[PATCH v1 0/6] Add new device Agilex7 support
*** BLURB HERE ***
Sin Hui Kho (6): arm: socfpga: agilex7: Enable AGILEX7 SoC build board: intel: agilex7: Add socdk board support for Intel AGILEX7 SoC arm: dts: agilex7: Add base dtsi and devkit dts arm: socfpga: agilex7: Add SPL for AGILEX7 SoC arm: socfpga: agilex7: Add clock manager support for AGILEX7 arm: socfpga: agilex7: Add base address for AGILEX7
arch/arm/dts/Makefile | 1 + arch/arm/dts/socfpga_agilex7-u-boot.dtsi | 98 +++ arch/arm/dts/socfpga_agilex7.dtsi | 627 ++++++++++++++++++ .../arm/dts/socfpga_agilex7_socdk-u-boot.dtsi | 59 ++ arch/arm/dts/socfpga_agilex7_socdk.dts | 137 ++++ arch/arm/mach-socfpga/Kconfig | 18 + arch/arm/mach-socfpga/Makefile | 18 +- .../include/mach/base_addr_soc64.h | 3 +- .../mach-socfpga/include/mach/clock_manager.h | 2 +- .../mach-socfpga/include/mach/handoff_soc64.h | 3 +- arch/arm/mach-socfpga/misc.c | 3 + arch/arm/mach-socfpga/spl_agilex7.c | 87 +++ board/intel/agilex7-socdk/MAINTAINERS | 7 + board/intel/agilex7-socdk/Makefile | 7 + board/intel/agilex7-socdk/socfpga.c | 7 + configs/socfpga_agilex7_defconfig | 95 +++ drivers/clk/altera/Makefile | 1 + include/configs/socfpga_agilex7_socdk.h | 12 + 18 files changed, 1181 insertions(+), 4 deletions(-) create mode 100644 arch/arm/dts/socfpga_agilex7-u-boot.dtsi create mode 100644 arch/arm/dts/socfpga_agilex7.dtsi create mode 100644 arch/arm/dts/socfpga_agilex7_socdk-u-boot.dtsi create mode 100644 arch/arm/dts/socfpga_agilex7_socdk.dts create mode 100644 arch/arm/mach-socfpga/spl_agilex7.c create mode 100644 board/intel/agilex7-socdk/MAINTAINERS create mode 100644 board/intel/agilex7-socdk/Makefile create mode 100644 board/intel/agilex7-socdk/socfpga.c create mode 100644 configs/socfpga_agilex7_defconfig create mode 100644 include/configs/socfpga_agilex7_socdk.h
Add build support for AGILEX7 SoC.
Signed-off-by: Sin Hui Kho sin.hui.kho@intel.com --- arch/arm/mach-socfpga/Kconfig | 18 +++++ arch/arm/mach-socfpga/Makefile | 14 +++- configs/socfpga_agilex7_defconfig | 95 +++++++++++++++++++++++++ include/configs/socfpga_agilex7_socdk.h | 12 ++++ 4 files changed, 138 insertions(+), 1 deletion(-) create mode 100644 configs/socfpga_agilex7_defconfig create mode 100644 include/configs/socfpga_agilex7_socdk.h
diff --git a/arch/arm/mach-socfpga/Kconfig b/arch/arm/mach-socfpga/Kconfig index 503c82d388..e3d4503168 100644 --- a/arch/arm/mach-socfpga/Kconfig +++ b/arch/arm/mach-socfpga/Kconfig @@ -55,6 +55,17 @@ config TARGET_SOCFPGA_AGILEX select SPL_CLK if SPL select TARGET_SOCFPGA_SOC64
+config TARGET_SOCFPGA_AGILEX7 + bool + select ARMV8_MULTIENTRY + select ARMV8_SET_SMPEN + select BINMAN if SPL_ATF + select CLK + select FPGA_INTEL_SDM_MAILBOX + select NCORE_CACHE + select SPL_CLK if SPL + select TARGET_SOCFPGA_SOC64 + config TARGET_SOCFPGA_ARRIA5 bool select TARGET_SOCFPGA_GEN5 @@ -126,6 +137,10 @@ config TARGET_SOCFPGA_AGILEX_SOCDK bool "Intel SOCFPGA SoCDK (Agilex)" select TARGET_SOCFPGA_AGILEX
+config TARGET_SOCFPGA_AGILEX7_SOCDK + bool "Intel SOCFPGA SoCDK (Agilex7)" + select TARGET_SOCFPGA_AGILEX7 + config TARGET_SOCFPGA_ARIES_MCVEVK bool "Aries MCVEVK (Cyclone V)" select TARGET_SOCFPGA_CYCLONE5 @@ -200,6 +215,7 @@ endchoice
config SYS_BOARD default "agilex-socdk" if TARGET_SOCFPGA_AGILEX_SOCDK + default "agilex7-socdk" if TARGET_SOCFPGA_AGILEX7_SOCDK default "arria5-socdk" if TARGET_SOCFPGA_ARRIA5_SOCDK default "arria10-socdk" if TARGET_SOCFPGA_ARRIA10_SOCDK default "chameleonv3" if TARGET_SOCFPGA_CHAMELEONV3 @@ -221,6 +237,7 @@ config SYS_BOARD
config SYS_VENDOR default "intel" if TARGET_SOCFPGA_AGILEX_SOCDK + default "intel" if TARGET_SOCFPGA_AGILEX7_SOCDK default "intel" if TARGET_SOCFPGA_N5X_SOCDK default "altera" if TARGET_SOCFPGA_ARRIA5_SOCDK default "altera" if TARGET_SOCFPGA_ARRIA10_SOCDK @@ -243,6 +260,7 @@ config SYS_SOC
config SYS_CONFIG_NAME default "socfpga_agilex_socdk" if TARGET_SOCFPGA_AGILEX_SOCDK + default "socfpga_agilex7_socdk" if TARGET_SOCFPGA_AGILEX7_SOCDK default "socfpga_arria5_secu1" if TARGET_SOCFPGA_ARRIA5_SECU1 default "socfpga_arria5_socdk" if TARGET_SOCFPGA_ARRIA5_SOCDK default "socfpga_arria10_socdk" if TARGET_SOCFPGA_ARRIA10_SOCDK diff --git a/arch/arm/mach-socfpga/Makefile b/arch/arm/mach-socfpga/Makefile index ec38b64dd4..2b26be3f41 100644 --- a/arch/arm/mach-socfpga/Makefile +++ b/arch/arm/mach-socfpga/Makefile @@ -4,7 +4,7 @@ # Wolfgang Denk, DENX Software Engineering, wd@denx.de. # # Copyright (C) 2012-2017 Altera Corporation <www.altera.com> -# Copyright (C) 2017-2021 Intel Corporation <www.intel.com> +# Copyright (C) 2017-2023 Intel Corporation <www.intel.com>
obj-y += board.o obj-y += clock_manager.o @@ -71,6 +71,18 @@ obj-y += wrap_handoff_soc64.o obj-y += wrap_pll_config_soc64.o endif
