreset_rk3188) = { - .name = "rk3188_sysreset", - .id = UCLASS_SYSRESET, - .ops = &rk3188_sysreset, -}; diff --git a/drivers/sysreset/sysreset_rk322x.c b/drivers/sysreset/sysreset_rk322x.c deleted file mode 100644 index 5fce79b..0000000 --- a/drivers/sysreset/sysreset_rk322x.c +++ /dev/null @@ -1,45 +0,0 @@ -/* - * (C) Copyright 2017 Rockchip Electronics Co., Ltd - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <dm.h> -#include <errno.h> -#include <sysreset.h> -#include <asm/io.h> -#include <asm/arch/clock.h> -#include <asm/arch/cru_rk322x.h> -#include <asm/arch/hardware.h> -#include <linux/err.h> - -int rk322x_sysreset_request(struct udevice *dev, enum sysreset_t type) -{ - struct rk322x_cru *cru = rockchip_get_cru(); - - if (IS_ERR(cru)) - return PTR_ERR(cru); - switch (type) { - case SYSRESET_WARM: - writel(0xeca8, &cru->cru_glb_srst_snd_value); - break; - case SYSRESET_COLD: - writel(0xfdb9, &cru->cru_glb_srst_fst_value); - break; - default: - return -EPROTONOSUPPORT; - } - - return -EINPROGRESS; -} - -static struct sysreset_ops rk322x_sysreset = { - .request = rk322x_sysreset_request, -}; - -U_BOOT_DRIVER(sysreset_rk322x) = { - .name = "rk322x_sysreset", - .id = UCLASS_SYSRESET, - .ops = &rk322x_sysreset, -}; diff --git a/drivers/sysreset/sysreset_rk3288.c b/drivers/sysreset/sysreset_rk3288.c deleted file mode 100644 index 0aad1c2..0000000 --- a/drivers/sysreset/sysreset_rk3288.c +++ /dev/null @@ -1,47 +0,0 @@ -/* - * (C) Copyright 2015 Google, Inc - * - * SPDX-License-Identifier: GPL-2.0 - */ - -#include <common.h> -#include <dm.h> -#include <errno.h> -#include <sysreset.h> -#include <asm/io.h> -#include <asm/arch/clock.h> -#include <asm/arch/cru_rk3288.h> -#include <asm/arch/hardware.h> -#include <linux/err.h> - -int rk3288_sysreset_request(struct udevice *dev, enum sysreset_t type) -{ - struct rk3288_cru *cru = rockchip_get_cru(); - - if (IS_ERR(cru)) - return PTR_ERR(cru); - switch (type) { - case SYSRESET_WARM: - rk_clrreg(&cru->cru_mode_con, 0xffff); - writel(0xeca8, &cru->cru_glb_srst_snd_value); - break; - case SYSRESET_COLD: - rk_clrreg(&cru->cru_mode_con, 0xffff); - writel(0xfdb9, &cru->cru_glb_srst_fst_value); - break; - default: - return -EPROTONOSUPPORT; - } - - return -EINPROGRESS; -} - -static struct sysreset_ops rk3288_sysreset = { - .request = rk3288_sysreset_request, -}; - -U_BOOT_DRIVER(sysreset_rk3288) = { - .name = "rk3288_sysreset", - .id = UCLASS_SYSRESET, - .ops = &rk3288_sysreset, -}; diff --git a/drivers/sysreset/sysreset_rk3328.c b/drivers/sysreset/sysreset_rk3328.c deleted file mode 100644 index 7b9af09..0000000 --- a/drivers/sysreset/sysreset_rk3328.c +++ /dev/null @@ -1,45 +0,0 @@ -/* - * (C) Copyright 2016 Rockchip Electronics Co., Ltd - * - * SPDX-License-Identifier: GPL-2.0 - */ - -#include <common.h> -#include <dm.h> -#include <errno.h> -#include <sysreset.h> -#include <asm/arch/clock.h> -#include <asm/arch/cru_rk3328.h> -#include <asm/arch/hardware.h> -#include <asm/io.h> -#include <linux/err.h> - -int