[GIT] Pull request: u-boot-dfu (27.08.2019)
Dear Marek,
Please find a set of DFU/Gadget/sdp/fastboot related fixes and enhancements:
https://gitlab.denx.de/u-boot/custodians/u-boot-dfu/-/commits/master
The git tag with detailed changes description in this PR can be found here:
https://gitlab.denx.de/u-boot/custodians/u-boot-dfu/-/tags/u-boot-dfu-27Aug2...
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-59 Fax: (+49)-8142-66989-80 Email: lukma@denx.de
On 8/27/20 11:10 PM, Lukasz Majewski wrote:
Dear Marek,
Is this some new format of pull request, are we no longer using git-request-pull ?
Also note that the UPDATE_TFTP is being actively used, why is it removed here and this late in rc3 ? I think these patches should really be postponed until after the release.
Can you please re-do the PR with only fixes ?
Thanks
Hi Marek,
Dear Marek,
I thought that it would be more convenient to send the direct link to gitlab, as it is easy to have access to merge tag information.
From the other discussion, which was led mostly by Heinrich (CCed) it was apparent that this was a dead code.
The only non-fix patches are: - one which adds max3420 gadget
- sdp enhancements (which looks to be self contained).
Thanks
Lukasz Majewski
On 8/28/20 10:24 AM, Lukasz Majewski wrote:
Hi Marek,
Hello Lukasz,
Dear Marek,
Nope, all that is really needed is the remote and refspec , all of which is in the git request-pull output. All I really ever do with the DFU PR is $ git fetch u-boot-dfu ; <inspect the refspec> ; git merge <refspec> and this operation doesn't involve booting the web browser :)
Nope, I see it used, still.
Being able to download fitImage with various fragments of update and apply them with single command is convenient, I would dislike to lose that functionality. I don't think using $preboot is in any way a replacement of this.
This one is rather isolated.
OK
So just move the update_tftp patches to next, because they need more discussion.
Thanks
Dear Marek,
Please find a set of DFU/Gadget related fixes:
The following changes since commit 9f04a634ef331b4fc6b3e677f276156192a413c7:
Merge branch '2020-08-27-misc-fixes' (2020-08-28 08:51:37 -0400)
git@gitlab.denx.de:u-boot/custodians/u-boot-dfu.git
for you to fetch changes up to 7b55046329df3d14193debec34da515138335575:
fastboot: getvar: fix partition-size return value (2020-08-30 19:17:47 +0200)
---------------------------------------------------------------- Filip Brozovic (1): fastboot: Support defining raw partitions without a partition table
Frank Li (1): sdp: call board_usb_init at spl_sdp_load_image
Gary Bisson (1): fastboot: getvar: fix partition-size return value
Heinrich Schuchardt (4): dfu: fix typo parameteres dfu: DFU_MTD depends on CMD_MTDPARTS configs: qemu: enable dfu testing dfu: fix dfu tftp on sandbox
Jassi Brar (1): usb: max3420: add the gadget driver
Peng Fan (2): f_sdp: Support searching and loading FIT or container image spl: add g_dnl_get_board_bcd_device_number
Roman Kovalivskyi (3): fastboot: Extend fastboot_set_reboot_flag with reboot reason fastboot: Add support for 'reboot fastboot' command fastboot: Add default fastboot_set_reboot_flag implementation
Sherry Sun (2): f_sdp: Add EP1_OUT as default data receive pipe in sdp f_sdp: Change bInterval of interrupt endpoint to 3
Ye Li (4): usb: gadget: Fix controller index in UMS usb: ci_udc: Add function to remove usb device f_sdp: Add high speed endpoint descriptor f_sdp: Fix wrong usb request size
yurii.pidhornyi (1): fastboot: Fix fastboot reboot fail by changing functions order
Merge tag data/information:
- gadget: Add code to set UMS controller index - fastboot: Allow updating raw eMMC partitions (based on LBA offset) - dfu: various fixes, remove UPDATE_TFTP Kconfig option, add qemu testing and fix sandbox DFU test - fastboot: Add 'reboot fastboot' command - usb: max3420: Add gadget driver (new code) - sdp: Several enhancements - adding support for high speed descriptors, using ep 3 - sdp: Support searching and loading FIT or container image - fastboot: Fix partition size return value for getvar
(Can be also found here: https://gitlab.denx.de/u-boot/custodians/u-boot-dfu/-/tags/u-boot-dfu-30Aug2...)
Lukasz Majewski
On 8/30/20 9:42 PM, Lukasz Majewski wrote:
Dear Marek,
Pulled to u-boot-usb/master, thanks.
Lukasz Majewski
