[U-Boot] [PATCH 1/2] 83xx: Replace CONFIG_MPC83XX with CONFIG_MPC83xx
Use the standard lowercase "xx" capitalization that other Freescale architectures use for CPU defines to prevent confusion and errors
Signed-off-by: Peter Tyser ptyser@xes-inc.com --- api/api_platform-ppc.c | 2 +- board/freescale/mpc8349emds/mpc8349emds.c | 2 +- board/sbc8349/sbc8349.c | 2 +- common/fdt_support.c | 4 ++-- cpu/mpc83xx/config.mk | 2 +- doc/README.mpc832xemds | 2 +- doc/README.mpc8349itx | 2 +- doc/README.mpc8360emds | 2 +- doc/README.mpc837xemds | 2 +- doc/README.mpc837xerdb | 2 +- include/asm-ppc/global_data.h | 6 +++--- include/asm-ppc/processor.h | 4 ++-- include/asm-ppc/u-boot.h | 2 +- include/common.h | 8 ++++---- include/configs/MPC8313ERDB.h | 2 +- include/configs/MPC8315ERDB.h | 2 +- include/configs/MPC8323ERDB.h | 2 +- include/configs/MPC832XEMDS.h | 2 +- include/configs/MPC8349EMDS.h | 2 +- include/configs/MPC8360EMDS.h | 2 +- include/configs/MPC8360ERDK.h | 2 +- include/configs/MPC837XEMDS.h | 2 +- include/configs/MPC837XERDB.h | 2 +- include/configs/MVBLM7.h | 2 +- include/configs/SIMPC8313.h | 2 +- include/configs/TQM834x.h | 2 +- include/configs/kmeter1.h | 2 +- include/configs/sbc8349.h | 2 +- include/fdt_support.h | 2 +- include/tsec.h | 2 +- lib_ppc/board.c | 8 ++++---- 31 files changed, 41 insertions(+), 41 deletions(-)
diff --git a/api/api_platform-ppc.c b/api/api_platform-ppc.c index bfcc417..a3d981f 100644 --- a/api/api_platform-ppc.c +++ b/api/api_platform-ppc.c @@ -53,7 +53,7 @@ int platform_sys_info(struct sys_info *si) #define bi_bar bi_immr_base #elif defined(CONFIG_MPC5xxx) #define bi_bar bi_mbar_base -#elif defined(CONFIG_MPC83XX) +#elif defined(CONFIG_MPC83xx) #define bi_bar bi_immrbar #elif defined(CONFIG_MPC8220) #define bi_bar bi_mbar_base diff --git a/board/freescale/mpc8349emds/mpc8349emds.c b/board/freescale/mpc8349emds/mpc8349emds.c index 06064d9..61d1249 100644 --- a/board/freescale/mpc8349emds/mpc8349emds.c +++ b/board/freescale/mpc8349emds/mpc8349emds.c @@ -38,7 +38,7 @@ int fixed_sdram(void); void sdram_init(void);
-#if defined(CONFIG_DDR_ECC) && defined(CONFIG_MPC83XX) +#if defined(CONFIG_DDR_ECC) && defined(CONFIG_MPC83xx) void ddr_enable_ecc(unsigned int dram_size); #endif
diff --git a/board/sbc8349/sbc8349.c b/board/sbc8349/sbc8349.c index e01cb03..34861d4 100644 --- a/board/sbc8349/sbc8349.c +++ b/board/sbc8349/sbc8349.c @@ -39,7 +39,7 @@ int fixed_sdram(void); void sdram_init(void);
diff --git a/common/fdt_support.c b/common/fdt_support.c index b54f886..fc077e8 100644 --- a/common/fdt_support.c +++ b/common/fdt_support.c @@ -495,7 +495,7 @@ void fdt_fixup_dr_usb(void *blob, bd_t *bd) } #endif /* CONFIG_HAS_FSL_DR_USB */
-#if defined(CONFIG_MPC83XX) || defined(CONFIG_MPC85xx) +#if defined(CONFIG_MPC83xx) || defined(CONFIG_MPC85xx) /* * update crypto node properties to a specified revision of the SEC * called with sec_rev == 0 if not on an mpc8xxxE processor @@ -580,7 +580,7 @@ void fdt_fixup_crypto_node(void *blob, int sec_rev) printf("WARNING: could not set crypto property: %s\n", fdt_strerror(err)); } -#endif /* defined(CONFIG_MPC83XX) || defined(CONFIG_MPC85xx) */ +#endif /* defined(CONFIG_MPC83xx) || defined(CONFIG_MPC85xx) */
/* Resize the fdt to its actual size + a bit of padding */ int fdt_resize(void *blob) diff --git a/cpu/mpc83xx/config.mk b/cpu/mpc83xx/config.mk index 2f0f1ce..d619426 100644 --- a/cpu/mpc83xx/config.mk +++ b/cpu/mpc83xx/config.mk @@ -22,7 +22,7 @@
PLATFORM_RELFLAGS += -fPIC -ffixed-r14 -meabi
-PLATFORM_CPPFLAGS += -DCONFIG_MPC83XX -DCONFIG_E300 \ +PLATFORM_CPPFLAGS += -DCONFIG_MPC83xx -DCONFIG_E300 \ -ffixed-r2 -msoft-float
# Use default linker script. Board port can override in board/*/config.mk diff --git a/doc/README.mpc832xemds b/doc/README.mpc832xemds index b63cc79..9f7409c 100644 --- a/doc/README.mpc832xemds +++ b/doc/README.mpc832xemds @@ -83,7 +83,7 @@ Freescale MPC832XEMDS Board
include/configs/MPC832XEPB.h
- CONFIG_MPC83XX MPC83XX family for MPC8349, MPC8360 and MPC832X + CONFIG_MPC83xx MPC83XX family for MPC8349, MPC8360 and MPC832X CONFIG_MPC832X MPC832X specific CONFIG_MPC832XEMDS MPC832XEMDS board specific
diff --git a/doc/README.mpc8349itx b/doc/README.mpc8349itx index 7f24623..48bbd50 100644 --- a/doc/README.mpc8349itx +++ b/doc/README.mpc8349itx @@ -88,7 +88,7 @@ Freescale MPC8349E-mITX and MPC8349E-mITX-GP Boards
include/configs/MPC8349ITX.h
- CONFIG_MPC83XX MPC83xx family + CONFIG_MPC83xx MPC83xx family CONFIG_MPC8349 MPC8349 specific CONFIG_MPC8349ITX MPC8349E-mITX CONFIG_MPC8349ITXGP MPC8349E-mITX-GP diff --git a/doc/README.mpc8360emds b/doc/README.mpc8360emds index 7c841ce..d65a2a4 100644 --- a/doc/README.mpc8360emds +++ b/doc/README.mpc8360emds @@ -81,7 +81,7 @@ Freescale MPC8360EMDS Board
- CONFIG_MPC83XX MPC83xx family for both MPC8349 and MPC8360 + CONFIG_MPC83xx MPC83xx family for both MPC8349 and MPC8360 CONFIG_MPC8360 MPC8360 specific CONFIG_MPC8360EMDS MPC8360EMDS board specific
diff --git a/doc/README.mpc837xemds b/doc/README.mpc837xemds index a14da0f..d8500c2 100644 --- a/doc/README.mpc837xemds +++ b/doc/README.mpc837xemds @@ -60,7 +60,7 @@ Freescale MPC837xEMDS Board
- CONFIG_MPC83XX MPC83xx family for both MPC837x and MPC8360 + CONFIG_MPC83xx MPC83xx family for both MPC837x and MPC8360 CONFIG_MPC837X MPC837x specific CONFIG_MPC837XEMDS MPC837XEMDS board specific