rk3328_sysreset_request(struct udevice *dev, enum sysreset_t type) -{ - struct rk3328_cru *cru = rockchip_get_cru(); - - if (IS_ERR(cru)) - return PTR_ERR(cru); - switch (type) { - case SYSRESET_WARM: - writel(0xeca8, &cru->glb_srst_snd_value); - break; - case SYSRESET_COLD: - writel(0xfdb9, &cru->glb_srst_fst_value); - break; - default: - return -EPROTONOSUPPORT; - } - - return -EINPROGRESS; -} - -static struct sysreset_ops rk3328_sysreset = { - .request = rk3328_sysreset_request, -}; - -U_BOOT_DRIVER(sysreset_rk3328) = { - .name = "rk3328_sysreset", - .id = UCLASS_SYSRESET, - .ops = &rk3328_sysreset, -}; diff --git a/drivers/sysreset/sysreset_rk3368.c b/drivers/sysreset/sysreset_rk3368.c deleted file mode 100644 index de62921..0000000 --- a/drivers/sysreset/sysreset_rk3368.c +++ /dev/null @@ -1,62 +0,0 @@ -/* - * (C) Copyright Rockchip Electronics Co., Ltd - * - * SPDX-License-Identifier: GPL-2.0 - */ - -#include <common.h> -#include <dm.h> -#include <errno.h> -#include <sysreset.h> -#include <asm/io.h> -#include <asm/arch/clock.h> -#include <asm/arch/cru_rk3368.h> -#include <asm/arch/hardware.h> -#include <linux/err.h> - -static void rk3368_pll_enter_slow_mode(struct rk3368_cru *cru) -{ - struct rk3368_pll *pll; - int i; - - for (i = 0; i < 6; i++) { - pll = &cru->pll[i]; - rk_clrreg(&pll->con3, PLL_MODE_MASK); - } -} - -static int rk3368_sysreset_request(struct udevice *dev, enum sysreset_t type) -{ - struct rk3368_cru *cru = rockchip_get_cru(); - - if (IS_ERR(cru)) - return PTR_ERR(cru); - switch (type) { - case SYSRESET_WARM: - rk3368_pll_enter_slow_mode(cru); - rk_clrsetreg(&cru->glb_rst_con, PMU_GLB_SRST_CTRL_MASK, - PMU_RST_BY_SND_GLB_SRST << PMU_GLB_SRST_CTRL_SHIFT); - writel(0xeca8, &cru->glb_srst_snd_val); - break; - case SYSRESET_COLD: - rk3368_pll_enter_slow_mode(cru); - rk_clrsetreg(&cru->glb_rst_con, PMU_GLB_SRST_CTRL_MASK, - PMU_RST_BY_FST_GLB_SRST << PMU_GLB_SRST_CTRL_SHIFT); - writel(0xfdb9, &cru->glb_srst_fst_val); - break; - default: - return -EPROTONOSUPPORT; - } - - return -EINPROGRESS; -} - -static struct sysreset_ops rk3368_sysreset = { - .request = rk3368_sysreset_request, -}; - -U_BOOT_DRIVER(sysreset_rk3368) = { - .name = "rk3368_sysreset", - .id = UCLASS_SYSRESET, - .ops = &rk3368_sysreset, -}; diff --git a/drivers/sysreset/sysreset_rk3399.c b/drivers/sysreset/sysreset_rk3399.c deleted file mode 100644 index 9a55546..0000000 --- a/drivers/sysreset/sysreset_rk3399.c +++ /dev/null @@ -1,45 +0,0 @@ -/* - * (C) Copyright 2016 Rockchip Electronics Co., Ltd - * - * SPDX-License-Identifier: GPL-2.0 - */ - -#include <common.h> -#include <dm.h> -#include <errno.h> -#include <sysreset.h> -#include <asm/io.h> -#include <asm/arch/clock.h> -#include <asm/arch/cru_rk3399.h> -#include <asm/arch/hardware.h> -#include <linux/err.h> - -int rk3399_sysreset_request(struct udevice *dev, enum sysreset_t type) -{ - struct rk3399_cru *cru = rockchip_get_cru(); - - if (IS_ERR(cru)) - return PTR_ERR(cru); - switch (type) { - case