[PATCH 1/1] efi_loader: segfault in efi_clear_os_indications()
If we call efi_clear_os_indications() before initializing the memory store for UEFI variables a NULL pointer dereference occurs.
The error was observed on the sandbox with:
usb start host bind 0 sandbox.img load host 0:1 $kernel_addr_r helloworld.efi bootefi $kernel_addr_r
Here efi_resister_disk() failed due to an error in the BTRFS implementation.
It is enough to clear EFI_OS_INDICATIONS_FILE_CAPSULE_DELIVERY_SUPPORTED if we have successfully initialized the UEFI sub-system.
Fixes: 149108a3eb59 ("efi_loader: clear OsIndications") Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- lib/efi_loader/efi_setup.c | 3 +-- 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/lib/efi_loader/efi_setup.c b/lib/efi_loader/efi_setup.c index a2338d74af..661868811f 100644 --- a/lib/efi_loader/efi_setup.c +++ b/lib/efi_loader/efi_setup.c @@ -331,11 +331,10 @@ efi_status_t efi_init_obj_list(void) if (IS_ENABLED(CONFIG_EFI_CAPSULE_ON_DISK) && !IS_ENABLED(CONFIG_EFI_CAPSULE_ON_DISK_EARLY)) ret = efi_launch_capsules(); - -out: r = efi_clear_os_indications(); if (ret == EFI_SUCCESS) ret = r; +out: efi_obj_list_initialized = ret; return ret; }
I think that it would be better move this function into efi_launch_capsules() as we should defer to a responsible sub-component, capsule support in this case, on whether a particular bit should be cleared.
-Takahiro Akashi
-out: r = efi_clear_os_indications(); if (ret == EFI_SUCCESS) ret = r; +out: efi_obj_list_initialized = ret; return ret; } -- 2.32.0
AKASHI Takahiro
