[U-Boot] [PATCH] board: pm9263: Update to support DT and DM
Update the configuration files to support the device tree and driver model. The peripheral clock and pins configuration are handled by the clock and the pinctrl drivers respectively.
Signed-off-by: Wenyou Yang wenyou.yang@microchip.com ---
arch/arm/dts/Makefile | 2 ++ board/ronetix/pm9263/Makefile | 2 +- board/ronetix/pm9263/pm9263.c | 22 +++------------------- configs/pm9263_defconfig | 17 +++++++++++++++++ include/configs/pm9263.h | 32 +++++++------------------------- 5 files changed, 30 insertions(+), 45 deletions(-)
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index cff325e6c0..c7cc35ca3e 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -379,6 +379,8 @@ dtb-$(CONFIG_SOC_KEYSTONE) += keystone-k2hk-evm.dtb \
dtb-$(CONFIG_TARGET_AT91SAM9261EK) += at91sam9261ek.dtb
+dtb-$(CONFIG_TARGET_PM9263) += at91sam9263ek.dtb + dtb-$(CONFIG_TARGET_AT91SAM9263EK) += at91sam9263ek.dtb
dtb-$(CONFIG_TARGET_AT91SAM9RLEK) += at91sam9rlek.dtb diff --git a/board/ronetix/pm9263/Makefile b/board/ronetix/pm9263/Makefile index 43ea599c4f..53e621dc80 100644 --- a/board/ronetix/pm9263/Makefile +++ b/board/ronetix/pm9263/Makefile @@ -11,5 +11,5 @@ #
obj-y += pm9263.o -obj-y += led.o +obj-$(CONFIG_AT91_LED) += led.o obj-$(CONFIG_HAS_DATAFLASH) += partition.o diff --git a/board/ronetix/pm9263/pm9263.c b/board/ronetix/pm9263/pm9263.c index 0c23bb6c65..8d20084240 100644 --- a/board/ronetix/pm9263/pm9263.c +++ b/board/ronetix/pm9263/pm9263.c @@ -20,7 +20,6 @@ #include <asm/arch/gpio.h> #include <lcd.h> #include <atmel_lcdc.h> -#include <dataflash.h> #if defined(CONFIG_RESET_PHY_R) && defined(CONFIG_MACB) #include <net.h> #endif @@ -277,7 +276,7 @@ extern flash_info_t flash_info[];
void lcd_show_board_info(void) { - ulong dram_size, nand_size, flash_size, dataflash_size; + ulong dram_size, nand_size, flash_size; int i; char temp[32];
@@ -300,17 +299,11 @@ void lcd_show_board_info(void) for (i = 0; i < CONFIG_SYS_MAX_FLASH_BANKS; i++) flash_size += flash_info[i].size;
- dataflash_size = 0; - for (i = 0; i < CONFIG_SYS_MAX_DATAFLASH_BANKS; i++) - dataflash_size += (unsigned int) dataflash_info[i].Device.pages_number * - dataflash_info[i].Device.pages_size; - lcd_printf ("%ld MB SDRAM, %ld MB NAND\n%ld MB NOR Flash\n" - "4 MB PSRAM, %ld MB DataFlash\n", + "4 MB PSRAM\n", dram_size >> 20, nand_size >> 20, - flash_size >> 20, - dataflash_size >> 20); + flash_size >> 20); } #endif /* CONFIG_LCD_INFO */
@@ -318,12 +311,6 @@ void lcd_show_board_info(void)
int board_early_init_f(void) { - at91_periph_clk_enable(ATMEL_ID_PIOA); - at91_periph_clk_enable(ATMEL_ID_PIOB); - at91_periph_clk_enable(ATMEL_ID_PIOCDE); - - at91_seriald_hw_init(); - return 0; }