diff --git a/doc/README.mpc837xerdb b/doc/README.mpc837xerdb index 510e3bb..25ea65b 100644 --- a/doc/README.mpc837xerdb +++ b/doc/README.mpc837xerdb @@ -52,7 +52,7 @@ Freescale MPC837xE-RDB Board
- CONFIG_MPC83XX MPC83xx family for both MPC8349 and MPC8360 + CONFIG_MPC83xx MPC83xx family for both MPC8349 and MPC8360 CONFIG_MPC837X MPC837x specific CONFIG_MPC837XERDB MPC837xE-RDB board specific
diff --git a/include/asm-ppc/global_data.h b/include/asm-ppc/global_data.h index e5a3b2c..c188199 100644 --- a/include/asm-ppc/global_data.h +++ b/include/asm-ppc/global_data.h @@ -56,7 +56,7 @@ typedef struct global_data { #endif #endif unsigned long mem_clk; -#if defined(CONFIG_MPC83XX) +#if defined(CONFIG_MPC83xx) /* There are other clocks in the MPC83XX */ u32 csb_clk; #if defined(CONFIG_MPC834X) || defined(CONFIG_MPC831X) || defined(CONFIG_MPC837X) @@ -92,7 +92,7 @@ typedef struct global_data { #if defined(CONFIG_MPC85xx) || defined(CONFIG_MPC86xx) u32 lbc_clk; #endif /* CONFIG_MPC85xx || CONFIG_MPC86xx */ -#if defined(CONFIG_MPC83XX) || defined(CONFIG_MPC85xx) || defined(CONFIG_MPC86xx) +#if defined(CONFIG_MPC83xx) || defined(CONFIG_MPC85xx) || defined(CONFIG_MPC86xx) u32 i2c1_clk; u32 i2c2_clk; #endif @@ -125,7 +125,7 @@ typedef struct global_data { phys_size_t ram_size; /* RAM size */ unsigned long reloc_off; /* Relocation Offset */ unsigned long reset_status; /* reset status register at boot */ -#if defined(CONFIG_MPC83XX) +#if defined(CONFIG_MPC83xx) unsigned long arbiter_event_attributes; unsigned long arbiter_event_address; #endif diff --git a/include/asm-ppc/processor.h b/include/asm-ppc/processor.h index 83e3581..8f73c69 100644 --- a/include/asm-ppc/processor.h +++ b/include/asm-ppc/processor.h @@ -923,7 +923,7 @@ #if defined(CONFIG_MPC85xx) #define IS_E_PROCESSOR(svr) (svr & 0x80000) #else -#if defined(CONFIG_MPC83XX) +#if defined(CONFIG_MPC83xx) #define IS_E_PROCESSOR(spridr) (!(spridr & 0x00010000)) #endif #endif @@ -1023,7 +1023,7 @@ struct cpu_type *identify_cpu(u32 ver); #define CPU_TYPE_ENTRY(n, v) \ { .name = #n, .soc_ver = SVR_##v, } #else -#if defined(CONFIG_MPC83XX) +#if defined(CONFIG_MPC83xx) #define CPU_TYPE_ENTRY(x) {#x, SPR_##x} #endif #endif diff --git a/include/asm-ppc/u-boot.h b/include/asm-ppc/u-boot.h index e6c56e9..ea2d22d 100644 --- a/include/asm-ppc/u-boot.h +++ b/include/asm-ppc/u-boot.h @@ -51,7 +51,7 @@ typedef struct bd_info { #if defined(CONFIG_MPC5xxx) unsigned long bi_mbar_base; /* base of internal registers */ #endif -#if defined(CONFIG_MPC83XX) +#if defined(CONFIG_MPC83xx) unsigned long bi_immrbar; #endif #if defined(CONFIG_MPC8220) diff --git a/include/common.h b/include/common.h index 30fff7d..99abc9e 100644 --- a/include/common.h +++ b/include/common.h @@ -90,7 +90,7 @@ typedef volatile unsigned char vu_char; #include <mpc85xx.h> #include <asm/immap_85xx.h> #endif -#ifdef CONFIG_MPC83XX +#ifdef CONFIG_MPC83xx #include <mpc83xx.h> #include <asm/immap_83xx.h> #endif @@ -410,7 +410,7 @@ void trap_init (ulong); defined (CONFIG_MPC8220) || \ defined (CONFIG_MPC85xx) || \ defined (CONFIG_MPC86xx) || \ - defined (CONFIG_MPC83XX) + defined (CONFIG_MPC83xx) unsigned char in8(unsigned int); void out8(unsigned int, unsigned char); unsigned short in16(unsigned int); @@ -431,7 +431,7 @@ unsigned short in16(unsigned int); void out16(unsigned int, unsigned short value); #endif
-#if defined (CONFIG_MPC83XX) +#if defined (CONFIG_MPC83xx) void ppcDWload(unsigned int *addr, unsigned int *ret); void ppcDWstore(unsigned int *addr, unsigned int *value); #endif @@ -548,7 +548,7 @@ void cpu_init_f (void); int cpu_init_r (void); #if defined(CONFIG_8260) int prt_8260_rsr (void); -#elif defined(CONFIG_MPC83XX) +#elif defined(CONFIG_MPC83xx) int prt_83xx_rsr (void); #endif
diff --git a/include/configs/MPC8313ERDB.h b/include/configs/MPC8313ERDB.h index 52d27a1..f0592a8 100644 --- a/include/configs/MPC8313ERDB.h +++ b/include/configs/MPC8313ERDB.h @@ -30,7 +30,7 @@ * High Level Configuration Options */ #define CONFIG_E300 1 -#define CONFIG_MPC83XX 1 +#define CONFIG_MPC83xx 1 #define CONFIG_MPC831X 1 #define CONFIG_MPC8313 1 #define CONFIG_MPC8313ERDB 1 diff --git a/include/configs/MPC8315ERDB.h b/include/configs/MPC8315ERDB.h index 9fa91f4..b5f5a0b 100644 --- a/include/configs/MPC8315ERDB.h +++ b/include/configs/MPC8315ERDB.h @@ -29,7 +29,7 @@ * High Level Configuration Options */ #define CONFIG_E300 1 /* E300 family */ -#define CONFIG_MPC83XX 1 /* MPC83xx family */ +#define CONFIG_MPC83xx 1 /* MPC83xx family */ #define CONFIG_MPC831X 1 /* MPC831x CPU family */ #define CONFIG_MPC8315 1 /* MPC8315 CPU specific */ #define CONFIG_MPC8315ERDB 1 /* MPC8315ERDB board specific */ diff --git a/include/configs/MPC8323ERDB.h b/include/configs/MPC8323ERDB.h index 9b8b033..7d5bca6 100644 --- a/include/configs/MPC8323ERDB.h +++ b/include/configs/MPC8323ERDB.h @@ -14,7 +14,7 @@ */ #define CONFIG_E300 1 /* E300 family */ #define CONFIG_QE 1 /* Has QE */ -#define CONFIG_MPC83XX 1 /* MPC83xx family */ +#define CONFIG_MPC83xx 1 /* MPC83xx family */ #define CONFIG_MPC832X 1 /* MPC832x CPU specific */