SYSRESET_WARM: - writel(0xeca8, &cru->glb_srst_snd_value); - break; - case SYSRESET_COLD: - writel(0xfdb9, &cru->glb_srst_fst_value); - break; - default: - return -EPROTONOSUPPORT; - } - - return -EINPROGRESS; -} - -static struct sysreset_ops rk3399_sysreset = { - .request = rk3399_sysreset_request, -}; - -U_BOOT_DRIVER(sysreset_rk3399) = { - .name = "rk3399_sysreset", - .id = UCLASS_SYSRESET, - .ops = &rk3399_sysreset, -}; diff --git a/drivers/sysreset/sysreset_rockchip.c b/drivers/sysreset/sysreset_rockchip.c new file mode 100644 index 0000000..591ef05 --- /dev/null +++ b/drivers/sysreset/sysreset_rockchip.c @@ -0,0 +1,48 @@ +/* + * (C) Copyright 2017 Rockchip Electronics Co., Ltd + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#include <common.h> +#include <dm.h> +#include <errno.h> +#include <sysreset.h> +#include <asm/io.h> +#include <asm/arch/clock.h> +#include <asm/arch/cru_rk3328.h> +#include <asm/arch/hardware.h> +#include <linux/err.h> + +int rockchip_sysreset_request(struct udevice *dev, enum sysreset_t type) +{ + struct sysreset_reg *offset = dev_get_driver_data(dev); + unsigned long cru_base = (unsigned long)rockchip_get_cru(); + + if (IS_ERR_VALUE(cru_base)) + return (int)cru_base; + + switch (type) { + case SYSRESET_WARM: + writel(0xfdb9, cru_base + offset->glb_srst_fst_value); + writel(0xeca8, cru_base + offset->glb_srst_snd_value); + break; + case SYSRESET_COLD: + writel(0xfdb9, cru_base + offset->glb_srst_fst_value); + break; + default: + return -EPROTONOSUPPORT; + } + + return -EINPROGRESS; +} + +static struct sysreset_ops rockchip_sysreset = { + .request = rockchip_sysreset_request, +}; + +U_BOOT_DRIVER(sysreset_rockchip) = { + .name = "rockchip_sysreset", + .id = UCLASS_SYSRESET, + .ops = &rockchip_sysreset, +}; diff --git a/drivers/sysreset/sysreset_rv1108.c b/drivers/sysreset/sysreset_rv1108.c deleted file mode 100644 index 9d8e9f7..0000000 --- a/drivers/sysreset/sysreset_rv1108.c +++ /dev/null @@ -1,46 +0,0 @@ -/* - * (C) Copyright 2015 Rockchip Electronics Co., Ltd - * Author: Andy Yan andy.yan@rock-chips.com - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <dm.h> -#include <errno.h> -#include <sysreset.h> -#include <asm/io.h> -#include <asm/arch/clock.h> -#include <asm/arch/cru_rv1108.h> -#include <asm/arch/hardware.h> -#include <linux/err.h> - -int rv1108_sysreset_request(struct udevice *dev, enum sysreset_t type) -{ - struct rv1108_cru *cru = rockchip_get_cru(); - - if (IS_ERR(cru)) - return PTR_ERR(cru); - - switch (type) { - case SYSRESET_WARM: - writel(0xeca8, &cru->glb_srst_snd_val); - break; - case SYSRESET_COLD: - writel(0xfdb9, &cru->glb_srst_fst_val); - break; - default: - return -EPROTONOSUPPORT; - } - - return -EINPROGRESS; -} - -static struct sysreset_ops rv1108_sysreset = { - .request = rv1108_sysreset_request, -}; - -U_BOOT_DRIVER(sysreset_rv1108) = { - .name = "rv1108_sysreset", - .id = UCLASS_SYSRESET, - .ops = &rv1108_sysreset, -};
Using driver_data for new sysreset driver binding.
