[U-Boot] [PATCH v2 0/4] mtd: spi: spi-nor-core: Add SST vendor specific SFDP parser
Parse manufacturer specific SFDP table. The SST SFDP table contains pre-programmed globally unique MAC addresses. Retrieve the MAC address from the SPI NOR flash and set it in ethaddr in env.
v2: - s/SFDP_MICROCHIP_ID/SFDP_SST_ID - don't drop all information we extracted from BFPT if optional table parsers fail. In case of failing, each optional SFDP parser is responsible to roll back to the previously known spi_nor data.
Tudor Ambarus (4): mtd: spi: spi-nor-core: Add SST vendor specific SFDP parser board: atmel: sama5d27_wlsom1_ek: Set ethaddr from spi-nor flash configs: sama5d27_wlsom1_ek: qspiflash: Enable SPI NOR ethaddr retrieval configs: sama5d27_wlsom1_ek: mmc: Enable SPI NOR ethaddr retrieval
arch/arm/mach-at91/include/mach/at91_common.h | 1 + board/atmel/common/Makefile | 1 + board/atmel/common/mac-spi-nor.c | 127 +++++++++++++++++++++ .../atmel/sama5d27_wlsom1_ek/sama5d27_wlsom1_ek.c | 3 + configs/sama5d27_wlsom1_ek_mmc_defconfig | 5 + configs/sama5d27_wlsom1_ek_qspiflash_defconfig | 1 + drivers/mtd/spi/spi-nor-core.c | 46 +++++++- include/linux/mtd/spi-nor.h | 2 + 8 files changed, 184 insertions(+), 2 deletions(-) create mode 100644 board/atmel/common/mac-spi-nor.c
JESD216 allow vendors to define their own SFDP tables.
Add SST SFDP parser. The vendor table is allocated using resource-managed kmalloc - the table will be freed on driver detach. It will be accessible by getting the UCLASS_SPI_FLASH's private data.
The SST's SFDP table is particularly of interest because contains pre-programmed globally unique EUI-48 and EUI-64 identifiers.
Signed-off-by: Tudor Ambarus tudor.ambarus@microchip.com --- drivers/mtd/spi/spi-nor-core.c | 46 ++++++++++++++++++++++++++++++++++++++++-- include/linux/mtd/spi-nor.h | 2 ++ 2 files changed, 46 insertions(+), 2 deletions(-)
diff --git a/drivers/mtd/spi/spi-nor-core.c b/drivers/mtd/spi/spi-nor-core.c index 5a8c08425566..ee77151f20de 100644 --- a/drivers/mtd/spi/spi-nor-core.c +++ b/drivers/mtd/spi/spi-nor-core.c @@ -1588,6 +1588,7 @@ struct sfdp_parameter_header {
#define SFDP_BFPT_ID 0xff00 /* Basic Flash Parameter Table */ #define SFDP_SECTOR_MAP_ID 0xff81 /* Sector Map Table */ +#define SFDP_SST_ID 0x01bf /* Manufacturer specific Table */
#define SFDP_SIGNATURE 0x50444653U #define SFDP_JESD216_MAJOR 1 @@ -1968,6 +1969,34 @@ static int spi_nor_parse_bfpt(struct spi_nor *nor, }
/** + * spi_nor_parse_microchip_sfdp() - parse the Microchip manufacturer specific + * SFDP table. + * @nor: pointer to a 'struct spi_nor'. + * @param_header: pointer to the SFDP parameter header. + * + * Return: 0 on success, -errno otherwise. + */ +static int +spi_nor_parse_microchip_sfdp(struct spi_nor *nor, + const struct sfdp_parameter_header *param_header) +{ + size_t size; + u32 addr; + int ret; + + size = param_header->length * sizeof(u32); + addr = SFDP_PARAM_HEADER_PTP(param_header); + + nor->manufacturer_sfdp = devm_kmalloc(nor->dev, size, GFP_KERNEL); + if (!nor->manufacturer_sfdp) + return -ENOMEM; + + ret = spi_nor_read_sfdp(nor, addr, size, nor->manufacturer_sfdp); + + return ret; +} + +/** * spi_nor_parse_sfdp() - parse the Serial Flash Discoverable Parameters. * @nor: pointer to a 'struct spi_nor' * @params: pointer to the 'struct spi_nor_flash_parameter' to be @@ -2063,12 +2092,25 @@ static int spi_nor_parse_sfdp(struct spi_nor *nor, dev_info(dev, "non-uniform erase sector maps are not supported yet.\n"); break;
