[U-Boot] [PATCH] ARM: fix address setup in start.S
Fix address setup bug for ARM. This bug stops u-boot booting if CONFIG_SKIP_RELOCATE_UBOOT is defined.
Signed-off-by: Darius Augulis augulis.darius@gmail.com --- arch/arm/cpu/arm1136/start.S | 6 ++++-- arch/arm/cpu/arm926ejs/start.S | 6 ++++-- arch/arm/cpu/armv7/start.S | 6 ++++-- arch/arm/cpu/pxa/start.S | 6 ++++-- 4 files changed, 16 insertions(+), 8 deletions(-)
diff --git a/arch/arm/cpu/arm1136/start.S b/arch/arm/cpu/arm1136/start.S index 29ed065..6a82310 100644 --- a/arch/arm/cpu/arm1136/start.S +++ b/arch/arm/cpu/arm1136/start.S @@ -296,8 +296,10 @@ _nand_boot_ofs jump_2_ram: ldr r0, _board_init_r_ofs adr r1, _start - add r0, r0, r1 - add lr, r0, r9 + add lr, r0, r1 +#ifndef CONFIG_SKIP_RELOCATE_UBOOT + add lr, lr, r9 +#endif /* setup parameters for board_init_r */ mov r0, r5 /* gd_t */ mov r1, r7 /* dest_addr */ diff --git a/arch/arm/cpu/arm926ejs/start.S b/arch/arm/cpu/arm926ejs/start.S index 863de3b..e7e985a 100644 --- a/arch/arm/cpu/arm926ejs/start.S +++ b/arch/arm/cpu/arm926ejs/start.S @@ -286,8 +286,10 @@ _nand_boot_ofs: #else ldr r0, _board_init_r_ofs adr r1, _start - add r0, r0, r1 - add lr, r0, r9 + add lr, r0, r1 +#ifndef CONFIG_SKIP_RELOCATE_UBOOT + add lr, lr, r9 +#endif /* setup parameters for board_init_r */ mov r0, r5 /* gd_t */ mov r1, r7 /* dest_addr */ diff --git a/arch/arm/cpu/armv7/start.S b/arch/arm/cpu/armv7/start.S index 64c86e9..91e0523 100644 --- a/arch/arm/cpu/armv7/start.S +++ b/arch/arm/cpu/armv7/start.S @@ -274,8 +274,10 @@ clbss_l:str r2, [r0] /* clear loop... */ jump_2_ram: ldr r0, _board_init_r_ofs adr r1, _start - add r0, r0, r1 - add lr, r0, r9 + add lr, r0, r1 +#ifndef CONFIG_SKIP_RELOCATE_UBOOT + add lr, lr, r9 +#endif /* setup parameters for board_init_r */ mov r0, r5 /* gd_t */ mov r1, r7 /* dest_addr */ diff --git a/arch/arm/cpu/pxa/start.S b/arch/arm/cpu/pxa/start.S index 3c5bd84..73166c8 100644 --- a/arch/arm/cpu/pxa/start.S +++ b/arch/arm/cpu/pxa/start.S @@ -330,8 +330,10 @@ _start_oneboot_ofs #else ldr r0, _board_init_r_ofs adr r1, _start - add r0, r0, r1 - add lr, r0, r9 + add lr, r0, r1 +#ifndef CONFIG_SKIP_RELOCATE_UBOOT + add lr, lr, r9 +#endif /* setup parameters for board_init_r */ mov r0, r5 /* gd_t */ mov r1, r7 /* dest_addr */
Dear Darius Augulis,
Applied, thanks.
Darius Augulis