drivers/clk/rockchip/clk_rk3036.c | 15 +++++++++++++-- drivers/clk/rockchip/clk_rk3188.c | 16 ++++++++++++++-- drivers/clk/rockchip/clk_rk322x.c | 15 +++++++++++++-- drivers/clk/rockchip/clk_rk3288.c | 15 +++++++++++++-- drivers/clk/rockchip/clk_rk3328.c | 16 ++++++++++++++-- drivers/clk/rockchip/clk_rk3368.c | 15 +++++++++++++-- drivers/clk/rockchip/clk_rk3399.c | 15 +++++++++++++-- drivers/clk/rockchip/clk_rv1108.c | 15 +++++++++++++-- 8 files changed, 106 insertions(+), 16 deletions(-)
diff --git a/drivers/clk/rockchip/clk_rk3036.c b/drivers/clk/rockchip/clk_rk3036.c index 83f4ae6..5d7556f 100644 --- a/drivers/clk/rockchip/clk_rk3036.c +++ b/drivers/clk/rockchip/clk_rk3036.c @@ -330,11 +330,22 @@ static int rk3036_clk_probe(struct udevice *dev) static int rk3036_clk_bind(struct udevice *dev) { int ret; + struct udevice *sys_child; + struct driver *sysreset_drv; + struct sysreset_reg *drv_data = malloc(sizeof(struct sysreset_reg)); + + sysreset_drv = lists_driver_lookup_name("rockchip_sysreset"); + drv_data->glb_srst_fst_value = offsetof(struct rk3036_cru, + cru_glb_srst_fst_value); + drv_data->glb_srst_snd_value = offsetof(struct rk3036_cru, + cru_glb_srst_snd_value);
/* The reset driver does not have a device node, so bind it here */ - ret = device_bind_driver(gd->dm_root, "rk3036_sysreset", "reset", &dev); + ret = device_bind_with_driver_data(dev, sysreset_drv, + "rockchip_sysreset", drv_data, + ofnode_null(), &sys_child); if (ret) - debug("Warning: No RK3036 reset driver: ret=%d\n", ret); + debug("Warning: No sysreset driver: ret=%d\n", ret);
return 0; } diff --git a/drivers/clk/rockchip/clk_rk3188.c b/drivers/clk/rockchip/clk_rk3188.c index 8c2c9bc..5740e33 100644 --- a/drivers/clk/rockchip/clk_rk3188.c +++ b/drivers/clk/rockchip/clk_rk3188.c @@ -573,11 +573,23 @@ static int rk3188_clk_probe(struct udevice *dev) static int rk3188_clk_bind(struct udevice *dev) { int ret; + struct udevice *sys_child; + struct driver *sysreset_drv; + struct sysreset_reg *drv_data = malloc(sizeof(struct sysreset_reg)); + + sysreset_drv = lists_driver_lookup_name("rockchip_sysreset"); + drv_data->glb_srst_fst_value = offsetof(struct rk3188_cru, + cru_glb_srst_fst_value); + drv_data->glb_srst_snd_value = offsetof(struct rk3188_cru, + cru_glb_srst_snd_value);
/* The reset driver does not have a device node, so bind it here */ - ret = device_bind_driver(gd->dm_root, "rk3188_sysreset", "reset", &dev); + ret = device_bind_with_driver_data(dev, sysreset_drv, + "rockchip_sysreset", + drv_data, ofnode_null(), + &sys_child); if (ret) - debug("Warning: No rk3188 reset driver: ret=%d\n", ret); + debug("Warning: No sysreset driver: ret=%d\n", ret);
return 0; } diff --git a/drivers/clk/rockchip/clk_rk322x.c b/drivers/clk/rockchip/clk_rk322x.c index e87267d..36750a2 100644 --- a/drivers/clk/rockchip/clk_rk322x.c +++ b/drivers/clk/rockchip/clk_rk322x.c @@ -385,11 +385,22 @@ static int rk322x_clk_probe(struct udevice *dev) static int rk322x_clk_bind(struct udevice *dev) { int ret; + struct udevice *sys_child; + struct driver *sysreset_drv; + struct sysreset_reg *drv_data = malloc(sizeof(struct sysreset_reg)); + + sysreset_drv = lists_driver_lookup_name("rockchip_sysreset"); + drv_data->glb_srst_fst_value = offsetof(struct rk322x_cru, + cru_glb_srst_fst_value); + drv_data->glb_srst_snd_value = offsetof(struct rk322x_cru, + cru_glb_srst_snd_value);