+ifdef CONFIG_TARGET_SOCFPGA_AGILEX7 +obj-y += lowlevel_init_soc64.o +obj-y += mailbox_s10.o +obj-y += misc_soc64.o +obj-y += mmu-arm64_s10.o +obj-y += reset_manager_s10.o +obj-y += system_manager_soc64.o +obj-y += timer_s10.o +obj-y += wrap_handoff_soc64.o +obj-y += wrap_pll_config_soc64.o +endif + ifdef CONFIG_SPL_BUILD ifdef CONFIG_TARGET_SOCFPGA_GEN5 obj-y += spl_gen5.o diff --git a/configs/socfpga_agilex7_defconfig b/configs/socfpga_agilex7_defconfig new file mode 100644 index 0000000000..d8ed226fb1 --- /dev/null +++ b/configs/socfpga_agilex7_defconfig @@ -0,0 +1,95 @@ +CONFIG_ARM=y +CONFIG_COUNTER_FREQUENCY=400000000 +CONFIG_SPL_LDSCRIPT="arch/arm/mach-socfpga/u-boot-spl-soc64.lds" +CONFIG_ARCH_SOCFPGA=y +CONFIG_TEXT_BASE=0x200000 +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_NR_DRAM_BANKS=2 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x02100000 +CONFIG_ENV_SECT_SIZE=0x20000 +CONFIG_SYS_SPI_U_BOOT_OFFS=0x02000000 +CONFIG_DM_GPIO=y +CONFIG_DEFAULT_DEVICE_TREE="socfpga_agilex7_socdk" +CONFIG_SPL_TEXT_BASE=0xFFE00000 +CONFIG_TARGET_SOCFPGA_AGILEX7_SOCDK=y +CONFIG_IDENT_STRING="socfpga_agilex7" +CONFIG_SPL_FS_FAT=y +CONFIG_DISTRO_DEFAULTS=y +CONFIG_FIT=y +CONFIG_SPL_FIT_SIGNATURE=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_SPL_LOAD_FIT_ADDRESS=0x02000000 +CONFIG_SYS_LOAD_ADDR=0x02000000 +# CONFIG_USE_SPL_FIT_GENERATOR is not set +CONFIG_QSPI_BOOT=y +CONFIG_BOOTDELAY=5 +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="earlycon panic=-1" +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y +CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x300000 +CONFIG_SPL_MAX_SIZE=0x40000 +CONFIG_SPL_HAS_BSS_LINKER_SECTION=y +CONFIG_SPL_BSS_START_ADDR=0x3ff00000 +# CONFIG_SPL_SHARES_INIT_SP_ADDR is not set +CONFIG_SPL_STACK=0xffe3f000 +CONFIG_SYS_SPL_MALLOC=y +CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y +CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x3fa00000 +CONFIG_SYS_SPL_MALLOC_SIZE=0x500000 +CONFIG_SPL_BSS_MAX_SIZE=0x100000 +CONFIG_SPL_CRC32=y +CONFIG_SPL_MTD_SUPPORT=y +CONFIG_SPL_CACHE=y +CONFIG_SPL_SPI_LOAD=y +CONFIG_SPL_ATF=y +CONFIG_SPL_ATF_NO_PLATFORM_PARAM=y +CONFIG_SYS_PROMPT="SOCFPGA_AGILEX7 # " +CONFIG_CMD_NVEDIT_SELECT=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_MTD=y +CONFIG_CMD_SPI=y +CONFIG_CMD_USB=y +CONFIG_CMD_CACHE=y +# CONFIG_ISO_PARTITION is not set +# CONFIG_EFI_PARTITION is not set +CONFIG_OF_LIST="" +CONFIG_ENV_IS_IN_FAT=y +CONFIG_ENV_FAT_DEVICE_AND_PART="0:1" +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_SPL_ALTERA_SDRAM=y +CONFIG_FPGA_INTEL_PR=y +CONFIG_DWAPB_GPIO=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_DW=y +CONFIG_MISC=y +CONFIG_MMC_DW=y +CONFIG_MTD=y +CONFIG_DM_MTD=y +CONFIG_SF_DEFAULT_MODE=0x2003 +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_PHY_MICREL=y +CONFIG_PHY_MICREL_KSZ90X1=y +CONFIG_DM_ETH=y +CONFIG_ETH_DESIGNWARE=y +CONFIG_MII=y +CONFIG_DM_RESET=y +CONFIG_SPI=y +CONFIG_CADENCE_QSPI=y +CONFIG_DESIGNWARE_SPI=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_DWC2=y +CONFIG_DESIGNWARE_WATCHDOG=y +CONFIG_WDT=y +# CONFIG_SPL_USE_TINY_PRINTF is not set +CONFIG_PANIC_HANG=y +CONFIG_USE_BOOTFILE=y +CONFIG_BOOTFILE="kernel.itb" diff --git a/include/configs/socfpga_agilex7_socdk.h b/include/configs/socfpga_agilex7_socdk.h new file mode 100644 index 0000000000..7fdc0e0449 --- /dev/null +++ b/include/configs/socfpga_agilex7_socdk.h @@ -0,0 +1,12 @@ +/* SPDX-License-Identifier: GPL-2.0 + * + * Copyright (C) 2023 Intel Corporation <www.intel.com> + * + */ + +#ifndef __CONFIG_SOCFGPA_AGILEX7_H__ +#define __CONFIG_SOCFGPA_AGILEX7_H__ + +#include <configs/socfpga_soc64_common.h> + +#endif /* __CONFIG_SOCFGPA_AGILEX7_H__ */
Signed-off-by: Sin Hui Kho sin.hui.kho@intel.com --- board/intel/agilex7-socdk/MAINTAINERS | 7 +++++++ board/intel/agilex7-socdk/Makefile | 7 +++++++ board/intel/agilex7-socdk/socfpga.c | 7 +++++++ 3 files changed, 21 insertions(+) create mode 100644 board/intel/agilex7-socdk/MAINTAINERS create mode 100644 board/intel/agilex7-socdk/Makefile create mode 100644 board/intel/agilex7-socdk/socfpga.c
diff --git a/board/intel/agilex7-socdk/MAINTAINERS b/board/intel/agilex7-socdk/MAINTAINERS new file mode 100644 index 0000000000..8a9d178c3e --- /dev/null +++ b/board/intel/agilex7-socdk/MAINTAINERS @@ -0,0 +1,7 @@ +SOCFPGA BOARD +M: Tien Fong Chee tien.fong.chee@intel.com +M: Sin Hui Kho sin.hui.kho@intel.com +S: Maintained +F: board/intel/agilex7-socdk/ +F: include/configs/socfpga_agilex7_socdk.h +F: configs/socfpga_agilex7_defconfig diff --git a/board/intel/agilex7-socdk/Makefile b/board/intel/agilex7-socdk/Makefile new file mode 100644 index 0000000000..abbcbc6e2d --- /dev/null +++ b/board/intel/agilex7-socdk/Makefile @@ -0,0 +1,7 @@ +# +# Copyright (C) 2023 Intel Corporation <www.intel.com> +# +# SPDX-License-Identifier: GPL-2.0 +# + +obj-y := socfpga.o diff --git a/board/intel/agilex7-socdk/socfpga.c b/board/intel/agilex7-socdk/socfpga.c new file mode 100644 index 0000000000..df6a34109d --- /dev/null +++ b/board/intel/agilex7-socdk/socfpga.c @@ -0,0 +1,7 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2023 Intel Corporation <www.intel.com> + * + */ + +#include <common.h>
Add device tree files for AGILEX7 SoC platform. All clock setting is reuse from Agilex.