+ case SFDP_SST_ID: + err = spi_nor_parse_microchip_sfdp(nor, param_header); + break; + default: break; }
- if (err) - goto exit; + if (err) { + dev_warn(dev, "Failed to parse optional parameter table: %04x\n", + SFDP_PARAM_HEADER_ID(param_header)); + /* + * Let's not drop all information we extracted so far + * if optional table parsers fail. In case of failing, + * each optional parser is responsible to roll back to + * the previously known spi_nor data. + */ + err = 0; + } }
exit: diff --git a/include/linux/mtd/spi-nor.h b/include/linux/mtd/spi-nor.h index f9964a766456..1d911772917d 100644 --- a/include/linux/mtd/spi-nor.h +++ b/include/linux/mtd/spi-nor.h @@ -261,6 +261,7 @@ struct flash_info; * @lock: the lock for the read/write/erase/lock/unlock operations * @dev: point to a spi device, or a spi nor controller device. * @info: spi-nor part JDEC MFR id and other info + * @manufacturer_sfdp: manufacturer specific SFDP table * @page_size: the page size of the SPI NOR * @addr_width: number of address bytes * @erase_opcode: the opcode for erasing a sector @@ -299,6 +300,7 @@ struct spi_nor { struct udevice *dev; struct spi_slave *spi; const struct flash_info *info; + u8 *manufacturer_sfdp; u32 page_size; u8 addr_width; u8 erase_opcode;
Hi
Reviewed-by: Vignesh Raghavendra vigneshr@ti.com
Regards Vignesh
- spi_nor_parse_microchip_sfdp() - parse the Microchip manufacturer specific
- SFDP table.
- @nor: pointer to a 'struct spi_nor'.
- @param_header: pointer to the SFDP parameter header.
- Return: 0 on success, -errno otherwise.
- size_t size;
- u32 addr;
- int ret;
- size = param_header->length * sizeof(u32);
- addr = SFDP_PARAM_HEADER_PTP(param_header);
- nor->manufacturer_sfdp = devm_kmalloc(nor->dev, size, GFP_KERNEL);
- if (!nor->manufacturer_sfdp)
return -ENOMEM;
- ret = spi_nor_read_sfdp(nor, addr, size, nor->manufacturer_sfdp);
- return ret;
- spi_nor_parse_sfdp() - parse the Serial Flash Discoverable Parameters.
- @params: pointer to the 'struct spi_nor_flash_parameter' to be
case SFDP_SST_ID:
break;
- default: break; }
if (err)
goto exit;
if (err) {
err = 0;
- @lock: the lock for the read/write/erase/lock/unlock operations
- @dev: point to a spi device, or a spi nor controller device.
- @info: spi-nor part JDEC MFR id and other info
- @manufacturer_sfdp: manufacturer specific SFDP table
- @page_size: the page size of the SPI NOR
- @addr_width: number of address bytes
- @erase_opcode: the opcode for erasing a sector
- u8 *manufacturer_sfdp; u32 page_size; u8 addr_width; u8 erase_opcode;
The SST26VF064BEUI spi-nor flash is programmed at the factory with a globally unique address stored in the SFDP vendor parameter table and it is permanently writeprotected. Retrieve the EUI-48 address and set it as ethaddr env.