#define CONFIG_PCI 1 diff --git a/include/configs/MPC832XEMDS.h b/include/configs/MPC832XEMDS.h index c82cda2..6b3b198 100644 --- a/include/configs/MPC832XEMDS.h +++ b/include/configs/MPC832XEMDS.h @@ -25,7 +25,7 @@ */ #define CONFIG_E300 1 /* E300 family */ #define CONFIG_QE 1 /* Has QE */ -#define CONFIG_MPC83XX 1 /* MPC83xx family */ +#define CONFIG_MPC83xx 1 /* MPC83xx family */ #define CONFIG_MPC832X 1 /* MPC832x CPU specific */ #define CONFIG_MPC832XEMDS 1 /* MPC832XEMDS board specific */ #undef CONFIG_PQ_MDS_PIB /* POWERQUICC MDS Platform IO Board */ diff --git a/include/configs/MPC8349EMDS.h b/include/configs/MPC8349EMDS.h index 387f22f..b792025 100644 --- a/include/configs/MPC8349EMDS.h +++ b/include/configs/MPC8349EMDS.h @@ -33,7 +33,7 @@ * High Level Configuration Options */ #define CONFIG_E300 1 /* E300 Family */ -#define CONFIG_MPC83XX 1 /* MPC83XX family */ +#define CONFIG_MPC83xx 1 /* MPC83xx family */ #define CONFIG_MPC834X 1 /* MPC834X family */ #define CONFIG_MPC8349 1 /* MPC8349 specific */ #define CONFIG_MPC8349EMDS 1 /* MPC8349EMDS board specific */ diff --git a/include/configs/MPC8360EMDS.h b/include/configs/MPC8360EMDS.h index 4b09de1..3497ba0 100644 --- a/include/configs/MPC8360EMDS.h +++ b/include/configs/MPC8360EMDS.h @@ -27,7 +27,7 @@ */ #define CONFIG_E300 1 /* E300 family */ #define CONFIG_QE 1 /* Has QE */ -#define CONFIG_MPC83XX 1 /* MPC83XX family */ +#define CONFIG_MPC83xx 1 /* MPC83xx family */ #define CONFIG_MPC8360 1 /* MPC8360 CPU specific */ #define CONFIG_MPC8360EMDS 1 /* MPC8360EMDS board specific */ #undef CONFIG_PQ_MDS_PIB /* POWERQUICC MDS Platform IO Board */ diff --git a/include/configs/MPC8360ERDK.h b/include/configs/MPC8360ERDK.h index 1387504..f584435 100644 --- a/include/configs/MPC8360ERDK.h +++ b/include/configs/MPC8360ERDK.h @@ -22,7 +22,7 @@ */ #define CONFIG_E300 1 /* E300 family */ #define CONFIG_QE 1 /* Has QE */ -#define CONFIG_MPC83XX 1 /* MPC83XX family */ +#define CONFIG_MPC83xx 1 /* MPC83xx family */ #define CONFIG_MPC8360 1 /* MPC8360 CPU specific */ #define CONFIG_MPC8360ERDK 1 /* MPC8360ERDK board specific */
diff --git a/include/configs/MPC837XEMDS.h b/include/configs/MPC837XEMDS.h index a62d805..8596470 100644 --- a/include/configs/MPC837XEMDS.h +++ b/include/configs/MPC837XEMDS.h @@ -25,7 +25,7 @@ * High Level Configuration Options */ #define CONFIG_E300 1 /* E300 family */ -#define CONFIG_MPC83XX 1 /* MPC83XX family */ +#define CONFIG_MPC83xx 1 /* MPC83xx family */ #define CONFIG_MPC837X 1 /* MPC837X CPU specific */ #define CONFIG_MPC837XEMDS 1 /* MPC837XEMDS board specific */
diff --git a/include/configs/MPC837XERDB.h b/include/configs/MPC837XERDB.h index 8d0c93b..5f2bd99 100644 --- a/include/configs/MPC837XERDB.h +++ b/include/configs/MPC837XERDB.h @@ -26,7 +26,7 @@ * High Level Configuration Options */ #define CONFIG_E300 1 /* E300 family */ -#define CONFIG_MPC83XX 1 /* MPC83XX family */ +#define CONFIG_MPC83xx 1 /* MPC83XX family */ #define CONFIG_MPC837X 1 /* MPC837X CPU specific */ #define CONFIG_MPC837XERDB 1
diff --git a/include/configs/MVBLM7.h b/include/configs/MVBLM7.h index 9fd27e3..e6aba86 100644 --- a/include/configs/MVBLM7.h +++ b/include/configs/MVBLM7.h @@ -33,7 +33,7 @@ * High Level Configuration Options */ #define CONFIG_E300 1 -#define CONFIG_MPC83XX 1 +#define CONFIG_MPC83xx 1 #define CONFIG_MPC834X 1 #define CONFIG_MPC8343 1
diff --git a/include/configs/SIMPC8313.h b/include/configs/SIMPC8313.h index 88ea7c7..a814d10 100644 --- a/include/configs/SIMPC8313.h +++ b/include/configs/SIMPC8313.h @@ -32,7 +32,7 @@ #define CONFIG_NAND_U_BOOT
diff --git a/include/configs/TQM834x.h b/include/configs/TQM834x.h index c504ecb..03cb45b 100644 --- a/include/configs/TQM834x.h +++ b/include/configs/TQM834x.h @@ -32,7 +32,7 @@ * High Level Configuration Options */ #define CONFIG_E300 1 /* E300 Family */ -#define CONFIG_MPC83XX 1 /* MPC83XX family */ +#define CONFIG_MPC83xx 1 /* MPC83xx family */ #define CONFIG_MPC834X 1 /* MPC834X specific */ #define CONFIG_MPC8349 1 /* MPC8349 specific */ #define CONFIG_TQM834X 1 /* TQM834X board specific */ diff --git a/include/configs/kmeter1.h b/include/configs/kmeter1.h index 61250ad..19da133 100644 --- a/include/configs/kmeter1.h +++ b/include/configs/kmeter1.h @@ -25,7 +25,7 @@ */ #define CONFIG_E300 1 /* E300 family */ #define CONFIG_QE 1 /* Has QE */ -#define CONFIG_MPC83XX 1 /* MPC83XX family */ +#define CONFIG_MPC83xx 1 /* MPC83xx family */ #define CONFIG_MPC8360 1 /* MPC8360 CPU specific */ #define CONFIG_KMETER1 1 /* KMETER1 board specific */ #define CONFIG_HOSTNAME kmeter1 diff --git a/include/configs/sbc8349.h b/include/configs/sbc8349.h index 2ea1897..15584d8 100644 --- a/include/configs/sbc8349.h +++ b/include/configs/sbc8349.h @@ -35,7 +35,7 @@ * High Level Configuration Options */ #define CONFIG_E300 1 /* E300 Family */ -#define CONFIG_MPC83XX 1 /* MPC83XX family */ +#define CONFIG_MPC83xx 1 /* MPC83xx family */ #define CONFIG_MPC834X 1 /* MPC834X family */ #define CONFIG_MPC8349 1 /* MPC8349 specific */ #define CONFIG_SBC8349 1 /* WRS SBC8349 board specific */ diff --git a/include/fdt_support.h b/include/fdt_support.h index 6062df9..16734c5 100644 --- a/include/fdt_support.h +++ b/include/fdt_support.h @@ -59,7 +59,7 @@ void fdt_fixup_dr_usb(void *blob, bd_t *bd); static inline void fdt_fixup_dr_usb(void *blob, bd_t *bd) {} #endif /* CONFIG_HAS_FSL_DR_USB */
-#if defined(CONFIG_MPC85xx) || defined(CONFIG_MPC83XX) +#if defined(CONFIG_MPC85xx) || defined(CONFIG_MPC83xx) void fdt_fixup_crypto_node(void *blob, int sec_rev); #else static inline void fdt_fixup_crypto_node(void *blob, int sec_rev) {} diff --git a/include/tsec.h b/include/tsec.h index 7b52e06..9184256 100644 --- a/include/tsec.h +++ b/include/tsec.h @@ -28,7 +28,7 @@