Signed-off-by: Sin Hui Kho sin.hui.kho@intel.com --- arch/arm/dts/Makefile | 1 + arch/arm/dts/socfpga_agilex7-u-boot.dtsi | 98 +++ arch/arm/dts/socfpga_agilex7.dtsi | 627 ++++++++++++++++++ .../arm/dts/socfpga_agilex7_socdk-u-boot.dtsi | 59 ++ arch/arm/dts/socfpga_agilex7_socdk.dts | 137 ++++ 5 files changed, 922 insertions(+) create mode 100644 arch/arm/dts/socfpga_agilex7-u-boot.dtsi create mode 100644 arch/arm/dts/socfpga_agilex7.dtsi create mode 100644 arch/arm/dts/socfpga_agilex7_socdk-u-boot.dtsi create mode 100644 arch/arm/dts/socfpga_agilex7_socdk.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index c160e884bf..00cfd2566a 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -446,6 +446,7 @@ dtb-$(CONFIG_TARGET_THUNDERX_88XX) += thunderx-88xx.dtb
dtb-$(CONFIG_ARCH_SOCFPGA) += \ socfpga_agilex_socdk.dtb \ + socfpga_agilex7_socdk.dtb \ socfpga_arria5_secu1.dtb \ socfpga_arria5_socdk.dtb \ socfpga_arria10_chameleonv3_270_2.dtb \ diff --git a/arch/arm/dts/socfpga_agilex7-u-boot.dtsi b/arch/arm/dts/socfpga_agilex7-u-boot.dtsi new file mode 100644 index 0000000000..8735e236c1 --- /dev/null +++ b/arch/arm/dts/socfpga_agilex7-u-boot.dtsi @@ -0,0 +1,98 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * U-Boot additions + * + * Copyright (C) 2023 Intel Corporation <www.intel.com> + */ + +#include "socfpga_soc64_fit-u-boot.dtsi" + +/{ + memory { + #address-cells = <2>; + #size-cells = <2>; + u-boot,dm-pre-reloc; + }; + + soc { + u-boot,dm-pre-reloc; + + ccu: cache-controller@f7000000 { + compatible = "arteris,ncore-ccu"; + reg = <0xf7000000 0x100900>; + u-boot,dm-pre-reloc; + }; + }; +}; + +&clkmgr { + u-boot,dm-pre-reloc; +}; + +&gmac1 { + altr,sysmgr-syscon = <&sysmgr 0x48 0>; +}; + +&gmac2 { + altr,sysmgr-syscon = <&sysmgr 0x4c 0>; +}; + +&i2c0 { + reset-names = "i2c"; +}; + +&i2c1 { + reset-names = "i2c"; +}; + +&i2c2 { + reset-names = "i2c"; +}; + +&i2c3 { + reset-names = "i2c"; +}; + +&mmc { + resets = <&rst SDMMC_RESET>, <&rst SDMMC_OCP_RESET>; +}; + +&porta { + bank-name = "porta"; +}; + +&portb { + bank-name = "portb"; +}; + +&qspi { + u-boot,dm-pre-reloc; +}; + +&rst { + compatible = "altr,rst-mgr"; + altr,modrst-offset = <0x20>; + u-boot,dm-pre-reloc; +}; + +&sdr { + compatible = "intel,sdr-ctl-agilex7"; + reg = <0xf8020000 0x100>, + <0xf8400000 0x1000>, + <0xf8800000 0x1000>; + resets = <&rst DDRSCH_RESET>; + u-boot,dm-pre-reloc; +}; + +&sysmgr { + compatible = "altr,sys-mgr", "syscon"; + u-boot,dm-pre-reloc; +}; + +&uart0 { + u-boot,dm-pre-reloc; +}; + +&watchdog0 { + u-boot,dm-pre-reloc; +}; diff --git a/arch/arm/dts/socfpga_agilex7.dtsi b/arch/arm/dts/socfpga_agilex7.dtsi new file mode 100644 index 0000000000..065ae7749f --- /dev/null +++ b/arch/arm/dts/socfpga_agilex7.dtsi @@ -0,0 +1,627 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2023, Intel Corporation + */ + +/dts-v1/; +#include <dt-bindings/reset/altr,rst-mgr-s10.h> +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/clock/agilex-clock.h> + +/ { + compatible = "intel,socfpga-agilex7"; + #address-cells = <2>; + #size-cells = <2>; + + reserved-memory { + #address-cells = <2>; + #size-cells = <2>; + ranges; + + service_reserved: svcbuffer@0 { + compatible = "shared-dma-pool"; + reg = <0x0 0x0 0x0 0x2000000>; + alignment = <0x1000>; + no-map; + }; + }; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + + cpu0: cpu@0 { + compatible = "arm,cortex-a53"; + device_type = "cpu"; + enable-method = "psci"; + reg = <0x0>; + }; + + cpu1: cpu@1 { + compatible = "arm,cortex-a53"; + device_type = "cpu"; + enable-method = "psci"; + reg = <0x1>; + }; + + cpu2: cpu@2 { + compatible = "arm,cortex-a53"; + device_type = "cpu"; + enable-method = "psci"; + reg = <0x2>; + }; + + cpu3: cpu@3 { + compatible = "arm,cortex-a53"; + device_type = "cpu"; + enable-method = "psci"; + reg = <0x3>; + }; + }; + + pmu { + compatible = "arm,armv8-pmuv3"; + interrupts = <0 170 4>, + <0 171 4>, + <0 172 4>, + <0 173 4>; + interrupt-affinity = <&cpu0>, + <&cpu1>, + <&cpu2>, + <&cpu3>; + interrupt-parent = <&intc>; + }; + + psci { + compatible = "arm,psci-0.2"; + method = "smc"; + }; + + intc: intc@fffc1000 { + compatible = "arm,gic-400", "arm,cortex-a15-gic"; + #interrupt-cells = <3>; + interrupt-controller; + reg = <0x0 0xfffc1000 0x0 0x1000>, + <0x0 0xfffc2000 0x0 0x2000>, + <0x0 0xfffc4000 0x0 0x2000>, + <0x0 0xfffc6000 0x0 0x2000>; + }; + + soc { + #address-cells = <1>; + #size-cells = <1>; + compatible = "simple-bus"; + device_type = "soc"; + interrupt-parent = <&intc>; + ranges = <0 0 0 0xffffffff>; + + base_fpga_region { + #address-cells = <0x1>; + #size-cells = <0x1>; + compatible = "fpga-region"; + fpga-mgr = <&fpga_mgr>; + }; + + clkmgr: clock-controller@ffd10000 { + compatible = "intel,agilex-clkmgr"; + reg = <0xffd10000 0x1000>; + #clock-cells = <1>; + }; + + clocks { + cb_intosc_hs_div2_clk: cb-intosc-hs-div2-clk { + #clock-cells = <0>; + compatible = "fixed-clock"; + }; + + cb_intosc_ls_clk: cb-intosc-ls-clk { + #clock-cells = <0>; + compatible = "fixed-clock"; + }; + + f2s_free_clk: f2s-free-clk { + #clock-cells = <0>; + compatible = "fixed-clock"; + }; + + osc1: osc1 { + #clock-cells = <0>; + compatible = "fixed-clock"; + }; + + qspi_clk: qspi-clk { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <200000000>; + }; + }; + gmac0: ethernet@ff800000 { + compatible = "altr,socfpga-stmmac", "snps,dwmac-3.74a", "snps,dwmac"; + reg = <0xff800000 0x2000>; + interrupts = <0 90 4>; + interrupt-names = "macirq"; + mac-address = [00 00 00 00 00 00]; + resets = <&rst EMAC0_RESET>, <&rst EMAC0_OCP_RESET>; + reset-names = "stmmaceth", "stmmaceth-ocp"; + tx-fifo-depth = <16384>; + rx-fifo-depth = <16384>; + snps,multicast-filter-bins = <256>; + iommus = <&smmu 1>; + altr,sysmgr-syscon = <&sysmgr 0x44 0>; + clocks = <&clkmgr AGILEX_EMAC0_CLK>; + clock-names = "stmmaceth"; + status = "disabled"; + }; + + gmac1: ethernet@ff802000 { + compatible = "altr,socfpga-stmmac", "snps,dwmac-3.74a", "snps,dwmac"; + reg = <0xff802000 0x2000>; + interrupts = <0 91 4>; + interrupt-names = "macirq"; + mac-address = [00 00 00 00 00 00]; + resets = <&rst EMAC1_RESET>, <&rst EMAC1_OCP_RESET>; + reset-names = "stmmaceth", "stmmaceth-ocp"; + tx-fifo-depth = <16384>; + rx-fifo-depth = <16384>; + snps,multicast-filter-bins = <256>; + iommus = <&smmu 2>; + altr,sysmgr-syscon = <&sysmgr 0x48 8>; + clocks = <&clkmgr AGILEX_EMAC1_CLK>; + clock-names = "stmmaceth"; + status = "disabled"; + }; + + gmac2: ethernet@ff804000 { + compatible = "altr,socfpga-stmmac", "snps,dwmac-3.74a", "snps,dwmac"; + reg = <0xff804000 0x2000>; + interrupts = <0 92 4>; + interrupt-names = "macirq"; + mac-address = [00 00 00 00 00 00]; + resets = <&rst EMAC2_RESET>, <&rst EMAC2_OCP_RESET>; + reset-names = "stmmaceth", "stmmaceth-ocp"; + tx-fifo-depth = <16384>; + rx-fifo-depth = <16384>; + snps,multicast-filter-bins = <256>; + iommus = <&smmu 3>; + altr,sysmgr-syscon = <&sysmgr 0x4c 16>; + clocks = <&clkmgr AGILEX_EMAC2_CLK>; + clock-names = "stmmaceth"; + status = "disabled"; + }; + + gpio0: gpio@ffc03200 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "snps,dw-apb-gpio"; + reg = <0xffc03200 0x100>; + resets = <&rst GPIO0_RESET>; + status = "disabled"; + + porta: gpio-controller@0 { + compatible = "snps,dw-apb-gpio-port"; + gpio-controller; + #gpio-cells = <2>; + snps,nr-gpios = <24>; + reg = <0>; + interrupt-controller; + #interrupt-cells = <2>; + interrupts = <0 110 4>; + }; + }; + + gpio1: gpio@ffc03300 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "snps,dw-apb-gpio"; + reg = <0xffc03300 0x100>; + resets = <&rst GPIO1_RESET>; + status = "disabled"; + + portb: gpio-controller@0 { + compatible = "snps,dw-apb-gpio-port"; + gpio-controller; + #gpio-cells = <2>; + snps,nr-gpios = <24>; + reg = <0>; + interrupt-controller; + #interrupt-cells = <2>; + interrupts = <0 111 4>; + }; + }; + + i2c0: i2c@ffc02800 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "snps,designware-i2c"; + reg = <0xffc02800 0x100>; + interrupts = <0 103 4>; + resets = <&rst I2C0_RESET>; + clocks = <&clkmgr AGILEX_L4_SP_CLK>; + status = "disabled"; + }; + + i2c1: i2c@ffc02900 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "snps,designware-i2c"; + reg = <0xffc02900 0x100>; + interrupts = <0 104 4>; + resets = <&rst I2C1_RESET>; + clocks = <&clkmgr AGILEX_L4_SP_CLK>; + status = "disabled"; + }; + + i2c2: i2c@ffc02a00 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "snps,designware-i2c"; + reg = <0xffc02a00 0x100>; + interrupts = <0 105 4>; + resets = <&rst I2C2_RESET>; + clocks = <&clkmgr AGILEX_L4_SP_CLK>; + status = "disabled"; + }; + + i2c3: i2c@ffc02b00 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "snps,designware-i2c"; + reg = <0xffc02b00 0x100>; + interrupts = <0 106 4>; + resets = <&rst I2C3_RESET>; + clocks = <&clkmgr AGILEX_L4_SP_CLK>; + status = "disabled"; + }; + + i2c4: i2c@ffc02c00 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "snps,designware-i2c"; + reg = <0xffc02c00 0x100>; + interrupts = <0 107 4>; + resets = <&rst I2C4_RESET>; + clocks = <&clkmgr AGILEX_L4_SP_CLK>; + status = "disabled"; + }; + + mmc: dwmmc0@ff808000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "altr,socfpga-dw-mshc"; + reg = <0xff808000 0x1000>; + interrupts = <0 96 4>; + fifo-depth = <0x400>; + resets = <&rst SDMMC_RESET>; + reset-names = "reset"; + clocks = <&clkmgr AGILEX_L4_MP_CLK>, + <&clkmgr AGILEX_SDMMC_CLK>; + clock-names = "biu", "ciu"; + iommus = <&smmu 