/* The reset driver does not have a device node, so bind it here */ - ret = device_bind_driver(gd->dm_root, "rk322x_sysreset", "reset", &dev); + ret = device_bind_with_driver_data(dev, sysreset_drv, + "rockchip_sysreset", drv_data, + ofnode_null(), &sys_child); if (ret) - debug("Warning: No RK322x reset driver: ret=%d\n", ret); + debug("Warning: No sysreset driver: ret=%d\n", ret);
return 0; } diff --git a/drivers/clk/rockchip/clk_rk3288.c b/drivers/clk/rockchip/clk_rk3288.c index a133810..330991b 100644 --- a/drivers/clk/rockchip/clk_rk3288.c +++ b/drivers/clk/rockchip/clk_rk3288.c @@ -859,11 +859,22 @@ static int rk3288_clk_probe(struct udevice *dev) static int rk3288_clk_bind(struct udevice *dev) { int ret; + struct udevice *sys_child; + struct driver *sysreset_drv; + struct sysreset_reg *drv_data = malloc(sizeof(struct sysreset_reg)); + + sysreset_drv = lists_driver_lookup_name("rockchip_sysreset"); + drv_data->glb_srst_fst_value = offsetof(struct rk3288_cru, + cru_glb_srst_fst_value); + drv_data->glb_srst_snd_value = offsetof(struct rk3288_cru, + cru_glb_srst_snd_value);
/* The reset driver does not have a device node, so bind it here */ - ret = device_bind_driver(gd->dm_root, "rk3288_sysreset", "reset", &dev); + ret = device_bind_with_driver_data(dev, sysreset_drv, + "rockchip_sysreset", drv_data, + ofnode_null(), &sys_child); if (ret) - debug("Warning: No RK3288 reset driver: ret=%d\n", ret); + debug("Warning: No sysreset driver: ret=%d\n", ret);
return 0; } diff --git a/drivers/clk/rockchip/clk_rk3328.c b/drivers/clk/rockchip/clk_rk3328.c index 540d910..75a45a8 100644 --- a/drivers/clk/rockchip/clk_rk3328.c +++ b/drivers/clk/rockchip/clk_rk3328.c @@ -14,6 +14,7 @@ #include <asm/arch/cru_rk3328.h> #include <asm/arch/hardware.h> #include <asm/io.h> +#include <dm/device-internal.h> #include <dm/lists.h> #include <dt-bindings/clock/rk3328-cru.h>
@@ -597,11 +598,22 @@ static int rk3328_clk_ofdata_to_platdata(struct udevice *dev) static int rk3328_clk_bind(struct udevice *dev) { int ret; + struct udevice *sys_child; + struct driver *sysreset_drv; + struct sysreset_reg *drv_data = malloc(sizeof(struct sysreset_reg)); + + sysreset_drv = lists_driver_lookup_name("rockchip_sysreset"); + drv_data->glb_srst_fst_value = offsetof(struct rk3328_cru, + glb_srst_fst_value); + drv_data->glb_srst_snd_value = offsetof(struct rk3328_cru, + glb_srst_snd_value);
/* The reset driver does not have a device node, so bind it here */ - ret = device_bind_driver(gd->dm_root, "rk3328_sysreset", "reset", &dev); + ret = device_bind_with_driver_data(dev, sysreset_drv, + "rockchip_sysreset", drv_data, + ofnode_null(), &sys_child); if (ret) - printf("Warning: No RK3328 reset driver: ret=%d\n", ret); + debug("Warning: No sysreset driver: ret=%d\n", ret);
