[U-Boot] [PATCH] rockchip: rk3399-puma: support Gigadevice SPI-NOR flash
Over the last quarter, a part of our production has used NOR flash from Gigadevice in addition to the Winbond parts that we typically source. This requires the SPI_FLASH_GIGADEVICE config to be set.
Enable SPI_FLASH_GIGADEVICE in the board's default defconfig.
Signed-off-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com ---
configs/puma-rk3399_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/puma-rk3399_defconfig b/configs/puma-rk3399_defconfig index 3fcff25..9b4bfaf 100644 --- a/configs/puma-rk3399_defconfig +++ b/configs/puma-rk3399_defconfig @@ -67,6 +67,7 @@ CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_SDMA=y CONFIG_MMC_SDHCI_ROCKCHIP=y CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_GIGADEVICE=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y
Reviewed-by: Klaus Goger klaus.goger@theobroma-systems.com
Signed-off-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com Reviewed-by: Klaus Goger klaus.goger@theobroma-systems.com
Applied to u-boot-rockchip, thanks!
Philipp Tomsich