5>; + status = "disabled"; + }; + + nand: nand@ffb90000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "altr,socfpga-denali-nand"; + reg = <0xffb90000 0x10000>, + <0xffb80000 0x1000>; + reg-names = "nand_data", "denali_reg"; + interrupts = <0 97 4>; + clocks = <&clkmgr AGILEX_NAND_CLK>, + <&clkmgr AGILEX_NAND_X_CLK>; + clock-names = "nand", "nand_x"; + resets = <&rst NAND_RESET>, <&rst NAND_OCP_RESET>; + status = "disabled"; + }; + + ocram: sram@ffe00000 { + compatible = "mmio-sram"; + reg = <0xffe00000 0x40000>; + }; + + pdma: pdma@ffda0000 { + compatible = "arm,pl330", "arm,primecell"; + reg = <0xffda0000 0x1000>; + interrupts = <0 81 4>, + <0 82 4>, + <0 83 4>, + <0 84 4>, + <0 85 4>, + <0 86 4>, + <0 87 4>, + <0 88 4>, + <0 89 4>; + #dma-cells = <1>; + #dma-channels = <8>; + #dma-requests = <32>; + resets = <&rst DMA_RESET>, <&rst DMA_OCP_RESET>; + reset-names = "dma", "dma-ocp"; + clocks = <&clkmgr AGILEX_L4_MAIN_CLK>; + clock-names = "apb_pclk"; + }; + + rst: rstmgr@ffd11000 { + #reset-cells = <1>; + compatible = "altr,stratix10-rst-mgr"; + reg = <0xffd11000 0x100>; + }; + + smmu: iommu@fa000000 { + compatible = "arm,mmu-500", "arm,smmu-v2"; + reg = <0xfa000000 0x40000>; + #global-interrupts = <2>; + #iommu-cells = <1>; + interrupt-parent = <&intc>; + interrupts = <0 128 4>, /* Global Secure Fault */ + <0 129 4>, /* Global Non-secure Fault */ + /* Non-secure Context Interrupts (32) */ + <0 138 4>, <0 139 4>, <0 140 4>, <0 141 4>, + <0 142 4>, <0 143 4>, <0 144 4>, <0 145 4>, + <0 146 4>, <0 147 4>, <0 148 4>, <0 149 4>, + <0 150 4>, <0 151 4>, <0 152 4>, <0 153 4>, + <0 154 4>, <0 155 4>, <0 156 4>, <0 157 4>, + <0 158 4>, <0 159 4>, <0 160 4>, <0 161 4>, + <0 162 4>, <0 163 4>, <0 164 4>, <0 165 4>, + <0 166 4>, <0 167 4>, <0 168 4>, <0 169 4>; + stream-match-mask = <0x7ff0>; + status = "disabled"; + }; + + spi0: spi@ffda4000 { + compatible = "intel,agilex-spi", + "snps,dw-apb-ssi-4.00a", "snps,dw-apb-ssi"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0xffda4000 0x1000>; + interrupts = <0 99 4>; + resets = <&rst SPIM0_RESET>; + reg-io-width = <4>; + num-cs = <4>; + clocks = <&clkmgr AGILEX_L4_MAIN_CLK>; + status = "disabled"; + }; + + spi1: spi@ffda5000 { + compatible = "intel,agilex-spi", + "snps,dw-apb-ssi-4.00a", "snps,dw-apb-ssi"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0xffda5000 0x1000>; + interrupts = <0 100 4>; + resets = <&rst SPIM1_RESET>; + reg-io-width = <4>; + num-cs = <4>; + clocks = <&clkmgr AGILEX_L4_MAIN_CLK>; + status = "disabled"; + }; + + sysmgr: sysmgr@ffd12000 { + compatible = "altr,sys-mgr-s10","altr,sys-mgr"; + reg = <0xffd12000 0x500>; + }; + + /* Local timer */ + timer { + compatible = "arm,armv8-timer"; + interrupts = <1 13 0xf08>, + <1 14 0xf08>, + <1 11 0xf08>, + <1 10 0xf08>; + }; + + timer0: timer0@ffc03000 { + compatible = "snps,dw-apb-timer"; + interrupts = <0 113 4>; + reg = <0xffc03000 0x100>; + clocks = <&clkmgr AGILEX_L4_SP_CLK>; + clock-names = "timer"; + }; + + timer1: timer1@ffc03100 { + compatible = "snps,dw-apb-timer"; + interrupts = <0 114 4>; + reg = <0xffc03100 0x100>; + clocks = <&clkmgr AGILEX_L4_SP_CLK>; + clock-names = "timer"; + }; + + timer2: timer2@ffd00000 { + compatible = "snps,dw-apb-timer"; + interrupts = <0 115 4>; + reg = <0xffd00000 0x100>; + clocks = <&clkmgr AGILEX_L4_SP_CLK>; + clock-names = "timer"; + }; + + timer3: timer3@ffd00100 { + compatible = "snps,dw-apb-timer"; + interrupts = <0 116 4>; + reg = <0xffd00100 0x100>; + clocks = <&clkmgr AGILEX_L4_SP_CLK>; + clock-names = "timer"; + }; + + uart0: serial0@ffc02000 { + compatible = "snps,dw-apb-uart"; + reg = <0xffc02000 0x100>; + interrupts = <0 108 4>; + reg-shift = <2>; + reg-io-width = <4>; + resets = <&rst UART0_RESET>; + status = "disabled"; + clocks = <&clkmgr AGILEX_L4_SP_CLK>; + clock-frequency = <100000000>; + }; + + uart1: serial1@ffc02100 { + compatible = "snps,dw-apb-uart"; + reg = <0xffc02100 0x100>; + interrupts = <0 109 4>; + reg-shift = <2>; + reg-io-width = <4>; + resets = <&rst UART1_RESET>; + clocks = <&clkmgr AGILEX_L4_SP_CLK>; + status = "disabled"; + }; + + usbphy0: usbphy@0 { + #phy-cells = <0>; + compatible = "usb-nop-xceiv"; + status = "okay"; + }; + + usb0: usb@ffb00000 { + compatible = "snps,dwc2"; + reg = <0xffb00000 0x40000>; + interrupts = <0 93 4>; + phys = <&usbphy0>; + phy-names = "usb2-phy"; + resets = <&rst USB0_RESET>, <&rst USB0_OCP_RESET>; + reset-names = "dwc2", "dwc2-ecc"; + clocks = <&clkmgr AGILEX_USB_CLK>; + iommus = <&smmu 6>; + status = "disabled"; + }; + + usb1: usb@ffb40000 { + compatible = "snps,dwc2"; + reg = <0xffb40000 0x40000>; + interrupts = <0 94 4>; + phys = <&usbphy0>; + phy-names = "usb2-phy"; + resets = <&rst USB1_RESET>, <&rst