/* FIXME: Should these be pushed back to 83xx and 85xx config files? */ #if defined(CONFIG_MPC85xx) || defined(CONFIG_MPC86xx) \ - || defined(CONFIG_MPC83XX) + || defined(CONFIG_MPC83xx) #define TSEC_BASE_ADDR (CONFIG_SYS_IMMR + CONFIG_SYS_TSEC1_OFFSET) #endif
diff --git a/lib_ppc/board.c b/lib_ppc/board.c index a0e6b20..ca30276 100644 --- a/lib_ppc/board.c +++ b/lib_ppc/board.c @@ -321,7 +321,7 @@ init_fnc_t *init_sequence[] = { prt_8260_rsr, prt_8260_clks, #endif /* CONFIG_8260 */ -#if defined(CONFIG_MPC83XX) +#if defined(CONFIG_MPC83xx) prt_83xx_rsr, #endif checkcpu, @@ -408,7 +408,7 @@ void board_init_f (ulong bootflag) /* compiler optimization barrier needed for GCC >= 3.4 */ __asm__ __volatile__("": : :"memory");
-#if !defined(CONFIG_CPM2) && !defined(CONFIG_MPC83XX) && \ +#if !defined(CONFIG_CPM2) && !defined(CONFIG_MPC83xx) && \ !defined(CONFIG_MPC85xx) && !defined(CONFIG_MPC86xx) /* Clear initial global data */ memset ((void *) gd, 0, sizeof (gd_t)); @@ -570,7 +570,7 @@ void board_init_f (ulong bootflag) #if defined(CONFIG_MPC5xxx) bd->bi_mbar_base = CONFIG_SYS_MBAR; /* base of internal registers */ #endif -#if defined(CONFIG_MPC83XX) +#if defined(CONFIG_MPC83xx) bd->bi_immrbar = CONFIG_SYS_IMMR; #endif #if defined(CONFIG_MPC8220) @@ -750,7 +750,7 @@ void board_init_r (gd_t *id, ulong dest_addr)
WATCHDOG_RESET();
-#if defined(CONFIG_SYS_DELAYED_ICACHE) || defined(CONFIG_MPC83XX) +#if defined(CONFIG_SYS_DELAYED_ICACHE) || defined(CONFIG_MPC83xx) icache_enable (); /* it's time to enable the instruction cache */ #endif
Use the standard lowercase "x" capitalization that other Freescale architectures use for CPU defines to prevent confusion and errors
Signed-off-by: Peter Tyser ptyser@xes-inc.com --- cpu/mpc83xx/cpu_init.c | 2 +- cpu/mpc83xx/speed.c | 66 ++++++++++++++++++++-------------------- doc/README.mpc832xemds | 6 ++-- doc/README.mpc837xemds | 2 +- doc/README.mpc837xerdb | 2 +- drivers/pci/pci_auto.c | 2 +- include/asm-ppc/fsl_lbc.h | 4 +- include/asm-ppc/global_data.h | 12 ++++---- include/asm-ppc/immap_83xx.h | 6 ++-- include/asm-ppc/immap_qe.h | 2 +- include/asm-ppc/mpc8xxx_spi.h | 4 +- include/configs/MPC8313ERDB.h | 2 +- include/configs/MPC8315ERDB.h | 2 +- include/configs/MPC8323ERDB.h | 2 +- include/configs/MPC832XEMDS.h | 2 +- include/configs/MPC8349EMDS.h | 2 +- include/configs/MPC8349ITX.h | 2 +- include/configs/MPC837XEMDS.h | 2 +- include/configs/MPC837XERDB.h | 4 +- include/configs/MVBLM7.h | 2 +- include/configs/SIMPC8313.h | 2 +- include/configs/TQM834x.h | 2 +- include/configs/sbc8349.h | 2 +- include/mpc83xx.h | 36 +++++++++++----------- 24 files changed, 85 insertions(+), 85 deletions(-)
diff --git a/cpu/mpc83xx/cpu_init.c b/cpu/mpc83xx/cpu_init.c index 8e9c875..d9b96b5 100644 --- a/cpu/mpc83xx/cpu_init.c +++ b/cpu/mpc83xx/cpu_init.c @@ -185,7 +185,7 @@ void cpu_init_f (volatile immap_t * im)
/* System General Purpose Register */ #ifdef CONFIG_SYS_SICRH -#if defined(CONFIG_MPC834X) || defined(CONFIG_MPC8313) +#if defined(CONFIG_MPC834x) || defined(CONFIG_MPC8313) /* regarding to MPC34x manual rev.1 bits 28..29 must be preserved */ im->sysconf.sicrh = (im->sysconf.sicrh & 0x0000000C) | CONFIG_SYS_SICRH; #else diff --git a/cpu/mpc83xx/speed.c b/cpu/mpc83xx/speed.c index 9b7e7b5..5d61559 100644 --- a/cpu/mpc83xx/speed.c +++ b/cpu/mpc83xx/speed.c @@ -100,23 +100,23 @@ int get_clocks(void) u32 lcrr;
u32 csb_clk; -#if defined(CONFIG_MPC834X) || defined(CONFIG_MPC831X) || defined(CONFIG_MPC837X) +#if defined(CONFIG_MPC834x) || defined(CONFIG_MPC831x) || defined(CONFIG_MPC837x) u32 tsec1_clk; u32 tsec2_clk; u32 usbdr_clk; #endif -#ifdef CONFIG_MPC834X +#ifdef CONFIG_MPC834x u32 usbmph_clk; #endif u32 core_clk; u32 i2c1_clk; -#if !defined(CONFIG_MPC832X) +#if !defined(CONFIG_MPC832x) u32 i2c2_clk; #endif #if defined(CONFIG_MPC8315) u32 tdm_clk; #endif -#if defined(CONFIG_MPC837X) +#if defined(CONFIG_MPC837x) u32 sdhc_clk; #endif u32 enc_clk; @@ -126,17 +126,17 @@ int get_clocks(void) #if defined(CONFIG_MPC8360) u32 mem_sec_clk; #endif -#if defined(CONFIG_MPC8360) || defined(CONFIG_MPC832X) +#if defined(CONFIG_MPC8360) || defined(CONFIG_MPC832x) u32 qepmf; u32 qepdf; u32 qe_clk; u32 brg_clk; #endif -#if defined(CONFIG_MPC837X) || defined(CONFIG_MPC831X) +#if defined(CONFIG_MPC837x) || defined(CONFIG_MPC831x) u32 pciexp1_clk; u32 pciexp2_clk; #endif -#if defined(CONFIG_MPC837X) || defined(CONFIG_MPC8315) +#if defined(CONFIG_MPC837x) || defined(CONFIG_MPC8315) u32 sata_clk; #endif
@@ -164,7 +164,7 @@ int get_clocks(void)
sccr = im->clk.sccr;
-#if defined(CONFIG_MPC834X) || defined(CONFIG_MPC831X) || defined(CONFIG_MPC837X) +#if defined(CONFIG_MPC834x) || defined(CONFIG_MPC831x) || defined(CONFIG_MPC837x) switch ((sccr & SCCR_TSEC1CM) >> SCCR_TSEC1CM_SHIFT) { case 0: tsec1_clk = 0; @@ -202,7 +202,7 @@ int get_clocks(void) } #endif
-#if defined(CONFIG_MPC834X) || defined(CONFIG_MPC837X) || defined(CONFIG_MPC8315) +#if defined(CONFIG_MPC834x) || defined(CONFIG_MPC837x) || defined(CONFIG_MPC8315) switch ((sccr & SCCR_TSEC2CM) >> SCCR_TSEC2CM_SHIFT) { case 0: tsec2_clk = 0; @@ -229,7 +229,7 @@ int get_clocks(void) tsec2_clk = 0; #endif
-#if defined(CONFIG_MPC834X) +#if defined(CONFIG_MPC834x) switch ((sccr & SCCR_USBMPHCM) >> SCCR_USBMPHCM_SHIFT) { case 0: usbmph_clk = 0; @@ -274,7 +274,7 @@ int get_clocks(void) return -7; }