@@ -338,9 +325,6 @@ int board_init(void) #ifdef CONFIG_CMD_NAND pm9263_nand_hw_init(); #endif -#ifdef CONFIG_HAS_DATAFLASH - at91_spi0_hw_init(1 << 0); -#endif #ifdef CONFIG_MACB pm9263_macb_hw_init(); #endif diff --git a/configs/pm9263_defconfig b/configs/pm9263_defconfig index 7cf2722740..981cdf2000 100644 --- a/configs/pm9263_defconfig +++ b/configs/pm9263_defconfig @@ -1,6 +1,8 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_PM9263=y +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_DEFAULT_DEVICE_TREE="at91sam9263ek" CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9263" CONFIG_BOOTDELAY=3 # CONFIG_CONSOLE_MUX is not set @@ -11,6 +13,7 @@ CONFIG_SYS_PROMPT="u-boot-pm9263> " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set +CONFIG_CMD_SF=y CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set @@ -18,8 +21,22 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_JFFS2=y +CONFIG_OF_CONTROL=y +CONFIG_DM=y +CONFIG_CLK=y +CONFIG_CLK_AT91=y +CONFIG_DM_GPIO=y +CONFIG_AT91_GPIO=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_ATMEL=y +CONFIG_SPI_FLASH_DATAFLASH=y +CONFIG_DM_SERIAL=y +CONFIG_ATMEL_USART=y +CONFIG_DM_SPI=y +CONFIG_ATMEL_SPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_LCD=y diff --git a/include/configs/pm9263.h b/include/configs/pm9263.h index 41d5722490..0d33c7aaf2 100644 --- a/include/configs/pm9263.h +++ b/include/configs/pm9263.h @@ -154,11 +154,6 @@ /* * Hardware drivers */ -#define CONFIG_AT91_GPIO 1 -#define CONFIG_ATMEL_USART 1 -#define CONFIG_USART_BASE ATMEL_BASE_DBGU -#define CONFIG_USART_ID ATMEL_ID_SYS - /* LCD */ #define LCD_BPP LCD_COLOR8 #define CONFIG_LCD_LOGO 1 @@ -170,12 +165,6 @@
#define CONFIG_LCD_IN_PSRAM 1
-/* LED */ -#define CONFIG_AT91_LED -#define CONFIG_RED_LED GPIO_PIN_PB(7) /* this is the power led */ -#define CONFIG_GREEN_LED GPIO_PIN_PB(8) /* this is the user1 led */ - - /* * BOOTP options */ @@ -194,15 +183,6 @@ #define PHYS_SDRAM 0x20000000 #define PHYS_SDRAM_SIZE 0x04000000 /* 64 megs */
-/* DataFlash */ -#define CONFIG_ATMEL_DATAFLASH_SPI -#define CONFIG_HAS_DATAFLASH 1 -#define CONFIG_SYS_MAX_DATAFLASH_BANKS 1 -#define CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 0xC0000000 /* CS0 */ -#define AT91_SPI_CLK 15000000 -#define DATAFLASH_TCSS (0x1a << 16) -#define DATAFLASH_TCHS (0x1 << 24) - /* NOR flash, if populated */ #define CONFIG_SYS_FLASH_CFI 1 #define CONFIG_FLASH_CFI_DRIVER 1 @@ -268,12 +248,14 @@ #ifdef CONFIG_SYS_USE_DATAFLASH
/* bootstrap + u-boot + env + linux in dataflash on CS0 */ -#define CONFIG_ENV_IS_IN_DATAFLASH -#define CFG_MONITOR_BASE (CFG_DATAFLASH_LOGIC_ADDR_CS0 + 0x8400) +#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_OFFSET 0x4200 -#define CONFIG_ENV_ADDR (CFG_DATAFLASH_LOGIC_ADDR_CS0 + CONFIG_ENV_OFFSET) #define CONFIG_ENV_SIZE 0x4200 -#define CONFIG_BOOTCOMMAND "cp.b 0xC0042000 0x22000000 0x210000; bootm" +#define CONFIG_ENV_SECT_SIZE 0x210 +#define CONFIG_ENV_SPI_MAX_HZ 15000000 +#define CONFIG_BOOTCOMMAND "sf probe 0; " \ + "sf read 0x22000000 0x84000 0x294000; " \ + "bootm 0x22000000" #define CONFIG_BOOTARGS "console=ttyS0,115200 " \ "root=/dev/mtdblock0 " \ "mtdparts=atmel_nand:-(root) "\ @@ -364,7 +346,7 @@ #define CONFIG_SYS_MALLOC_LEN ROUND(3 * CONFIG_ENV_SIZE + 128 * 1024, 0x1000)
#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM -#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_SDRAM_BASE + 0x1000 - \ +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_SDRAM_BASE + 16 * 1024 - \ GENERATED_GBL_DATA_SIZE)
#endif
Signed-off-by: Wenyou Yang wenyou.yang@microchip.com Reviewed-by: Simon Glass sjg@chromium.org
Wenyou Yang