USB1_OCP_RESET>; + reset-names = "dwc2", "dwc2-ecc"; + iommus = <&smmu 7>; + clocks = <&clkmgr AGILEX_USB_CLK>; + status = "disabled"; + }; + + watchdog0: watchdog@ffd00200 { + compatible = "snps,dw-wdt"; + reg = <0xffd00200 0x100>; + interrupts = <0 117 4>; + resets = <&rst WATCHDOG0_RESET>; + clocks = <&clkmgr AGILEX_L4_SYS_FREE_CLK>; + status = "disabled"; + }; + + watchdog1: watchdog@ffd00300 { + compatible = "snps,dw-wdt"; + reg = <0xffd00300 0x100>; + interrupts = <0 118 4>; + resets = <&rst WATCHDOG1_RESET>; + clocks = <&clkmgr AGILEX_L4_SYS_FREE_CLK>; + status = "disabled"; + }; + + watchdog2: watchdog@ffd00400 { + compatible = "snps,dw-wdt"; + reg = <0xffd00400 0x100>; + interrupts = <0 125 4>; + resets = <&rst WATCHDOG2_RESET>; + clocks = <&clkmgr AGILEX_L4_SYS_FREE_CLK>; + status = "disabled"; + }; + + watchdog3: watchdog@ffd00500 { + compatible = "snps,dw-wdt"; + reg = <0xffd00500 0x100>; + interrupts = <0 126 4>; + resets = <&rst WATCHDOG3_RESET>; + clocks = <&clkmgr AGILEX_L4_SYS_FREE_CLK>; + status = "disabled"; + }; + + sdr: sdr@f8011100 { + compatible = "altr,sdr-ctl", "syscon"; + reg = <0xf8011100 0xc0>; + }; + + eccmgr { + compatible = "altr,socfpga-s10-ecc-manager", + "altr,socfpga-a10-ecc-manager"; + altr,sysmgr-syscon = <&sysmgr>; + #address-cells = <1>; + #size-cells = <1>; + interrupts = <0 15 4>; + interrupt-controller; + #interrupt-cells = <2>; + ranges; + + sdramedac { + compatible = "altr,sdram-edac-s10"; + altr,sdr-syscon = <&sdr>; + interrupts = <16 4>; + }; + + ocram-ecc@ff8cc000 { + compatible = "altr,socfpga-s10-ocram-ecc", + "altr,socfpga-a10-ocram-ecc"; + reg = <0xff8cc000 0x100>; + altr,ecc-parent = <&ocram>; + interrupts = <1 4>; + }; + + usb0-ecc@ff8c4000 { + compatible = "altr,socfpga-s10-usb-ecc", + "altr,socfpga-usb-ecc"; + reg = <0xff8c4000 0x100>; + altr,ecc-parent = <&usb0>; + interrupts = <2 4>; + }; + + emac0-rx-ecc@ff8c0000 { + compatible = "altr,socfpga-s10-eth-mac-ecc", + "altr,socfpga-eth-mac-ecc"; + reg = <0xff8c0000 0x100>; + altr,ecc-parent = <&gmac0>; + interrupts = <4 4>; + }; + + emac0-tx-ecc@ff8c0400 { + compatible = "altr,socfpga-s10-eth-mac-ecc", + "altr,socfpga-eth-mac-ecc"; + reg = <0xff8c0400 0x100>; + altr,ecc-parent = <&gmac0>; + interrupts = <5 4>; + }; + + sdmmca-ecc@ff8c8c00 { + compatible = "altr,socfpga-s10-sdmmc-ecc", + "altr,socfpga-sdmmc-ecc"; + reg = <0xff8c8c00 0x100>; + altr,ecc-parent = <&mmc>; + interrupts = <14 4>, + <15 4>; + }; + }; + + qspi: spi@ff8d2000 { + compatible = "cdns,qspi-nor"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0xff8d2000 0x100>, + <0xff900000 0x100000>; + interrupts = <0 3 4>; + cdns,fifo-depth = <128>; + cdns,fifo-width = <4>; + cdns,trigger-address = <0x00000000>; + clocks = <&qspi_clk>; + + status = "disabled"; + }; + + firmware { + svc { + compatible = "intel,stratix10-svc"; + method = "smc"; + memory-region = <&service_reserved>; + + fpga_mgr: fpga-mgr { + compatible = "intel,stratix10-soc-fpga-mgr"; + }; + }; + }; + }; +}; diff --git a/arch/arm/dts/socfpga_agilex7_socdk-u-boot.dtsi b/arch/arm/dts/socfpga_agilex7_socdk-u-boot.dtsi new file mode 100644 index 0000000000..9b880997e1 --- /dev/null +++ b/arch/arm/dts/socfpga_agilex7_socdk-u-boot.dtsi @@ -0,0 +1,59 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * U-Boot additions + * + * Copyright (C) 2023 Intel Corporation <www.intel.com> + */ + +#include "socfpga_agilex7-u-boot.dtsi" + +/{ + chosen { + stdout-path = "serial0:115200n8"; + }; + + aliases { + spi0 = &qspi; + i2c0 = &i2c1; + freeze_br0 = &freeze_controller; + }; + + soc { + freeze_controller: freeze_controller@f9000450 { + compatible = "altr,freeze-bridge-controller"; + reg = <0xf9000450 0x00000010>; + status = "disabled"; + }; + }; + + memory { + /* 4GB */ + reg = <0 0x00000000 0 0x80000000>, + <1 0x80000000 0 0x80000000>; + }; +}; + +&flash0 { + compatible = "jedec,spi-nor"; + spi-tx-bus-width = <4>; + spi-rx-bus-width = <4>; + u-boot,dm-pre-reloc; +}; + +&i2c1 { + status = "okay"; +}; + +&mmc { + drvsel = <3>; + smplsel = <0>; + u-boot,dm-pre-reloc; +}; + +&qspi { + status = "okay"; +}; + +&watchdog0 { + u-boot,dm-pre-reloc; +}; diff --git a/arch/arm/dts/socfpga_agilex7_socdk.dts b/arch/arm/dts/socfpga_agilex7_socdk.dts new file mode 100644 index 0000000000..356992ed23 --- /dev/null +++ b/arch/arm/dts/socfpga_agilex7_socdk.dts @@ -0,0 +1,137 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2023, Intel Corporation + */ +#include "socfpga_agilex7.dtsi" + +/ { + model = "SoCFPGA AGILEX7 SoCDK"; + + aliases { + serial0 = &uart0; + ethernet0 = &gmac0; + ethernet1 = &gmac1; + ethernet2 = &gmac2; + }; + + leds { + compatible = "gpio-leds"; + hps0 { + label = "hps_led0"; + gpios = <&portb 20 GPIO_ACTIVE_HIGH>; + }; + + hps1 { + label = "hps_led1"; + gpios = <&portb 19 GPIO_ACTIVE_HIGH>; + }; + + hps2 { + label = "hps_led2"; + gpios = <&portb 21 GPIO_ACTIVE_HIGH>; + }; + }; + + memory { + device_type = "memory"; + /* We expect the bootloader to fill in the reg */ + reg = <0 0 0 0>; + }; + + soc { + clocks { + osc1 { + clock-frequency = <25000000>; + }; + }; + }; +}; + +&gpio1 { + status = "okay"; +}; + +&gmac0 { + status = "okay"; + phy-mode = "rgmii"; + phy-handle = <&phy0>; + + max-frame-size = <9000>; + + mdio0 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "snps,dwmac-mdio"; + phy0: ethernet-phy@0 { + reg = <4>; + + txd0-skew-ps = <0>; /* -420ps */ + txd1-skew-ps = <0>; /* -420ps */ + txd2-skew-ps = <0>; /* -420ps */ + txd3-skew-ps = <0>; /* -420ps */ + rxd0-skew-ps = <420>; /* 0ps */ + rxd1-skew-ps = <420>; /* 0ps */ + rxd2-skew-ps = <420>; /* 0ps */ + rxd3-skew-ps = <420>; /* 0ps */ + txen-skew-ps = <0>; /* -420ps */ + txc-skew-ps = <900>; /* 0ps */ + rxdv-skew-ps = <420>; /* 0ps */ + rxc-skew-ps = <1680>; /* 780ps */ + }; + }; +}; + +&mmc { + status = "okay"; + cap-sd-highspeed; + broken-cd; + bus-width = <4>; +}; + +&uart0 { + status = "okay"; +}; + +&usb0 { + status = "okay"; + disable-over-current; +}; + +&watchdog0 { + status = "okay"; +}; + +&qspi { + flash0: flash@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "mt25qu02g"; + reg = <0>; + spi-max-frequency = <100000000>; + + m25p,fast-read; + cdns,page-size = <256>; + cdns,block-size = <16>; + cdns,read-delay = <1>; + cdns,tshsl-ns = <50>; + cdns,tsd2d-ns = <50>; + cdns,tchsh-ns = <4>; + cdns,tslch-ns = <4>; + + partitions { + compatible = "fixed-partitions"; + #address-cells = <1>; + #size-cells = <1>; + + qspi_boot: partition@0 { + label = "Boot and fpga data"; + reg = <0x0 0x034B0000>; + }; + + qspi_rootfs: partition@34B0000 { + label = "Root Filesystem - JFFS2"; + reg = <0x034B0000 0x0EB50000>; + }; + }; + }; +};
Add SPL support for AGILEX7 SoC.
Signed-off-by: Sin Hui Kho sin.hui.kho@intel.com --- arch/arm/mach-socfpga/Makefile | 3 + arch/arm/mach-socfpga/spl_agilex7.c | 87 +++++++++++++++++++++++++++++ 2 files changed, 90 insertions(+) create mode 100644 arch/arm/mach-socfpga/spl_agilex7.c
diff --git a/arch/arm/mach-socfpga/Makefile b/arch/arm/mach-socfpga/Makefile index 2b26be3f41..224ed02865 100644 --- a/arch/arm/mach-socfpga/Makefile +++ b/arch/arm/mach-socfpga/Makefile @@ -107,6 +107,9 @@ endif ifdef CONFIG_TARGET_SOCFPGA_N5X obj-y += spl_n5x.o endif +ifdef CONFIG_TARGET_SOCFPGA_AGILEX7 +obj-y += spl_agilex7.o +endif else obj-$(CONFIG_SPL_ATF) += secure_reg_helper.o obj-$(CONFIG_SPL_ATF) += smc_api.o diff --git a/arch/arm/mach-socfpga/spl_agilex7.c b/arch/arm/mach-socfpga/spl_agilex7.c new file mode 100644 index 0000000000..1225ade387 --- /dev/null +++ b/arch/arm/mach-socfpga/spl_agilex7.c @@ -0,0 +1,87 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2023 Intel Corporation <www.intel.com> + * + */ + +#include <init.h> +#include <log.h> +#include <asm/global_data.h> +#include <asm/io.h> +#include <asm/u-boot.h> +#include <asm/utils.h> +#include <common.h> +#include <hang.h> +#include <image.h> +#include <spl.h> +#include <asm/arch/clock_manager.h> +#include <asm/arch/firewall.h> +#include <asm/arch/mailbox_s10.h> +#include <asm/arch/misc.h> +#include <asm/arch/reset_manager.h> +#include <asm/arch/system_manager.h> +#include <watchdog.h> +#include <dm/uclass.h> + +DECLARE_GLOBAL_DATA_PTR; + +void board_init_f(ulong dummy) +{ + int ret; + struct udevice *dev; + + ret = spl_early_init(); + if (ret) + hang(); + + socfpga_get_managers_addr(); + + /* Ensure watchdog is paused when debugging is happening */ + writel(SYSMGR_WDDBG_PAUSE_ALL_CPU, + socfpga_get_sysmgr_addr() + SYSMGR_SOC64_WDDBG); + +#ifdef CONFIG_HW_WATCHDOG + /* Enable watchdog before initializing the HW */ + socfpga_per_reset(SOCFPGA_RESET(L4WD0), 1); + socfpga_per_reset(SOCFPGA_RESET(L4WD0), 0); + hw_watchdog_init(); +#endif + + /* ensure all processors are not released prior Linux boot */ + writeq(0, CPU_RELEASE_ADDR); + + timer_init(); + + sysmgr_pinmux_init(); + + ret = uclass_get_device(UCLASS_CLK, 0, &dev); + if (ret) { + debug("Clock init failed: %d\n", ret); + hang(); + } + + preloader_console_init(); + print_reset_info(); + cm_print_clock_quick_summary(); + + firewall_setup(); + ret = uclass_get_device(UCLASS_CACHE, 0, &dev); + if (ret) { + debug("CCU init failed: %d\n", ret); + hang(); + } + +#if CONFIG_IS_ENABLED(ALTERA_SDRAM) + ret = uclass_get_device(UCLASS_RAM, 0, &dev); + if (ret) { + debug("DRAM init failed: %d\n", ret); + hang(); + } +#endif + + mbox_init(); + +#ifdef CONFIG_CADENCE_QSPI + mbox_qspi_open(); +#endif +}
Add clock manager driver support for AGILEX7 by reuse Agilex clock manager.