-#if defined(CONFIG_MPC837X) +#if defined(CONFIG_MPC837x) switch ((sccr & SCCR_SDHCCM) >> SCCR_SDHCCM_SHIFT) { case 0: sdhc_clk = 0; @@ -313,22 +313,22 @@ int get_clocks(void) } #endif
-#if defined(CONFIG_MPC834X) +#if defined(CONFIG_MPC834x) i2c1_clk = tsec2_clk; #elif defined(CONFIG_MPC8360) i2c1_clk = csb_clk; -#elif defined(CONFIG_MPC832X) +#elif defined(CONFIG_MPC832x) i2c1_clk = enc_clk; -#elif defined(CONFIG_MPC831X) +#elif defined(CONFIG_MPC831x) i2c1_clk = enc_clk; -#elif defined(CONFIG_MPC837X) +#elif defined(CONFIG_MPC837x) i2c1_clk = sdhc_clk; #endif -#if !defined(CONFIG_MPC832X) +#if !defined(CONFIG_MPC832x) i2c2_clk = csb_clk; /* i2c-2 clk is equal to csb clk */ #endif
-#if defined(CONFIG_MPC837X) || defined(CONFIG_MPC831X) +#if defined(CONFIG_MPC837x) || defined(CONFIG_MPC831x) switch ((sccr & SCCR_PCIEXP1CM) >> SCCR_PCIEXP1CM_SHIFT) { case 0: pciexp1_clk = 0; @@ -366,7 +366,7 @@ int get_clocks(void) } #endif
-#if defined(CONFIG_MPC837X) || defined(CONFIG_MPC8315) +#if defined(CONFIG_MPC837x) || defined(CONFIG_MPC8315) switch ((sccr & SCCR_SATA1CM) >> SCCR_SATA1CM_SHIFT) { case 0: sata_clk = 0; @@ -436,7 +436,7 @@ int get_clocks(void) return -13; }
-#if defined(CONFIG_MPC8360) || defined(CONFIG_MPC832X) +#if defined(CONFIG_MPC8360) || defined(CONFIG_MPC832x) qepmf = (im->reset.rcwl & HRCWL_CEPMF) >> HRCWL_CEPMF_SHIFT; qepdf = (im->reset.rcwl & HRCWL_CEPDF) >> HRCWL_CEPDF_SHIFT; qe_clk = (pci_sync_in * qepmf) / (1 + qepdf); @@ -444,23 +444,23 @@ int get_clocks(void) #endif
gd->csb_clk = csb_clk; -#if defined(CONFIG_MPC834X) || defined(CONFIG_MPC831X) || defined(CONFIG_MPC837X) +#if defined(CONFIG_MPC834x) || defined(CONFIG_MPC831x) || defined(CONFIG_MPC837x) gd->tsec1_clk = tsec1_clk; gd->tsec2_clk = tsec2_clk; gd->usbdr_clk = usbdr_clk; #endif -#if defined(CONFIG_MPC834X) +#if defined(CONFIG_MPC834x) gd->usbmph_clk = usbmph_clk; #endif #if defined(CONFIG_MPC8315) gd->tdm_clk = tdm_clk; #endif -#if defined(CONFIG_MPC837X) +#if defined(CONFIG_MPC837x) gd->sdhc_clk = sdhc_clk; #endif gd->core_clk = core_clk; gd->i2c1_clk = i2c1_clk; -#if !defined(CONFIG_MPC832X) +#if !defined(CONFIG_MPC832x) gd->i2c2_clk = i2c2_clk; #endif gd->enc_clk = enc_clk; @@ -470,15 +470,15 @@ int get_clocks(void) #if defined(CONFIG_MPC8360) gd->mem_sec_clk = mem_sec_clk; #endif -#if defined(CONFIG_MPC8360) || defined(CONFIG_MPC832X) +#if defined(CONFIG_MPC8360) || defined(CONFIG_MPC832x) gd->qe_clk = qe_clk; gd->brg_clk = brg_clk; #endif -#if defined(CONFIG_MPC837X) +#if defined(CONFIG_MPC837x) gd->pciexp1_clk = pciexp1_clk; gd->pciexp2_clk = pciexp2_clk; #endif -#if defined(CONFIG_MPC837X) || defined(CONFIG_MPC8315) +#if defined(CONFIG_MPC837x) || defined(CONFIG_MPC8315) gd->sata_clk = sata_clk; #endif gd->pci_clk = pci_sync_in; @@ -504,7 +504,7 @@ int do_clocks (cmd_tbl_t * cmdtp, int flag, int argc, char *argv[]) printf("Clock configuration:\n"); printf(" Core: %-4s MHz\n", strmhz(buf, gd->core_clk)); printf(" Coherent System Bus: %-4s MHz\n", strmhz(buf, gd->csb_clk)); -#if defined(CONFIG_MPC8360) || defined(CONFIG_MPC832X) +#if defined(CONFIG_MPC8360) || defined(CONFIG_MPC832x) printf(" QE: %-4s MHz\n", strmhz(buf, gd->qe_clk)); printf(" BRG: %-4s MHz\n", strmhz(buf, gd->brg_clk)); #endif @@ -516,28 +516,28 @@ int do_clocks (cmd_tbl_t * cmdtp, int flag, int argc, char *argv[]) #endif printf(" SEC: %-4s MHz\n", strmhz(buf, gd->enc_clk)); printf(" I2C1: %-4s MHz\n", strmhz(buf, gd->i2c1_clk)); -#if !defined(CONFIG_MPC832X) +#if !defined(CONFIG_MPC832x) printf(" I2C2: %-4s MHz\n", strmhz(buf, gd->i2c2_clk)); #endif #if defined(CONFIG_MPC8315) printf(" TDM: %-4s MHz\n", strmhz(buf, gd->tdm_clk)); #endif -#if defined(CONFIG_MPC837X) +#if defined(CONFIG_MPC837x) printf(" SDHC: %-4s MHz\n", strmhz(buf, gd->sdhc_clk)); #endif -#if defined(CONFIG_MPC834X) || defined(CONFIG_MPC831X) || defined(CONFIG_MPC837X) +#if defined(CONFIG_MPC834x) || defined(CONFIG_MPC831x) || defined(CONFIG_MPC837x) printf(" TSEC1: %-4s MHz\n", strmhz(buf, gd->tsec1_clk)); printf(" TSEC2: %-4s MHz\n", strmhz(buf, gd->tsec2_clk)); printf(" USB DR: %-4s MHz\n", strmhz(buf, gd->usbdr_clk)); #endif -#if defined(CONFIG_MPC834X) +#if defined(CONFIG_MPC834x) printf(" USB MPH: %-4s MHz\n", strmhz(buf, gd->usbmph_clk)); #endif -#if defined(CONFIG_MPC837X) +#if defined(CONFIG_MPC837x) printf(" PCIEXP1: %-4s MHz\n", strmhz(buf, gd->pciexp1_clk)); printf(" PCIEXP2: %-4s MHz\n", strmhz(buf, gd->pciexp2_clk)); #endif -#if defined(CONFIG_MPC837X) || defined(CONFIG_MPC8315) +#if defined(CONFIG_MPC837x) || defined(CONFIG_MPC8315) printf(" SATA: %-4s MHz\n", strmhz(buf, gd->sata_clk)); #endif return 0; diff --git a/doc/README.mpc832xemds b/doc/README.mpc832xemds index 9f7409c..688bdbb 100644 --- a/doc/README.mpc832xemds +++ b/doc/README.mpc832xemds @@ -83,8 +83,8 @@ Freescale MPC832XEMDS Board
- CONFIG_MPC83xx MPC83XX family for MPC8349, MPC8360 and MPC832X - CONFIG_MPC832X MPC832X specific + CONFIG_MPC83xx MPC83xx family for MPC8349, MPC8360 and MPC832x + CONFIG_MPC832x MPC832x specific CONFIG_MPC832XEMDS MPC832XEMDS board specific
4. Compilation @@ -97,7 +97,7 @@ Freescale MPC832XEMDS Board make MPC832XEMDS_config make
- MPC832X support PCI 33MHz and PCI 66MHz, to make u-boot support PCI: + MPC832x support PCI 33MHz and PCI 66MHz, to make u-boot support PCI:
1)Make sure the DIP SW support PCI mode as described in Section 1.1.