return ret; } diff --git a/drivers/clk/rockchip/clk_rk3368.c b/drivers/clk/rockchip/clk_rk3368.c index 3661769..46351ce 100644 --- a/drivers/clk/rockchip/clk_rk3368.c +++ b/drivers/clk/rockchip/clk_rk3368.c @@ -526,11 +526,22 @@ static int rk3368_clk_ofdata_to_platdata(struct udevice *dev) static int rk3368_clk_bind(struct udevice *dev) { int ret; + struct udevice *sys_child; + struct driver *sysreset_drv; + struct sysreset_reg *drv_data = malloc(sizeof(struct sysreset_reg)); + + sysreset_drv = lists_driver_lookup_name("rockchip_sysreset"); + drv_data->glb_srst_fst_value = offsetof(struct rk3368_cru, + glb_srst_fst_val); + drv_data->glb_srst_snd_value = offsetof(struct rk3368_cru, + glb_srst_snd_val);
/* The reset driver does not have a device node, so bind it here */ - ret = device_bind_driver(gd->dm_root, "rk3368_sysreset", "reset", &dev); + ret = device_bind_with_driver_data(dev, sysreset_drv, + "rockchip_sysreset", drv_data, + ofnode_null(), &sys_child); if (ret) - pr_err("bind RK3368 reset driver failed: ret=%d\n", ret); + debug("Warning: No sysreset driver: ret=%d\n", ret);
return ret; } diff --git a/drivers/clk/rockchip/clk_rk3399.c b/drivers/clk/rockchip/clk_rk3399.c index f45bba4..6e4a8bb 100644 --- a/drivers/clk/rockchip/clk_rk3399.c +++ b/drivers/clk/rockchip/clk_rk3399.c @@ -1032,11 +1032,22 @@ static int rk3399_clk_ofdata_to_platdata(struct udevice *dev) static int rk3399_clk_bind(struct udevice *dev) { int ret; + struct udevice *sys_child; + struct driver *sysreset_drv; + struct sysreset_reg *drv_data = malloc(sizeof(struct sysreset_reg)); + + sysreset_drv = lists_driver_lookup_name("rockchip_sysreset"); + drv_data->glb_srst_fst_value = offsetof(struct rk3399_cru, + glb_srst_fst_value); + drv_data->glb_srst_snd_value = offsetof(struct rk3399_cru, + glb_srst_snd_value);
/* The reset driver does not have a device node, so bind it here */ - ret = device_bind_driver(gd->dm_root, "rk3399_sysreset", "reset", &dev); + ret = device_bind_with_driver_data(dev, sysreset_drv, + "rockchip_sysreset", drv_data, + ofnode_null(), &sys_child); if (ret) - printf("Warning: No RK3399 reset driver: ret=%d\n", ret); + debug("Warning: No sysreset driver: ret=%d\n", ret);
return 0; } diff --git a/drivers/clk/rockchip/clk_rv1108.c b/drivers/clk/rockchip/clk_rv1108.c index 55741c3..9432d45 100644 --- a/drivers/clk/rockchip/clk_rv1108.c +++ b/drivers/clk/rockchip/clk_rv1108.c @@ -223,11 +223,22 @@ static int rv1108_clk_probe(struct udevice *dev) static int rv1108_clk_bind(struct udevice *dev) { int ret; + struct udevice *sys_child; + struct driver *sysreset_drv; + struct sysreset_reg *drv_data = malloc(sizeof(struct sysreset_reg)); + + sysreset_drv = lists_driver_lookup_name("rockchip_sysreset"); + drv_data->glb_srst_fst_value = offsetof(struct rv1108_cru, + glb_srst_fst_val); + drv_data->glb_srst_snd_value = offsetof(struct rv1108_cru, + glb_srst_snd_val);
/* The reset driver does not have a device node, so bind it here */ - ret = device_bind_driver(gd->dm_root, "rv1108_sysreset", "reset", &dev); + ret = device_bind_with_driver_data(dev, sysreset_drv, + "rockchip_sysreset", drv_data, + ofnode_null(), &sys_child); if (ret) - pr_err("No Rv1108 reset driver: ret=%d\n", ret); + debug("Warning: No sysreset driver: ret=%d\n", ret);
return 0; }
Kever Yang