Signed-off-by: Tudor Ambarus tudor.ambarus@microchip.com --- arch/arm/mach-at91/include/mach/at91_common.h | 1 + board/atmel/common/Makefile | 1 + board/atmel/common/mac-spi-nor.c | 127 +++++++++++++++++++++ .../atmel/sama5d27_wlsom1_ek/sama5d27_wlsom1_ek.c | 3 + 4 files changed, 132 insertions(+) create mode 100644 board/atmel/common/mac-spi-nor.c
diff --git a/arch/arm/mach-at91/include/mach/at91_common.h b/arch/arm/mach-at91/include/mach/at91_common.h index e929b5e1d207..01e00c508a8a 100644 --- a/arch/arm/mach-at91/include/mach/at91_common.h +++ b/arch/arm/mach-at91/include/mach/at91_common.h @@ -40,6 +40,7 @@ void configure_ddrcfg_input_buffers(bool open); #endif
int at91_set_ethaddr(int offset); +void at91_spi_nor_set_ethaddr(void); int at91_video_show_board_info(void);
#endif /* AT91_COMMON_H */ diff --git a/board/atmel/common/Makefile b/board/atmel/common/Makefile index 4de0912f22e6..6bc8cabb8d6d 100644 --- a/board/atmel/common/Makefile +++ b/board/atmel/common/Makefile @@ -5,4 +5,5 @@
obj-y += board.o obj-$(CONFIG_I2C_EEPROM) += mac_eeprom.o +obj-$(CONFIG_SPI_FLASH_SFDP_SUPPORT) += mac-spi-nor.o obj-$(CONFIG_DM_VIDEO) += video_display.o diff --git a/board/atmel/common/mac-spi-nor.c b/board/atmel/common/mac-spi-nor.c new file mode 100644 index 000000000000..96343678e0b6 --- /dev/null +++ b/board/atmel/common/mac-spi-nor.c @@ -0,0 +1,127 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 Microchip Technology Inc. and its subsidiaries + * + * Author: Tudor Ambarus tudor.ambarus@microchip.com + */ + +#include <common.h> +#include <dm.h> +#include <env.h> +#include <linux/mtd/spi-nor.h> +#include <netdev.h> + +#define ETH_ADDR_SIZE 6 + +#ifdef CONFIG_SPI_FLASH_SST +#define SFDP_MICROCHIP_MANUF_ID 0xbf +#define SFDP_MICROCHIP_MEM_TYPE 0x26 +#define SFDP_MICROCHIP_DEV_ID 0x43 + +#define SFDP_MICROCHIP_EUI_OFFSET 0x60 +#define SFDP_MICROCHIP_EUI48 0x30 + +struct sst26vf064beui { + u8 manufacturer_id; + u8 memory_type; + u8 device_id; + u8 reserved; +}; + +/** + * sst26vf064beui_check() - Check the validity of the EUI-48 information from + * the sst26vf064beui SPI NOR Microchip SFDP table. + * @manufacturer_sfdp: pointer to the Microchip manufacturer specific SFDP + * table. + * + * Return: 0 on success, -errno otherwise. + */ +static int sst26vf064beui_check(const u8 *manufacturer_sfdp) +{ + struct sst26vf064beui *sst26vf064beui = + (struct sst26vf064beui *)manufacturer_sfdp; + + if (sst26vf064beui->manufacturer_id != SFDP_MICROCHIP_MANUF_ID) + return -EINVAL; + + if (sst26vf064beui->memory_type != SFDP_MICROCHIP_MEM_TYPE) + return -EINVAL; + + if (sst26vf064beui->device_id != SFDP_MICROCHIP_DEV_ID) + return -EINVAL; + + /* + * Check if the EUI-48 MAC address is programmed in the next six address + * locations. + */ + if (manufacturer_sfdp[SFDP_MICROCHIP_EUI_OFFSET] != + SFDP_MICROCHIP_EUI48) + return -EINVAL; + + return 0; +} + +/** + * sst26vf064beui_get_ethaddr() - Get the ethernet address from the + * sst26vf064beui SPI NOR Microchip SFDP table. + * @manufacturer_sfdp: pointer to the Microchip manufacturer specific SFDP + * table. + * @ethaddr: pointer where to fill the ethernet address + * @size: size of the ethernet address. + * + * Return: 0 on success, -errno otherwise. + */ +static int sst26vf064beui_get_ethaddr(const u8 *manufacturer_sfdp, + u8 *ethaddr, size_t size) +{ + u64 eui_table[2]; + u64 *p = (u64 *)&manufacturer_sfdp[SFDP_MICROCHIP_EUI_OFFSET]; + int i, ret; + + ret = sst26vf064beui_check(manufacturer_sfdp); + if (ret) + return ret; + + for (i = 0; i < 2; i++) + eui_table[i] = le64_to_cpu(p[i]); + + /* Ethaddr starts at offset one. */ + memcpy(ethaddr, &((u8 *)eui_table)[1], size); + + return 0; +} +#endif + +/** + * at91_spi_nor_set_ethaddr() - Retrieve and set the ethernet address from the + * SPI NOR manufacturer specific SFDP table. + */ +void at91_spi_nor_set_ethaddr(void) +{ + struct udevice *dev; + struct spi_nor *nor; + const char *ethaddr_name = "ethaddr"; + u8 ethaddr[ETH_ADDR_SIZE] = {0}; + + if (env_get(ethaddr_name)) + return; + + if (uclass_first_device_err(UCLASS_SPI_FLASH, &dev)) + return; + + nor = dev_get_uclass_priv(dev); + if (!nor) + return; + + if (!nor->manufacturer_sfdp) + return; + +#ifdef CONFIG_SPI_FLASH_SST + if (sst26vf064beui_get_ethaddr(nor->manufacturer_sfdp, ethaddr, + ETH_ADDR_SIZE)) + return; +#endif + + if (is_valid_ethaddr(ethaddr)) + eth_env_set_enetaddr(ethaddr_name, ethaddr); +} diff --git a/board/atmel/sama5d27_wlsom1_ek/sama5d27_wlsom1_ek.c b/board/atmel/sama5d27_wlsom1_ek/sama5d27_wlsom1_ek.c index fda06c824d53..fc563ebb7150 100644 --- a/board/atmel/sama5d27_wlsom1_ek/sama5d27_wlsom1_ek.c +++ b/board/atmel/sama5d27_wlsom1_ek/sama5d27_wlsom1_ek.c @@ -68,6 +68,9 @@ int board_init(void) #ifdef CONFIG_MISC_INIT_R int misc_init_r(void) { +#ifdef CONFIG_SPI_FLASH_SFDP_SUPPORT + at91_spi_nor_set_ethaddr(); +#endif return 0; } #endif
CONFIG_SPI_FLASH_SFDP_SUPPORT enables the SFDP Vendor parser, and for the SST case, the retrieval of the ethaddr from the SPI NOR flash.
Signed-off-by: Tudor Ambarus tudor.ambarus@microchip.com --- configs/sama5d27_wlsom1_ek_qspiflash_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/sama5d27_wlsom1_ek_qspiflash_defconfig b/configs/sama5d27_wlsom1_ek_qspiflash_defconfig index 3196a88f1131..26a06270b276 100644 --- a/configs/sama5d27_wlsom1_ek_qspiflash_defconfig +++ b/configs/sama5d27_wlsom1_ek_qspiflash_defconfig @@ -78,6 +78,7 @@ CONFIG_MMC_SDHCI_ATMEL=y CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_BUS=2 CONFIG_SF_DEFAULT_SPEED=50000000 +CONFIG_SPI_FLASH_SFDP_SUPPORT=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_SPANSION=y
Enable the SPI NOR SFDP support and the Microchip QSPI driver. CONFIG_SPI_FLASH_SFDP_SUPPORT enables the SFDP Vendor parser, and for the SST case, the retrieval of the ethaddr from the SPI NOR flash.
While touching the SPI NOR logic, sync with the sama5d27_wlsom1_ek_qspiflash_defconfig and enable CONFIG_SPI_FLASH_SPANSION.
Signed-off-by: Tudor Ambarus tudor.ambarus@microchip.com --- configs/sama5d27_wlsom1_ek_mmc_defconfig | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/configs/sama5d27_wlsom1_ek_mmc_defconfig b/configs/sama5d27_wlsom1_ek_mmc_defconfig index ffafc21ab3ce..ad59e73999b5 100644 --- a/configs/sama5d27_wlsom1_ek_mmc_defconfig +++ b/configs/sama5d27_wlsom1_ek_mmc_defconfig @@ -65,8 +65,12 @@ CONFIG_DM_MMC=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ATMEL=y CONFIG_DM_SPI_FLASH=y +CONFIG_SF_DEFAULT_BUS=2 +CONFIG_SF_DEFAULT_SPEED=50000000 +CONFIG_SPI_FLASH_SFDP_SUPPORT=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_SST=y CONFIG_PHY_MICREL=y @@ -81,6 +85,7 @@ CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_ATMEL_USART=y CONFIG_SPI=y CONFIG_DM_SPI=y +CONFIG_ATMEL_QSPI=y CONFIG_TIMER=y CONFIG_SPL_TIMER=y CONFIG_ATMEL_PIT_TIMER=y
v2:
Applied series to u-boot-atmel/next Thanks !
Eugen.Hristev@microchip.com
Vignesh Raghavendra