diff --git a/doc/README.mpc837xemds b/doc/README.mpc837xemds index d8500c2..aa767ae 100644 --- a/doc/README.mpc837xemds +++ b/doc/README.mpc837xemds @@ -61,7 +61,7 @@ Freescale MPC837xEMDS Board include/configs/MPC837XEMDS.h
CONFIG_MPC83xx MPC83xx family for both MPC837x and MPC8360 - CONFIG_MPC837X MPC837x specific + CONFIG_MPC837x MPC837x specific CONFIG_MPC837XEMDS MPC837XEMDS board specific
4. Compilation diff --git a/doc/README.mpc837xerdb b/doc/README.mpc837xerdb index 25ea65b..cfb6efa 100644 --- a/doc/README.mpc837xerdb +++ b/doc/README.mpc837xerdb @@ -53,7 +53,7 @@ Freescale MPC837xE-RDB Board include/configs/MPC837XERDB.h
CONFIG_MPC83xx MPC83xx family for both MPC8349 and MPC8360 - CONFIG_MPC837X MPC837x specific + CONFIG_MPC837x MPC837x specific CONFIG_MPC837XERDB MPC837xE-RDB board specific
diff --git a/drivers/pci/pci_auto.c b/drivers/pci/pci_auto.c index c20b981..35c82b9 100644 --- a/drivers/pci/pci_auto.c +++ b/drivers/pci/pci_auto.c @@ -403,7 +403,7 @@ int pciauto_config_device(struct pci_controller *hose, pci_dev_t dev) PCI_DEV(dev)); break; #endif -#ifdef CONFIG_MPC834X +#ifdef CONFIG_MPC834x case PCI_CLASS_BRIDGE_OTHER: /* * The host/PCI bridge 1 seems broken in 8349 - it presents diff --git a/include/asm-ppc/fsl_lbc.h b/include/asm-ppc/fsl_lbc.h index bc1ebe6..a28082e 100644 --- a/include/asm-ppc/fsl_lbc.h +++ b/include/asm-ppc/fsl_lbc.h @@ -54,7 +54,7 @@ #define BR_MS_UPMA 0x00000080 /* UPMA */ #define BR_MS_UPMB 0x000000A0 /* UPMB */ #define BR_MS_UPMC 0x000000C0 /* UPMC */ -#if !defined(CONFIG_MPC834X) +#if !defined(CONFIG_MPC834x) #define BR_ATOM 0x0000000C #define BR_ATOM_SHIFT 2 #endif @@ -65,7 +65,7 @@ #define UPMB 1 #define UPMC 2
-#if defined(CONFIG_MPC834X) +#if defined(CONFIG_MPC834x) #define BR_RES ~(BR_BA | BR_PS | BR_DECC | BR_WP | BR_MSEL | BR_V) #else #define BR_RES ~(BR_BA | BR_PS | BR_DECC | BR_WP | BR_MSEL | BR_ATOM | BR_V) diff --git a/include/asm-ppc/global_data.h b/include/asm-ppc/global_data.h index c188199..244c161 100644 --- a/include/asm-ppc/global_data.h +++ b/include/asm-ppc/global_data.h @@ -59,14 +59,14 @@ typedef struct global_data { #if defined(CONFIG_MPC83xx) /* There are other clocks in the MPC83XX */ u32 csb_clk; -#if defined(CONFIG_MPC834X) || defined(CONFIG_MPC831X) || defined(CONFIG_MPC837X) +#if defined(CONFIG_MPC834x) || defined(CONFIG_MPC831x) || defined(CONFIG_MPC837x) u32 tsec1_clk; u32 tsec2_clk; u32 usbdr_clk; #endif -#if defined (CONFIG_MPC834X) +#if defined (CONFIG_MPC834x) u32 usbmph_clk; -#endif /* CONFIG_MPC834X */ +#endif /* CONFIG_MPC834x */ #if defined(CONFIG_MPC8315) u32 tdm_clk; #endif @@ -75,18 +75,18 @@ typedef struct global_data { u32 lbiu_clk; u32 lclk_clk; u32 pci_clk; -#if defined(CONFIG_MPC837X) || defined(CONFIG_MPC831X) +#if defined(CONFIG_MPC837x) || defined(CONFIG_MPC831x) u32 pciexp1_clk; u32 pciexp2_clk; #endif -#if defined(CONFIG_MPC837X) || defined(CONFIG_MPC8315) +#if defined(CONFIG_MPC837x) || defined(CONFIG_MPC8315) u32 sata_clk; #endif #if defined(CONFIG_MPC8360) u32 mem_sec_clk; #endif /* CONFIG_MPC8360 */ #endif -#if defined(CONFIG_MPC837X) || defined(CONFIG_MPC8536) +#if defined(CONFIG_MPC837x) || defined(CONFIG_MPC8536) u32 sdhc_clk; #endif #if defined(CONFIG_MPC85xx) || defined(CONFIG_MPC86xx) diff --git a/include/asm-ppc/immap_83xx.h b/include/asm-ppc/immap_83xx.h index 7b847f8..1e67de6 100644 --- a/include/asm-ppc/immap_83xx.h +++ b/include/asm-ppc/immap_83xx.h @@ -656,7 +656,7 @@ typedef struct tdmdmac83xx { u8 fixme[0x2000]; } tdmdmac83xx_t;
-#if defined(CONFIG_MPC834X) +#if defined(CONFIG_MPC834x) typedef struct immap { sysconf83xx_t sysconf; /* System configuration */ wdt83xx_t wdt; /* Watch Dog Timer (WDT) Registers */ @@ -773,7 +773,7 @@ typedef struct immap { u8 res12[0x1CF00]; } immap_t;
-#elif defined(CONFIG_MPC837X) +#elif defined(CONFIG_MPC837x) typedef struct immap { sysconf83xx_t sysconf; /* System configuration */ wdt83xx_t wdt; /* Watch Dog Timer (WDT) Registers */ @@ -857,7 +857,7 @@ typedef struct immap { u8 qe[0x100000]; /* QE block */ } immap_t;
-#elif defined(CONFIG_MPC832X) +#elif defined(CONFIG_MPC832x) typedef struct immap { sysconf83xx_t sysconf; /* System configuration */ wdt83xx_t wdt; /* Watch Dog Timer (WDT) Registers */ diff --git a/include/asm-ppc/immap_qe.h b/include/asm-ppc/immap_qe.h index 66a4735..d7c7c6f 100644 --- a/include/asm-ppc/immap_qe.h +++ b/include/asm-ppc/immap_qe.h @@ -598,7 +598,7 @@ extern qe_map_t *qe_immr; #define QE_MURAM_SIZE 0x10000UL #elif defined(CONFIG_MPC8360) #define QE_MURAM_SIZE 0xc000UL -#elif defined(CONFIG_MPC832X) +#elif defined(CONFIG_MPC832x) #define QE_MURAM_SIZE 0x4000UL #endif
diff --git a/include/asm-ppc/mpc8xxx_spi.h b/include/asm-ppc/mpc8xxx_spi.h index 48b15e4..41737d3 100644 --- a/include/asm-ppc/mpc8xxx_spi.h +++ b/include/asm-ppc/mpc8xxx_spi.h @@ -27,10 +27,10 @@
#include <asm/types.h>
-#if defined(CONFIG_MPC834X) || \ +#if defined(CONFIG_MPC834x) || \ defined(CONFIG_MPC8313) || \ defined(CONFIG_MPC8315) || \ - defined(CONFIG_MPC837X) + defined(CONFIG_MPC837x)
typedef struct spi8xxx { u8 res0[0x20]; /* 0x0-0x01f reserved */ diff --git a/include/configs/MPC8313ERDB.h b/include/configs/MPC8313ERDB.h index f0592a8..2308568 100644 --- a/include/configs/MPC8313ERDB.h +++ b/include/configs/MPC8313ERDB.h @@ -31,7 +31,7 @@ */ #define CONFIG_E300 1 #define CONFIG_MPC83xx 1 -#define CONFIG_MPC831X 1 +#define CONFIG_MPC831x 1 #define CONFIG_MPC8313 1 #define CONFIG_MPC8313ERDB 1