Signed-off-by: Sin Hui Kho sin.hui.kho@intel.com --- arch/arm/mach-socfpga/Makefile | 1 + arch/arm/mach-socfpga/include/mach/clock_manager.h | 2 +- arch/arm/mach-socfpga/misc.c | 3 +++ drivers/clk/altera/Makefile | 1 + 4 files changed, 6 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-socfpga/Makefile b/arch/arm/mach-socfpga/Makefile index 224ed02865..39b1168821 100644 --- a/arch/arm/mach-socfpga/Makefile +++ b/arch/arm/mach-socfpga/Makefile @@ -72,6 +72,7 @@ obj-y += wrap_pll_config_soc64.o endif
ifdef CONFIG_TARGET_SOCFPGA_AGILEX7 +obj-y += clock_manager_agilex.o obj-y += lowlevel_init_soc64.o obj-y += mailbox_s10.o obj-y += misc_soc64.o diff --git a/arch/arm/mach-socfpga/include/mach/clock_manager.h b/arch/arm/mach-socfpga/include/mach/clock_manager.h index a8cb07a1c4..252db8204e 100644 --- a/arch/arm/mach-socfpga/include/mach/clock_manager.h +++ b/arch/arm/mach-socfpga/include/mach/clock_manager.h @@ -26,7 +26,7 @@ int cm_set_qspi_controller_clk_hz(u32 clk_hz); #include <asm/arch/clock_manager_arria10.h> #elif defined(CONFIG_TARGET_SOCFPGA_STRATIX10) #include <asm/arch/clock_manager_s10.h> -#elif defined(CONFIG_TARGET_SOCFPGA_AGILEX) +#elif defined(CONFIG_TARGET_SOCFPGA_AGILEX) || defined(CONFIG_TARGET_SOCFPGA_AGILEX7) #include <asm/arch/clock_manager_agilex.h> #elif IS_ENABLED(CONFIG_TARGET_SOCFPGA_N5X) #include <asm/arch/clock_manager_n5x.h> diff --git a/arch/arm/mach-socfpga/misc.c b/arch/arm/mach-socfpga/misc.c index 5b5a81a255..fe3cb1ec01 100644 --- a/arch/arm/mach-socfpga/misc.c +++ b/arch/arm/mach-socfpga/misc.c @@ -257,6 +257,9 @@ void socfpga_get_managers_addr(void) #elif IS_ENABLED(CONFIG_TARGET_SOCFPGA_N5X) ret = socfpga_get_base_addr("intel,n5x-clkmgr", &socfpga_clkmgr_base); +#elif IS_ENABLED(CONFIG_TARGET_SOCFPGA_AGILEX7) + ret = socfpga_get_base_addr("intel,agilex-clkmgr", + &socfpga_clkmgr_base); #else ret = socfpga_get_base_addr("altr,clk-mgr", &socfpga_clkmgr_base); #endif diff --git a/drivers/clk/altera/Makefile b/drivers/clk/altera/Makefile index 33db092918..247a44b093 100644 --- a/drivers/clk/altera/Makefile +++ b/drivers/clk/altera/Makefile @@ -4,6 +4,7 @@ #
obj-$(CONFIG_TARGET_SOCFPGA_AGILEX) += clk-agilex.o +obj-$(CONFIG_TARGET_SOCFPGA_AGILEX7) += clk-agilex.o obj-$(CONFIG_TARGET_SOCFPGA_ARRIA10) += clk-arria10.o obj-$(CONFIG_TARGET_SOCFPGA_N5X) += clk-n5x.o obj-$(CONFIG_TARGET_SOCFPGA_N5X) += clk-mem-n5x.o
Add base address support for AGILEX7. Reuse same base as Agilex.
Signed-off-by: Sin Hui Kho sin.hui.kho@intel.com --- arch/arm/mach-socfpga/include/mach/base_addr_soc64.h | 3 ++- arch/arm/mach-socfpga/include/mach/handoff_soc64.h | 3 ++- 2 files changed, 4 insertions(+), 2 deletions(-)
diff --git a/arch/arm/mach-socfpga/include/mach/base_addr_soc64.h b/arch/arm/mach-socfpga/include/mach/base_addr_soc64.h index 3f899fcfa3..eecbb037f5 100644 --- a/arch/arm/mach-socfpga/include/mach/base_addr_soc64.h +++ b/arch/arm/mach-socfpga/include/mach/base_addr_soc64.h @@ -11,7 +11,8 @@ #define SOCFPGA_HMC_MMR_IO48_ADDRESS 0xf8010000 #define SOCFPGA_SDR_ADDRESS 0xf8011000 #if IS_ENABLED(CONFIG_TARGET_SOCFPGA_AGILEX) || \ - IS_ENABLED(CONFIG_TARGET_SOCFPGA_N5X) + IS_ENABLED(CONFIG_TARGET_SOCFPGA_N5X) || \ + IS_ENABLED(CONFIG_TARGET_SOCFPGA_AGILEX7) #define SOCFPGA_FW_MPU_DDR_SCR_ADDRESS 0xf8020200 #else #define SOCFPGA_FW_MPU_DDR_SCR_ADDRESS 0xf8020100 diff --git a/arch/arm/mach-socfpga/include/mach/handoff_soc64.h b/arch/arm/mach-socfpga/include/mach/handoff_soc64.h index 902fc6bfb5..b0134dd9bd 100644 --- a/arch/arm/mach-socfpga/include/mach/handoff_soc64.h +++ b/arch/arm/mach-socfpga/include/mach/handoff_soc64.h @@ -24,7 +24,8 @@ #define SOC64_HANDOFF_SIZE 4096
#if IS_ENABLED(CONFIG_TARGET_SOCFPGA_STRATIX10) || \ - IS_ENABLED(CONFIG_TARGET_SOCFPGA_AGILEX) + IS_ENABLED(CONFIG_TARGET_SOCFPGA_AGILEX) || \ + IS_ENABLED(CONFIG_TARGET_SOCFPGA_AGILEX7) #define SOC64_HANDOFF_BASE 0xFFE3F000 #define SOC64_HANDOFF_MISC (SOC64_HANDOFF_BASE + 0x610) #elif IS_ENABLED(CONFIG_TARGET_SOCFPGA_N5X)
