[U-Boot-Users] [PATCH] Fix warnings if compiling with IDE support.
Hello,
this patch fixes the following warnings, if compiling u-boot with ide support.
[hs@pollux u-boot]$ make -s all cmd_ide.c:827: Warnung: weak declaration of `ide_outb' after first use results in unspecified behavior cmd_ide.c:839: Warnung: weak declaration of `ide_inb' after first use results in unspecified behavior [hs@pollux u-boot]$
Signed-off-by: Heiko Schocher hs@denx.de --- common/cmd_ide.c | 46 ++++++++++++++++++++++------------------------ 1 files changed, 22 insertions(+), 24 deletions(-)
diff --git a/common/cmd_ide.c b/common/cmd_ide.c index 6560702..948a9d2 100644 --- a/common/cmd_ide.c +++ b/common/cmd_ide.c @@ -161,8 +161,6 @@ static uchar ide_wait (int dev, ulong t);
#define IDE_SPIN_UP_TIME_OUT 5000 /* 5 sec spin-up timeout */
-void inline ide_outb(int dev, int port, unsigned char val); -unsigned char inline ide_inb(int dev, int port); static void input_data(int dev, ulong *sect_buf, int words); static void output_data(int dev, ulong *sect_buf, int words); static void ident_cpy (unsigned char *dest, unsigned char *src, unsigned int len); @@ -522,6 +520,28 @@ int do_diskboot (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[])
+void inline +__ide_outb(int dev, int port, unsigned char val) +{ + debug ("ide_outb (dev= %d, port= 0x%x, val= 0x%02x) : @ 0x%08lx\n", + dev, port, val, (ATA_CURR_BASE(dev)+CFG_ATA_PORT_ADDR(port))); + outb(val, (ATA_CURR_BASE(dev)+CFG_ATA_PORT_ADDR(port))); +} +void inline ide_outb (int dev, int port, unsigned char val) + __attribute__((weak, alias("__ide_outb"))); + +unsigned char inline +__ide_inb(int dev, int port) +{ + uchar val; + val = inb((ATA_CURR_BASE(dev)+CFG_ATA_PORT_ADDR(port))); + debug ("ide_inb (dev= %d, port= 0x%x) : @ 0x%08lx -> 0x%02x\n", + dev, port, (ATA_CURR_BASE(dev)+CFG_ATA_PORT_ADDR(port)), val); + return val; +} +unsigned char inline ide_inb(int dev, int port) + __attribute__((weak, alias("__ide_inb"))); + void ide_init (void) {
@@ -816,28 +836,6 @@ set_pcmcia_timing (int pmode)
-void inline -__ide_outb(int dev, int port, unsigned char val) -{ - debug ("ide_outb (dev= %d, port= 0x%x, val= 0x%02x) : @ 0x%08lx\n", - dev, port, val, (ATA_CURR_BASE(dev)+CFG_ATA_PORT_ADDR(port))); - outb(val, (ATA_CURR_BASE(dev)+CFG_ATA_PORT_ADDR(port))); -} -void inline ide_outb (int dev, int port, unsigned char val) - __attribute__((weak, alias("__ide_outb"))); - -unsigned char inline -__ide_inb(int dev, int port) -{ - uchar val; - val = inb((ATA_CURR_BASE(dev)+CFG_ATA_PORT_ADDR(port))); - debug ("ide_inb (dev= %d, port= 0x%x) : @ 0x%08lx -> 0x%02x\n", - dev, port, (ATA_CURR_BASE(dev)+CFG_ATA_PORT_ADDR(port)), val); - return val; -} -unsigned char inline ide_inb(int dev, int port) - __attribute__((weak, alias("__ide_inb"))); - #ifdef __PPC__ # ifdef CONFIG_AMIGAONEG3SE static void
Hello,
--- Added to GNATS database as unassigned-patches/5
Responsible: patch-coord Message-Id: 4886C206.8040608@denx.de In-Reply-To: References: Patch-Date: Wed Jul 23 07:30:46 +0200 2008
In message 4886C206.8040608@denx.de you wrote:
Hello,
Applied, thanks.
Heiko Schocher
u-boot@bugs.denx.de