diff --git a/include/configs/MPC8315ERDB.h b/include/configs/MPC8315ERDB.h index b5f5a0b..d9888f5 100644 --- a/include/configs/MPC8315ERDB.h +++ b/include/configs/MPC8315ERDB.h @@ -30,7 +30,7 @@ */ #define CONFIG_E300 1 /* E300 family */ #define CONFIG_MPC83xx 1 /* MPC83xx family */ -#define CONFIG_MPC831X 1 /* MPC831x CPU family */ +#define CONFIG_MPC831x 1 /* MPC831x CPU family */ #define CONFIG_MPC8315 1 /* MPC8315 CPU specific */ #define CONFIG_MPC8315ERDB 1 /* MPC8315ERDB board specific */
diff --git a/include/configs/MPC8323ERDB.h b/include/configs/MPC8323ERDB.h index 7d5bca6..24f37e7 100644 --- a/include/configs/MPC8323ERDB.h +++ b/include/configs/MPC8323ERDB.h @@ -15,7 +15,7 @@ #define CONFIG_E300 1 /* E300 family */ #define CONFIG_QE 1 /* Has QE */ #define CONFIG_MPC83xx 1 /* MPC83xx family */ -#define CONFIG_MPC832X 1 /* MPC832x CPU specific */ +#define CONFIG_MPC832x 1 /* MPC832x CPU specific */
#define CONFIG_PCI 1 #define CONFIG_83XX_GENERIC_PCI 1 diff --git a/include/configs/MPC832XEMDS.h b/include/configs/MPC832XEMDS.h index 6b3b198..669577e 100644 --- a/include/configs/MPC832XEMDS.h +++ b/include/configs/MPC832XEMDS.h @@ -26,7 +26,7 @@ #define CONFIG_E300 1 /* E300 family */ #define CONFIG_QE 1 /* Has QE */ #define CONFIG_MPC83xx 1 /* MPC83xx family */ -#define CONFIG_MPC832X 1 /* MPC832x CPU specific */ +#define CONFIG_MPC832x 1 /* MPC832x CPU specific */ #define CONFIG_MPC832XEMDS 1 /* MPC832XEMDS board specific */ #undef CONFIG_PQ_MDS_PIB /* POWERQUICC MDS Platform IO Board */ #undef CONFIG_PQ_MDS_PIB_ATM /* QOC3 ATM card */ diff --git a/include/configs/MPC8349EMDS.h b/include/configs/MPC8349EMDS.h index b792025..2281790 100644 --- a/include/configs/MPC8349EMDS.h +++ b/include/configs/MPC8349EMDS.h @@ -34,7 +34,7 @@ */ #define CONFIG_E300 1 /* E300 Family */ #define CONFIG_MPC83xx 1 /* MPC83xx family */ -#define CONFIG_MPC834X 1 /* MPC834X family */ +#define CONFIG_MPC834x 1 /* MPC834x family */ #define CONFIG_MPC8349 1 /* MPC8349 specific */ #define CONFIG_MPC8349EMDS 1 /* MPC8349EMDS board specific */
diff --git a/include/configs/MPC8349ITX.h b/include/configs/MPC8349ITX.h index ef0a09f..f2e574b 100644 --- a/include/configs/MPC8349ITX.h +++ b/include/configs/MPC8349ITX.h @@ -63,7 +63,7 @@ /* * High Level Configuration Options */ -#define CONFIG_MPC834X /* MPC834x family (8343, 8347, 8349) */ +#define CONFIG_MPC834x /* MPC834x family (8343, 8347, 8349) */ #define CONFIG_MPC8349 /* MPC8349 specific */
#define CONFIG_SYS_IMMR 0xE0000000 /* The IMMR is relocated to here */ diff --git a/include/configs/MPC837XEMDS.h b/include/configs/MPC837XEMDS.h index 8596470..4befcab 100644 --- a/include/configs/MPC837XEMDS.h +++ b/include/configs/MPC837XEMDS.h @@ -26,7 +26,7 @@ */ #define CONFIG_E300 1 /* E300 family */ #define CONFIG_MPC83xx 1 /* MPC83xx family */ -#define CONFIG_MPC837X 1 /* MPC837X CPU specific */ +#define CONFIG_MPC837x 1 /* MPC837x CPU specific */ #define CONFIG_MPC837XEMDS 1 /* MPC837XEMDS board specific */
/* diff --git a/include/configs/MPC837XERDB.h b/include/configs/MPC837XERDB.h index 5f2bd99..2b7d629 100644 --- a/include/configs/MPC837XERDB.h +++ b/include/configs/MPC837XERDB.h @@ -26,8 +26,8 @@ * High Level Configuration Options */ #define CONFIG_E300 1 /* E300 family */ -#define CONFIG_MPC83xx 1 /* MPC83XX family */ -#define CONFIG_MPC837X 1 /* MPC837X CPU specific */ +#define CONFIG_MPC83xx 1 /* MPC83xx family */ +#define CONFIG_MPC837x 1 /* MPC837x CPU specific */ #define CONFIG_MPC837XERDB 1
#define CONFIG_PCI 1 diff --git a/include/configs/MVBLM7.h b/include/configs/MVBLM7.h index e6aba86..9675205 100644 --- a/include/configs/MVBLM7.h +++ b/include/configs/MVBLM7.h @@ -34,7 +34,7 @@ */ #define CONFIG_E300 1 #define CONFIG_MPC83xx 1 -#define CONFIG_MPC834X 1 +#define CONFIG_MPC834x 1 #define CONFIG_MPC8343 1
#define CONFIG_SYS_IMMR 0xE0000000 diff --git a/include/configs/SIMPC8313.h b/include/configs/SIMPC8313.h index a814d10..330276a 100644 --- a/include/configs/SIMPC8313.h +++ b/include/configs/SIMPC8313.h @@ -33,7 +33,7 @@
#define CONFIG_PCI diff --git a/include/configs/TQM834x.h b/include/configs/TQM834x.h index 03cb45b..a37f8ec 100644 --- a/include/configs/TQM834x.h +++ b/include/configs/TQM834x.h @@ -33,7 +33,7 @@ */ #define CONFIG_E300 1 /* E300 Family */ #define CONFIG_MPC83xx 1 /* MPC83xx family */ -#define CONFIG_MPC834X 1 /* MPC834X specific */ +#define CONFIG_MPC834x 1 /* MPC834x specific */ #define CONFIG_MPC8349 1 /* MPC8349 specific */ #define CONFIG_TQM834X 1 /* TQM834X board specific */
diff --git a/include/configs/sbc8349.h b/include/configs/sbc8349.h index 15584d8..e2894eb 100644 --- a/include/configs/sbc8349.h +++ b/include/configs/sbc8349.h @@ -36,7 +36,7 @@ */ #define CONFIG_E300 1 /* E300 Family */ #define CONFIG_MPC83xx 1 /* MPC83xx family */ -#define CONFIG_MPC834X 1 /* MPC834X family */ +#define CONFIG_MPC834x 1 /* MPC834x family */ #define CONFIG_MPC8349 1 /* MPC8349 specific */ #define CONFIG_SBC8349 1 /* WRS SBC8349 board specific */
diff --git a/include/mpc83xx.h b/include/mpc83xx.h index fab3751..c5bd6cb 100644 --- a/include/mpc83xx.h +++ b/include/mpc83xx.h @@ -54,7 +54,7 @@ #define SPRIDR_PARTID 0xFFFF0000 /* Part Id */ #define SPRIDR_REVID 0x0000FFFF /* Revision Id */
-#if defined(CONFIG_MPC834X) +#if defined(CONFIG_MPC834x) #define REVID_MAJOR(spridr) ((spridr & 0x0000FF00) >> 8) #define REVID_MINOR(spridr) (spridr & 0x000000FF) #else @@ -100,7 +100,7 @@ #define SPCR_COREPR 0x00300000 /* E300 PowerPC Core system bus request priority */ #define SPCR_COREPR_SHIFT (31-11)
-#if defined(CONFIG_MPC834X) +#if defined(CONFIG_MPC834x) /* SPCR bits - MPC8349 specific */ #define SPCR_TSEC1DP 0x00003000 /* TSEC1 data priority */ #define SPCR_TSEC1DP_SHIFT (31-19) @@ -115,7 +115,7 @@ #define SPCR_TSEC2EP 0x00000003 /* TSEC2 emergency priority */ #define SPCR_TSEC2EP_SHIFT (31-31)
