[U-Boot] [PATCH] configs: Remove CONFIG_MARVELL
This option is defined by a few boards but doesn't guard any code. Remove it from the boards and config_whitelist.txt.
Signed-off-by: Chris Packham judge.packham@gmail.com ---
include/configs/edminiv2.h | 1 - include/configs/km/km_arm.h | 1 - include/configs/mv-common.h | 1 - scripts/config_whitelist.txt | 1 - 4 files changed, 4 deletions(-)
diff --git a/include/configs/edminiv2.h b/include/configs/edminiv2.h index 89aa11c0ed43..645fc3ffb81c 100644 --- a/include/configs/edminiv2.h +++ b/include/configs/edminiv2.h @@ -29,7 +29,6 @@ * High Level Configuration Options (easy to change) */
-#define CONFIG_MARVELL 1 #define CONFIG_FEROCEON 1 /* CPU Core subversion */ #define CONFIG_88F5182 1 /* SOC Name */
diff --git a/include/configs/km/km_arm.h b/include/configs/km/km_arm.h index e2585171afb9..0de83f6723c5 100644 --- a/include/configs/km/km_arm.h +++ b/include/configs/km/km_arm.h @@ -22,7 +22,6 @@ /* * High Level Configuration Options (easy to change) */ -#define CONFIG_MARVELL #define CONFIG_FEROCEON_88FR131 /* CPU Core subversion */ #define CONFIG_KW88F6281 /* SOC Name */
diff --git a/include/configs/mv-common.h b/include/configs/mv-common.h index 5eeb5a162494..a80309316351 100644 --- a/include/configs/mv-common.h +++ b/include/configs/mv-common.h @@ -19,7 +19,6 @@ /* * High Level Configuration Options (easy to change) */ -#define CONFIG_MARVELL 1
/* * Custom CONFIG_SYS_TEXT_BASE can be done in <board>.h diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index abfb0ff89fa9..2d5cad986897 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -1200,7 +1200,6 @@ CONFIG_MALLOC_F_ADDR CONFIG_MALTA CONFIG_MARCO_MEMSET CONFIG_MARUBUN_PCCARD -CONFIG_MARVELL CONFIG_MARVELL_GPIO CONFIG_MARVELL_MFP CONFIG_MASK_AER_AO
Thanks, Stefan
Signed-off-by: Chris Packham judge.packham@gmail.com Reviewed-by: Stefan Roese sr@denx.de
Chris Packham
Stefan Roese