-#elif defined(CONFIG_MPC831X) || defined(CONFIG_MPC837X) +#elif defined(CONFIG_MPC831x) || defined(CONFIG_MPC837x) /* SPCR bits - MPC831x and MPC837x specific */ #define SPCR_TSECDP 0x00003000 /* TSEC data priority */ #define SPCR_TSECDP_SHIFT (31-19) @@ -127,7 +127,7 @@
/* SICRL/H - System I/O Configuration Register Low/High */ -#if defined(CONFIG_MPC834X) +#if defined(CONFIG_MPC834x) /* SICRL bits - MPC8349 specific */ #define SICRL_LDP_A 0x80000000 #define SICRL_USB1 0x40000000 @@ -190,8 +190,8 @@ #define SICRH_UC2E1OBI 0x00000002 #define SICRH_UC2E2OBI 0x00000001
-#elif defined(CONFIG_MPC832X) -/* SICRL bits - MPC832X specific */ +#elif defined(CONFIG_MPC832x) +/* SICRL bits - MPC832x specific */ #define SICRL_LDP_LCS_A 0x80000000 #define SICRL_IRQ_CKS 0x20000000 #define SICRL_PCI_MSRC 0x10000000 @@ -262,7 +262,7 @@ #define SICRH_TSOBI1 0x00000002 #define SICRH_TSOBI2 0x00000001
-#elif defined(CONFIG_MPC837X) +#elif defined(CONFIG_MPC837x) /* SICRL bits - MPC837x specific */ #define SICRL_USB_A 0xC0000000 #define SICRL_USB_B 0x30000000 @@ -424,7 +424,7 @@ #define HRCWL_CORE_TO_CSB_2_5X1 0x00050000 #define HRCWL_CORE_TO_CSB_3X1 0x00060000
-#if defined(CONFIG_MPC8360) || defined(CONFIG_MPC832X) +#if defined(CONFIG_MPC8360) || defined(CONFIG_MPC832x) #define HRCWL_CEVCOD 0x000000C0 #define HRCWL_CEVCOD_SHIFT 6 #define HRCWL_CE_PLL_VCO_DIV_4 0x00000000 @@ -478,7 +478,7 @@ #define HRCWL_SVCOD_DIV_8 0x20000000 #define HRCWL_SVCOD_DIV_1 0x30000000
-#elif defined(CONFIG_MPC837X) +#elif defined(CONFIG_MPC837x) #define HRCWL_SVCOD 0x30000000 #define HRCWL_SVCOD_SHIFT 28 #define HRCWL_SVCOD_DIV_4 0x00000000 @@ -493,7 +493,7 @@ #define HRCWH_PCI_HOST_SHIFT 31 #define HRCWH_PCI_AGENT 0x00000000
-#if defined(CONFIG_MPC834X) +#if defined(CONFIG_MPC834x) #define HRCWH_32_BIT_PCI 0x00000000 #define HRCWH_64_BIT_PCI 0x40000000 #endif @@ -504,7 +504,7 @@ #define HRCWH_PCI_ARBITER_DISABLE 0x00000000 #define HRCWH_PCI_ARBITER_ENABLE 0x20000000
-#if defined(CONFIG_MPC834X) +#if defined(CONFIG_MPC834x) #define HRCWH_PCI2_ARBITER_DISABLE 0x00000000 #define HRCWH_PCI2_ARBITER_ENABLE 0x10000000
@@ -528,17 +528,17 @@
#define HRCWH_ROM_LOC_DDR_SDRAM 0x00000000 #define HRCWH_ROM_LOC_PCI1 0x00100000 -#if defined(CONFIG_MPC834X) +#if defined(CONFIG_MPC834x) #define HRCWH_ROM_LOC_PCI2 0x00200000 #endif -#if defined(CONFIG_MPC837X) +#if defined(CONFIG_MPC837x) #define HRCWH_ROM_LOC_ON_CHIP_ROM 0x00300000 #endif #define HRCWH_ROM_LOC_LOCAL_8BIT 0x00500000 #define HRCWH_ROM_LOC_LOCAL_16BIT 0x00600000 #define HRCWH_ROM_LOC_LOCAL_32BIT 0x00700000
-#if defined(CONFIG_MPC831X) || defined(CONFIG_MPC837X) +#if defined(CONFIG_MPC831x) || defined(CONFIG_MPC837x) #define HRCWH_ROM_LOC_NAND_SP_8BIT 0x00100000 #define HRCWH_ROM_LOC_NAND_SP_16BIT 0x00200000 #define HRCWH_ROM_LOC_NAND_LP_8BIT 0x00500000 @@ -562,7 +562,7 @@ #define HRCWH_TSEC2M_IN_SGMII 0x00001800 #endif
-#if defined(CONFIG_MPC834X) +#if defined(CONFIG_MPC834x) #define HRCWH_TSEC1M_IN_RGMII 0x00000000 #define HRCWH_TSEC1M_IN_RTBI 0x00004000 #define HRCWH_TSEC1M_IN_GMII 0x00008000 @@ -589,7 +589,7 @@
/* RSR - Reset Status Register */ -#if defined(CONFIG_MPC831X) || defined(CONFIG_MPC837X) +#if defined(CONFIG_MPC831x) || defined(CONFIG_MPC837x) #define RSR_RSTSRC 0xF0000000 /* Reset source */ #define RSR_RSTSRC_SHIFT 28 #else @@ -682,7 +682,7 @@ #define SCCR_PCICM 0x00010000 #define SCCR_PCICM_SHIFT 16
-#if defined(CONFIG_MPC834X) +#if defined(CONFIG_MPC834x) /* SCCR bits - MPC834x specific */ #define SCCR_TSEC1CM 0xc0000000 #define SCCR_TSEC1CM_SHIFT 30 @@ -770,7 +770,7 @@ #define SCCR_TDMCM_2 0x00000020 #define SCCR_TDMCM_3 0x00000030
-#elif defined(CONFIG_MPC837X) +#elif defined(CONFIG_MPC837x) /* SCCR bits - MPC837x specific */ #define SCCR_TSEC1CM 0xc0000000 #define SCCR_TSEC1CM_SHIFT 30
CodingStyle Ch.12 suggests that it's the other fsl arches that are in violation here, not 83XX:
--- Names of macros defining constants and labels in enums are capitalized.
#define CONSTANT 0x12345 ---
Kim
Either way is fine with me, as long as things are consistent. It looked like most Freescale CPUs in U-Boot as well as Linux used the lowercase convention for CONFIG_<cpu type> so I thought: a. Most likely someone made a conscious decision to use lowercase b. It'd be much easier to change just 83xx than all other arches:)
If others would prefer standardizing on uppercase, I can submit new patches for 85xx, 5xxx, 86xx, etc. This would be still be inconsistent with Linux though, which is a bit annoying.
Best, Peter
Dear Peter,
Agreed...
It seems Linux uses 8?xx with very few exceptions (CONFIG_SND_VIA82XX* and CONFIG_EDAC_MPC85XX), so let's do the same here.
On Sun, 24 May 2009 22:13:27 +0200 Wolfgang Denk wd@denx.de wrote:
Dear Peter,
Agreed...
I can understand it in comments and quotes, just not in constants in the code.
that's not a good reason to do it this way though.
so linux is inconsistent too.
I'm a fan of a more self-consistent CONFIG_MPC85XX_MDS over mixed-case names like linux' CONFIG_MPC85xx_MDS.
I wonder if the linux ppc guys would accept a s/CONFIG_MPC8?xx/CONFIG_MPC8?XX/g rename patch for linux...
Kim
Just to add my 0.02$ as well, I prefer the lower case version CONFIG_8?xx. It's used for 4xx this way as well in Linux and U-Boot. Perhaps I'm just used to reading it this way...
Best regards, Stefan
Agreed...
applied 1-2 to u-boot-mpc83xx's next branch.
reluctantly, that is. I just don't have the time to fix it myself right now.
Kim
Dear Kim Phillips,
But Linux also uses CONFIG_PPC_83xx etc. ...
Kim Phillips
Peter Tyser
Stefan Roese
